Staro 08.08.2004., 04:16   #1
AdiBoy
Datum registracije: Jul 2004
Lokacija: BIH, Sarajevo
Postovi: 31
Powercolor 9800SE@9800PRO - DooM 3 benchmark
Nakon zavrsetka igre malo sam se zabavio sa pokretanjem timedemo demo1 na razlicitim rezolucijama i detaljima.
Bez puno price idemo na rezultate : ) .
Test sistem:
- EpoX 8RDA+ Ultra 400 @ Powerpack
- AMD Mobile Barton 2500+ @ 3200+ (11x200 @ 1.6V) - IQYHA
- Zalman CNPS7000A-Cu @ 2000 rpm
- Kingmax 2x256 DDR 433MHZ (Dual Channel)
- Powercolor ATI Radeon 9800SE @ 9800PRO (380/340 Mhz) 128 MB (256bit)
- Case "Plus", 4 case fans (3 codegen, 1 chieftec)
- Chieftec GPS-350BB-101L 350W PSU (12cm fan @ 26db)
- Maxtor 120 GB 7200 RPM, ATA 133, 8 MB cache (DiamondMax Plus 9)
- Zalman ZM-2HC1 HDD cooler
- itd.
- Operativni sistem: Windows XP SP1 + zakrpe do februara 2004.
Driveri: nVIDIA ForceWare nForce 4.24, ATi Catalyst 4.7 (softmod.ocfaq.com), DirectX 9.0c.
Rezultati (DooM 3 - timedemo demo1):
Detalji: Low
- 640x480 = 59.8
- 800x600 = 56.6
- 1024x768 = 44.3
- 1280x1024 = 30.0
- 1600x1200 = 20.4
Detalji: Medium
- 640x480 = 59.9
- 800x600 = 56.3
- 1024x768 = 44.1
- 1280x1024 = 29.8
- 1600x1200 = 20.3
Detalji: High
- 640x480 = 58.1
- 800x600 = 51.7
- 1024x768 = 39.8
- 1280x1024 = 27.0
- 1600x1200 = 19.1
Detalji: Ultra
- 640x480 = 45.0
- 800x600 = 35.2
- 1024x768 = 27.7
Dakako, svi rezultati izrazeni u FPS (frames per second).
AMD Mobile Barton 2500+ @ 3500+ (12.5x200 @ 1.8V) - IQYHA
Zalman CNPS7000A-Cu
Logitech MX 500 + Steelpad 4S
AdiBoy je offline   Reply With Quote
Staro 08.08.2004., 12:43   #2
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
Dobri rezultati.
Di si prije postao ovdje ili na OCFAQ?
Nemam više lema!!!
Staro 08.08.2004., 13:24   #3
MentalHarikiri
MentalHarikiri's Avatar
Postovi: 2,560
mene čudi JAKO mali gubitak u 1280x1024 kad se gleda High naprema Low detalje :confused:
a ovaj Ultra High je očito samo za 6800/x800....
Staro 08.08.2004., 13:40   #4
dr.fiksi
doktor, trekkie, amd-ovac
dr.fiksi's Avatar
Postovi: 1,043
ili bolje rečeno-prije 6800...
x800 zaostaje.Za ovu igru igrivo je sve oko 60+ FPSa, barem ja tako držim.
Svijet je monitor s beskonačnom rezolucijom!
1.a64 3500+,abit av8,1.5gb corsair, leadtek geforce 6800 ultra,2x200gb seagate@raid 0,tagan 480w...
2.mobilac 2600+ na 2332mhz,epox 8rda3i,r9800pro,120gb,512ddr,ener 350w...
3.MSI centrino 1.5(dothan), ati9600,40gb...
-->HDD u externom kućištu USB 2.0+firewire-hitachi 200 giga
dr.fiksi je offline   Reply With Quote
Staro 08.08.2004., 14:34   #5
LorD ClockaN
od LemilicE
Postovi: 4,712
Rezultati bi bili puno bolji da ima gigu rama.
Ista stvar kao i sa FarCry-em, gladni su memorije.
Nemam više lema!!!
Staro 08.08.2004., 15:53   #6
AdiBoy
Postovi: 31
Originally posted by LorD ClockaN
Dobri rezultati.
hehe, ovdje sam prije : ) .
Uglavnom zadovoljan rezultatima...dok nabavim vga cooler idem do 9800xt pa ce biti za koji fps bolje .
Zalman CNPS7000A-Cu
Staro 08.08.2004., 19:53   #7
LorD ClockaN
od LemilicE
Postovi: 4,712
Nemoj bit previše optimističan da ćeš moć dostić XT frekvencije
Ja sa Silencerom ne mogu preko 391 na jezgri bez artefakata
Nemam više lema!!!
Staro 08.08.2004., 22:19   #8
AdiBoy
Postovi: 31
Pravo da ti kazem i ovo mi je dosta tako da optimistican za 9800xt i nisam ali u svakom slucaju cu probati .
Zalman CNPS7000A-Cu
Staro 09.08.2004., 10:37   #9
Tumor
prof.dr. gospodar svemira
Tumor's Avatar
Postovi: 422
Evo i nekih benchmarka s X800PRO.
Ovo je Copy/Paste mog posta na Gamer forumu. U medjuvremenu sam napravio onaj Humusov tweak, pa su sada FPS-ovi veci za 2-3 u odnosu na dolje navedene:
Evo dobio i ja danas Doom3 i izvrtio onaj "timedemo demo1" da vidim rezultate. U advanced opcijama je sve ukljuceno osim vsync:
P4 3.0 @ 3.2
Abit IS7-E
2x512 DDR400
X800PRO (overdrive iskljucen)
1024x768, High details, AA off = 64 FPS
1024X768, High details, AA 2x = 40,9 FPS
1280x1024, High details, AA off = 49 FPS
1280x1024, High details, AA 2x = 31 FPS
1600X1200, High details, AA off = 37,7 FPS
1600X1200, High details, AA 2x = 24,8 FPS
Na kraju sam izvrtio i s Ultra High postavkama koje bi trebale biti rezervirane za kartice s 512MB RAM-a:
1600x1200, Ultra High detail, AA off = 35,5 FPS
1600x1200, Ultra High detail, AA 2x = 23,5 FPS
Pri Ultra High postavkama sam primjetio da se procesor i ploca griju k'o mutavi...
Inace kada spustim konzolu da upisem komandu za pokretanje demoa vidim da javlja Warning poruku: Couldn't load sound 'quisounds.wav' using default
Pretpostavljam da je to zbog toga sto imam AC'97 onboard zvuk, a ne neku kvalitetniju zvucnu karticu...
Tumor je offline   Reply With Quote
