Hoker
Datum registracije: Aug 2008
Postovi: 10
I ja sam imao isti problem ali sam skinuo riva tuner i dignuo fan na 50% i sad mi je 48. Jest da je bucna u pm ali morao sam.
"Two in harmony surpasses one in perfection"
Od nonine sestre kunjado
Lokacija: (Vinjro)
Postovi: 1,130
N00B
Postovi: 3,886
Inace se zna da se vise griju serije 4xxx nisu sa hladenjem na ti ali sa grijanjem da ..Ili stavi vent na 50% bude pomoglo ili ako te bas smeta promjeni cooler ![]() |
Lokacija: (Vinjro)
Postovi: 1,130
Hoker
Postovi: 10
Odi na main prozor, onda customize low level system settings pa fan. Stavi na 50-60, zavisi kaliko podnosis buku i apply fan settings at win startup. I to je to
Lokacija: Splity
Postovi: 3,003
Lokacija: (Vinjro)
Postovi: 1,130
Hoker
Postovi: 10
Sad sam vidio da 4850 ne podrzava riva tuner. Procitao sam ovo na jednom forumun mozda ti pomogne, ja nisam isprobao tak da neznam dal radi if you make a profile in catalyst after turning on Overdrive( make sure clock and memory settings are correct). You can then go to the file "C:\Users\Bretware\AppData\Local\ATI\ACE\Bretware. XML. the xml file will have the same name as the catalyst profile you saved. right click and hit edit. <Feature name="FanSpeedAlgorithm_0"> <Property name="FanSpeedAlgorithm" value="Manual" /> </Feature> <Feature name="FanSpeedRPMTarget_0"> <Property name="Want" value="0" /> </Feature> <Feature name="FanSpeedPercentTarget_0"> <Property name="Want" value="65" /> Change the value to "manual" and Want value to "65" Save the file then reload your profile in catalyst. 65% seemed perfect for me, 70% was loud but you may need it if your case has poor air flow. You will may have to select the profile everytime you start the computer, but it will work until there is a fix or better info so i can figure how to change the auto target temp.
Lokacija: (Vinjro)
Postovi: 1,130
Nakon čitanja po ATI forumu, skinuo AtiTrayTools,povisio na 40,, ne čuje se , a temp je na 58... Thx... Link za Tools : http://k0hnbq.bay.livefilestore.com/...Y/attsetup.exe
