Staro 23.08.2008., 17:04   #1
remplir
Datum registracije: Aug 2008
Postovi: 2
WinRAR screwup
Dakle... htio sam nesto strpati u .rar preko WinRAR-a i sve lijepo pokrenuo, zatim se sjetio kako mi nedostaje jedan file i stoga cancel-ao.
I sad... umjesto da je WinRAR obrisao onaj file koji je poceo stvarati kao .rar (kao sto inace a i sada radi) ostavio ga je na desktopu.
File nema nikakvu ekstenziju, ima 0 byte-a, niti ikakve druge informacije kada je stvoren itd itd... svaki put kada ga pokusam obrisati ili premjestiti u bilo koji drugi folder bilo gdje na hardu (opcenito sa desktop foldera) javlja "Cannot move file: Cannot read from the source file or disk".
Mislio sam kako cu sa "advanced" file-sharing promjeniti ownership file-a (jer sam tako rijesavao slicne probleme kada nije dao micati file) ali nista, jer file ne pokazuje nikakve druge opcije preko properties (cak ni hidden ili read only opcije ignorira).
Pokusao sam preko safe mode-a i preko Administrator log in ali nista svejedno ne da. I tako stoji na desktopu... mogu ga samo micati po njemu i ne znam sto vise s njim................
remplir je offline   Reply With Quote
Staro 23.08.2008., 17:25   #2
Joke
N00B
Joke's Avatar
Postovi: 3,886
Manual Method
If you already know the path to the file, please skip to Step 7
1. Click on Start, Search, All Files and Folders
2. Type the name of the undeletable file in the box shown
3. Make sure the Look In box shows the correct drive letter
4. Click Search and let the computer find the file
5. Once the file is located, right-click on it and choose properties, make a note of the file location. Usually this is something similar to
c:\windows\system32\undeleteablefilesname.exe
6. Close the search box
7. Click on Start, Run, and type CMD and Press Enter to open a Command Prompt window
8. Leave the Command Prompt window open, but proceed to close all other open programs
9. Click on Start, Run and type TASKMGR.EXE and press Enter to start Task Manager
10. Click on the Processes tab, click on the process named Explorer.exe and click on End Process.
11. Minimize Task Manager but leave it open
12. Go back to the Command Prompt window and change to the directory where the file is located. To do this, use the CD command. You can follow the example below.
Example: to change to the Windows\System32 directory you would enter the following command and Press Enter
cd \windows\system32
13. Now use the DEL command to delete the offending file. Type DEL <filename> where <filename> is the file you wish to delete.
Example: del undeletable.exe
14. Use ALT-TAB to go back to Task Manager
15. In Task Manager, click File, New Task and enter EXPLORER.EXE to restart the Windows shell.
16. Close Task Manager
Programs to automatically delete a file:
Remove on Reboot Shell Extension
Pocket Killbox
Unlocker
MoveOnBoot
IE6
Linux is Not Windows
Staro 23.08.2008., 18:54   #3
remplir
Postovi: 2
Nope. Nista od navedenog. Preko command prompt-a sam probao prije, a sada i ove programe. Tretira file kao da ne postoji.
Staro 23.08.2008., 23:06   #4
m4dm4n
Does youer dewg byte?
m4dm4n's Avatar
Postovi: 1,953
Probaj skinuti neku Live distribuciju , tipa ERD Commander za windowse, ili neki Live Linux, ili NAJBOLJE nađi boot disketu za DOS pa obriši, on sigurno neće ništa kenjati
Staro 25.08.2008., 14:18   #5
mrga
all you need is freeware
mrga's Avatar
Lokacija: Stolica
Postovi: 897
Ummm, kaj Unlocker ne pomaže?
Ovo je potpis.
mrga je offline   Reply With Quote
