Datum registracije: Dec 2003
Postovi: 391
Gotovo nikakva, ako trazite neku vga za malo para a zelite postic je... performanse, 9800se@pro, jednostavno i lako! P.S. samo staviti pasivce na memoriju, jer je razlika u memi (links, bakreni 45kn) A RAZLIKU MOZETE SAMI VIDJETI: www.club-3d.com ili 9800PRO Brand:_ATI Chip:_R350 Form_Factor:_AGP 4/8X GPU_Mhz:_380 Memory_MHz:_340 Video_memory:_128 Mb Memory_Bandwith:_256 bit Memory_Type:_BGA DDR DVI:_Yes TV/OUT:_Yes Features:_RADEON™ 9800 series is the ultimate accelerator of the most demanding next-generation 3D titles, scenes and environments Featuring highly programmable cinematic shader engines and support for the latest Microsoft® DirectX® 9.0 and OpenGL® feature sets Experience unparalleled 3D visual realism with the advanced engineering of ATI technology RADEON™ 9800 series beats with the heart of a champion, backed by the latest CATALYST™ software suite Order_Code:_CGA-P988TVD 9800SE Brand:_ATI Chip:_R350 Form_Factor:_AGP 2X/4X/8X GPU_Mhz:_380 Memory_MHz:_340 Video_memory:_128 Mb Memory_Bandwith:_256 bit Memory_Type:_DDR DVI:_Yes TV/OUT:_Yes Features:_RADEON™ 9800 series is the ultimate accelerator of the most demanding next-generation 3D titles, scenes and environments Featuring highly programmable cinematic shader engines and support for the latest Microsoft® DirectX® 9.0 and OpenGL® feature sets Experience unparalleled 3D visual realism with the advanced engineering of ATI technology RADEON™ 9800 series beats with the heart of a champion, backed by the latest CATALYST™ software suite Order_Code:_CGA-S988TVD
Toshiba U400 - 1.86GHz, 3Gb, 250Gb, 13.3'' --- HP NX7300 - 1.66GHz, 2Gb, 80Gb, 15.4'' --- Intel Server Board, XEON 2.0GHz, 1Gb ECC, 2x18.1Gb 10000rpm raid, 3x250Gb. 2x320Gb, 1x120Gb |
od LemilicE
Lokacija: Veli Lošinj
Postovi: 4,712
Re: CLUB3D 9800SE i 9800PRO RAZLIKA
Dobro jutro!!! Ja je imam već više od 6 mjeseci. Jest da mi u sigu ne piše da je Club3D, ali bio je to topic prije na ATI forumu
#3 | |
Postovi: 391
Re: Re: CLUB3D 9800SE i 9800PRO RAZLIKA
e da i jos nesto ide i na frekvu XT i vise(naravno origigi oma 256Mb rama), ali treba je.....acko hladenje, ako nista drugo vodeno, probo, jako brzo se mema zagrije!
...(=_o)...
Lokacija: Osijek/Đakovo
Postovi: 401
Jel dovoljno stavit pasivce na memoriju ili treba još nešto drugo ?De nek mi netko malo pojasni kako to ide |
od LemilicE
Postovi: 4,712
Moja ne ide na XT freqve. Najviše bez artefakata sa Artic-Silencerom i pasivcima je 390/370 Vodeno na grafu dolazi ubrzo
#6 | |
Postovi: 391
Pa ako se samo mod-a iz SE u pro, dovovljni su ti pasivci na memi, proc se malo jace grije, al on ima osigurano zracno hladenje, dok zbog meme ako joj ne stavis barem pasivce, imas na ekranu pri pokretanju 3d igre ili sl. hrpu artefekatata, pucanje slike i mjesanje boja i dr.! E da bi jos sa PRO modo na XT, za to treba odlicno hladenje jer se grije u PM. (pro clock je 380/340, a treba dignut iznad 415/370), (mislim da zalman ima odlican zracni cooler od bakra, ugraduje se sa obje strane vga-e). Uskoro cu ga kupiti, pa probat, javim na forum.
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
XT takt ti je 412/365 U pravilu skoro svaki GPU hoće ići toliko, memorija zna zezati. Nije ni meni išlo preko 400 dok nisam promjenio BIOS. Sad bez beda dela na 412 ![]() |
#8 | |
od LemilicE
Postovi: 4,712
#9 | |
Postovi: 391
MOzes mi dat link za update bios-a? Ili sendaj na forum Hvala!
#10 | |
Super Moderators
Postovi: 17,485
http://my.tbaytel.net/panthor/files/ Hrpetina svih živih tu: http://my.tbaytel.net/panthor/files/ |
#11 | |
od LemilicE
Postovi: 4,712
Club3d 9800SE ima Hynixovu memoriju, a oni biosi su svi sa Samsung memorijom. Našao sam bios od Club3D 9800XT 128MB Hynix, ali kad ga učitam u Rabit, on mi napiše R360, pa me strah flashat da ne bi opet sjebo grafičku. Kad bi bio takav bio sa R350...
#12 | |
Super Moderators
Postovi: 17,485
Dakle R350 sam flashao sa moddanim R360 BIOS-om. Imam artifakte u par testova iz 2003 Marka ali u igrama i u 2D-u ne. Ne možeš tek tak zajebati grafu sa BIOS-om Samo sejvaj stari, ako ne dela kak treba vrati i nikom ništa... Dobro je imati neku jeftinu PCI grafu pri flashu, ako ne dobro zapamti proceduru i re-flashaj "na sljepo" ako nekaj zezneš. |
#13 | |
Postovi: 391
thx
#14 | |
Super Moderators
Postovi: 17,485
#15 | |
Super Moderators
Postovi: 17,485
Htio sam staviti http://www.ocfaq.com/softmod/bios.php pa mi se prst omakao Vidio sam kod http://www.rojakpot.com/ neki Sapphireov, Hynix 2.8ns 412/365 128 MB. Ne znam da li je to vama paše... |
#16 | |
Postovi: 391
#17 |
od LemilicE
Postovi: 4,712
Znači ja bi na moju R350 sa Hynix memorijom mogao flashat bios za R360 i Samsung memorijom??? Imam PCI S3 32/64V+ u ladici ![]()
#18 | |
Postovi: 391
#19 |
od LemilicE
Postovi: 4,712
Upravo sam probao flashat XT bios od Club3D XT kartice sa 128MB Hynix memorije. Sa Rabitom sam biosu smanjio latencije da radio kao PRO (tako meni radi) i smanjio sam joj fekvencije GPUa i memorije. Nakon flasha ekran mi je bio scrambled, pa sam opet morao napamet flashat nazad original bios. Možda nisam smio micat latencije memorije, ali probao sam na mom original biosu stavit latencije XTa i ekran mi je također bio scrambled, ali puno manje nego kad sam flashao cijeli XT bios (sa PRO latencijama). Mislim da nam nema nade, osim da probam još malo zategnut latencije memorije
#20 |
Super Moderators
Postovi: 17,485
Ja sam svoju Herc NP flashao sa modanim XT (isto Herc) i dela. Kaj se tiče Hynix memorije-jedino sam je vidio na rojakpotu, ak naletim na još koju javim... |
#21 |
Super Moderators
Postovi: 17,485
Ovak-veli škvadra da kad su probali flashati sa Hynix baziranim da nije išlo, ali da im dela sa Samsungovim Jedan je flashao sa Powercolor.9800XT.128MB.Samsung.E-Die i veli da dela fino. Taj PowerColor je navodno jedan od bržih. Ajde Lorde na posao E da-ja sam isto flashao sa PRO frekvama a ne sa XT. Pa kad ti se hoće lako clockneš ili si prek RadLinkera napraviš profil za igru sa višljim frekvama... |
#22 |
od LemilicE
Postovi: 4,712
Uspješno sam flashao sa Powercolor 9800XT Samsung (bez Die-E) 128MB biosom, nije bilo artefakata, ali ima jedan drugi problem. Kad reinstaliravam driver kaže mi da ne postoji driver za moju karticu. Da li trebam editirat još nešto? Imam 2 različita PowerColor biosa, za oba 2 mi u Rabitu pod DeviceID kaže 4E4A (to je XT), ali kad flasham u RivaTuneru kaže mi da imam 414A, provjerio sam u instal.inf datoteci Catalysta i taj broj ne postoji. Riješenje? Jel ima još koj bios editor??
#23 |
od LemilicE
Postovi: 4,712
Sad sa probao flashat, ali bez da forsam flash i lijepo piše da je bios koji pokušavam flashat 4e4a (XT), znači nije u tome problem. Da li moram napravit Hard-Mod u PRO, da bi mogao flashat u XT i normalno instalirat drivere?
#24 | |
Postovi: 391
Kad si flash-ao sigurno si zaboravio staviti 0 za no video adapter ili 1 za neki bla bla, uglavnom, pise ti sve u helpu od flashrom-a
#25 | |
od LemilicE
Postovi: 4,712
Uspijem ja flashat, sve prođe kako spada, ali ne mogu instalirat drivere. Kao što sam napisao u zadnjem postu, time sam samo htio provjerit točan DeviceID biosa
#26 | |
Postovi: 391
#27 |
od LemilicE
Postovi: 4,712
Malo sam zategnuo latencije memorije po uzoru na XT bios koji ima latencije najsličnije mojima i uspio natuć 6406 Marka (399/375), na tim freqvama ima nešto artefakata, ali su mi sva testiranja na toj freqvi i sve slike koje imam, pa ne mijenjam. Reci na kojim freqvama ti testiraš, pa da probam i ja, pa ćemo usporedit. Da li se isplati zajebavat sa tim latencijama.
#28 |
Super Moderators
Postovi: 17,485
Ja sam neke stvari mjenjao sa BiosEdit 2.5 verzijom. Sa njim mjenjaš i id i SubSys itd... Imam sa 432/368 oko 6618 http://service.futuremark.com/servle...jectId=2761671 S tim da sam mjenjao ploču i nisam radio re-instal OS-a Sa čistim OS-om i procom na 2500 kak ga inače držim bilo bi nekaj više... Sve razmišljam da konačno skinem onu tvorničku žvaku ili kaj je već gore, stavim Dr.Thermala pa da vidim do koliko ide GPU... |
#29 |
od LemilicE
Postovi: 4,712
E kad bi barem meni radio na 400 bez artefakata i to još sa Artic-Sinencerom. Kad sam kupovao SE, nisam znao da se i NP može modat u PRO, a kamoli u XT. Drugi put neću kupovat ćim izađe ![]()
#30 | |
Super Moderators
Postovi: 17,485
Eventualno mu promijeni takt na Pro frekve. Probaj sa onim BiosEditom 2.5 ili novijim ili sa RadEdit-om. Dobro je prije flasha pobrisati drivere i očistiti smeće od starih. |
