Staro 18.07.2004., 14:45   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Novi Radeon Omega Drivers v2.5.58 (Cat 4.7)
Početkom tjedna je izbacio drivere za mrsku nam Nvidiu , pa smo morali malo pričekati...
What's New? (2k/XP 2.5.58)
* Based on the official Catalyst 4.7 drivers.
* Added support for some new Radeon cards.
* Updated the CS OpenGL to a new version that fixes the 16bit bug from my
previous set.
* Included an ATI utility to enable/disable TAA.
* Included a new utility to swap between the Normal and CS OpenGL driver.
* Changed the compression method for internet distribution, now the drivers are
compressed with 7-Zip self-extractor.
Using Special OGL file: Since this OGL file has some small bugs, if you got
video corruption in Counter-Strike, all you need to do is to add "-32bpp" to
the game's command line or set it up in Launch Options (CS 1.6 + CS:CZ). The
game will run FASTER and look better than using 16bit color.
http://www.omegadrivers.net/
