Staro 25.06.2004., 00:45   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Novi MMC 9.1
Evo i nove verzije, nešto su popravili, nešto dodali...
Resolved issues in the ATI MULTIMEDIA CENTER™ 9.1:
Using the file player to play an MPEG1 movie clip in full screen mode no longer results in the ATI MULTIMEDIA CENTER™ control panel failing to respond to certain commands
Clicking the loop button in the Media Library to start the playback of a TV-ON-DEMAND file no longer results in all TV-ON-DEMAND files being played back before starting the selected TV-ON-DEMAND file
Display corruption is no longer seen when re-launching the ATI File Player's controls in full screen mode
Un-muting the volume on the file player by increasing or decreasing the volume setting no longer results in the Permanent Mute OSI remaining on the screen
A qdvd.dll error message no longer occurs when shutting down the TV on a server followed by shutting down the TV on a client and then attempting to restart the TV on a client
Setting a scheduled TV event no longer results in the event failing to be triggered
The operating system no longer fails to respond when EAZYLAUNCH™ is enabled
EAZYSHARE now supports systems using multiple monitors
Attempting to schedule recordings using the composite input under Windows XP with an ATI TV WONDER™ II installed on a system containing an ATI RADEON™ 9000/9100 IGP series no longer results in the input source changing during the scheduled recording
The Record Program history dialog now provides the correct start time, and duration
Entering or exiting TV-ON-DEMAND™ mode while in THRUVIEW™ now results in video becoming non transparent
Performing an MPEG2 or AVI recording no longer results in the ATI MULTIMEDIA CENTER™ failing to respond if the recording space runs out
Setting channel skip duration for TV-ON-DEMAND™ using the setup button is now functioning properly
The ATI Scheduler no longer fails to start after downloading remote jobs from Fast TVTV for the first time
The Fast TVTV guide found in the TV application no longer produces an un-sorted and un-filtered channel list when using German regional setting
Known Issues with the ATI MULTIMEDIA CENTER™ 9.1:
Attempting to rotate the display two or more times while playing a DVD results in the DVD Player failing to respond
Enabling DVD audio through ATI Rage pass thru device results in choppy audio and video
Icons remain on the screen after a feature is triggered when using EAZYLAUNCH
Playing back recorded EAZYSHARE content through the Media Library on more than one client may cause erratic system behavior
Attempting to play a pre-recorded .VCR file with EAZYLOOK
enabled results in only the audio being played back
http://www.ati.com/support/drivers/w...2&submit=GO%21
