Staro 09.06.2004., 22:26   #1
Veky
Veky's Avatar
Datum registracije: Nov 2002
Postovi: 1,950
Catalyst 4.6
Release Notes
WinXP/Win2K
Opet ima poboljsanja performansi.
Lijepo lijepo.
Performance Improvements
  • Pixel Shader compiler improvements bring significant performance gains to PS 2.0 applications such as Halo (2-3%), Tomb Raider (4-5%) and Mother Nature (4-5%). ShaderMark 2 shows numerous gains in the 3-6% range. The High Dynamic Range scenes in ShaderMark (Tests 20 & 21) gain 10-15%.
  • RADEON X800 driver tuning improves performance for several Vertex-Shader-heavy tests. For example, Battle of Proxycon, Troll's Lair and Mother Nature gain 9-15% on the RADEON X800 PRO.
  • Improvements in our surface allocation and texture management code have increased performance for resource-challenged cases. Re-Volt scores improve 25% at 1600x1200 across several RADEON configurations. ShaderMark Test 14 (Veined Marble) improves dramatically (up 380% at 1600x1200) on some 256MB products.
  • Improvements in OpenGL driver efficiency bring numerous small gains (1-3%) in Call of Duty, Wolfenstein - Enemy Territory, Star Trek - Elite Force II, Serious Sam, Return to Castle Wolfenstein and Quake III Arena.
  • X800 memory tuning improves Anti-Aliasing performance in a number of games and benchmarks. For example, at 4xAA, 3DMark2001 gains 4-7%, UT2003 Antalus and Asbestos Flybys improve 2-7%, and the CodeCreatures score rises 15%.
itd
Zadnje izmijenjeno od: Veky. 10.06.2004. u 13:51.
Veky je offline   Reply With Quote
Staro 09.06.2004., 22:58   #2
ßellerophon
Sannin
ßellerophon's Avatar
Datum registracije: Jun 2003
Postovi: 1,568
da... iz prilozenog se lijepo vidi kako nova super turbo kartica dobija pusta poboljsanja zahvaljujuci novim driverima...
a ruku na srce njoj to i treba jel tako?
nije kvragu isto ako izgura nature 120fps umisto samo 100fps....
tko sljivi slabije kartice... ionako smo svi u redu da kupimo x800...
YES - BUT /
Staro 09.06.2004., 23:16   #3
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
nemam zivaca za usporedbe al se sjecam jos od prije za vrijeme 3x drivera islo je ovak odprilike.(od ljudi koji su testirali)
3.8 malo brzi od 3.9, 3.9 malo brzio od 3.10..
Dok sam imal TNT2 kod nvidie je to bilo zakon,,driveri 2,8 najbrzi a najnoviji su bilo 30% sporiji od 2.8
Imam sad 4,5 i vise se ne zamaram s tim, mozda metnem i te 4,6 barem bi kompatibilnost trebala bit OK
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
BrunoZG je offline   Reply With Quote
Staro 09.06.2004., 23:17   #4
LightForce1308
cmiiiiiiiiiiiiiiiiiii
LightForce1308's Avatar
Datum registracije: Jul 2003
Postovi: 452
Pa nismo baš svi!
LightForce1308 je offline   Reply With Quote
Staro 09.06.2004., 23:48   #5
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Evo i komparacije novih drivera
http://www.amd-insight.de/main.php?c...parison&page=1
Verzije od 3.0 pa sve do 4.6
Staro 10.06.2004., 00:19   #6
MentalHarikiri
MentalHarikiri's Avatar
Postovi: 2,560
a jesu li stavili mogućnost uključivanja trilinearnog filtriranja??? : evil :
Staro 10.06.2004., 00:57   #7
BrunoZG
Junior Member
BrunoZG's Avatar
Postovi: 3,205
Bome dal si je covjek truda sa tom komparacijom, tak se vec da usporedit kad ima gotovo
ELSA 7600GT
Staro 10.06.2004., 01:40   #8
ßellerophon
Sannin
Postovi: 1,568
svaka cast tipu...
zakljucak igram sve igrice osim FC na 3.1 driverima...
YES - BUT /
Staro 10.06.2004., 09:59   #9
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Kad će već jednom XP SP2, da se i ja prebacim
Staro 10.06.2004., 16:22   #10
ßellerophon
Sannin
Postovi: 1,568
kraj ovog - mozda sljedeci mjesec...
YES - BUT /
Staro 10.06.2004., 20:16   #11
Bl@de
Bl@de's Avatar
Lokacija: Ispred kompa
Postovi: 2,004
Ja bum pricekal omegu, iako neznam jel ce mi se dati skidati. ipak nije svejedno skidati 20 mb svako malo.
Intel i5 4670k
ASrock Z87 Extreme 3
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
OCZ SSD Vertex 4 - 128 GB
Samsung T166 500 GB 7200 okr/min 16 MB HD501LJ
Samsung F1 1 TB 7200 okr/min 32 MB HD103UJ
Dell S2522HG
Chieftec DX-01BD-V, Corsair 520W CMPSU-520HXEU
Bl@de je offline   Reply With Quote
Staro 10.06.2004., 22:38   #12
flajpan
flajpan's Avatar
Lokacija: Zagreb, Centar
Postovi: 1,796
Skinem ja pa ti dam ak hoćeš. Za manje od 5 min
