Staro 08.05.2008., 18:22   #1
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Question Gdje naći Drivere za ATI mobility HD2300
Naime gledam na ATI site-u i piše da samo imaju drivere za desktop računala a ništ za laptope.Inače radi se o Fujitsu Siemens AMILO Pi 2530 i na njihovoj stranici stoje driveri iz 2007 a siguran sam da mora bit noviji samo neznam di bi trebao pogledat pa ako ima tko koji info...
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 08.05.2008., 18:33   #2
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
http://www.ati.com/online/mobilecatalyst/
trebao si barem OS napisat koji je
danij3l je offline   Reply With Quote
Staro 08.05.2008., 18:37   #3
Lihto
Lihto's Avatar
Postovi: 3,945
Autor DaNiJ3L Pregled postova
za vistu mi treba
al čekaj sad sam bio tamo i meni baci ovo evo pročitaj
http://support.ati.com/ics/support/d...estionID=26978
Nego naišao sam na zanimljivu stvar na Drive Heaven http://www.driverheaven.net/modtool.php
iPhone XR 128gb
Staro 08.05.2008., 19:08   #4
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
Autor Lihto Pregled postova
za vistu mi treba
32 ili 64 bit hahaha
sva sreca da to ATI pakuje zajedno
sto nije daleko od istine - na njihovim stranicam putem linkova i sl nije moguce doci do mobility catalysta. morash znati link ili nista od zabave
probaj prvo ovo:
WINDOWS VISTA DRIVERS/INTEGRATED ATI VIDEO CARD DRIVERS
1. Download the display driver from ATI here.
2. Double-click the installer and let the installation fail - all we needed to do was extract the files.
3. Go into the Device Manager and expand the Display Adapters by clicking the "+" sign. Right-click on your adapter (there should only be one) and click "Update Driver Software." Install the driver of your choice and do not let Windows search for it. Click "Have Disk" and go into the folder where the drivers were extracted - the default location is C:\ATI\Support\[driver name - something like "7-1_xp_dd_40211"]2KXP_INF.
4. Choose the "_CX" .INF file and click OK.
5. Scroll down and find your graphics card.
6. Finish the installation by following the wizard.
If when installing drivers you get any messages regarding testing or similar, always hit "Continue Anyway".
Having trouble? See this post first by Fade to Black.
Izvor: forum.notebookreview.com
Staro 08.05.2008., 19:46   #5
Lihto
Lihto's Avatar
Postovi: 3,945
32bit
probaj prvo ovo:
budem probao thx
iPhone XR 128gb
Staro 08.05.2008., 22:55   #6
Lihto
Lihto's Avatar
Postovi: 3,945
Evo probao sam ovo i jedno što nalazim od ovih grafička najbliže je HD2350 jel da onda nju stavim ili ?
iPhone XR 128gb
Staro 09.05.2008., 00:26   #7
danij3l
danij3l's Avatar
Lokacija: NA
Postovi: 2,620
to nebi znao
Staro 09.05.2008., 00:54   #8
Lihto
Lihto's Avatar
Postovi: 3,945
to nebi znao
probao sam i preko onog programa i jednostavno neće updateat stoji u device manageru stari datum drivera,probao sam stavit kao tu HD2350 i onda radi ali piše HD2350 i normalno driveri updateani,ali nekako se bojim ostavit tak,neznam dal se može šta pokvarit,tj. moguće da će ga brkat itd. Ako još netko ima kakav prijedlog...
iPhone XR 128gb
Staro 09.05.2008., 10:06   #9
Postovi: 33,950
Zašto uopće tražiš noviji driver za grafu? Stari ne radi dobro?
Staro 09.05.2008., 10:14   #10
Lihto
Lihto's Avatar
Postovi: 3,945
Autor coconut Pregled postova
pa siguran sam da WoW može bolje radit,nego što radi,pa se nadam da je do drivera
iPhone XR 128gb
