Staro 07.05.2008., 14:20   #1
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Nero - "Illegal Disc" na Samsungu 203B
Nero 8.2.8.0
Ahead Software
4K22-0117-1100-1M84-5915-AC7M-****
EC06-206A-99K5-2527-940M-3227-****
9C00-E0A2-98K1-294K-06XC-MX2C-****
4C04-5032-9953-2A16-09E3-KC8M-****
EC05-E087-9964-2703-05E2-88XA-****
5C0X-205M-99M1-2435-2118-K246-****
4C0E-4009-9863-2X6M-1939-12A1-****
Windows Vista 6.0
AMD64
Wow64Process
WinAspi: -
NT-SPTI used
Nero Version: 8.3.2.1
Internal Version: 8, 3, 2, 1
Recorder: <TSSTcorp CDDVDW SH-S203B>Version: SB03 - HA 1 TA 3 - 8.3.2.1
Adapter driver: <Serial ATA> HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: <SM3132A GMQ515L >Version: 1.01 - HA 1 TA 1 - 8.3.2.1
Adapter driver: <IDE> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : RAID0-410AS iaStorV Port 0 ID 0 DMA: On
DiskPeripheral : Maxtor 6L250S0 iaStorV Port 0 ID 1 DMA: Off
CdRomPeripheral : SM3132A GMQ515L 1.01 aapyocg2 Port 4 ID 0 DMA: Off
=== CDRom-Device-Map ===
SM3132A GMQ515L I: CdRom1
TSSTcorp CDDVDW SH-S203B H: CdRom3
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2045MB (2094800kB)
Free physical memory: 725MB (742972kB)
Memory in use : 64 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
7.5.2008
Burn DVD Image
14:00:18 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
14:00:18 #2 Text 0 File Burncd.cpp, Line 3568
Turn on Disc-At-Once, using DVD media
14:00:18 #3 Text 0 File DlgWaitCD.cpp, Line 311
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1919275 (426:30.25, 3748MB)
14:00:18 #4 Text 0 File DlgWaitCD.cpp, Line 323
Write in overburning mode: NO (enabled: CD)
14:00:18 #5 Text 0 File DlgWaitCD.cpp, Line 2932
Recorder: TSSTcorp CDDVDW SH-S203B, Media type: DVD-R
Disc Manufacturer ID: <RITEKF> <1>
Disc Application Code: 64, Disc Physical Code: 193
14:00:18 #6 Text 0 File DlgWaitCD.cpp, Line 497
>>> Protocol of DlgWaitCD activities: <<<
14:00:18 #7 Text 0 File ThreadedTransferInterface.cpp, Line 754
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, ISO 9660)
2 indices, index0 (150) not provided
original disc pos #0 + 1919276 (1919276) = #1919276/426:30.26
not relocatable, disc pos for caching/writing not required/not required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1919276 blocks [H: TSSTcorp CDDVDW SH-S203B]
14:00:18 #8 Text 0 File ThreadedTransferInterface.cpp, Line 956
Prepare [H: TSSTcorp CDDVDW SH-S203B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3930677248, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 1919276 | 1919276 | 0x00
1919276 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
14:00:18 #9 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
14:00:18 #10 Text 0 File Burncd.cpp, Line 4359
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
14:00:18 #11 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
14:00:18 #12 Text 0 File Burncd.cpp, Line 4481
Cache writing successful.
14:00:18 #13 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
14:00:18 #14 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 8x (11.080 KB/s)
14:00:18 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2673
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
14:00:18 #16 Text 0 File DVDR.cpp, Line 3280
Recording mode: Sequential Recording Mode
14:00:18 #17 Text 0 File DVDR.cpp, Line 3434
Start write address at LBA 0
DVD high compatibility mode: Yes
14:00:18 #18 Text 0 File Cdrdrv.cpp, Line 10164
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
Outer Limit of Data Recordable Area: 0 h
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: 6.0
Revision number of minimum recording speed: -
Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
Class: 0, Extended part version: 33
Start PSN of the Extra Border Zone: 0 h
Start PSN of Physical format information blocks in Extra Border Zone: 0 h
Media Specific [16..783]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
1D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
01 40 C1 FD 9E D8 52 00 - 02 87 0D 13 87 88 90 00 .@....R.........
03 52 49 54 45 4B 46 00 - 04 31 00 00 00 00 00 00 .RITEKF..1......
05 88 80 00 00 00 02 00 - 06 09 0F 15 87 88 90 00 ................
07 A8 82 00 20 00 00 00 - 08 06 16 10 14 0F 0B 00 ................
09 94 07 0D 0B 88 88 00 - 0A 80 00 00 00 00 10 00 ................
0B 09 1E 17 A7 89 85 00 - 0C B7 89 02 00 20 02 00 ................
0D 00 00 D0 00 00 00 00 - 0E 0C 2B 39 33 29 1C 00 ..........+93)..
0F 50 1D 2B 0F 97 B5 00 - 10 88 80 00 00 00 00 00 .P.+............
11 00 00 00 00 00 00 00 - 12 0C 32 45 41 2D 27 00 ..........2EA-'.
13 50 23 2F 0F 97 B5 00 - 14 88 80 00 00 00 00 00 .P#/............
15 00 00 00 00 00 00 00 - 16 0A 4A 4F 4B 23 29 00 ..........JOK#).
17 80 1B 27 10 68 B5 00 - 18 88 88 00 08 00 08 00 ...'.h..........
19 00 00 00 00 00 00 00 - 1A 08 59 55 52 2D 2B 00 ..........YUR-+.
1B 60 1F 29 0B A9 B5 00 - 1C 88 80 00 00 00 00 00 .`.)............
14:00:18 #19 Text 0 File DVDR.cpp, Line 3572
Reserved Track size: 1919280 (1D4930h, 3748MB) -> return code 0
14:00:18 #20 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
14:00:35 #21 Text 0 File Cdrdrv.cpp, Line 1404
14:00:35.245 - H: TSSTcorp CDDVDW SH-S203B : Queue again later
14:04:31 #22 SPTI -1046 File SCSIPassThrough.cpp, Line 196
CdRom3: SCSIStatus(x02) WinError(0) NeroError(-1046)
CDB Data: 0x2A 00 00 09 03 60 00 00 20 00 00 00
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x30
Sense Qual: 0x05
Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 30 05
Buffer x0bf88e00: Len x10000
0x27 B8 81 0B 90 8D 3C 60 75 10 B6 02 C8 86 F6 46
0x85 E7 FA 22 DC 4F 0D EC 13 63 55 32 E2 82 ED 11
0x4A B5 08 5A 19 D4 18 77 65 F5 3D 84 4E 8E 40 CB
14:04:31 #23 CDR -1046 File Writer.cpp, Line 306
Illegal disc
14:04:34 #24 Text 0 File DVDR.cpp, Line 3840
EndDAO: Last written address was 590687 (9035Fh)
14:04:34 #25 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 8x (11.080 KB/s)
14:04:34 #26 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
14:04:38 #27 Text 0 File Cdrdrv.cpp, Line 11420
DriveLocker: UnLockVolume completed
14:04:38 #28 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
Ubacio sam tu, da ne smetim post.
HMHM, Ritek je medij, al mi oke izgleda crta...
Poz, jednu stvar ne kužim... Pržilo se sve u redu dosad, no ima problem. Stane na pola i baci error "Illegal disc". Zanima me samo što se događa te da li je do Samija ili DVD-a. Našao sam tu neke printable DVD-ove, stvarno ne znam proizvođača, piše gore: J4-05F60512221294H02.
Ovo je log:
Nero 8.2.8.0
Ahead Software
Windows Vista 6.0
AMD64
Wow64Process
WinAspi: -
NT-SPTI used
Bus Type : default
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Use Inquiry : 1
7.5.2008
Burn DVD Image
DAO infos:
MCN: ""
DAO layout:
Sense Code: 0x30
Sense Qual: 0x05
Illegal disc
Existing drivers:
Registry Keys:
Zadnje izmijenjeno od: IcyTexx. 07.05.2008. u 15:18.
Staro 03.07.2008., 21:37   #2
Bambusha
Bambusha's Avatar
Lokacija: Čepin
Postovi: 297
sry što dizem temu, al isti problem kod mog frenda, pa ak netko zna nek reče
Intel G1610; ASUS B75M-LX Plus; 4096 MB; Intel HD; Hitachi 7K1000.C 500 GB; LG GH24NS95; Silverstone Strider Essential 400 W; Logitech K200; Logitech B110; Logitech X-240 2.1; Philips 200V4LAB 20" DVI; Windows 7 64-bit Professional
Bambusha je offline   Reply With Quote
