Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Catalyst BETA available for Windows XP 64-Bit
Evo-za sretnike sa takvim pilama ![]() ATI has released a Beta version of their Catalyst driver and control panel for Windows XP 64-Bit. Release notes: - Running 3DLabs sample X29.exe under XP 64 AMD with an ATI FireGL X2 board installed results in the sample using Microsoft software OpenGL - Direct 3D performance issues are noticed when running applications such as; 3DMark2001SE, 3DMark2003, Serious Sam 2, and AquaMark. under XP 64 AMD with an ATI MOBILITY RADEON 9600/9700 series installed - OpenGL performance issues are noticed when running applications such as; Serious Sam 2, and Quake 3. under XP 64 AMD with an ATI MOBILITY RADEON 9600/9700 series installed - Having the option Link Time Code Generation enabled results in an error message indicating that there is Insufficient Destination Size for Storage - Entering the display properties and unchecking the option to Use DDC Information results in a dialog box being displayed indication Run a DLL as an App has encountered a problem and needs to close Entering S3 or S4 power state under a Windows XP64 system results in a machine check error message being displayed - Installing the ATI software driver under Windows XP64 AMD results in the TV option tab not being displayed http://www.ati.com/support/drivers/w...=13&submit.y=7 |
