Super Moderators
Datum registracije: May 2002
Postovi: 17,485
R300 Ruby Rap v1
Evo-nije dugo trebalo čekati ![]() Za gledanje novog X800 dema trebate samo skinuti: http://www.users.on.net/triforce/ruby/r300rubyrap.zip i kratke upute: http://www.users.on.net/triforce/ruby/r300readme.txt System Requirements =================== Minimum: 128 MB Video Memory 512 MB System Memory Recommended: 256 MB Video Memory 768 MB System Memory Notes ===== This should work for all 128 MB Radeon 9500 and above cards. A 128 MB card is REQUIRED! It will NOT run on 64 MB cards. If you have a 128 MB card, you should have your AGP aperture size set to 256 MB. You should also change resolution to 640x480 and multisampleType to 1 in Sushi.ini. You 'really' need more than 512 MB of memory to run this other wise speed will probably be terrible, if it runs at all. Make sure your Antialiasing Settings in your Control Panel is set to Application To decrease the size of the shaders so they would work on R300 class card, certain effects are now gone. These include Depth of Field and many specular highlights. A future version may attempt to put these back in." I da, demo je tu: http://www.ati.com/developer/demos/rx800.html 130 mega. Uživajte, nude patch je već u izradi ![]() ![]() ![]() |
Caught Somewhere In Time
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
upravo skidam pa ćemo da vidimo kak to zgleda ![]() |
Postovi: 1,860
eto skinuo odgledao i zgleda ok ![]() no ipak nije to ono pravo vjerojatno zgleda daleko bolje na x800 a to ćemo malo pričekati da i to vidimo nadam se da neću čekat predugo baj d vej ne pokrećite bez skoro pa gige rama jer svapa inače i to opako |
#4 | |
Super Moderators
Postovi: 17,485
Ja bum dobil demo sutra-prekosutra, a veli tip da to nije zadnja verzija wrappera, napravio je i da se može gledati i na FX-icama. Samo je na njima sp-oro ![]() |
Lokacija: Ispred kompa
Postovi: 2,004
ma ja bum radje skinul video demo. jel ionak nemrem na svojoj vidjeti field depth kaj me najvise zanima. potraziti cu high resolutio filmek i uzivati. BTW Jelc ak nagavis demo daj bumo se nasli samo da vidim kak ce stekati na mojoj grafi.
#6 | |
Postovi: 1,860
baj d vej nekak mi je čudno kaj se na fx-icama to sporo vrti a tebi?? ![]() ![]() |
#7 | |
Super Moderators
Postovi: 17,485
![]() ![]() ![]() Jeeee...da se čovjek zamisli:burn: A šupci iz Nvidie još ni nisu dali svoj demo u javnost, a baš lijepo izgleda... Da ne bi bilo ko i zadnji put-da se brže vrtio na ATI-ju ![]() Ma bilo je još dobrih wrappera i rendera po netu, sam kaj škvadra ne zna za to...npr. oko 150 mega OGL ATI render za UT, mrak izgleda...brz.... Još da mi je nekaj brže a ne 56k... ![]() |
CyberSky
Datum registracije: Feb 2004
Lokacija: Jastrebarsko
Postovi: 1,168
Evo ja sam skinuo taj demo ali neznam di to treba iskopirati,pročito sam readme i dalje neznam
The šuma... |
#9 | |
Super Moderators
Postovi: 17,485
Installation ============ Extract r300rubyrap.zip (with directories) to the "ATI Demos\DoubleCross" directory and you are done. ![]() |
#10 | |
Postovi: 1,860
#11 | |
Super Moderators
Postovi: 17,485
#12 | |
Postovi: 1,860
![]() a i ne mora bit samo za UT bilo kakvi demoi i slično zna bit na netu super stvari sam kaj ja u zadnje vreme nemam baš vremena to poiskat a kaj se tiče auteka ma pusti fakat ne znam kad sam nekaj zadnji put igral nema se cajta al sa zato danas skinuo GTR press demo i zgleda fenomenalno ![]() |
Sannin
Datum registracije: Jun 2003
Postovi: 1,568
ovaj... skinio sam mpeg ruby i snimka trokaje... ![]() pa koliko je to zahtjevno??? ![]()
YES - BUT / your evaluation is superb - behold the underlying truth |
PC Ekspert
Datum registracije: Sep 2000
Lokacija: Zagreb, Hrvatska
Postovi: 1,214
Ruby demo je meni totalno bezveze... neovisno jel na X800 ili na romobilu...
Nissan GT-R Black Edition |
#15 | |
Super Moderators
Postovi: 17,485
![]() Onu njihovu sirenu nisam još našao za skidanje... I nije bio topic hvalospjev o tom demu nego o mogućnosti pokretanja istog na starijem hardwareu ![]() |
#16 | |
Postovi: 1,860
#17 |
Super Moderators
Postovi: 17,485
Evo-probao i ja maloprije, ide fino ![]() I bogme je velika razlika u brzini kad se grafi da 256 MB u BIOS-u. Mislim-nije demo loš, ali da su ga mogli i bolje napraviti jesu... Ona eksplozija je ko da je žaba prdnula ![]() Dakle-kad se stavi 256 MB ide brže, tak i piše u uputstvu. Bar je tak na mojoj 9800 NP flashanoj u PRO i na kraju silovanoj XT BIOS-om ![]() ![]() ![]() Jadna grafa... |
#18 | |
Postovi: 1,860
#19 |
Sannin
Postovi: 1,568
istina... -kad ce past cijene memorija pocinjem ozbiljno razmisljat o kupnji jos jedno 512mb....
