Staro 05.03.2008., 12:34   #1
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
program za obradu HD sadržaja
Treba mi neki program s kojim bi mogao obrađivat HD sadržaj tipa smanjivat veličinu HD ripova sa 8gb na 4.5gb i tak dalje,pa preporučite mi neki...
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 05.03.2008., 17:33   #2
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
DVD Shrink? To ti nije dosta?
Staro 08.03.2008., 15:47   #3
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
DVD shrink nisam probao, ali ovako se moze skolski:
- VirtualDubMod za recompress AVI container-A. Sve isto kao i za SD AVI.
- Ako je MKV HDrip, onda prije VirtualDubMod-a izvuces streamove sa AVI-MUX (Gui).
- Ako je WMV HDrip, konvertiras sa All-to-AVI.
Sve besplatno.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 08.03.2008., 19:44   #4
Lihto
Lihto's Avatar
Postovi: 3,945
e thx to sam tražio,neznam baš kak bi to išlo preko DVD šrinka pošto se tu radi o MKV fileovima...
iPhone XR 128gb
Staro 08.03.2008., 20:26   #5
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Nisam skužio da je riječ o tome...
Staro 08.03.2008., 21:13   #6
domy_os
domy_os's Avatar
Postovi: 18,869
Ne znam koliko ti se to isplati jer i na tih 8 GB se malo vide artefakti od kompresije, a na 4.3 GB će se vidjeti još više zbog velike rezolucije i ponovnog rekodiranja. Jedino da smanjiš rezoluciju, ali to onda više nije HD nego DVD kvaliteta...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 09.03.2008., 17:17   #7
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor domy_os Pregled postova
Na 4GB 720p HD ripu se ne vide artefakti ako se kvalitetno ripa. U principu ja nisam osjetio bitnu razliku (gledano na 24" PVA LCD 1900*1200) izmedju 4-8GB HD ripa kad se radi o 720p. 1080p je druga prica. A HDrip od 4GB ima VELIKU prednost; stane na DVD, naravno.
Istina da "ripanje" ripa nije bas neko sretno rjesenje, ali ako je prvi rip dobar, mislim da se opet isplati.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 09.03.2008. u 18:02.
Staro 09.03.2008., 17:57   #8
Lihto
Lihto's Avatar
Postovi: 3,945
Autor estugarda Pregled postova
Na 4GB 720p HD ripu se ne vide artefakti ako se kvalitetno ripa. U principu ja nisam osjetio bitnu razliku (gledano na 24" PVA LCD 1900*1200) izmedju 4-8GB HD ripa kad se rado o 720p. 1080p je druga prica. A 4GB i VELIKU prednost; stane na DVD, naravno.
Istina da ripanje ripa nije bas neko sretno rjesenje, ali ako je prvi rip dobar, mislim da se opet isplati.
ma čisto da mi neke stvari stanu dok ne dođe 1Tb disk
iPhone XR 128gb
