Staro 30.09.2009., 20:30   #511
Necronomicon
सच्चाई यह है कि वहाँ से ब
Necronomicon's Avatar
Lokacija: Dubrovnik
Postovi: 570
Ne, u mene je ovakva:
Necronomicon je offline   Reply With Quote
Staro 30.09.2009., 20:46   #512
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Referentni ladnjak. Sve bi bilo razumljivo da XFX nije izbacio 1ghz karticu s tim istim referentnim ladnjakom ....
Staro 30.09.2009., 21:14   #513
Denis the Coach
Postovi: 20
Autor ZeljaOs Pregled postova
hmm znaci vi sa ovime modelom problema imate ?
http://www.links.hr/index.php?option...kl=051.806.443
Bas sam se maloprije bio odlucio na kupnju :/ a sad citam vase probleme, uopce mi se neda potrositi 1400-1500kn i onda jos mjenjati cooler na njoj :I
ima tko nekakvu drugu preporuku do 1400-1500kn ?
Ne. Ovo je BattleStation Edition. Nego s ovom...
http://www.sapphiretech.com/presenta...000101&pid=219
MBO: Asus P5Q-E
CPU: Intel Core 2 Quad Q9550 2.83 GhZ
Cooler: ASUS Silent Square
RAM: 8Gb DDR2 800MhZ
VGA: Sapphire Ati HD4890 1Gb GDDR5 PCI-E
Power: Gigabyte Odin GT 800W
HDD: Seagate 250Gb, Seagate 1.5 Tb
Case: Gigabyte full tower 3D AURORA 570S Plexy
OS: Windows 7 Ultimate 64bit
Denis the Coach je offline   Reply With Quote
Staro 30.09.2009., 21:19   #514
Denis the Coach
Postovi: 20
Autor Necronomicon Pregled postova
E s tom imam probleme...
MBO: Asus P5Q-E
Staro 30.09.2009., 21:36   #515
Router
Hejter
Postovi: 6,521
Autor trouble Pregled postova
Mislis 1 GB ?
Staro 30.09.2009., 22:06   #516
Wolverine
Wolverine's Avatar
Postovi: 12,433
misli 1GHz tj Radeon HD4870BlackEdition čiji GPU kuca na 1GHz a hladi ga takav referentni dual-slot cooler iako kalibriran na veći broj okretaja
Mark Twain
Intel Core i7 2760QM
2x 8GB DDR3
Intel HD3000
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 30.09.2009., 23:44   #517
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Hell yeah
A čim se vrti više samim tim je i bučniji....šteta što nisu sljedili sistem Safirea(vapor-X) i Club3D/PowerC. kartica koje uspješno ladi Zerotherm.....
Staro 01.10.2009., 11:47   #518
Denis the Coach
Postovi: 20
Dakle kako onda riješiti problem,odnosno kako natjerati ventilator da se brže vrti - ako je do toga?
Dali se to može u Ati Catalyst Center podesiti?
MBO: Asus P5Q-E
Staro 01.10.2009., 11:50   #519
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,300
rivatuner
Staro 01.10.2009., 12:36   #520
Wolverine
Wolverine's Avatar
Postovi: 12,433
Autor Denis the Coach Pregled postova
Možeš u CCC-u to podesit
Fino odeš na Overdrive i tamo imaš opciju za ručno podešavanje brzine ventilatora
Mark Twain
2x 8GB DDR3
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 01.10.2009., 16:39   #521
ZeljaOs
Postovi: 189
pokusavam naci nekakav review za tu 4890 battlestation ali ne uspijevam , ponajprije me zanima ovaj hladnjak na njoj da li je dostatan, ima netko link na review bas toga modela ili netko mozda posjeduje doticnu :?
ZeljaOs je offline   Reply With Quote
Staro 05.10.2009., 21:16   #522
ZeljaOs
Postovi: 189
eto kupio doticnu , malo sam se provozao u nfs shiftu i za sada rada kako spada, kasnije cu malo vise istestirati, no kao i uvijek pojavio se jedan problem
naime od kad sam stavio 4890 nemogu vise clockati procesor, prije je radio bez problema na 4ghz, sada cim dignem frekvencije i upalim komp on resetira postavke u biosu na default, sada mislim da bi to moglo biti do napajanja (chieftec 550w) mozda ono nije dostatno za ovu konfiguraciju ?
jedino mi nije jasno zasto resetira bios na default cim ga pokrenem ? zar se nebi ti problemi trebali pojaviti u samim igrama a ne cim pokrenem pc :?
Staro 06.10.2009., 10:53   #523
dart_tom
dart_tom's Avatar
Lokacija: osijek
Postovi: 460
nebi trebalo biti problem u napajanju,ja imam 530w be quiet i tijera ga bez problema!
dart_tom je online   Reply With Quote
Staro 06.10.2009., 11:02   #524
Postovi: 34,105
greška. mod - briši.
Staro 06.10.2009., 13:11   #525
ZeljaOs
Postovi: 189
koji sam ja baksuz, cini se da sam naletio na problem kompatibilnoscu ove graficke sa gigabytovim maticnim plocama, i to ne samo mojim modelom, zato upozorenje svima koji razmisljaju o kupovini doticne graficke a imaju gigabyte maticnu plocu , pogotovo saphire i msi model, ukoliko mozete bilo bi dobro da je prije kupnje prvo probate, ja sad procesor nemogu dici ni jedan mhz
potpuno identicne probleme mozete naci ovdje
http://forum-en.msi.com/index.php?topic=129934.0
http://forums.ncix.com/forums/?mode=...nt=7&subpage=1
edit jos jedan
http://www.overclock.net/intel-gener...oot-stock.html
koliko vidim doticni imaju ove maticne
Gigabyte GA-P35-DS3R rev. 2.1 (F13 bios)
Gigabyte EP45-UD3P
+ moja x38 dq6
Poslao sam upit na gigabyte support, ostaje mi samo nadati se da oni mogu pomoci , mozda da posaljem i saphiru :/
Zadnje izmijenjeno od: ZeljaOs. 06.10.2009. u 13:32.
Staro 06.10.2009., 13:20   #526
dejanbinladen
konjpjukter
Postovi: 934
Gigabyte EP45-UD3P
+ moja x38 dq6
probaj malo dic pci-e sabirnicu pa onda klokaj tipa 105-110 nemoj puno preko toga
dejanbinladen je offline   Reply With Quote
Staro 06.10.2009., 13:38   #527
ZeljaOs
Postovi: 189
evo upravo probao , isti vrag samo baci bios na defaultne postavke cim pokrenem pc , jos imam jednu ideju cackati malo po ramima, izvaditi jednu plocicu ili ih izbaciti iz dual channela :I uvijek me zateknu ovakvi egzoticni problemi
Staro 06.10.2009., 13:57   #528
dejanbinladen
konjpjukter
Postovi: 934
clearaj bios al ono par minuta, prebaci jumper i izvadi bateriju, ako nece ni onda onda fleshaj bios makar imas zadnji stavi opet taj isti, bilo je par situacija da pomogne
Staro 06.10.2009., 14:10   #529
ZeljaOs
Postovi: 189
Autor dejanbinladen Pregled postova
zavrsio sa ramima, nikakve pomoci post i dalje ocajno spor procesor neide gore ni jedan mhz, clear cmosa je nazalost bio prvo sto sam probao
flashati ponovno bios mozda probam, makar sumnjam da ce pomoci posto su neki sa istim ovim problemom to i pokusali , jedino rjesenje je bilo zamjena branda graficke , sto nevidim kako bih mogao izvesti, cini mi se da je i jednom pomoglo vadjenje jedne plocice rama (meni nije ni to)
za sada dizem ruke na neko vrijeme od ovoga i cekam eventualni odgovor gigabytovog supporta, posto su jedine konstante u ovoj prici gigabytove maticne, saphire i msi 4890 (od procesora dva e8400, e8500, xeon x3230 , od onoga sto sam pronasao naravno :/ )
Staro 06.10.2009., 15:55   #530
dart_tom
dart_tom's Avatar
Lokacija: osijek
Postovi: 460
ja imam konfu iz siga i nikakvih problema,e8500 na 4gh, tak da si stvarno izgleda baksuz ali probaj još štogod prćkat možda dođe sebi!
Staro 07.10.2009., 17:41   #531
DomagojX
Lokacija: Zagreb/Sesvete
Postovi: 1,307
evo našao sam kupca za svoju 4870...i namjeravam onda sad uzeti 4890...koju biste mi točno preporučili..dakle najvjerojatnije ću uzet novu jer na tržnici ima neš slabo tih 4890
DomagojX je offline   Reply With Quote
Staro 07.10.2009., 17:44   #532
Wolverine
Wolverine's Avatar
Postovi: 12,433
Sapphire Vapor-X ili Toxic
koja god ti bude jeftinija
Mark Twain
2x 8GB DDR3
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 07.10.2009., 18:03   #533
žile
žile's Avatar
Postovi: 3,074
Ti u osvit 5870 kartica ideš na vrijednost te svoje lupit još makar 50% cijene kako bi dobio 5fps-a više?Ti si lud ko šiba.
Osim ako nisi dobio nerealno visoku cijenu za nju (>1000kn) - čitaj zajebo nekog.
Ja bi rekao da ideš na neku najjeftiniju pa makar i sa referentnim kulerom jer ta investicija jednostavno nema budućnosti - vrijeme za kupovinu tih kartica je bio lipanj.
*sad vidim kako je razlika između najjeftinije i Vapor-X kartice ~100kn.Zaključak se sam nameće.
žile je offline   Reply With Quote
Staro 07.10.2009., 20:14   #534
DomagojX
Postovi: 1,307
a stavio sam an njuškalo 850kn i jedan čovjek bi to čak uzeo...ali ipak će još ostat doma par mjeseci dok ne padnu cijene malo 4890 ili ako se koja ne pojavi na tržnici
Staro 07.10.2009., 20:14   #535
dzura
bla bla...
dzura's Avatar
Postovi: 244
imam problem, primjetil sam da mi u igricama tu i tam steka pa sam napravil 3dmark vantage i dobil za gpu samo 5632.Zna neko mozda u cemu bi bil problem? Graficka je VTX 4890 1gb...
dzura je offline   Reply With Quote
Staro 09.11.2009., 19:56   #536
pc user
Postovi: 77
pc user je offline   Reply With Quote
Staro 09.11.2009., 20:02   #537
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
C L O W N I N G A R O U N D
Staro 09.11.2009., 20:07   #538
Majo
Lokacija: Zagreb,Dubrava
Postovi: 2,281
Ipak onu iz linksa,izgleda da ima jako dobro rijeseno hladenje,a skuplja je samo 120ak kn!
Majo je offline   Reply With Quote
Staro 09.11.2009., 21:28   #539
DomagojX
Postovi: 1,307
i ove XFX mogu se brutalno klokat
Staro 09.11.2009., 22:02   #540
cleary_555
Postovi: 29
Imam msi R4890. U catalystu bez podizanja memory clocka stavim gpu na 1 Ghz i pise kad kliknem test custom clocks passed. Malo mi je cudno jer kazu da ostale idu najvise do cca. 955 Mhz. Grafa je OC edition.
cleary_555 je offline   Reply With Quote
