Lokacija: Tenja
Postovi: 164
Catalyst 8.2
http://ati.amd.com/support/driver.html Resolved Issues for the Windows Vista Operating System This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows Vista. These include: Enemy Territory: Quake Wars: Corruption is no longer noticed when editing levels. Further details can be found in topic number 737-32141 World of Warcraft: Flickering and missing objects are no longer noticed when playing the game in OpenGL mode. Further details can be found in topic number 737-32140 .NET Framework an Unhandled Exception error no longer occurs when upon booting or re-booting the system. Further details can be found in topic number 737-32115 A white dot no longer appears on the windows desktop when launching the Catalyst Control Center. However, this issue may still be experienced under the Windows XP operating system. Further details can be found in topic number 737-31715 Audio stutter is no longer noticed when using the HDMI connector. Further details can be found in topic number 737-32118 Running the Spanish version of the Windows operating system no longer results in the Catalyst Control Center option failing to be available when right-clicking the Windows desktop menu bar. Further details can be found in topic number 737-32125 The Catalyst Control Center options are no longer missing for the secondary extended display when hot unplugging and hot plugging the display device. Further details can be found in topic number 737-32126 Native CrossFire™ can now be enabled when the primary display device is connected to the master card using a CV or TV. Further details can be found in topic number 737-32131 Enabling clone mode on a system containing an ATI Radeon™ X1200/1250/1270 series of product no longer results in the resolution and color depth changing to 640x480 8bpp. Further details can be found in topic number 737-32132 Playing DVD content using the Windows Media Player no longer results in the playback being choppy. Further details can be found in topic number 737-32136 Hot plugging and hot-unplugging an HDMI display device multiple times during one windows session may result in the display device failing to be detected. Further details can be found in topic number 737-32137 Enabling CrossFire™ on a system containing an ATI Radeon™ X1950 series of product no longer results in the Windows Vista operating system intermittently failing to respond. Further details can be found in topic number 737-32138 The lower portion of the Catalyst Control Center is no longer cropped when changing the display resolution from 640x480 to 1920x1200. Further details can be found in topic number 737-32139 An error message is no longer displayed when attempting to set both the primary (HDMI) display device and secondary (DVI) display device to a display resolution of 1280x1024. Further details can be found in topic number 737-32142 The Windows XP Professional x64 Edition operating system no longer reboots when installing the T200 driver. Further details can be found in topic number 737-32143 Setting the DPI to 120 in the Display Properties no longer results in the combo box being cut-off. Further details can be found in topic number 737-32144 The antenna signal strength is no longer reported by Vista Media Center as low. Further details can be found in topic number 737-32145 A black line is no longer noticed when using VIVO for capturing and using Radeon™ HD 2900. Further details can be found in topic number 737-32146 The PAL-N video captured from the ATI Radeon™ HD2900 no longer displays colors and with vertical bars. Further details can be found in topic number 737-32147 The T200 NTSC capture card no longer fails to capture the Closed Captioning signal. Further details can be found in topic number 737-32148 A Reduce DVI frequency on high-resolution displays option no longer appears when an HDMI display device is connected using an HDMI-DVI cable. Further details can be found in topic number 737-32149 Resolved Issues for the Windows XP Operating System This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows XP. These include: Doom3: Running an OpenGL application with CrossFire™ enabled and AA set to 16x no longer results in corruption being noticed when the display resolution is set to 2048x1536 or higher. Further details can be found in topic number 737-32150 TianXia2: Launching the game no longer results in the Windows XP operating system rebooting. Further details can be found in topic number 737-32152 Playing an H.264/VC1 title on a system with a display resolution higher than 1440x900 no longer results in the content failing to play in hardware mode. Further details can be found in topic number 737-32154 Changing the display resolution when CrossFire™ is enabled no longer results in the running 3D application failing to respond. Further details can be found in topic number 737-32155 Zadnje izmijenjeno od: Jelc. 14.02.2008. u 02:34. |
Eddie
Postovi: 5,508
Ajmo pokusni kunići!
Postovi: 469
hm da, ja sam bio pokusni za 8.1 pa sam vracao na stare drivere sad neka netko drugi testira ![]() |
JDM
Datum registracije: Sep 2004
Postovi: 6,137
Skidam ![]() javim kroz pol sata kakvi su ![]() |
Lokacija: Velika / Osijek
Postovi: 1,442
Evo skino, instaliro i.. Sve radi noramalno, probo witchera čini mi se da ima malo više frejmova ili je to možda palcebo efekat XD, nema nikakvih kvadratića il tak nešto, vrati sa Clear Type na Standard i sve OK sa bojama u firefoxu, 3d čmark javim skoro... Evo i 3DČmark 21 bod manje nego sa 7.11 Zadnje izmijenjeno od: ShebY. 14.02.2008. u 00:35. |
Lokacija: Tenja
Postovi: 164
Lokacija: Tenja
Postovi: 164
Postovi: 367
na nije lose mora da ga je doso jedno 15k sa svime sta pise ali nije bitno mogao si ga pitati preko PM-a a ne da tu OT pokreces |
JDM
Postovi: 6,137
Mah. Isto shranje ko i prije kolko vidim. 3dmark 21 bod manje il tako nesto ![]() @SRV: Budi sretan da si ti na ono brdo i dovukli kabel, a ti bi jos i flat ![]() |
#16 |
Postovi: 469
instaliro sam nije vrag dal mira i radi sve kak treba nema nikakvih kockica i firefoxu su sve boje kako trebaju biti ... kad stignem budem 3dmark odvrtio ... meni gpu z pokazuje uredno HD3870edit: ja sam dobio 46 bodova vise u 3D Mark-u slike stavljam u top 10 3DM poboljsao sam rezultat ![]() Zadnje izmijenjeno od: Thommy. 14.02.2008. u 01:29. |
#17 |
Postovi: 1,442
Da.. ma ljudi previše očekujete od ti vozača (drivera) pa nemogu oni sad napravit drivere da imate 2000k više bodova. Sve što mogu, a to i rade je dat podršku za neke nove igre,grafe i ispravit neka sranja iz prijašnjih verzija kao famozni "kvadratić"![]() Ja sam sretan što su ispravili ovo sa crvenim slovima zato jer mi sa clear type izgledaju slova mutno Edit: GPU-Z meni isto piše samo 3800 series, ali mi ni brzinu vrtnje venta neočitava točno.. |
#19 |
JDM
Postovi: 6,137
credits needed to fix bug = 60 points ![]() |
#20 |
Postovi: 1,442
#22 |
Lokacija: n/a
Postovi: 6,128
#25 |
JDM
Postovi: 6,137
#27 |
Lokacija: N/A
Postovi: 772
#30 |
The All Seeing Eye
Postovi: 1,103
Piše da ima neki boost u Crossfire-u, ali za x2 nisam ziher jel vrijedi isto!? |
