Datum registracije: Dec 2003
Postovi: 336
3DMark01SE Problem
Ne kužim u čemu je stvar, svaki put kad bi trebo počet test Nature, izbaci me u windovse i pojavi se ovaj ERROR Reinstaliro sam drivere, i 3DMark i opet ništa, reinstaliro sam i DirectX i opet ništa. Application info ---------------- Name 3DMark2001 SE Pro Build 330 Error log --------- FATAL ERROR: failed to validate material System info available: yes Project available: yes Result file ----------- 3DMARK2001 PROJECT FILE PROJECT Name My Benchmark Description Registration Name Registration Key 3DMark Version 330 DISPLAY Platform NVIDIA GeForce4 Ti 4200 CPU Optimization D3D Pure Hardware T&L Width 1024 Height 768 Depth 32 bit Z-Buffering 24 bit Texture Format Compressed Buffering Double Refresh Rate 60 Hz FSAA Mode None OPTIONS Show Title Screens Yes Continuous Benchmark No Benchmark Run Count 1 Demo Sounds Enabled Yes Continuous Demo No Game Sound Effects Enabled Yes Game Music Enabled Yes Game Detail Level Low RESULTS 3DMark Score N/A Game 1 - Car Chase - Low Detail 161.5 fps Game 1 - Car Chase - High Detail 58.1 fps Game 2 - Dragothic - Low Detail 194.8 fps Game 2 - Dragothic - High Detail 105.3 fps Game 3 - Lobby - Low Detail 140.2 fps Game 3 - Lobby - High Detail 64.9 fps Game 4 - Nature N/A Fill Rate (Single-Texturing) N/A Fill Rate (Multi-Texturing) N/A High Polygon Count (1 Light) N/A High Polygon Count (8 Lights) N/A Environment Bump Mapping N/A DOT3 Bump Mapping N/A Vertex Shader N/A Pixel Shader N/A Advanced Pixel Shader N/A Point Sprites N/A SYSTEM INFO System Info Version 2.2 Installation ID 0x00000000 OEM ID CPU INFO CENTRAL PROCESSING UNITS Manufacturer AMD Family ThoroughBred Internal Clock 2 GHz Internal Clock Maximum 2 GHz External Clock 133 MHz Socket Designation Socket-A Type Central Upgrade <unknown> Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE Version Model 8, Stepping 1 CPUID 0x00000681 CACHES Level 1 Capacity 128 KB Type <unknown> Type Details <unknown> Error Correction Type <unknown> Associativity <unknown> Level 2 Capacity 256 KB Type <unknown> Type Details <unknown> Error Correction Type <unknown> Associativity <unknown> DIRECTX INFO DirectX Version 9.0 DIRECTDRAW INFO DirectDraw Version 5.3.0000000.900 DISPLAY DEVICES Description Primary Display Driver Manufacturer NVIDIA Name NVIDIA GeForce4 Ti 4200 Total Local Video Memory 64 MB Total Local Texture Memory 64 MB Total AGP Memory 128 MB Display Driver nv4_disp.dll Display Driver Version 6.13.10.4109 Driver WHQL Certified No Max Texture Width 4096 Max Texture Height 4096 Max User Clipping Planes 0 Max Active Hardware Lights 8 Max Texture Blending Stages 8 Textures In Single Pass 4 Vertex Shader Version 1.1 Pixel Shader Version 1.3 Max Vertex Blend Matrices 0 Max Texture Coordinates 8 Vendor ID 0x10de Device ID 0x0253 Sub-System ID 0x87001462 Revision 0xa3 Pomozite, unaprijed hvala ![]()
AMD AthlonXP (Thorton) 2400+@2400MHz (15x160) 1,700 V MSI KT3 Ultra2-R, VIA KT333 2*256MB Kingmax SuperRam 433 @320 (2.0 2-2-5) MSI GeForce4 Ti4200 64Mb DDR @ 310/610 WD800BB, 80Gb , 7200rpm , ATA/100 Zadnje izmijenjeno od: Ujoma. 18.03.2004. u 00:48. |
Administrator
Lokacija: Sesvete
Postovi: 15,963
1. Preocan sistem. 2. Driveri od grafulje 3. Direct X |
Postovi: 336
Najgore je to šta mi sad nije ništa OCano, drivere sam stavio druge i DirectX sam reinstaliro i opet se događa isto. Ali to mi se počelo događat kad sam OCo grafičku, i mislio sam da je zbog prevelokog OCa, ali kad sam je vratio na deafoult još se uvijek to događa.
AMD AthlonXP (Thorton) 2400+@2400MHz (15x160) 1,700 V MSI KT3 Ultra2-R, VIA KT333 2*256MB Kingmax SuperRam 433 @320 (2.0 2-2-5) MSI GeForce4 Ti4200 64Mb DDR @ 310/610 WD800BB, 80Gb , 7200rpm , ATA/100 |
Postovi: 336
Ajde, ajde ljudi pa šta baš niko nezna u čemu je problem.
Datum registracije: Aug 2003
Postovi: 183
Probaj formatirat disk, pa natrag sve snimiti, ako ne upali posudi od frenda grafulju, rame itd. pa isprobavaj, mozda ti neka komponenta ne radi kak spada. Meni je grafulja srala, radila 2h testove i onda najedamput zelena slika po ekranu, a grafulja hladna. Odneso na popravak i dobio novu i to ATI orginal |
Treba kaj skurit??
Lokacija: Zgb
Postovi: 4,030
Pa sam si rekao da ti je to od kada si overclockao grafulju. Možda si malo pretjerao pa si jus*ebal. Probaj kod nekog drugog grafičku. |
Datum registracije: Feb 2004
Postovi: 71
Hvala na usernameu i passwordu za 3Dmark. Ha-ha, ne brini imam ja svoj ali pripazi drugi put. |
#8 | |
Postovi: 336
, evo obrisat ču ga za svaki slučaj.
Datum registracije: Jun 2003
Lokacija: Kuća
Postovi: 5,405
Instaliraj Norton Ghost i napravi si imiđ na drugu particiju koju nećeš dirati (ne zaboravi si napravit bootabilnu disketu, za svaki slučaj). Sad kad si spremio windoze sa svim drajverima i programima formatiraj tu particiju i instaliraj ponovno windowse sa drajverima i osnovnim programčićima pa češ vidjet. Ako ti neće i dalje radit još uvjek imaš imiđ windowsa koje možeš vratit. Sa Norton Ghostom 2003 možeš sve radit iz windowsa bez bootabilne diskete i ulaska u DOS. ![]()
Administrator
Lokacija: Sesvete
Postovi: 15,963
Malo lakše s tim UN i paswordima... |
Postovi: 336
Evo problem je uspiješno riješen, inače problem je bio u PowerStripu kad sam ga unistaliro i zavrtio 3DMark sve je prošlo OK. Hvala svima na pomoći ![]()
