Postovi: 1
DVD przilica ATAPI DVD A DH20A4P
Molim pomoc.. nova przilica nece radit ono za sto je napravljena.. PRZITI.. ![]() Hvala unaprijed... Log od Nera mi je ostao ovakav... Windows XP 5.1 IA32 WinAspi: - NT-SPTI used Nero Version: 7.7.5.1 Internal Version: 7, 7, 5, 1 Recorder: <ATAPI DVD A DH20A4P> Version: 9P53 - HA 1 TA 0 - 7.7.5.1 Adapter driver: <IDE> HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: <ATAPI DVD A DH20A4P >Version: 9P53 - HA 1 TA 0 - 7.7.5.1 Adapter driver: <IDE> HA 1 === Scsi-Device-Map === DiskPeripheral : Maxtor 6Y200P0 YAR4 nvidesm Port 0 ID 0 DMA: Off DiskPeripheral : QUANTUM FIREBALL EX6 A0A. nvidesm Port 0 ID 1 DMA: Off CdRomPeripheral : ATAPI DVD A DH20A4P 9P53 nvidesm Port 0 ID 0 DMA: Off CdRomPeripheral : HL-DT-STCD-RW GCE-8520B 1.02 nvidesm Port 0 ID 1 DMA: Off CdRomPeripheral : RS7044S LSF243R 1.01 a3vpypxv Port 1 ID 0 DMA: Off === CDRom-Device-Map === ATAPI DVD A DH20A4P D: CDRom0 HL-DT-ST CD-RW GCE-8520B G: CDRom1 RS7044S LSF243R J: CDRom2 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte BUFE : 0 Physical memory : 1023MB (1048048kB) Free physical memory: 544MB (557396kB) Memory in use : 46 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 18.1.2008 ISO compilation 17:36:11 #1 Text 0 File SCSIPTICommands.cpp, Line 411 LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL 17:36:11 #2 Text 0 File Isodoc.cpp, Line 6527 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 17:36:11 #3 ISO9660GEN -11 File Geniso.cpp, Line 3334 First writeable address = 0 (0x00000000) 17:36:11 #4 Text 0 File Burncd.cpp, Line 3465 Turn on Disc-At-Once, using DVD media 17:36:12 #5 Text 0 File DlgWaitCD.cpp, Line 306 Last possible write address on media: 2295103 (510:01.28, 4482MB) Last address to be written: 1724191 (383:09.16, 3367MB) 17:36:12 #6 Text 0 File DlgWaitCD.cpp, Line 318 Write in overburning mode: NO (enabled: CD) 17:36:12 #7 Text 0 File DlgWaitCD.cpp, Line 2912 Recorder: ATAPI DVD A DH20A4P, Media type: DVD+R Disc Manufacturer ID: MCC, Media Type ID: 004, Product revision number: 0 Disc Application Code: 0, Extended Information Indicators: 7 17:36:12 #8 Text 0 File DlgWaitCD.cpp, Line 490 >>> Protocol of DlgWaitCD activities: <<< ========================================= 17:36:12 #9 Text 0 File ThreadedTransferInterface.cpp, Line 823 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 1724192 (1724192) = #1724192/383:9.17 relocatable, disc pos for caching/writing not required/ required -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1724192 blocks [D: ATAPI DVD A DH20A4P] -------------------------------------------------------------- 17:36:12 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1026 Prepare [D: ATAPI DVD A DH20A4P] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: Idx 0 Idx 1 Next Trk 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3531145216, ISRC "" DAO layout: =========== ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00 0 | 1 | 0 | 0x41 | 1724192 | 0 | 0x00 0 | 1 | 1 | 0x41 | 1724192 | 0 | 0x00 1724192 | lead-out | 1 | 0x41 | 0 | 0 | 0x00 17:36:12 #11 Text 0 File SCSIPTICommands.cpp, Line 209 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 17:36:12 #12 Phase 24 File dlgbrnst.cpp, Line 1760 Caching of files started 17:36:12 #13 Text 0 File Burncd.cpp, Line 4298 Cache writing successful. 17:36:12 #14 Phase 25 File dlgbrnst.cpp, Line 1760 Caching of files completed 17:36:12 #15 Phase 36 File dlgbrnst.cpp, Line 1760 Burn process started at 8x (11.080 KB/s) 17:36:12 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2764 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 17:36:12 #17 Text 0 File Cdrdrv.cpp, Line 9288 ---- DVD Structure: Physical Format Information (00h) ---- Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD+R (10), Part Version: 1.0x (1) Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26053F h End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB) Data in Burst Cutting Area (BCA) does not exist Disc Application Code: 0 / 0 h Extended Information indicators: 7 h Disc Manufacturer ID: MCC..... Media type ID: 004 Product revision number: 0 Number of Physical format information bytes in use in ADIP up to byte 63: 56 Media Specific [16..63]: 00 00 07 4D 43 43 00 00 - 00 00 00 30 30 34 00 38 ...MCC.....004.8 23 54 37 12 02 54 6C 02 - 92 5F 15 15 0B 0B 08 08 #T7..Tl.._...... 01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................ 17:36:12 #18 Text 0 File DVDR.cpp, Line 6833 Drive: ATAPI DVD A DH20A4P Book Type request [LO], rev 3: DVD-ROM Changing the Book Type was finished successfully, return code 0 17:36:12 #19 CDR -1207 File DVDR.cpp, Line 6212 Book Type automatically set to: DVD-ROM 17:36:12 #20 Text 0 File DVDPlusRW.cpp, Line 674 Start write address at LBA 0 DVD high compatibility mode: Yes 17:36:19 #21 SPTI -500 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x00) WinError(1117) NeroError(-500) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00 Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00 Buffer x22040040: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 17:36:23 #22 SPTI -1033 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1033) Sense Key: 0x02 (KEY_NOT_READY) Sense Code: 0x04 Sense Qual: 0x01 CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00 Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 04 01 Buffer x08060080: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 17:36:23 #23 CDR -1033 File Writer.cpp, Line 301 Drive not ready D: ATAPI DVD A DH20A4P 17:36:23 #24 SPTI -1033 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1033) Sense Key: 0x02 (KEY_NOT_READY) Sense Code: 0x04 Sense Qual: 0x01 CDB Data: 0x35 02 00 00 00 00 00 00 00 00 00 00 Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 04 01 17:36:23 #25 SPTI -1033 File SCSIPassThrough.cpp, Line 179 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1033) Sense Key: 0x02 (KEY_NOT_READY) Sense Code: 0x04 Sense Qual: 0x01 CDB Data: 0x5B 01 05 00 00 00 00 00 00 00 00 00 Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 04 01 17:36:23 #26 Phase 127 File dlgbrnst.cpp, Line 1760 Generating DVD high compatibility borders 17:36:29 #27 Text 0 File DVDR.cpp, Line 6833 Drive: ATAPI DVD A DH20A4P Book Type request [LO], rev 3: DVD+R Changing the Book Type was finished successfully, return code 0 17:36:29 #28 CDR -1033 File WriterStatus.cpp, Line 162 Drive not ready D: ATAPI DVD A DH20A4P 17:36:30 #29 TRANSFER -24 File WriterStatus.cpp, Line 162 Could not perform end of Disc-at-once 17:36:31 #30 Phase 38 File dlgbrnst.cpp, Line 1760 Burn process failed at 8x (11.080 KB/s) 17:36:32 #31 Text 0 File SCSIPTICommands.cpp, Line 254 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 17:36:34 #32 Text 0 File Cdrdrv.cpp, Line 10529 DriveLocker: UnLockVolume completed 17:36:34 #33 Text 0 File SCSIPTICommands.cpp, Line 411 UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL Existing drivers: Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) Zadnje izmijenjeno od: Rahonavis. 18.01.2008. u 19:18. |
