Staro 14.03.2004., 19:21   #1
Ujoma
Ujoma's Avatar
Datum registracije: Dec 2003
Postovi: 336
3DMark01SE Problem
Ne kužim u čemu je stvar, svaki put kad bi trebo počet test Nature, izbaci me u windovse i pojavi se ovaj ERROR
Reinstaliro sam drivere, i 3DMark i opet ništa, reinstaliro sam i DirectX i opet ništa.
Application info
Name 3DMark2001 SE Pro
Build 330
Error log
FATAL ERROR: failed to validate material
System info available: yes
Project available: yes
Result file
3DMARK2001 PROJECT FILE
PROJECT
Name My Benchmark
Description
Registration Name
Registration Key
3DMark Version 330
DISPLAY
Platform NVIDIA GeForce4 Ti 4200
CPU Optimization D3D Pure Hardware T&L
Width 1024
Height 768
Depth 32 bit
Z-Buffering 24 bit
Texture Format Compressed
Buffering Double
Refresh Rate 60 Hz
FSAA Mode None
OPTIONS
Show Title Screens Yes
Continuous Benchmark No
Benchmark Run Count 1
Demo Sounds Enabled Yes
Continuous Demo No
Game Sound Effects Enabled Yes
Game Music Enabled Yes
Game Detail Level Low
RESULTS
3DMark Score N/A
Game 1 - Car Chase - Low Detail 161.5 fps
Game 1 - Car Chase - High Detail 58.1 fps
Game 2 - Dragothic - Low Detail 194.8 fps
Game 2 - Dragothic - High Detail 105.3 fps
Game 3 - Lobby - Low Detail 140.2 fps
Game 3 - Lobby - High Detail 64.9 fps
Game 4 - Nature N/A
Fill Rate (Single-Texturing) N/A
Fill Rate (Multi-Texturing) N/A
High Polygon Count (1 Light) N/A
High Polygon Count (8 Lights) N/A
Environment Bump Mapping N/A
DOT3 Bump Mapping N/A
Vertex Shader N/A
Pixel Shader N/A
Advanced Pixel Shader N/A
Point Sprites N/A
SYSTEM INFO
System Info Version 2.2
Installation ID 0x00000000
OEM ID
CPU INFO
CENTRAL PROCESSING UNITS
Manufacturer AMD
Family ThoroughBred
Internal Clock 2 GHz
Internal Clock Maximum 2 GHz
External Clock 133 MHz
Socket Designation Socket-A
Type Central
Upgrade <unknown>
Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE
Version Model 8, Stepping 1
CPUID 0x00000681
CACHES
Level 1
Capacity 128 KB
Type <unknown>
Type Details <unknown>
Error Correction Type <unknown>
Associativity <unknown>
Level 2
Capacity 256 KB
Type <unknown>
DIRECTX INFO
DirectX Version 9.0
DIRECTDRAW INFO
DirectDraw Version 5.3.0000000.900
DISPLAY DEVICES
Description Primary Display Driver
Manufacturer NVIDIA
Name NVIDIA GeForce4 Ti 4200
Total Local Video Memory 64 MB
Total Local Texture Memory 64 MB
Total AGP Memory 128 MB
Display Driver nv4_disp.dll
Display Driver Version 6.13.10.4109
Driver WHQL Certified No
Max Texture Width 4096
Max Texture Height 4096
Max User Clipping Planes 0
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Textures In Single Pass 4
Vertex Shader Version 1.1
Pixel Shader Version 1.3
Max Vertex Blend Matrices 0
Max Texture Coordinates 8
Vendor ID 0x10de
Device ID 0x0253
Sub-System ID 0x87001462
Revision 0xa3
Pomozite, unaprijed hvala
Name:	3dmark error.jpg‎
AMD AthlonXP (Thorton) 2400+@2400MHz (15x160) 1,700 V
MSI KT3 Ultra2-R, VIA KT333
2*256MB Kingmax SuperRam 433 @320 (2.0 2-2-5)
MSI GeForce4 Ti4200 64Mb DDR @ 310/610
WD800BB, 80Gb , 7200rpm , ATA/100
Zadnje izmijenjeno od: Ujoma. 18.03.2004. u 00:48.
Ujoma je offline   Reply With Quote
Staro 14.03.2004., 20:01   #2
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
1. Preocan sistem.
2. Driveri od grafulje
3. Direct X
Staro 14.03.2004., 22:32   #3
Ujoma
Ujoma's Avatar
Postovi: 336
Najgore je to šta mi sad nije ništa OCano, drivere sam stavio druge i DirectX sam reinstaliro i opet se događa isto.
Ali to mi se počelo događat kad sam OCo grafičku, i mislio sam da je zbog prevelokog OCa, ali kad sam je vratio na deafoult još se uvijek to događa.
Staro 17.03.2004., 00:17   #4
Ujoma
Ujoma's Avatar
Postovi: 336
Ajde, ajde ljudi pa šta baš niko nezna u čemu je problem.
Staro 17.03.2004., 21:18   #5
instinct
instinct's Avatar
Datum registracije: Aug 2003
Postovi: 183
Talking
Probaj formatirat disk, pa natrag sve snimiti, ako ne upali posudi od frenda grafulju, rame itd. pa isprobavaj, mozda ti neka komponenta ne radi kak spada.
Meni je grafulja srala, radila 2h testove i onda najedamput zelena slika po ekranu, a grafulja hladna. Odneso na popravak i dobio novu i to ATI orginal
instinct je offline   Reply With Quote
Staro 17.03.2004., 23:47   #6
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,029
Pa sam si rekao da ti je to od kada si overclockao grafulju. Možda si malo pretjerao pa si jus*ebal. Probaj kod nekog drugog grafičku.
Staro 18.03.2004., 00:43   #7
9500Pro
9500Pro's Avatar
Datum registracije: Feb 2004
Postovi: 71
Hvala na usernameu i passwordu za 3Dmark. Ha-ha, ne brini imam ja svoj ali pripazi drugi put.
9500Pro je offline   Reply With Quote
Staro 18.03.2004., 00:46   #8
Ujoma
Ujoma's Avatar
Postovi: 336
Nisam ni išo za tim, hvala na upozorenju , evo obrisat ču ga za svaki slučaj.
Staro 18.03.2004., 01:01   #9
Amdejac
Amdejac's Avatar
Datum registracije: Jun 2003
Lokacija: Kuća
Postovi: 5,405
Instaliraj Norton Ghost i napravi si imiđ na drugu particiju koju nećeš dirati (ne zaboravi si napravit bootabilnu disketu, za svaki slučaj).
Sad kad si spremio windoze sa svim drajverima i programima formatiraj tu particiju i instaliraj ponovno windowse sa drajverima i osnovnim programčićima pa češ vidjet. Ako ti neće i dalje radit još uvjek imaš imiđ windowsa koje možeš vratit.
Sa Norton Ghostom 2003 možeš sve radit iz windowsa bez bootabilne diskete i ulaska u DOS.
Asus N750JK (Upgrade)
MBO: Asus N750JK
RAM: 2x8 Gb PC3-12800 DDR3
PSU: Asus Li-ion 69486 mWh
OS: Windows 8.1
Monitor: 17,3 LCD (FHD)
Net: Intel AX210 NGW
Net: TP-Link Archer TX55E
PSU: Xilence, Bronze 550W
Monitor: Samsung
VGA: ATI RX570, 4 Gb
HDD: NVMe 1 Tb, Patriot
PSU: Inter-Tech SP750
Monitor: Samsung
Staro 18.03.2004., 21:14   #10
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Malo lakše s tim UN i paswordima...
Staro 19.03.2004., 21:34   #11
Ujoma
Ujoma's Avatar
Postovi: 336
Evo problem je uspiješno riješen, inače problem je bio u PowerStripu kad sam ga unistaliro i zavrtio 3DMark sve je prošlo OK.
Hvala svima na pomoći
