Staro 31.12.2007., 01:58   #1
beroland
to te ja pitam
beroland's Avatar
Postovi: 572
MBO Asrock ConRoe1333-DVI/H R2.0 pojašnjenje chipseta
Namjeravam kupiti ovu ploču iz naslovu u linksu i oni je deklariraju da je rev 2.0 (malo im je sprčkan naziv ali sam skužio) i da je chipset 945G na njoj
stranicuNa asrockovim stranicama piše da ta verzija 2.0 ima chipset 945G/945GC A2. Molio bi pojašnjenje ako netko zna kako to oni deklariraju chipset na asrockovim stranicama. Što im to znači 945G/945GC A2? Ovo je link na asrock stranicu.
Za verziju koja je prva revizija na asrocku pak kažu da je chipset 945G.
Btw, ploču bih spario sa E2140. Što mislite?
1: Intel Badaxe2 () C2Q Q6600 () 2x2GB Kingmax 800MHz () Gigabyte GF 7300GT () 2 x Seagate 7200.10 320GB SATA II () Corsair VX 550W () DVD±RW LG H22 () Rebel 12 Economy
2: Gigabyte GA-965GM-S2 () C2D E6400 () 2x1GB Kingmax 667MHz () Seasonic S12 380W
beroland je offline   Reply With Quote
Staro 31.12.2007., 08:22   #2
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
This is a great motherboard and I've had no problems at all with it apart from using all four memory slots. If you want to use them all you must use single sided ram.
Fun motherboard....tricky though.
Reviewed By Steve. Review Posted 30/11/2007
I bought this for the 4 memory slots to use with a cheap 200MHz bus E2140 processor. The supplied DVI HDCP video card is a bonus. As long as you're using onboard graphics, you can overclock the bus to 266 MHz, but because that takes the PCI bus to 120, it may not work with a graphics card. You should get a better motherboard for serious overclocking, I suspect. But it's fun to experiment. I had time-consuming problems with crackling HDA sound when gaming, which needed the latest Realtek 1.82 audio driver to cure. Front panel audio can be disabled in the bios if you have an older AC97 case. The onboard graphics are adequate for Tomb Raider Legend.
...i malo o chipsetima...nekad je korisno lurkati na intelovu stranicu
Intel® 945G Express Chipset
For Intel® Pentium® D Processor and Intel® Pentium® 4 Processor supporting HT Technology
Built-in Intel® GMA950 graphics
1066/800/533MHz
Intel® Flex Memory Technology
Dual channel DDR2 667/533/400
PCI Express* X16
Intel® HD Audio
PCI Express X 1 (4or6³)
Serial SATA 3Gbps/4
PATA/1
Intel® Matrix Storage Technology (NCQ, RAID 0, 1, 5, 10)
Intel® 945GC Express Chipset
For Intel® Core™2 Duo processor, Intel® Pentium® D Processor and Intel® Pentium® 4 Processor supporting HT Technology
800/533MHz
Dual channel DDR2 533/400
PCI Express* X16
Intel® HD Audio
Serial SATA 3Gbps/4
PATA/1
Rezimirajmo, bez puno guglanja zakljucio sam da revizija 1.0 te AssRokice podrzava samo Pentium 4 ili D procesore jer ima 945G chipset, dok revizija 2.0 iste podrzava i Core 2 procesore. Eto, nadam se da je pomoglo Ako mi se sto gadi na toj ploci i na svim ostalima je kad vidim 24-pinski ATX gore kod socketa, ali to je moje misljenje, nije nuzno da se i ostali slazu sa mnom.
Staro 31.12.2007., 09:19   #3
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,342
Autor Vin EuroDizel Pregled postova
20-pinski, još nisu prešli na 24-pinske konektore .
Staro 31.12.2007., 10:13   #4
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Autor stef Pregled postova
Right, nisam ni mislio da je jos netko ostao na 20-pinskom...
Staro 31.12.2007., 10:51   #5
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,727
Autor beroland Pregled postova
Ja sam u nekoliko tih ploca potrpao Celerone 420 i za tu cijenu sam super zadovoljan. Samo pazi, bundle je dosta skrt, tako da sam zbog SATA diska i SATA przilice morao natrag u ducan po dodatne kablove (dobijes samo jedan). I BTW, koliko god se EzRok kleo da dobijes ona DVI pimpek, ja ga u Linksu nisam dobio (ne da mi je trebao, no cisto da se ne iznenadis).
Programer
Staro 31.12.2007., 12:20   #6
beroland
to te ja pitam
beroland's Avatar
Postovi: 572
Hvala ekipo na savjetima!!
No, i dalje mi je ostalo jedno pitanje, a to je: zna li netko objasniti što im znači to da deklariraju ploču da ima northi chipset: 945G/945GC A2? Šta im to točno znači?
Staro 31.12.2007., 12:48   #7
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
A ***ote, pa objasnio sam ti da si pomnije citao moj reply. Revizija 1.0 je imala i945G, a revizija 2.0 ima i945GC northbridge Prva nije podrzavala Core2 prcesore, bar tako mislim. Iako kod AssRok kiklopa i hibrida nikad nije sigurno, oni to sve izmuljaju do bola, sjetim se samo onog P4 combo mutanta sa 2 slota na ploci, 478 i LGA 775, OMFG.
Staro 31.12.2007., 12:50   #8
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,727
Ocito im to znaci da ploca dolazi u izvedbi sa dva chipseta, od kojih jedan podrzava novije procesore i ostale pomodarske drke. S obzirom da su ovi Celeroni radili bez poteskoca na plocama iz Linksa, vjerojatno se radi o tom novijem chipsetu. Mene uopce nije takvo sto interesiralo, pa nisam ni obracao paznju na to kad sam imao ploce u rukama...
Programer
Staro 31.12.2007., 17:15   #9
beroland
to te ja pitam
beroland's Avatar
Postovi: 572
Ma citao sam ja tvoj post. No, mislim da si malo požurio sa zaključkom. Naime, evo link za rev1 i evo link za rev 2.0 iste ploče i obje ploče podržavaju c2d proceve. Tako da mislim da tvoje obrazloženje baš i nije najtočnije. Evo i link na intelove specifikacije 945G chipseta u kojima isto stoji da podržavaju c2d procesore. Ne pitam bezveze, pa pogledao sam po netu prije.
Autor Bubba Pregled postova
Da, valjda istu ploču iste revizije daju sa dva različita noth chipseta. Bo. Čudno.
Staro 31.12.2007., 17:32   #10
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
iako sam imao asrock koji me odlično služio, ovaj bih zaobišao.
prvotno sam ju kupio sebi za komp i nakon tjedan dana potpuno čudnog ponašanja, sam ju vratio i doplatio 100kn za Asus-a sa istim čipsetom, i s njim sam super zadovoljan.
Staro 14.02.2008., 00:41   #11
domy_os
domy_os's Avatar
Postovi: 18,809
Sorry što dižem temu, ali zanima me malo više detalja o ovoj ploči jer bih je možda kupio. Gore bi išao Celeronko 420, LAN i WLAN mrežna i neki diskić. Kako vam se pokazala u radu, koliko se griju NB i SB, kako radi sa četiri pločice RAM-a, može li se spustiti napon procesora,...?
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 14.02.2008., 18:49   #12
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,343
Ugradio sam ju u podosta kompova ali nisam ni jednom do sad testirao OC mogučnosti, i ostale pi*darije.
Sve što se stavilo na nju, sve je radilo bez ikakvih problema, a gore su išli; dotični celeronko, E21XX, 2GB RAMA, modem, x1050, hs2400Pro grafe.
Jedino što se neće upalit ako se ne spoji onaj dodatni 4 pinski naponski kabl (jednom izgubio živce zbog toga )
žmnpp
buljo je online   Reply With Quote
Staro 14.02.2008., 19:20   #13
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,727
Autor domy_os Pregled postova
Hm, nisam siguran mislis li ti na dobru plocu, no ova cuda imaju samo dva DIMM socketa. Trpao sam unutra od 2x 512 do 2x 2GB i nikakvih problema nije bilo. Taj Celeron sam stavljao u sve takve masine a uz njega je obicno isao nekakav Radeon 2600Pro/XT, SATA hardovi i optika, iii... - conclusion je otprilike jednak onom "plakatu": "Snimam po svadbama, jos mi se nitko nije rastao". Ploca suti, radi i vrijedi 300njak kn. Isprobano na ~15ak komada, do sada. Neke masine rade 24/7, na nekima se igra (otalen i taj Rade) i kao sto rekoh, jos nikakvih problema nije bilo.
Programer
Staro 14.02.2008., 23:20   #14
domy_os
domy_os's Avatar
Postovi: 18,809
Mislim na ploču iz naslova, ona ima četiri DIMM slota...
http://www.hgspot.hr/opis.aspx?ID=027553
Staro 14.02.2008., 23:40   #15
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,727
Maj bed. Ja mislio da mislis na ovo (IIRC, to su te koje ima Links, tj. koje sam ja koristio):
http://www.asrock.com/mb/overview.as...H%20R2.0&s=775
Ali predpostavljam da nisu previse razlicite. Jebalo ih sedamstopedesetosam revizija iste ploce.
Programer
