Zaključane teme
Staro 29.10.2007., 10:53   #331
murina
murina's Avatar
Postovi: 508
Trnje, jos uvijek 1 mb/s
murina je offline
Staro 29.10.2007., 11:29   #332
antunhr
Lokacija: Popovec(Sesvete-Zagreb)
Postovi: 552
Noise Margin (AKA Signal to Noise Margin or Signal to Noise Ratio)
Relative strength of the DSL signal to Noise ratio. The higher the
number the better for this measurement. In some instances interleaving
can help raise the noise margin to an acceptable level.
6dB or below is bad and will experience no synch or intermittent synch
problems
7dB-10dB is fair but does not leave much room for variances in conditions
11dB-20dB is good with little or no synch problems* (but see note below)
20dB-28dB is excellent
29dB or above is outstanding
Line Attenuation
Measure of how much the signal has degraded between the DSLAM and the
modem. This is largely a function of the distance from the exchange. The
lower the dB the better for this measurement.
20dB and below is outstanding
20dB-30dB is excellent
30dB-40dB is very good
40dB-50dB is good
50dB-60dB is poor and may experience connectivity issues
60dB or above is bad and will experience connectivity issues
Znaci, Noise Margin treba biti sto veci (od 11 dB navise), a Line
Attenuation treba biti sto nizi (od 20 dB nanize).
Lako je izracunati i koliko je kabela izmedju vaseg modema i centrale.
Svaki kilometar kabela povecava Line Attenuation za +13.63dB. Npr. ako
je vas Line Attenuation = 11 dB onda izmedju vas i centrale ima cca 800
metara kabela.
Evo pa nekima mozda pomogne
antunhr je offline
Staro 29.10.2007., 12:11   #333
tihomir2
Lokacija: cro
Postovi: 143
kod mene je udaljenost 4.4 km. podigli brzinu i u kasdi trenutno stoji 1568 / 256 nije baš bajno, ali ajd..bolje je nego ništa.. iako ponekad padne i na 1160... centrala je na adsl1 (G.DMT)
tihomir2 je offline
Staro 29.10.2007., 13:55   #334
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Hell yea digli mi drzinu ali samo ....
Downstream rate: 6208 kbps
Upstream rate: 736 kbps
sada 6496 kbps , valjda meljeju brzinu
' alt='' border=0>
Zadnje izmijenjeno od: Vejita. 29.10.2007. u 14:06.
Vejita je offline
Staro 29.10.2007., 14:10   #335
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,838
Autor Vejita Pregled postova
jel si ti možda bil privremeno na 3mbit?il su ti odma sa 1 na 8digli?
pošto sam zval SZK vele mi da prvo se aktivira 3mbit,pa tek onda 8,znaći još dva dana imaju fore,i ja bi trebal otić na 8mbit.
zvonac je offline
Staro 29.10.2007., 14:13   #336
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
sa 3 na 8.
Ovako ja sam ti 1.10 zatrazio sa mi digneju s 1/2 na 3/8 i evo tek danas nakon 29 jako kratkih (my ass) dana dobio sam ne 7,9 nego 6,5 ^^.
' alt='' border=0>
Vejita je offline
Staro 29.10.2007., 14:15   #337
zvonac
zvonac's Avatar
Postovi: 5,838
sa 3 na 8
aha ok,znaći i ja uskoro mogu očekivat povečanje
zvonac je offline
Staro 29.10.2007., 14:17   #338
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Sada vidim da tih 6,5 samo pise na modemu jer mi max skida na 250 , jos manje nego na 3 brzini, sada idem ih malo zvati.
Edit: zvao ih i kaze mi lik odite na nasu stranicu i testirajte brzinu ,ja ono no problem i tako ja pocnem skidati kada imam i vidjeti kaj max brzina preuzimanja cak 103 kb/s i onda je lik prijavio da imam sum u liniji pa ono.
Gledajte i placite od zavisti na 6700/768 brzini
' alt='' border=0>
Zadnje izmijenjeno od: Vejita. 29.10.2007. u 16:03.
Vejita je offline
Staro 29.10.2007., 14:34   #339
Galinjo21
Lokacija: požega
Postovi: 80
Lopovi
Evo i meni još na 1mb,a frendu digli prije 15 dana!
Galinjo21 je offline
Staro 29.10.2007., 15:05   #340
DANCI
Postovi: 735
neznam kog vraga čekaju valjda ne zadnji dan... mislim bio je njihov lik prije dva mj. kod mene i testirali su MAX brzinu DL 7.3mbit i UL 4mbit testirano dva put, e neznam koliki je šum zaboravio sam no reko je da je veza odlična i šum malen i da bi bezproblema mogo imati MAXTV i NET zajedno...
područje Vrapče
DANCI je offline
Staro 29.10.2007., 18:47   #341
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Evo doso covjek i stavio mi d-link i sada radi kako treba, sada mi je se555 ostao hehe.
' alt='' border=0>
Vejita je offline
Staro 29.10.2007., 18:58   #342
Željac
sto da napisem ?!
Željac's Avatar
Postovi: 880
WTF ?!
kad je meni prdnuo wireless na se555 i zamjenio ga frajer za zyxelom i morao je uzet se555 kao da ide na "otpis" (ne znam kako se frajer izrazio ali nesto na tu temu)...
a inace je kabelski radio ok, sve radi samo vajerles crknuo
ali, ko ga sevi, bitno da zyxel radi vec 3 mjeseca bez gasenja ili bilo cega
a jos nista od povecanja na zapadu grada zagreba...
Željac je offline
Staro 29.10.2007., 19:03   #343
MAHER
Postovi: 1,583
meni i dalje 1mb/s,koliko vas ovdje ima da isto nisu povecali?
MAHER je offline
Staro 29.10.2007., 19:05   #344
cromen
Postovi: 103
jel SZK jos uvijek uvjerava ljude da ce sve biti gotovo do 1.11?
cromen je offline
Staro 29.10.2007., 19:19   #345
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,953
Split, centar.
I dalje 1Mbit. Doduše nije baš tako, nego mi se ponavlja priča koju san opisao u predhodnom postu, a to je da 2 dana iman novuu brzinu pa 2 dana staru,...
Izgleda da smo mi u centru većih gradova ostavljani kao šlag na kraju
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Mr.Ex.President je offline
Staro 29.10.2007., 19:39   #346
Adisabeba
Postovi: 166
Autor cromen Pregled postova
Ovim tempom kojim rade nece biti gotovo do slijedece godine. Meni nije samo jasno kako ovi vani to rade. Neki ISP-ovi imaju po 1m korisnika. Sta oni isto "rucno dizu brzine na centrali"?
Adisabeba je offline
Staro 29.10.2007., 19:48   #347
Vejita
Hurr durr
Vejita's Avatar
Lokacija: Stančić
Postovi: 1,449
Ja sluzbeno sam imao Kasdu i da mu dam se555 yea right.
Ajde pomagajte ljudi.Ovako kada skidam s t-coma onaj test paket ili kada skidam preko rapida mi skida max 306 kb, kada idem testirati brzinu ispadne me 1700/300 ,a kada skidam preko DAP skida mi od 600 do 720 i skida brzo pa mi recite ko tu koga jj.
Edit 2: evo testirao sam test paket 100mb preko DAP i skidao ga je recimo stalno na 720 i skinio ga je za 2:08min kaj sam ja racunao da je to to, sada mi recite zakaj nece raditi normalno bez DAP-a
http://i24.tinypic.com/6iwk61.jpg evo pasite okice :P
' alt='' border=0>
Zadnje izmijenjeno od: Vejita. 29.10.2007. u 21:13.
Vejita je offline
Staro 29.10.2007., 21:04   #348
sina
Postovi: 13
Zagreb, Vrbani još uvijek na 1 Mbit/s.
Sina
sina je offline
Staro 29.10.2007., 22:00   #349
Artistar
Vječni Student
Artistar's Avatar
Postovi: 316
ZG - Gračani -> 1Mbit bez ijednoga skoka.
Artistar je offline
Staro 29.10.2007., 22:16   #350
Zlo
Postovi: 57
ZG - Centar-jos uvijek nista
Zlo je offline
Staro 29.10.2007., 22:22   #351
cromen
Postovi: 103
ZG - Malešnica- naja
cromen je offline
Staro 29.10.2007., 23:01   #352
Excalibur!
Excalibur!'s Avatar
Postovi: 24
Zagreb, Vrbik još uvijek na 1 Mbit/s.
Excalibur! je offline
Staro 29.10.2007., 23:17   #353
qbone
qbone's Avatar
Postovi: 146
Zagreb, Zvonimirova jos uvijek nista! jel se moze zatrazit od t-scuma novi adsl modem/router jer imam ono sranje od siemensa A-100 (star 2 ili 3 godine)
btw. pozdrav DBZ fanovima
qbone je offline
Staro 29.10.2007., 23:30   #354
Artistar
Vječni Student
Artistar's Avatar
Postovi: 316
Autor qbone Pregled postova
Možeš, ali samo ako potpišeš ugovor na još godinu dana.
Artistar je offline
Staro 30.10.2007., 00:38   #355
qbone
qbone's Avatar
Postovi: 146
čini mi se da nemam mnogo mogučnosti, jer mi nitko od alternative nije dostupan. zanima me da li taj dotični modem siemens a-100 moze koristiti vecu brzinu od 1Mbit ili ću morati mijenjati modem za noviji?
qbone je offline
Staro 30.10.2007., 00:40   #356
Adisabeba
Postovi: 166
8m je max tog modema. Imam ga ja.
Staro 30.10.2007., 00:47   #357
frANZi
Dr. Gonzo
frANZi's Avatar
Postovi: 958
Zagreb, Velika Mlaka - kita.
frANZi je offline
Staro 30.10.2007., 00:58   #358
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Marija Bistrica blizu Zg, jos uvijek kita.
IcyTexx je offline
Staro 30.10.2007., 01:03   #359
Zlo
Postovi: 57
ja sam ga koristio jedno 2godine i prije nekih mjesec dana sam kupio Dlink ne od t-scuma nego uducanu,Siemens a 100 ti maksimalno moze ici do 8mbita tako da nemas brige uopce ako si na najmanjoj brzini..
Zlo je offline
Staro 30.10.2007., 02:47   #360
njuskalo
njuskalo's Avatar
Lokacija: Remetinec
Postovi: 925
ADSL Line
Status: Cable connected
Line mode: G.992.1 (G.DMT)
Maximum line rate: 2016 kbps (downstream) / 256 kbps (upstream)
Noise margin: 24 dB (downstream) / 31 dB (upstream)
Line attenuation: 10 dB (downstream) / 13 dB (upstream)
Output power: 12 dBm (downstream) / 8 dBm (upstream)
hehe meni povecali jos prije 10 dana valjda.ko bi reko,u hrvatskom leskovcu;nemam ni vodovod al zato adsl ***en
PS. jel zna neko oce dizat mozda pakete?ja sam na 5 GB al uvjek potrosim vise (do sad vec 9.5 ) pa bi ak ne namjeravaju skoro to dic vjerojatno flat uzeo...
njuskalo je offline
Zaključane teme
