Staro 29.08.2007., 16:46   #1
markan
markan's Avatar
Postovi: 232
Buffalo WHR-G54S-2
Koji verziju dd-wrt fw-a preporucujete?
Molio bi one koji su probali da pojasne malo proceduru flashanja doticnog sa dd-wrt.
Thnx
Be yourself. Everyone else is already taken.
markan je offline   Reply With Quote
Staro 29.08.2007., 18:36   #2
raf
šlap
raf's Avatar
Lokacija: Zagreb, centar
Postovi: 939
Ja imam v23 SP2. I ona radi, a pise na stranici da podrzava svaki dd-wrt.
A tu su ti uputstva http://www.dd-wrt.com/wiki/index.php...4_and_WHR-G125
Ja sam koristio ako se dobro sjecam ovaj dio.
***If you are still having trouble with timeouts, etc., you may want to try using the TFTP client from Linksys. Be sure to set it to retry at least three (3) times. Five (5) would be a safe number to start with. Connect power while holding the reset button till the red diag button begins to blink, release the reset buttin and hit the Upgrade button on the Linksys TFTP Utility. For WHR-HP-G54 i had to flash through a switch with windows or suffer timeouts trying.***
na stranici imas i link za TFTP klijent. Procitaj sve za svaki slucaj.
raf je offline   Reply With Quote
Staro 29.08.2007., 23:15   #3
markan
markan's Avatar
Postovi: 232
Fala na infu, samo koju verziju sa ovog linka skinuti:
http://www.dd-wrt.com/dd-wrtv2/down....-wrt.v23+SP2/?
Staro 30.08.2007., 00:35   #4
raf
šlap
raf's Avatar
Postovi: 939
dd-wrt.v23_sp2_standard.zip
I unutra ti ih ima vise tebi treba generic.
konkretno ova
dd-wrt.v23_generic.bin
Staro 01.09.2007., 00:25   #5
markan
markan's Avatar
Postovi: 232
Rjesno. Hvala puno.
