Staro 21.07.2007., 15:08   #181
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,107
Sve da i radi, obicno su lopatice ventilatora dizajnirane za optimalno guranje zraka samo u jednom smjeru...
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 21.07.2007., 15:38   #182
Tomy9
Ja
Tomy9's Avatar
Lokacija: Bjelovar
Postovi: 169
to sam i napisao u prvom postu, ali mi nitko nije odgovorio.
Tomy9 je offline   Reply With Quote
Staro 24.07.2007., 10:54   #183
^SuperUnknown^
Prečupavi mod
Postovi: 9,107
Sori, ali nisam pratio bas
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 17.08.2007., 23:32   #184
Tuna
Unregistered User
Tuna's Avatar
Lokacija: Našice
Postovi: 426
evo i ja sam si nešto sredio za stišavanje ventova.
uzeo sam mikro sklopku (ona mala metalna) koja ima 3 položaja.
kada prebacim u položaj br.1 na vent dolazi 7V, u položaju br.2 12V i na položaj br.3 gasim vent.
spajao sam to na ovom principu:
poslikat ću to sve ako nekog zanima
Tuna je offline   Reply With Quote
Staro 22.08.2007., 14:54   #185
rams
80286
rams's Avatar
Datum registracije: Jul 2004
Lokacija: Dingolfing, DE
Postovi: 1,724
Mene zanima, uskoro bi mi se moglo nac 4 dodatna venta u kucistu pa bi bilo zgodno da mogu palit i gasit zadnja dva kao jedan sklop i prednja dva isto tako.
rams je offline   Reply With Quote
Staro 24.08.2007., 17:49   #186
Tuna
Unregistered User
Tuna's Avatar
Lokacija: Našice
Postovi: 426
poslikat ću to danas ili sutra pa metnem na forum
Staro 26.08.2007., 00:54   #187
rams
80286
rams's Avatar
Postovi: 1,724
Proslo i preksutra , nemoze mi doc u glavu kakva je to mala sklopka, de poslikaj pliz
Staro 26.08.2007., 02:58   #188
Optik
________
Lokacija: .
Postovi: 774
Autor rams Pregled postova
Sklopka (prekidac) ,imas ih u skorom svakom ducanu (poput chipoteka ,pevec ,bauhaus...) po jeftinoj cijeni u raznim bojama i oblicima
KLIK Nesto poput ovoga bi ti trebalo izgledat
Eto nadam se da sam pomogao
Zadnje izmijenjeno od: Optik. 26.08.2007. u 03:11.
Optik je offline   Reply With Quote
Staro 26.08.2007., 13:13   #189
Tuna
Unregistered User
Tuna's Avatar
Lokacija: Našice
Postovi: 426
ja sam korisito mikro sklopku koja ima 3 položaja tako da mogu regulirati napon na ventilatoru. ovdje je spojeno tako da venitaltori dobiju 7V, 12V ili da se ugase.
ako koristite sklopku sa samo 2 položaja imate gore shemu od kolege Optik.
ovo je slika ulaza, tj. spaja se na molex napajanja. žice su spojene: žuta na žutu, crna na crnu a zelena na crvenu. (jedan crni pin sam izvadio da mi ne smeta)
s lijeve strane je ulaz(napajanje) a na desnoj strani se spaja na ventilator. kao što vidite desno je odsječena zelena žica pošto nam ne treba.
ovdje spajamo ventilator.
na ovom 3pinskom konektoru ne koristimo žutu žicu. ovako je spojen 3pin konektor: crna na crnu, žuta na crvenu. (nadam se da razumijete)
molex je spojen: žuta na žutu, crna na crnu. (zelena se ne korisit)
ovo je ta mikro sklopka.
na kraju to izgleda ovako:
Staro 27.08.2007., 07:18   #190
Emissary
ČLAN FKTa
Emissary's Avatar
Postovi: 2,264
To je kip prekidač ako se ne varam.
Staro 30.08.2007., 00:17   #191
Scorpius
Scorpius's Avatar
Postovi: 393
Na koji se način mogu spojiti hladnjaci sa molex konektorima na jedan potenciometar. Treba mi neki poseban priključak, ili već ima neki potenciometar koji to podržava...
Imam Kućište SHARKOON Rebel9, sa 250 mm hladnjakom, a htjeo bi si to stišati... Vidio sam u Linksu http://www.links.hr/index.php?naziv=...kl=050.912.033
ali ak je moguće spojiti na neki potenciometar...
Scorpius je offline   Reply With Quote
Staro 30.08.2007., 01:03   #192
Optik
________
Lokacija: .
Postovi: 774
Ti imas ovo
A tebi treba ovo (treba ti da mozes spojit na potenciometar ,jer potenciometar za molex nema)
Da bi dobio ovu drugu sliku mozes kupit ovaj konektor ili otkinut sa nekon drugog ventilatora koji ti ne treba/ne koristis /otisli lezajevi...
te onda otkinuti oznaceni konektor i zamjeniti ga (stavit njega umjesto molexa)
kako ces otkinuti ?
Veoma jednostavna radnja ,pogotovo u ovoj situaciji. Trebaju ti klijesta (cvikcange) kojima ces prekinuti zicu (mozes na istom mjesto no neki preporucaju na razlicitim mjestima ,citaj i gledaj dalje) te onda sa tih vrhova skinuti izolaciju (mozes isto predvidjenim klijestima ,skalpelom ili slicnim stvarima) i onda spojiti po principu ISTA na ISTU (crna na crnu /crvena na crvenu ) Bijelu nemoj spajat jer ona ocitava rpm i moras onda to prikopcat na plocu.
kada prekines zice na jedan od ova dva nacina i onda spoji kako je gore navedeno ,zarolaj te zice (mozes i dodat kap-dvije tinola da se bolje prihvati no nije potrebno) i izoliraj izolir trakom (ili termobuzirom) da nebi poslje bilo...
Kada si sve uradio kako ovdje pise onda ti treba jedan potenciometar (klik) (osim prvog na listi ,to je termometar) .
Staro 30.08.2007., 10:14   #193
Scorpius
Scorpius's Avatar
Postovi: 393
Hvala puno
Staro 26.09.2007., 16:50   #194
domy_os
domy_os's Avatar
Postovi: 18,847
Evo jedan primjer usporavanja ventova...
Radi se o otporniku od 100 ohma i snage 1 W, zalemljen na pozitivni pol muškog i ženskog 3-pinskog konektora. Po potrebi se, naravno, makne i opet vrati.
Sad ću ga staviti da mi uspori vent na kućištu s 1000 na 700 rpm što je otprilike 8-9 V. Ne da mi se zezati sa SpeedFanom...
Napravio sam još adapter za spajanje tih ventova na grafu, ali je već na grafi pa ne mogu slikati.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 26.09.2007., 17:34   #195
Babaloo
In the lab...
Babaloo's Avatar
Postovi: 929
Evo jedno pitanje: ako na venitlatoru od coolera s procesora (koji se vrti na 5100 rpm-a) koji ima na kraju 3 pinski konektor, presječem žutu žicu i ostanu samo crvena i crna, i ako ga uključim nazad na matičnu hoće li normalno raditi i hoće li se usporiti?
** AMD FX-4300 @ 3.8 Ghz ** Asrock 990FX Deluxe 3 **16 GB G-Skill 1600Mhz ** Intel 545s 500 GB + 2xWD 1 TB ** MSI GTX 660 2GB ** DVD-RW LG H42N ** Corsair HX620 ** Logitech MX Master 2S ** Dell U2414 **SAMA Vulture
Babaloo je offline   Reply With Quote
Staro 26.09.2007., 17:43   #196
Optik
________
Lokacija: .
Postovi: 774
Kidanjem zute zice ne postizes nista osim ne mogucnosti brojanja rpm-a. I ne ,nece se usporit vent zbog toga
Staro 26.09.2007., 20:26   #197
dtr
dtr's Avatar
Lokacija: Kastav (Rijeka)
Postovi: 254
Jedan problem, mozda zna tko kako rjesit.
Imam dva venta, na 5v imaju sasvim dovoljan protok, ali se na toj voltazi nece zavrtit, na 7v su vec dosta bucniji a isto se ponekad nezavrte, na 12v su prebucni.
Na koji nacin da zavrtim ventove a da ostanu spojeni na 5v? (a da to nije rucno nakon svakog paljenja kompa)
dtr je offline   Reply With Quote
Staro 26.09.2007., 20:32   #198
Optik
________
Lokacija: .
Postovi: 774
2x muska )konektor i onda prilikom paljenja ih odvrnes i poslje ih stisas
mislim da te to sve zajedno nece ni 30kn izadjac
Mislim da bi ti bilo najjeftinije rjesenje kupit fanmate2 + "granu" (iz 1x zenskog-->2x muska )konektor i onda prilikom paljenja ih odvrnes i poslje ih stisas
Staro 26.09.2007., 21:13   #199
dtr
dtr's Avatar
Postovi: 254
ma imam vec nesto slicno slozeno
vent je spojen preko on-off-on prekidaca, na jednoj strani je 12v na drugoj 5v
stari ventovi su radili ok na 5v, ali su prozujali pa sam ih zamjenio sa xilencima, a oni nece startat sa 5v.
ovih 12v sam jako rjetko koristio, ali sam imao vec slozeno i koristio samo za zesci oc ili dugotrajniji full load
rado bi to sredio da se automatski zavrti, jer ponekad zaboravim a onda se diskovi malo zesce zagriju...
Staro 26.09.2007., 21:36   #200
Optik
________
Lokacija: .
Postovi: 774
Ako imas tako onda nema smisla u nista drugo ulagat ,sprintaj si kakve naljepnice u pinki boji da pri paljenu se malo poigras sa time (na 12v i onda brzo spustit na 5v i tako bi trebali radit)
Staro 09.10.2007., 12:39   #201
Hawky
Lokacija: Korkyra
Postovi: 4
Ej ljudi,jel mi mozete dat jedan savjet oko spajanja ventilatora na molex,koji mi ide u hard disk???Kako to da spojim i na sto moram paziti??
Hawky je offline   Reply With Quote
Staro 09.10.2007., 15:40   #202
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Ako nisi ništa micao (žice etc.) ne bi smjelo ništa biti. Većina ventova koji imaju molex imaju ih 2 komada kako se ne bi izgubio jedan taj molex na napajanju pa se može nastaviti i nešta još nadospojit nakon toga venta.
Spoji normalno, muški molex od napajanja u ženski molex od venta vent, i onda nastavak (muški) u HDD.
Staro 09.10.2007., 16:05   #203
Optik
________
Lokacija: .
Postovi: 774
~182kb
Kratka shema iz paint-a iako je Vuco sve objasnio
Staro 09.10.2007., 16:32   #204
Juggernaut
Lokacija: Varaždin, Bronx
Postovi: 1,097
da... samo ako izmešetari žice ispred hdd-a ima BSDPS ( bijeli sexy dim po sobi )
Juggernaut je offline   Reply With Quote
Staro 09.10.2007., 19:40   #205
Hawky
Lokacija: Korkyra
Postovi: 4
hvala
Staro 02.12.2007., 14:31   #206
Hrvoje S
Lokacija: Garešnica
Postovi: 43
Talking paljenje na 12V i prebacivanje na 5V nakon toga
vidim da neki ljudi nemogu zavrtiti vent na 5V pa stavljaju sklopku s položajem 12V i 5V i nakon pokretanja venta prebacuju na 5V, ja cu vam reci da to nije dobro za plocu jer u tom slucaju vent npr. radi na 2500 okretaja i vi prebacite na 5V (npr. 1500 okretaja) to je razlika od 1000 okretaja, a vent dok se vrti tj dok pada sa 2500 okr na 1500 okr radi kao generator i salje napon tj. struju maticnu ploco sto nikome od vas nije u interesu i ne zeli da mu izgori ploca pa vam ja predlazem da stavite na + vod jednu diodu npr 1N 4007 koja kosta par lipa a spasava plocu koja puno vise dojde pogledaj diodu ovdje http://www.kronos.hr/advanced_search...N+4007&x=0&y=0
Hrvoje S je offline   Reply With Quote
Staro 13.01.2008., 03:52   #207
srale7
srale7's Avatar
Postovi: 5,772
U biosu imam neku opciju CPU Q-fan i to sam stavio na silent ali vent se i dalje vrti na 1500 okr. Imam jos jedan problem. Naime u kućištu imam 3 venta, jedan napreijed za diskove, drugi iza na ispuhu, i treci na bocnoj stranici. Ali u everestu mi prikazuje samo onaj iza i na stranici, ali ovaj naprijed nikako. I jos nesto. U speedfanu ima ona opcija da se smanjuje brzina fanova ali to meni ne radi. Stavim brzinu svih 4 na 10% ali u everestu mi pokazuje da se vrte na deafult vrijednostima..Kako rijesiti ovaj problem?
Hvala
Staro 13.01.2008., 03:58   #208
TomG
TomG's Avatar
Lokacija: Munich
Postovi: 2,221
Autor srale7 Pregled postova
Hvala
gdje ti je spojen taj 3 vent? ako nije na ploči normalno da ne prikazuje...
taj speeed fan ne radi na pola ploča i ja sam isto probavao na ma69s3h i nece da ga hebes...
TomG je online   Reply With Quote
Staro 13.01.2008., 13:30   #209
srale7
srale7's Avatar
Postovi: 5,772
Naravno da mi je sopjen na plocu, ali ga ne cita. Probao sam i na raznim konektorima na ploci ali nista. Znaci taj Fanspeed je u qurcu. Iskreno, nikad mi se nije ni sviđao. Jel postoji koji drugi nacin da smanjim napon na ventilatorima(softwerski), a posebno na Mine-u?
Hvala
Staro 14.01.2008., 14:54   #210
Ozy
Spužva Bob Skockani.. :XD
Ozy's Avatar
Postovi: 1,685
A čuj...ovisi o senzoru na ploči...po meni je odličan SmartGuardian (DFI ploče uglavnom,WINBOND čip),pa EasyTune (ET bi mogao proći,osim na Gigabyte radi i na Asus pločama,bar nekim)...Asus SmartDoctor i Asus PCProbe - a imaš Asus ploču...pa probavaj dok ne nađeš.
Athlon64 X2 5400BE Brisbane @3000Mhz + KATANA 2 + AirTunel@2x Xilence 120mm
Gigabyte GA-MA78G-DS3H @F4
Mushkin Redline @1000Mhz 5-5-5
XFX 9600GSO @680/1700 || 2000Mhz
Seagate Gonzales 250GB & 320GB && Spinpoint F1 500GB
Coolermaster Elite Power RS460; Sharkoon Silvation; LG GH22NP20/LG GH20NS10/Pioneer DVR107D/Pioneer 216DBK/ Samsung SH-S223F; Logitech MX518; Philips 190P7ES 19" LCD
Ozy je offline   Reply With Quote
