					Postovi: 232
				Buffalo WHR-G54S-2
			Koji verziju dd-wrt fw-a preporucujete?  Molio bi one koji su probali da pojasne malo proceduru flashanja doticnog sa dd-wrt. Thnx
	Be yourself. Everyone else is already taken.  |
			 šlap
				Lokacija: Zagreb, centar
					Postovi: 939
		 Ja imam v23 SP2. I ona radi, a pise na stranici da podrzava svaki dd-wrt. A tu su ti uputstva http://www.dd-wrt.com/wiki/index.php...4_and_WHR-G125 Ja sam koristio ako se dobro sjecam ovaj dio. ***If you are still having trouble with timeouts, etc., you may want to try using the TFTP client from Linksys. Be sure to set it to retry at least three (3) times. Five (5) would be a safe number to start with. Connect power while holding the reset button till the red diag button begins to blink, release the reset buttin and hit the Upgrade button on the Linksys TFTP Utility. For WHR-HP-G54 i had to flash through a switch with windows or suffer timeouts trying.*** na stranici imas i link za TFTP klijent. Procitaj sve za svaki slucaj.  |
					Postovi: 232
		 Fala na infu, samo koju verziju sa ovog linka skinuti: http://www.dd-wrt.com/dd-wrtv2/down....-wrt.v23+SP2/?
					Postovi: 232
		 Rjesno. Hvala puno.
