Staro 19.08.2007., 23:22   #631
the_ghost
lar~
the_ghost's Avatar
Postovi: 1,558
Autor bakaideda Pregled postova
Gle stanje kod mene...
Vjeruj mi savršeno... 5 Mbit, Iskon. Realni download 615 kB/s... Veza u fast modu...
Tak da mislim da nije stvar Signal / Noise omjera nego je kriv Line Attenuation.
Kad ti pocne padati linija, nemoj reci da nisi bio upozoren...
Staro 19.08.2007., 23:26   #632
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Autor Codiac Pregled postova
ja sam sa amisom super zadovoljan
doduse moram torente zauzdati kada igram war na netu inace savrseno
I ja sam bio u početku ali onda... neka oni meni samo srede ono što im stalno pričam i opet sam na konju
LA ti je odličan a SNM u banani.
@All:
SN Margin (AKA Signal to Noise Margin or Signal to Noise Ratio)
Relative strength of the DSL signal to Noise ratio. 6dB is the lowest dB manufactures specify for modem to be able to synch. In some instances interleaving can help raise the noise margin to an acceptable level. The higher the number the better for this measurement.
6dB or below is bad and will experience no synch or intermittent synch problems
7dB-10dB is fair but does not leave much room for variances in conditions
11dB-20dB is good with no synch problems
20dB-28dB is excellent
29dB or above is outstanding
Line Attenuation
Measure of how much the signal has degraded between the DSLAM and the modem. Maximum signal loss recommendation is usually about 60dB. The lower the dB the better for this measurement.
20dB and below is outstanding
20dB-30dB is excellent
30dB-40dB is very good
40dB-50dB is good
50dB-60dB is poor and may experience connectivity issues
60dB or above is bad and will experience connectivity issues
IT IS EASY TO KILL FIVE HUNDRED NOOBS. BUT THERE IS STILL FIVE HUNDRED AND ONE AND YOU ARE OUT OF AMMO!
1oo1
NOOB - POWER IN NUMBERS!
Good judgment comes from bad experience and a lot of that comes from bad judgment.
MisterM je offline   Reply With Quote
Staro 19.08.2007., 23:54   #633
Mr. M
Postovi: 718
Autor MisterM Pregled postova
SN Margin
Line Attenuation
Znaci ja imam odlicnu liniju?
Mr. M je offline   Reply With Quote
Staro 20.08.2007., 01:17   #634
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Autor Mr. M Pregled postova
Da.
1oo1
Staro 20.08.2007., 02:41   #635
Mr. M
Postovi: 718
Da.
Jos da mi je znati kako mi je onda kod t-com-a uspjela veza pucati po tri puta dnevno (nema dsl linka)...da li je moguce da imaju razlicitu infrastrukturu t-com i amis?
Staro 20.08.2007., 02:53   #636
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
Sweet. Me happy. Odličnije od Mr.M-a (onog bez simpson avatara lol )
http://www.imagesforme.com/images/8993screenshot.jpg
Ladybug je offline   Reply With Quote
Staro 20.08.2007., 04:32   #637
JVC HX-Z10
Sruk
JVC HX-Z10's Avatar
Datum registracije: Sep 2004
Postovi: 1,163
to je tak, meni je kod T.coma, pucalo stalno a sporija mi je veza bila....a kod amisa puca samo kad vani grmi i lije kisa t-komovci su idioti, kod nas se zna dogodit da niko u naselju nema telefon po dan-dva...nista....i onda ih zoves sa mobitela i vele, da nemaju saznanja o tome i da je sve u redu i da nema kvara i onda nakon tih dan dva svi telefoni rade....tak da ko zna zasto je kod t.coma pucala veza, kak stvari stoje vjerojatno to ni t.komovci neznaju.
kaj se infrastrukutre tice. pa drukcije je nesto, vidis da na amisu, nemas onaj spliter kaj si imo kod t.coma nego ti sve ide preko thompsona...i kad nemas struje u kuci onda nemas ni telefona, jer telefon ti ide preko Thompsona,a bez struje thompson ne radi i nema ni telefona,ni interneta.....zapravo nema niceg bez struje
JVC HX-Z10 je offline   Reply With Quote
Staro 20.08.2007., 12:26   #638
bakaideda
bakaideda's Avatar
Postovi: 86
Autor the_ghost Pregled postova
Ak se ne sjećaš već ste mi takve stvari govorili prije mjesec dana ali od onda još uvijek nije ni jednom bilo problema niti pucanja linka... Zapravo postoji pucanje pppoe konekcije svakih 24h he, he...
Evo već sam tri mjeseca na Iskonu i nikad ni jednog problema... Samo sam ih jednom zvao da me prebace u fast mode i to je to...
bakaideda je offline   Reply With Quote
Staro 20.08.2007., 13:20   #639
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Različitu opremu i pristup.
Tvoja veza do centrale je dobra i to je razlog za dobar rezultat.
Autor JVC HX-Z10 Pregled postova
@bakaideda - ja kad pričam pričam isključivo o online igranju - inače mi net leti sve dok:
1oo1
Staro 20.08.2007., 14:56   #640
marauder16
upgrading...
Lokacija: Zagreb->G.Dubrava
Postovi: 438
ja onda imam gadne srece s linijom
to understand...
marauder16 je offline   Reply With Quote
Staro 20.08.2007., 15:22   #641
tomifish2002
Honda Prelude 2.0i driver
tomifish2002's Avatar
Lokacija: Zagreb Dubrava
Postovi: 1,128
meni je danas veza u banani. pingovi 3 do 5 puta veći i brzina downloada 30-50 %
tomifish2002 je offline   Reply With Quote
Staro 20.08.2007., 16:34   #642
the_ghost
lar~
the_ghost's Avatar
Postovi: 1,558
Super onda
Staro 20.08.2007., 22:42   #643
Bl@de
Bl@de's Avatar
Lokacija: Ispred kompa
Postovi: 2,004
Izgleda da amis opet puko danas. Sve ide preko iskona sto je totalno cudno kad imaju svoj debeli lik preko slovenije. Hmm mozda je jednostavno testiranje peeringa sa iskonom iako sumnjam, eto kome treba
Tracing route to www.l.google.com [209.85.135.104]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.200
2 9 ms 9 ms 9 ms zagreb5-ge-0-1.amis.net [194.146.109.23]
3 9 ms 9 ms 9 ms zagreb2-ge-0-0-0-1.amis.net [194.146.109.1]
4 10 ms 12 ms 9 ms 213.191.134.133
5 10 ms 10 ms 10 ms cat01-vl3.net.iskon.hr [213.191.142.1]
6 10 ms 10 ms 9 ms cat02-vl18.net.iskon.hr [213.191.142.82]
7 75 ms 80 ms * 212.73.203.1
8 79 ms 79 ms 139 ms ge-1-0-0.mp1.vienna1.level3.net [4.68.125.233]
9 92 ms 83 ms 88 ms as-0-0.bbr2.frankfurt1.level3.net [4.68.128.1]
10 98 ms 85 ms 88 ms ae-12-53.car2.frankfurt1.level3.net [4.68.118.80]
11 92 ms 92 ms 89 ms 212.162.4.42
12 86 ms 90 ms 84 ms 209.85.249.180
13 97 ms 94 ms 93 ms 209.85.248.248
14 95 ms 99 ms 202 ms 66.249.94.83
15 102 ms 101 ms * 72.14.239.58
16 98 ms 93 ms 100 ms mu-in-f104.google.com [209.85.135.104]
Trace complete.
Intel i5 4670k
ASrock Z87 Extreme 3
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
OCZ SSD Vertex 4 - 128 GB
Samsung T166 500 GB 7200 okr/min 16 MB HD501LJ
Samsung F1 1 TB 7200 okr/min 32 MB HD103UJ
Dell S2522HG
Chieftec DX-01BD-V, Corsair 520W CMPSU-520HXEU
Bl@de je offline   Reply With Quote
Staro 20.08.2007., 22:46   #644
tomifish2002
Postovi: 1,128
znači nisam jedini?
Staro 20.08.2007., 23:00   #645
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
tracert www.amis.si
Tracing route to www.amis.net [212.18.32.18] over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms server....
2 68 ms 100 ms 99 ms 192.168.1.254
3 8 ms 8 ms 8 ms zagreb5-ge-0-1.amis.net [194.146.109.2
4 8 ms 8 ms 8 ms zagreb2-ge-0-0-0-1.amis.net [194.146.1
5 78 ms 79 ms 70 ms maribor2-so-0-2-1-0.amis.net [212.18.3
6 15 ms 15 ms 15 ms maribor3-ge-2-8.amis.net [212.18.35.74
7 66 ms 65 ms 69 ms www.amis.net [212.18.32.18]
Trace complete.
1oo1
Staro 20.08.2007., 23:38   #646
Bl@de
Bl@de's Avatar
Postovi: 2,004
eh sad ocito su s***ali onda rute. jer na amis.si ide preko maribora a sve ostalo ide preko iskona, ukljucujuci i google.si. sto znaci da su im lokalne rute ok ali sav eksterni promet izvan amisa ide preko iskona.
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 21.08.2007., 14:30   #647
tomifish2002
Postovi: 1,128
danas ista stvar. pingovi ogromni , download jadan
Staro 21.08.2007., 15:14   #648
JVC MX-GT88
JVC MX-GT88's Avatar
Lokacija: Zagreb - istok
Postovi: 880
Autor tomifish2002 Pregled postova
Da, katastrofa...Meni isto tak...ping koji je inače oko 32, danas je cca 180,a download koji je inače 240kb/s danas je 30-ak...
JVC MX-GT88 je offline   Reply With Quote
Staro 21.08.2007., 15:42   #649
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
*NOTA BENE*
U tijeku su radovi na mreži koji su razlogom problema od jučer.
To bi trebalo potrajati još nekih 24 sata nakon čega bi se sve trebalo dovesti u red.
Dakle očekujte probleme sa netom još jedan dan.
Ni meni nije drago ali kaj je tu je...
1oo1
Staro 21.08.2007., 18:37   #650
-FoX-
Postovi: 50
...zakaj se to nas nije moglo obavjestiti ili barem kad sam ih nazvao da mi je download od 6mbit pao na 50Kb i pingovi bogu iza nogu visoki,zakaj nekazu oprostite ili idiote radimo na mrezi strpite se,a ne pa evo sad cemo pogledat u cemu je problem!!!Mislim ono bzvz.
-FoX- je offline   Reply With Quote
Staro 21.08.2007., 18:46   #651
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Autor -FoX- Pregled postova
Da i meni je jedan jučer uletio sa "Problemi - prvi glas - sve pet". Caka je u tome da dobiješ određenu osobu - preporučam tražiti Danijelu (nemreš fulat jedina je) ili Marka. Kod problema isto tako ako zapinje tražit Maju.
Mala je firma a valjda imaju i studente pa ono...
EDIT: plus tehnička služba je odvojena od SZK...
1oo1
Staro 21.08.2007., 19:11   #652
tomifish2002
Postovi: 1,128
hehe meni je Danijela baš ok
ja njima poslao:Poštovani,
Danas mi je oko 12 h naglo pala brzina downloada. Reconnectao sam se ponovno i nakon toga mi je na speedtestu ping prema mariboru skočio sa 17 na 110 ms a prema londonu sa 55 na 150 ms. Brzina downloada na torrentima mi je max 0.7 mbit a niti na rapidshareu nije puno bolja , ovisno o serveru. Download na speedtest.net mi je još i lošiji. Danas sam dva puta zvao vašu korisničku podršku i rečeno mi je da će mi se javiti međutim još niti glasa. Prilikom online igranja battlefielda2142 pingovi su duplo veći nego prije i nemože se igrati. Jeli problem samo sa mojom paricom ili danas vaša cijela mreža ima problema? Jako sam zadovoljan vašom uslugom međutim mislim da bi bilo uredu da mi onda kažete ako imate problema sa vašim linkom prema van ili ako radite nekakve nadogradnje sustava. nadam se da ćete to brzo riješiti te da se to neće često događati jer planiram uzeti 4 mbit vezu.
Hvala , pozdrav!
pa onda oni meni:Poštovani,
zahvaljujemo na Vašem upitu. Provjera Vaše poteškoće je u tijeku i o ishodu provjere biti će te obaviješteni u najkraćem mogućem roku.
Srdačan pozdrav
pa onda ja malo poizdim:Poštovani ,
Saznao sam da jučer nisam samo ja imao problema. Pošto vam link prema Europi opet radi, danas je sa vezom sve u redu, jedino je ping prema Mariboru malo veći no to je nezanemarivo. Ukratko – trenutno sve radi kako
treba.
naravno radilo je ok još pola sata
i na kraju mi odgovore: Kolege iz tehnike provjeravaju vezano za pingove, no moguće je da još postoje poteškoće vezane s prijašnjim prekidima linka.
lp
Miro
ne kužim kaj se prave grbavi
Staro 21.08.2007., 20:41   #653
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Njoj skidam kapu - kuži kaj hočeš dok veliš keks i to sredi ako može. Ako ne može veli ti kad bude.
Mislim da je problem u internim pravilima pa se večina ne snalazi kaj smije ili ne smije ili kaj treba ili ne treba reči. Imaš masu firmi gdje bossovi zabrane neke normalne stvari pa.... mislim da je pitanje organizacije tj. dezorganizacije. Nemoj zaboravit da su oni novi - ima puno starijih providera koji su veča katastfofa
1oo1
Staro 21.08.2007., 21:26   #654
tomifish2002
Postovi: 1,128
ma kužim to s internim pravilima ali živimo u 2007 g informacije su svuda oko nas i dostupne svima. uzmi naš forum za primjer. sve se brzo sazna. zbog toga je glupo da se prave grbavi pošto se sve zna.
Danijela ako čitaš ti si nam najcura iz szk i puno te pozdravljamo
hehe sad sam se sjetio , neki dan sam joj poklopio , tj htjela mi je reć da isključim modem i uključim nakon par minuta a čim je ona zaustila isključite modem ja odmah na prekidač i paf-mrtva linija (full sam se glup osjećao )a hebi ga
Staro 22.08.2007., 00:23   #655
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
meni je jucer bio ping koma i dl je bio porazavujce nizak zvao sam i danas je recimo ok i ping i dl iako je manji.
al ono mene nedira
.i.
Razer Blade 15
Staro 22.08.2007., 01:30   #656
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
...a čim je ona zaustila isključite modem ja odmah na prekidač i paf-mrtva linija (full sam se glup osjećao )a hebi ga
Danijela je prava.
1oo1
Staro 22.08.2007., 01:33   #657
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
lol sad će se Codiac baciti na zvanje SZK dok ne dobije Danijelu
btw ja dobivam Marka (zapamtim samo zato jer si zapišem da sljedeći put kad se radi o part2 istog problema, da zovem istog). Al vi znate da im to nisu prava imena?
Staro 22.08.2007., 03:01   #658
Mr. M
Postovi: 718
Autor Ladybug Pregled postova
Vise su im prava imena, nego sto nisu, provjereno (premalo ih je da bi trebali imati aliase)
Staro 22.08.2007., 10:39   #659
tomifish2002
Postovi: 1,128
eto ovak je danas. london mi je normalan a maribor nešto kilav i ping veći za 12 ms
Staro 22.08.2007., 18:36   #660
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,723
Ev moja veza:
Ping prema Amisu 8ms.
MMA
