Lokacija: Zaprešić
Postovi: 84
colin dirt
da li je ikako moguče pokrenuti colin dirt na radeonu x800xl s 512MB DDR3?? |
FC Bayern supporter
Datum registracije: Mar 2002
Lokacija: Kutina
Postovi: 454
Kao prvo thread o Colinu već postoji pa si mogao tamo pitat,a kao drugo taj Radeon ne podržava Shader 3.0 tako da neće ići!
Pozdrav! Vedran |
Datum registracije: Jun 2004
Postovi: 1,567
DiRT PC Demo Information ---------------------------------------- System Requirements ---------------------------------------- TCP/IP mode (2-100 players) Requirements Broadband internet connection required - 512kbps + Recommended TCP/IP Network ---------------------------- Minimum Specifications ---------------------------- - Windows XP - DirectX 9.0c - Pentium 4 @ 3.0GHz or Athlon 64 3000+ - 1GB RAM. - Graphics Card: GeForce 6800 / Radeon X1300 or above - DirectX Compatible Sound Card ---------------------------- Recommended Specifications ---------------------------- - Windows XP/Vista. - DirectX 9.0c - Intel Core 2 Duo @ 2.66Ghz or Athlon X2 3800+ - 2GB RAM. - Graphics Card: GeForce 8800 or Radeon X1950 - Sound Card: Creative Sound Blaster X-Fi Sound Card. ---------------------------- Supported Graphics Cards ---------------------------- Shader Model 3 is a MINIMUM REQUIREMENT for this game. - ATi Radeon x1300, x1600, x1800, x1900, x1950 - nVidia Geforce 6800, 7100, 7300, 7600, 7800, 7900, 7950, 8800 Not compatible with all integrated sound/graphics solutions (inc.Laptops) ---------------------------------------- Known issues: ---------------------------------------- Users with Windows Vista and ATi Radeon x1950/1900 graphics cards may find that bonnets do not get drawn on 2 of the demo cars. Alt-TAB, Alt-ENTER etc minimise the game but the game will not recover. On certain graphics cards they may be some graphical corruption e.g. flickering textures/shadows. There may be some slowdown on certain graphics cards. ---------------------------------------- Supported Controllers ---------------------------------------- DiRT™ can be configured to use almost any PC controller, however we recommend the following controllers for the best game play experience: - Logitech G25 - Logitech MOMO - Logitech Driving Force Pro - Microsoft X360 controller DiRT™ provides default configurations for all of the above, meaning that you should be able to plug-and-play, with no tweaking required.
Lokacija: Vukovar
Postovi: 160
Tvoja grafa nema shader 3.0 i koliko ja znam nema šanse da je pokreneš. |
