#91 |
Postovi: 7,568
45nm Xeoni u drugoj polovici godine
Server 45nm Xeon products based on the Penryn core will be available into production for the second half of 2007. Intel's latest desktop guidance claims 45nm desktop SKUs will also launch in late 2007, with volume shipments occuring in 2008. As it stands right now, only the mobile 45nm SKUs are expected to launch in 2008. Penryn-based Xeon processors will utilize the same server platform as Xeon 5000, 5100 and 5300. Nehalem, Intel's next-generation microarchitecture on the 45nm node slated for 2008, will require new platform technology and is not compatible with the Penryn platform. 45nm quad-core Harpertown and dual-core Wolfdale were originally slated to spearhead the next-generation Xeon launch in Q1 2008. The existing Bensley platform, Intel 5000P chipset, will still provide the heavy lifting for volume dual-socket on 45nm Xeon. A new platform, Cranberry Lake, will replace Bensley-VS for value dual-socket Intel platforms, and will support Harpertown and Wolfdale. Izvor: DailyTech |
#92 |
Postovi: 7,568
VRM ver. 11.1 za Bloomfield procesore i nasljednik Bearlake chipseta
VRM za Bloomfield
Eaglelake chipset
Izvor: HKEPC i VR-Zone |
#94 | |
Postovi: 7,568
Procesori iz serije 6050...era 1333MHz FSB-a
Intel will release third quarter 2007 version of Conroe deal with a new generation of FSB 1333MHz, and were named the 6050 Core 2 Duo family. According to the latest Intel processors plan 1333MHz FSB versions of the Conroe still using 65 nano process. This 1333MHz FSB Core 2 Duo lineup, includes models E6850, E6750, and E6550, which have respective clock speeds of 3GHz, 2.66GHz, and 2.33GHz with 4MB of L2 cache. According to Asus, all P965 P5B motherboards, P5B-E, P5B-E Plus, P5B and P5B Deluxe Premium will support 1333MHz FSB. Gigabyte Rev. version 3.3 or above models including GA-965P-S, GA-965P-DS3, GA-965P-DS3P, GA965P-DS4 and GA965P-DQ6 will support 1333MHz FSB. Citiraj:
#95 |
Prečupavi mod
Postovi: 9,154
A kakva je situacija i975X chipsetom, hoce li na njega ici 1333 FSB procevi (ako znas)?
Member of PCE 100+kg demolition squad Pozz, nezz, ojzz, jbt, owak, onak, inst, bzvz, svst, kuiš, neam, dns, nzm, oc, went, graf, laikam, oču, neču, e ovako, e sad, probo, neče, psmtr, ne beliiwam, ugl probo o5, tkđ neradi, pčkmtrnu, mslm onaak haaalo, reko dbr, stv, dali, jeli, zato jel, jer mi može neko, rispekt, thx......... ...wau, radi, zkn, pozz!?!?11 |
#96 | ||
Postovi: 7,568
EDIT - Ispravak netočnog navoda: Jedan od vlasnika Asus P5W DH Deluxe ploče me obavijestil da dotična ploča sa novom verzijom BIOS-a dobiva podršku za 1333MHz FSB. Čovek je dal i link, pa provjerite. Zadnje izmijenjeno od: McG. 10.03.2007. u 23:40. |
#98 | ||
Prečupavi mod
Postovi: 9,154
#100 |
Postovi: 7,568
Core 2 Quad Q6600, nagađanja oko 45nm i detaljan popis svih C2D procesora
Core 2 Quad Q6600 Intel recently unveiled its updated pricelist for Q3’s processor products. Intel Core 2 Quad Q6600 has already experienced a large cut from $851 per 1,000 units shipped to $530 on April 22. The company decided to make another cut to Core 2 Quad Q6600, where its price would be as low as $266 per 1,000 units shipped. Meaning this new processor would experience a 68.7% accumulative cut of price since its release in March. Another point that should deserve our attention is that Intel would no longer release any Dual-Core Intel Core 2 Extreme edition. Intel Core 2 Extreme QX6800 processor released in Q3 will be the last Dual Core of this series. Detalji i nagađanja oko 45nm procesora We won't see the things on the desktop until the beginning of 2008. Given Intel's 45nm fab plant schedule, the 45nm rollout will probably be slow like Conroe's. The cheapest price on the 45nm dual cores will be at the $183 price level, again, much like Conroe. 45nm will be the time when quadcores start becoming mainstream, and the cheapest 45nm quadcore will initially cost somewhere around $266. We don't expect Penryn to be dramatically better than Conroe, maybe 10-20% better mostly due to increased clock speeds. Izvor: HKEPC, Overclockers.com i Hardware Secrets Zadnje izmijenjeno od: McG. 12.03.2007. u 17:21. |
#102 |
Je suis Schumi
Postovi: 1,527
Di sam stao? -Stalji smo onda kad je *ebem Šćepanović ![]() |
#103 | |
Postovi: 7,568
Preview performansi Bearlake P35 chipseta
Intel has put a lot of work into this chipset by the design of it, and with more on the way we can only hope things do get even better. Citiraj:
Izvor: TweakTown i OCWorkbench Zadnje izmijenjeno od: McG. 13.03.2007. u 23:45. Razlog: Dodane ECS Bearlake ploče |
#104 |
Postovi: 7,568
Core 2 Duo E4400, E4500 i nVidia MCP73 chipset
Core 2 Duo E4400 i E4500 Intel will launch two more Core 2 Duo E4000-series processors. The Core 2 Duo E4400 will arrive next month clocked at 2.0 GHz for $133 per processor, in 1,000 unit quantities. In Q3’07, the Core 2 Duo E4400 will drop down to $113 with the introduction of the E4500. The Core 2 Duo E4500 clocks in at 2.2 GHz and takes over the $133 per processor, in 1,000 unit quantities. Intel will slowly phase out the Core 2 Duo E4300 processor in Q3’07. Foxconn MCP73 MCP73 is the Intel derivative of the integrated MCP68 solution from nVidia. This board supports Intel Core 2 Quad Core, Core 2 Extreme, Core 2 Duo processors of 1333/1066/800/533 MHz LGA775 socket. MCP73 integrates GeForce 7 performance graphics core with SM3.0, it supports only DDR2-667/533. The board comes with 1 PCIe x16, 3 PCI slots, 2 SATA II ports, 1 IDE port and 7.1 ch audio, Fast Ethernet and 10 USB ports. Izvor: DailyTech i OCWorkbench |
#106 |
Spužva Bob Skockani.. :XD
Postovi: 1,685
Pa hoće...imat će x10 i x11,neznam šta nije jasno... ![]()
Athlon64 X2 5400BE Brisbane @3000Mhz + KATANA 2 + AirTunel@2x Xilence 120mm Gigabyte GA-MA78G-DS3H @F4 Mushkin Redline @1000Mhz 5-5-5 XFX 9600GSO @680/1700 || 2000Mhz Seagate Gonzales 250GB & 320GB && Spinpoint F1 500GB Coolermaster Elite Power RS460; Sharkoon Silvation; LG GH22NP20/LG GH20NS10/Pioneer DVR107D/Pioneer 216DBK/ Samsung SH-S223F; Logitech MX518; Philips 190P7ES 19" LCD |
#107 | |
Postovi: 7,568
Yorkfiled, Wolfdale i finalne specifikacije i detalji oko Bearlake serije chipseta
Intel and its partners will kick of CeBIT 2007 with the launch of Intel's Bearlake family of chipsets for desktop PCs. The new series introduces support for DDR3 memory, front side bus speeds up to 1333MHz and are designed to support Intel's upcoming 45nm-process CPUs, the Core 2 Duo (Wolfdale) and Core 2 Quad (Yorkfield). Citiraj:
Izvor: DigiTimes i PCGH |
#108 | |
Postovi: 7,568
Performanse E6420, E6320 i E4400 procesora
In about a month Intel is going to launch three new low-cost processors in the Core 2 Duo family and reduce the prices of the already existing dual-core CPUs. Core 2 Duo E6420 and E6320, will be more advanced analogues of the existing Core 2 Duo E6400 and E6300: they will feature larger L2 cache – increased to 4MB. Core 2 Duo E4400, is none other but Core 2 Duo E4300 overclocked to 2.0GHz Citiraj:
Izvor: X-Bit Labs |
#109 |
Postovi: 7,568
Razotkriveni Penryn i Nehalem
Procesori iz Penryn obitelji
Nehalem arhitektura
Izvor: AnandTech i Hexus |
#110 |
PC Ekspert šerif
Datum registracije: Feb 2002
Lokacija: Vječno u labu...
Postovi: 1,496
#111 |
dr. sc.dipl. ing. stroj.
Lokacija: Rijeka-Opatija(-Pula)
Postovi: 3,191
Nehalem mi nekako sve više liči na "Athlon64 arhitekturu", pogotovo s ovim integriranim mem. kontrolerom Eh, sad se ceka da se vidi sto ce biti sa novom AMD arhitekturom..... u svakom slucaju, biti ce zanimljivo
Pouzdan i pošten trgovac! (ima još puno novijih primjera, nisam ni pratio jel me još tko stavljao u temu.. slobodno pretražite novije postove na temi) StarCitizen refferal code: |
#112 |
Postovi: 1,685
Nehalem...'tru' izraelsko-zhidovski procesor...kmh...
#113 |
Postovi: 3,191
Pa zna se gdje je i originalna Core arhitektura razvijena! ![]()
#114 | |
Premium moderator
Postovi: 4,600
@JC pa to i je daljni logičan korak ![]() Također će Nehalem će napustiti LGA775 a.k.a. socket T i doći će novi FCBGA 1088 pinski socket. |
#115 | |
Spiderpig
Postovi: 2,042
#116 |
PC Ekspert šerif
Postovi: 1,496
Pa ne kopira arhitekturu, ali kopira koncept - integrirani mem kontroler, point-to-point serijska veza ala HyperTransport. Ista shema ko i s x86-64. Ja se sjećam dok je Intel tvrdio kako je integrirani memorijski kontroler nefleksibilno rješenje (ala ne možeš dodat podršku za novu memoriju izmjenom čipseta) i kako to neće napraviti svojim korisnicima. |
#117 | |
Postovi: 3,191
Nisam ni AMD ni Intel fanatik. Bio sam vlasnik procesora i jednog i drugog proizvođača, birao sam isključivo za "best bang for buck" i to je jedino sto mene zanima. A praćenje razvoja novih procesora i implementiranih tehnologija - to mi je samo razonoda ![]()
#118 | |
Spiderpig
Postovi: 2,042
Također gledam šta je bolje za iste novce a ne šta mi piše u CPU-Z. |
#119 | |
Spiderpig
Postovi: 2,042
A to šta je on tvrdio ne znam, ali ispada isti qrac jer ovako moraš promjenit matičnu a onako procesor. Možda matične jesu jeftinije ali ne u svakom slučaju. |
#120 |
PC Ekspert šerif
Postovi: 1,496
E nije isto, ti to gledaš kao korisnik što je previše uzak pogled da bi se mogao komentirati utjecaj neke tehnologije na tržište. Za ilustraciju, ti kažeš da je svejedno da li moraš mijenjati ploču ili proc budući da gledaš samo na to koliko će te para doć upgrade. Za proizvođača procesora promjena ploče znači da će vrhnje ubrat proizvođači matičnih ploča i čipseta, a ako je kontroler integriran u procesor onda ljudi moraju kupovat procesore. To je recimo jedan od razloga zašto AMD koristi integrirani memorijski kontroler. Ali opet, kako god okreneš integracija memorijskog kontrolera u procesor je skuplja po korisnika jer ga forsira da kupuje i procesor i matičnu ploču. Dakako, ne uvijek, ali u slučaju da recimo DDR3 postane standard, ako je mem. kontroler na matičnoj ploči, kupiš samo ploču. Ak je na procu, onda moraš kupit i novi procesor koji ima mem. kontroler koji podržava DDR3, ali i matičnu ploču koja ima utore za DDR3. |
