Staro 19.02.2007., 00:00   #31
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
A u kojem OSu iskoristavaš te 4 gige???
Nemam više lema!!!
Staro 19.02.2007., 01:00   #32
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Šta 4 pločice sdrama od gigu?
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je online   Reply With Quote
Staro 19.02.2007., 10:54   #33
Gustavo
Lokacija: Sisak
Postovi: 357
Ma to bi ja na novi komp stavio,a ne na pentium 3,ne znam ni sam što radit?
Gustavo je offline   Reply With Quote
Staro 19.02.2007., 18:03   #34
beetleman
editor in chief
beetleman's Avatar
Postovi: 151
Nebi ni ja stavio iz svog djepa , dobio sam.. trenutno je Suse 9.2. na doticnom stroju! Stavio sam jel moze ic..
Lenovo Y510p with dual NVIDIA GeForce GT755M
beetleman je offline   Reply With Quote
Staro 19.02.2007., 20:16   #35
LorD ClockaN
od LemilicE
Postovi: 4,712
Ja već mislio na windowsima
Nemam više lema!!!
Staro 19.02.2007., 20:55   #36
terminator
Spermich Termich
terminator's Avatar
Lokacija: Zaprešić
Postovi: 885
Autor beetleman Pregled postova
PIII sa 4 gige rama i Ati Radeon 9600 Pro, cist ok radi!
sorry, baš ne kužim.
imaš komp p3 sa 4 gige rama?
neznam jer sam si ja kaj zabrijal il? al na moj p3 je išlo 512 max? : stoopid
terminator je offline   Reply With Quote
Staro 19.02.2007., 22:42   #37
DoDo
DoDo's Avatar
Postovi: 372
Autor Gustavo Pregled postova
Po mom misljenju ako klinci misle igrat one naslove koje si naveo mozes zaboravit na bilo kakav upgrade
postojeceg kompa,neisplativo.
Cak ni sljedeca generacija procesora to nece gurat.
Mozda recimo kakav p4 na3gz-a ili Mobilac stari naklokan na 2.5gza
sa nekom GF6800 ili 6600GT.
Po meni je to minimalno za normalno igranje .
Mislim da ce klinci morat malo spustiti kriterije : stoopid
P35-DS3 rev. 2.0
E8200 @457x8=3655 1.35V
2x1Gb kingmax 667 @ 915 5 5 5 2V
1x2Gb transcedent @ 915 5 5 5 2V
GTX460 768MB @ 830/1050
Fortron 350W
"Let's face it, we're not changing the world. We're building a product that helps people buy more crap - and watch porn."
- Bill Watkins- CEO Seagate Technology
DoDo je offline   Reply With Quote
Staro 20.02.2007., 19:15   #38
beetleman
editor in chief
beetleman's Avatar
Postovi: 151
2terminator: imam Abit BE6II plocu.
info:
PU
Supports Intel Pentium® III 450~700 MHz processor cartridge
Supports Intel Pentium® II 233~450 MHz processor cartridge
Supports Intel CeleronTM 266~533MHz processor
Chipset
Intel®440BX chipset (82443BX and 82371EB)
Supports Advanced Configuration and Power Management Interface (ACPI)
Supports AGP 1X/2X (Sideband)3.3V device
High Point HPT366 chipset supports Ultra DMA 66
Memory
4 168-pin DIMM sockets support SDRAM module
Supports up to 2 GB MAX. (8, 16, 32, 64, 128,512MB, 1GB SDRAM)
Supports ECC
BIOS
SOFT MENUTM III or DIP switches to set CPU parameters
Award Plug and Play BIOS version 6.0
Write-Protect Anti-Virus function by AWARD BIOS
Year 2000 Compliant
I/O Functions
2 Channels of Bus Master IDE Ports supporting up to four Ultra DMA 33/66 devices
2 Channels of Bus Master IDE Ports supporting up to four Ultra DMA 33 devices
PS/2 Keyboard and PS/2 Mouse Connectors
1 Floppy Port (up to 2.88MB)
1 Parallel Port (EPP/ECP)
2 Serial Ports
2 USB Connectors
Miscellaneous
1 AGP slot, 5 PCI slots and 1 ISA slot
Hardware monitoring
Keyboard/Mouse/Password and Hot Key multifunction Power On
Built-in Wake on LAN/Wake on Ring header
Built-in IrDA TX/RX header
One Thermal Sensor Cable Included
PC99 Color connectors
Dimensions : 305*200mm
S tim da sam upgrade biosa napravio..neki eksperimentalan..
Staro 20.02.2007., 19:17   #39
beetleman
editor in chief
beetleman's Avatar
Postovi: 151
btw ili kupis playku pa rijesis cijeli problem..
Staro 20.02.2007., 22:14   #40
LorD ClockaN
od LemilicE
Postovi: 4,712
Piše da ti max podržava 2gb, a ti imaš 4.
Jedino ako ti je tu podršku uveo experimentalan bios
Nemam više lema!!!
Staro 20.02.2007., 22:27   #41
beetleman
editor in chief
beetleman's Avatar
Postovi: 151
da to je dobiveno biosom.. suradjivao sam sa deckima iz Abita dok sam radio u HP-u, pa smo djelili neke stvari..poput toga.. naime objasnili su mi da izmedju 2GB i 4 GB nema nekakve hardwarske razlike nego je to do biosa..pa se malo modificirao. Ja sam dao opce informacije za serijsku plocu
Staro 21.02.2007., 12:28   #42
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Da...PCI je krivac za to, tzv. memory hole. Još prije P3-ke su čipovi mogli adresirati 4 Gb memorije
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
