Staro 08.11.2003., 22:09   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Novi Omega driveri
Evo i Omeginih
What's New? (2.4.96c)
* Based on the Official Catalyst 3.9 drivers. (2k/XP)
* Included the OGL fix for AIW cards. (2k/XP)
* Added a very powerful full-blown profiler utility. (2k/XP)
* Removed the ATI profiles from the ATI CP, the OGL and D3D tabs
are now separated as pre Cat 3.8 drivers. (2k/XP)
* Added support for more cards, including Mobility and IGP. (2k/XP)
* Added a Desktop shortcut to go directly to the ATI Control Panel. (2k/XP)
* Added an exclusive version of Driver Cleaner for the Omega Drivers. (2k/XP)
Important Notes:
1. If you are experiencing crashes or black screens just a few seconds after
entering a game, DISABLE VPU RECOVER (IF available), that should help.
2. If you play Call of Duty (Full version, not demo) and experience lockups
in certain game areas, DISABLE Fastwrites.
REMINDERS:
1- If you have the normal ATI drivers, uninstall the ATI Control Panel BEFORE
upgrading to these drivers, the drivers already have the CP integrated
and another CP may cause conflicts or other problems.
2- There is no need to uninstall ANY previous drivers (ATI or OMEGA) when
installing these, they will override any previous settings.
3- In Windows 2k/XP, ALWAYS disable DDC in the ATI "Displays/Monitor" CP after
installing drivers to be able to use ALL the refresh rates and resolutions
your monitor supports, also this is the best way to avoid the 60Hz RR bug.
4- The WDM drivers for VIVO and AIW cards are not included, but they can be
downloaded separately from a link in my drivers page.
5- I have received various E-Mails asking about FastWrites, there is only one
answer to that: TURN IT OFF
The Radeon cards do support FastWrites and they will work with it on
(on some machines), but it is not recommended, there is NO SPEED gain
when using FW, and this option will affect your PC's stability a LOT.
*** IMPORTANT FASTWRITES UPDATE ***
An important info has come to my attention, if you have a Radeon 9600 Pro card,
regardless of the manufacturer, you MUST enable Fastwrites to make it work
properly, if not, you may experience crashes and lockups! (This is only a temporary
fix until ATI resolves the problem)
Dakle-nema se kaj čekat
www.omegacorner.com
http://www.driverheaven.net/downloads/index4.htm
Za sada samo za 2k/xp...za 98-icu malo kasnije...
I još jedan
http://www.mikerosoft.ca/
Zadnje izmijenjeno od: Jelc. 08.11.2003. u 22:46.
Staro 08.11.2003., 22:45   #2
pinsla
Caught Somewhere In Time
pinsla's Avatar
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
Kaj je on to stavio svoj neki utylity za kreiranje profila za igre?
Uh to bi moglo bit zanimljivo a tek sam nabavio original 3.9 drajvere
pinsla je offline   Reply With Quote
Staro 08.11.2003., 22:49   #3
Jelc
Super Moderators
Postovi: 17,485
Ja budem skidao najvjerovatnije po noći pa bum vidio.
Pa kaj ti nije najednostavnije napraviti si profile u rage3dtweaku?
Staro 08.11.2003., 22:54   #4
pinsla
pinsla's Avatar
Postovi: 1,860
Pa najjednostavnije bi bilo u atijevom control panelu kad bi oni to napravili kak spada a kaj se tiče ragea nisam probavao nit ga više nemam čini mi se instaliranog
Staro 08.11.2003., 23:15   #5
Jelc
Super Moderators
Postovi: 17,485
Ja sam se sa tim bio jedno vrijeme zezao i delalo je fino.
Mislim na rage3dtweak, budemo vidjeli kaj je Omega smislio.
Znam da se neke stvari mogu dodati u liniju exe datoteke sa kojom pokrećeš igru, najvjerovatnije se može nekaj naštelati i u samoj igri...
Npr u HALO-u je znao zajebavati refresh pri pokretanju igre pa se moralo upisati halo.exe -vidmode 1024,768,85...negdje su se i ukucavale i naredbe za forsanje verzije shadera itd...
Pretpostavljam da bi ti najrađe to negdje namjestio, pa da ti se igra uvijek pokreće sa tim postavkama???
Staro 09.11.2003., 18:44   #6
pinsla
pinsla's Avatar
Postovi: 1,860
Ma je ja bi volio da ati konačno sredi te profile da rade kak je zamišljeno dakle da možeš određeni profil pridružiti exe datoteki pojedine igre. Pa tako npr jednu igru furam na 4x aa i 4 xaf nekaj zahtjevnije na 2xaa i 2xaf i tako. Mislim da ne moram stalno nekaj prčkat po control panelu nego da mi to dalje fino šljaka kad jednom naštelam. A i mene zanima kaj je omega smislio budemo probali
Staro 09.11.2003., 22:13   #7
Jelc
Super Moderators
Postovi: 17,485
Sa novim Omega ti je problem kaj ti taj 3dProfiler neće delati
Jer-da bi delao moraš imati na kompu NET Framework...imaš ga tu
http://www.microsoft.com/downloads/d...displaylang=en
Oko 23 mege...ja ga budem skinul-tak i tak bude zatrebao u budućnosti.
Mislim, nemoraš se zezati sa Omegom ak ti se ne da, možeš sve to poštelati i u rage3dtweaku ili u radlinkeru...
Ja sam Omegu skinuo i instalirao-sve dela fino
Staro 10.11.2003., 21:09   #8
ZMAJ
Postovi: 2,937
Da pitam, ovaj zanima me kako inace ATI-u izlaze novi driveri? Svakih koliko mjeseci?
ZMAJ je offline   Reply With Quote
Staro 10.11.2003., 23:11   #9
Paske
Ekspert iz sjene ...
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Re: ...
Jednom mjesećno
