#991 |
Torrent freek
Postovi: 3,946
#992 |
Pink Floyd fan
Lokacija: Santa Clara, CA
Postovi: 5,536
#993 | |
Torrent freek
Postovi: 3,946
Fala: cheers2
#994 |
Pink Floyd fan
Postovi: 5,536
#995 |
Torrent freek
Postovi: 3,946
#996 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Novi DFI forum
To give you better and more intuitive technical customer services that you deserve, we are announcing a change to our DFI-Street for our customers. Effective immediately a brand new worldwide technical support forum http://global.dficlub.com will serve everyone on a broader base. Covering idea interchange and allowing experience sharing for over-clocking and tweaking without the need to use DFI-street to discuss the boards. In the past, we have been welcomed and supported by many of you, for our DFI-Street program. It has been quite a success. At this moment, we would like to express our deepest thanks to Travis for his dedication in founding and maintaining the forum, when DFI Club was not available. To continue with the great work, our expert technical customer-service engineers will do everything they can to help you and provide detailed answers to any questions that you may. Thanks and happy overclocking with our remarkable devices!! DFI Inc. http://global.dficlub.com/
#997 |
Datum registracije: Jun 2004
Postovi: 368
Dali mi mozete reci koji je najbolji BIOS za oc DFI Lanparty ultra-d? |
#998 |
Super Moderators
Postovi: 17,485
Koji ti je BIOS na ploči sad?
#999 |
Lokacija: tuzla
Postovi: 25
704-2bta je po meni najbolji
DFI nf4 Ultra-D+Thermalright HR05-SLI AMD Athlon64 3000+ (venice) @ 2.7ghz 1.400v+Zalman 9500 LED Kingmax Superram PC3500 @ 473 mhz (2.5-3-3-7) Gigabyte 6600 Turboforce 256mb 450/500 @ 520/620 Enermax Liberty 500W HDD Hitachi 80GB S-ATA2 Asus DVDRW |
#1001 |
Super Moderators
Postovi: 17,485
#1002 |
Grazie Michael
Lokacija: Ogulin
Postovi: 360
#1003 |
Super Moderators
Postovi: 17,485
Meni je X2 3800+ i naclockan bio hladan-nemože ti biti na 55c pri 1.45v nikak...
#1005 |
Torrent freek
Postovi: 3,946
E to bi već moga bit problem. Još ako kućište nije baš provjetreno do 40-ak dođe bze problema
#1007 |
Spužva Bob Skockani.. :XD
Postovi: 1,685
I imaš stock kuler dižeš mu napon i frekvu,i očekuješ niske temperature...hajde malo budimo realni... ![]()
Athlon64 X2 5400BE Brisbane @3000Mhz + KATANA 2 + AirTunel@2x Xilence 120mm Gigabyte GA-MA78G-DS3H @F4 Mushkin Redline @1000Mhz 5-5-5 XFX 9600GSO @680/1700 || 2000Mhz Seagate Gonzales 250GB & 320GB && Spinpoint F1 500GB Coolermaster Elite Power RS460; Sharkoon Silvation; LG GH22NP20/LG GH20NS10/Pioneer DVR107D/Pioneer 216DBK/ Samsung SH-S223F; Logitech MX518; Philips 190P7ES 19" LCD |
#1008 |
Super Moderators
Postovi: 17,485
#1010 |
Super Moderators
Postovi: 17,485
Ma, možeš slobodno označiti update all.
#1011 |
Lokacija: Sv.Nedelja
Postovi: 5,822
koji bios koristite na dfi infinity ultra?tj koji se najbolje pokazal?zanima me zbog tog zato kaj mi everest izbaciva latencije 59.7ms 3-3-3-8...zadnja je revizija biosa 04/10/2006-NF-CK804-6A61FD49C-00 a sa predzadnjim biosom ck8ud301,izbacivalo latencije oko 52ms i latencije mi je pokazival 2.5-3-3-6,al s tim da je sistem bil nestabilan...pa deklarirano je da dela na 3-3-3-8 memorija...kolko ja znam,zakaj mi onda sa starijim biosom baca 2.5 lat.? sve je na default Zadnje izmijenjeno od: zvonac. 03.03.2007. u 22:13. |
#1012 |
Postovi: 1,685
Pa vrati si bios koji ti bolje odgovara... ![]() A sad dali je sistem stabilan ili nije to je druga priča...postavi sve najoptimalnije kako mo'š a da radi stabilno. ![]()
#1014 |
Super Moderators
Postovi: 17,485
Vidiš da je "friški" sa DFI, mogao si mu i ljink hitit ![]() http://www.diy-street.com/forum/showthread.php?t=22031
#1016 |
Postovi: 683
bok, kupio sam plocu dfi nf4 ultraII-M2 AM2 i 3800 X2 e sada..mema mi je 533Mhz,na 1T nakon sto sam kloknuo HTT sad mema radi na 800Mhz uz poviseni napon,ali nevidim nikakvih poboljsanja u Super PI, iako mi HTT radi na 330.. Tek kad odvrnem proc na 2400Mhz onda Super Pi radi bolje.... latencije mem su mi.. CAS #latency 4 RAS to CAS 4 RAS Prech 4 Tras 12 Trc 16 citano iz cpu-z dakle latencije nisam dirao samo sam smanjio mnioztelj i povecao HTT da bih dobio istu frekvu proca a vecu rama- ram radi na 2.1V.. A sto se tice biosa...gdje ima stranica sa neofficialnim biosima? |
#1017 | |
Ne znam šta da napišem
Postovi: 984
Nadam se da se svjestan da procesori kada ih mal previše klokaš rade sporije neg na defaultu... A više klokanom procu sporiji rad može uzrokovati mema, nekompatibilnost s matičnom(tj. da MBO ne dopušta), malo struje(napona), preniske latencije meme, zagrijavanje... itd
Nemam ništa pametno za reć! |
#1018 |
Postovi: 3,996
#1019 |
Postovi: 1,685
Pa kod mene ima DRAM data drive strenght isto Level 1 - Level 3 ![]() A ovo se nikad nisam igrao sa tim ostatkom postavki...u biti jesam jednom sa tccd-om;ali sve mi nekako najbolje šljakalo kad samo latencije sve poštelam a ova ostala sranja na Auto... ![]() ![]()
#1020 |
Grazie Michael
Lokacija: Ogulin
Postovi: 360
Koliki je max. siguran napon na procesoru, s tim da imam TT Big Typhoon gore. Čuo sa da više od 1,5V nije zdravo za X2 procove. Neki su išli do 1,6V. http://forums.tweakguides.com/showthread.php?t=4459
