Staro 18.09.2003., 21:19   #1
Veky
Veky's Avatar
Datum registracije: Nov 2002
Postovi: 1,950
WinXP patch za IE, fala k...
http://support.microsoft.com/default.aspx?kbid=331596
Download
When you browse the Web, you may notice that frames on some Web sites are not displayed correctly, and the HTML code may not be fully rendered.
This issue may occur after you install the Internet Explorer hotfix from the following Microsoft Knowledge Base article:
331596 Data Is Truncated When You Download a Gzip-Encoded Excel File in Internet Explorer
and then you perform the following procedure:
Log on to a Web page that contains gzip-encoded content.
Reload the content from the cache. Note: The hotfix that is described in Knowledge Base article 331596 is included in Windows 2000 Service Pack 4 (SP4).
Supported Operating Systems: Windows 2000 Service Pack 2, Windows 2000 Service Pack 3, Windows 98 Second Edition, Windows ME, Windows NT, Windows XP
This update applies to Internet Explorer 6 SP1 with the following operating systems:
Windows XP SP1
Windows XP
Windows 2000 SP3
Windows 2000 SP2
Windows 98 SE
Windows Millenium
Windows NT 4.0 SP6A
Ajde vise da su i to popravili. Uglavnom se desi da neka (ili vise) slika na stranici ili nema ili cudno izgledaju.
Veky je offline   Reply With Quote
Staro 18.09.2003., 21:44   #2
Veky
Veky's Avatar
Postovi: 1,950
Kaze da trebam IE6 SP1 da bi ga snimio a ja to i imam. :confused:
