Staro 21.10.2006., 13:30   #1
smoks1
smoks1's Avatar
Postovi: 343
Sonic tower
pa sta vise nigdje nema za kupit ST?
Gledao u Ve-milu, Hgspotu, i u Linksu...
smoks1 je offline   Reply With Quote
Staro 21.10.2006., 14:57   #2
frANZi
Dr. Gonzo
frANZi's Avatar
Postovi: 958
http://www.nabava.net/katalog/trazil...+tower&x=0&y=0
Ja baš mislim sljedeći tjedan kupit sonica, i sad ga nigdje nema!!! : Machineg
frANZi je offline   Reply With Quote
Staro 21.10.2006., 15:31   #3
atha
atha's Avatar
Postovi: 9,069
Ma nema ga niti u Optimumu.
___________
Just atha
x
Staro 21.10.2006., 15:46   #4
Wolverine
Wolverine's Avatar
Postovi: 12,433
Uzmi Scythe Mine u Linksu, iako je na popisu pasivnih coolera to je Aktivni cooler cijena je 270kn a hladi ko npr BigTyphoon
http://www.links.hr/index.php?option...kl=050.907.031
Mark Twain
Intel Core i7 2760QM
2x 8GB DDR3
Intel HD3000
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 21.10.2006., 16:09   #5
dDario
dDario's Avatar
Datum registracije: Jun 2004
Postovi: 1,567
Wolw jel bi stao u Scythe neki normalni 120mm vent, ili barem 92?
inače je mrak cooler
a SonicTower svako malo nestane pa ga kroz tjedan-dva opet dobiju.
IBM T43 > Centrino M750 > 2GB DDR2 > 60GB > DVD-RW > 14" XGA
Atom 230 > D945GCLF > 1GB Buffalo > 120GB > DVD-RW > HP L1940
Atom 330 > D945GCLF2 > 2GB G.SKILL > 160GB > DVD & DVD-RW > SM720N
E1400 > G31-M7 TE > GB DDR2 > 80GB > DVD & DVD-RW > SM720N
E1400 > G31-M7 TE > 2GB DDR2 > X1600Pro > 250GB > DVD & DVD-RW > SM932B
X4 9950 > AM2NF3-VSTA > 2x2GB G.SKILL > Parhelia 256 > 2x 640GB > DVD-RW > 2x SM205BW
E6300 > ASUS P5B > 2xGB kingmax > X1900AIW > 2x320GB > DVD-RW & DVD-RW > LG 194WT
dDario je offline   Reply With Quote
Staro 21.10.2006., 16:11   #6
Wolverine
Wolverine's Avatar
Postovi: 12,433
može stat i 92 i 120 koliko sam gledao no nema potrebe za mjenjanjem ovog venta jer je čist pristojan
samo je pitanje kak ga fiksirat no nađe se načina
Mark Twain
2x 8GB DDR3
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 21.10.2006., 17:51   #7
smoks1
smoks1's Avatar
Postovi: 343
da ali je 22 dB!!
Moglo bi se rec da mi je to malo previse...
Staro 21.10.2006., 17:52   #8
smoks1
smoks1's Avatar
Postovi: 343
Koliko dB je stock cooler od Intela, npr od D820?
Staro 21.10.2006., 17:56   #9
Wolverine
Wolverine's Avatar
Postovi: 12,433
Prvo imaš opciju Edit pa je koristi ubuduće
Drugo ako je to stvarnih 22dB onda to nije nikako previše
Npr jedan stock cooler ima preko 30 ovisno o broju okretaja i vrsti
A kolko bi ti dB?
Evo ti fino link pa vidi koliko je što?
imaš zvučne zapise pa poslušaj
http://www.silentpcreview.com/article285-page6.html
http://www.silentpcreview.com/article271-page5.html
Mark Twain
2x 8GB DDR3
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 21.10.2006., 17:58   #10
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,508
Autor smoks1 Pregled postova
da ali je 22 dB!!
Kupiš Zalmanov Fanmate 2 za 22KN staviš na 5-6V i ne vude se čuo. S obzirom na oblik trebalo bi hladiti jako dobro.
Staro 21.10.2006., 18:02   #11
smoks1
smoks1's Avatar
Postovi: 343
Za EDIT,nema problema
30dB?
a ma krasno...
Vec imam jednog BT ali sam ga prodao sa komponentama...
u ponedjeljak idem po nove i trebao bi mi neki cooler, mislio sam ST ali ih ocigledno nema,a neda mi se opet kasnije skidat i vracat maticnu...
a BT je 100 kn skuplji od ST...
ma sranje tesko...
izgleda da ce neko vrijeme radit sa stock-om dok ne dodje ST...
Vidis,mogao bi i Fanmate unutra ali...
svejedno imam jedan vent od 120mm viska koji sam planirao stavit na ST,a nema druge, kupit komponente i nek radi na stock cooleru dok ne dodje ST u neku od trgovina...
Staro 22.10.2006., 14:50   #12
Meddle
Meddle's Avatar
Postovi: 151
Je dovoljan taj cooler za e6600 overclocking ili je bolji BT?
Meddle je offline   Reply With Quote
Staro 22.10.2006., 15:35   #13
Wolverine
Wolverine's Avatar
Postovi: 12,433
koji dio rečenice di kažem da hladi ko i BigTyphoon ne razumijep?
Taj cooler je i više neg dovoljan
Mark Twain
2x 8GB DDR3
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 22.10.2006., 21:28   #14
Meddle
Meddle's Avatar
Postovi: 151
I nakolko cca mora vrtit vent da bi imao normalne temperature na full loadu na 3400Mhz?
Staro 22.10.2006., 22:11   #15
smoks1
smoks1's Avatar
Postovi: 343
da,ali BT je 16 dB a ovaj je 22 dB...
mozda to nekome ne igra razliku ali meni da,jer mi komp prakticki besumno radi...
Staro 22.10.2006., 22:55   #16
Meddle
Meddle's Avatar
Postovi: 151
Al dobra je stvar sta ih spojis na potenciometar pa mozes smanjivat napon. Kad igras pojacas a kad je u idelu samo smanjis.
[EDIT] Tek sad vidim da je vent 100mm a ne 120. Izgleda da cu cekat sonic towera ili uzet Btyphoona. Dal ima neka druga preporuka da je ful tih i da se moze dobro clockat. bilo bi dobro da je vent 120.
Staro 22.10.2006., 23:41   #17
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
najbolje ti je uzet freezera 7pro stvarno nečujan a predobro hladi...
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 07.11.2006., 19:12   #18
frANZi
Dr. Gonzo
frANZi's Avatar
Postovi: 958
Sonic Towera kako vidim još nema, a hladnjak mi treba.
Da li je ovaj Scythe Mine sposoban raditi bez ventilatora?
Jel bolje hladi Sonic Tower ili Scythe Mine?
Postoji li možda još neka alternativa ST-u?
Staro 07.11.2006., 20:42   #19
Wolverine
Wolverine's Avatar
Postovi: 12,433
svaki je cooler sposoban radditi bez venta
pitanje je samo kako onda hladi
sa ventom Mine hladi kao npr BigTyphoon možda stupanj dva slabije
kaj ti baš mora bit bez venta?
fino ga smanjiš i nećeš ga čut uopće
Mark Twain
2x 8GB DDR3
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 07.11.2006., 21:04   #20
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,042
kažu da je vent na mineu jako tih pa još ako ga smanjiš stvarno se nečuje a hladi
Smartguy je offline   Reply With Quote
Staro 09.11.2006., 13:10   #21
Gargamel
Gargamel's Avatar
Postovi: 400
dosao je st u links - 277ln
aj preporucite neki 12cm tihi vent koji kad bi delao na <1000rpm ima jos kakav takav protok zraka
i dal mi se vise ispati uzet st + takav vent ili bt... posto na kraju izade isto
Gargamel je offline   Reply With Quote
Staro 09.11.2006., 19:25   #22
Ph03n1x
Ph03n1x's Avatar
Lokacija: Varaždin/Zagreb
Postovi: 1,846
http://www.links.hr/index.php?option...kl=050.908.103
prilicno dobar ventilator
a i 120mm glacialtechi su dobri...
Ph03n1x je offline   Reply With Quote
Staro 09.11.2006., 19:53   #23
Wolverine
Wolverine's Avatar
Postovi: 12,433
Uzmi si Glacial-a u VeMilu ventovi su više nego dobri.
Mark Twain
2x 8GB DDR3
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 09.11.2006., 20:06   #24
Gargamel
Gargamel's Avatar
Postovi: 400
a st ili bt?
ajmo ljudi! dijelim bodove za reputaciju
Staro 09.11.2006., 20:17   #25
nino
nino's Avatar
Postovi: 12,613
Ja dajem prednost Typhoonu, probao sam oba i upravo zamjenio Sonica za BT, ipak mi je bolji! Reputation?
Staro 09.11.2006., 20:41   #26
Gargamel
Gargamel's Avatar
Postovi: 400
evo, evo
Staro 09.11.2006., 22:34   #27
Ph03n1x
Ph03n1x's Avatar
Postovi: 1,846
a meni?
dakle, bt je nesto bolji izbor eventualno zbog toga sto hladi i podrucje oko socketa, tj. regulaciju napajanja.
EDIT: procitaj wolvov post dolje. potpisujem ga
Zadnje izmijenjeno od: Ph03n1x. 09.11.2006. u 22:45.
Staro 09.11.2006., 22:43   #28
Wolverine
Wolverine's Avatar
Postovi: 12,433
Iskreno?
Išao bi na Scythe Mine ili Katanu SCKTN1000
Za tvoj proc bolje ne treba
Mark Twain
2x 8GB DDR3
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 09.11.2006., 23:27   #29
Gargamel
Gargamel's Avatar
Postovi: 400
stvar je u tom da ne mislim vozit jos godinama pa ce mi dobro doc za buduci c2d, x2... sta vec
inace trazim neki sto jaci da mi vent radi na sto nizim okretajima. na cipset ide hr-05 sli, na grafu modani vf700cu, a iza mi je cm-ov 1200rpm vent koji ce ic na 5v (vjerojatno i vise posto ne vjerujem da da ce bucit previse)
izvukao sam one railove za hard i uglavit cu ga spuzvom... jedino mi jos ostaje napajanje, a to mijenjam za nekog seasonica ili anteca kad skupim neke novce i kako naleti na onom forumu malo nize
kvragu vama sam vec dao za dva posta iznad pa nis od reputationa ovaj put
Staro 10.11.2006., 23:13   #30
masni
masni's Avatar
Datum registracije: Apr 2003
Lokacija: Zagreb,Travno
Postovi: 2,110
dečki, NINJA PLUS...oko 330kn...najjači zračni hladnjak...
e6300@3450mhz@1.525V (očitanje oko 1.47) -full load (orthos) 44 stupnja (max)...: goood :
mjereno sondom...
