Staro 19.09.2006., 01:37   #1
panaso
panaso's Avatar
Lokacija: split
Postovi: 119
Mišljenje o konfi
Molim vas mišljenje o konfi upotreba Cad,Adobe, statički proračuni, vizualizacija okoliša
Memoriju ću poslije još pojačat samo me buni ima ploča dual za memoriju reg i no reg koja je razlika
Tyan Thunder h2000M (S3992G3NR) Opteron 2000/ DDR2/ SATA/ RAID/ V&3LAN Server Motherboard MB-S3992G3 $427.45 $427.45
AMD Opteron Dual-Core Processor Model 265, OEM OS-265 $265.74 $531.48
Samsung DDR2-667 2GB/128x4 ECC/REG Original Memory D2667R2G4S $298.70 $1,194.80
Seagate ST3750640AS 750GB SATA2 7200rpm 16MB Hard Drive HD-ST750BS $352.26 $704.52
Leadtek nVidia GeForce 7950GT 512MB 2DVI/HDTV SLI PCI-Express Video Card LT-7950GT5 $303.85 $607.70
Topower/Epower Tagan TG900-U95 900W Quad SLI Power Supply PS-900U95 $267.80 $267.80
Zalman CNPS9500LED-CU Aluminum/Copper CPU Fan For Socket 478/775/754/939/940 FAN-9500CU $53.56 $107.12
Evercase R7270B-E35 350W EPS EATX 2U Rackmount Server Chassis (Black) CA-7270E35 $175.10 $175.10
Plextor PX-755SA 16x DVD+RW/-RW Drive w/Beige Bezel (Black), Retail PX755SA_SW $120.51 $241.02
Any changes above should be verified by pressing'Recalculate'
Sub Total
$4,256.99
panaso je offline   Reply With Quote
Staro 19.09.2006., 10:45   #2
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
tolko jako napajanje?!cemu? inace trebao si napisat da su neek svari 2x tj 4x
edit: pospan sam...ne pitaj uglavnom lijepa konfa/server...to ce ugodno raditi, samo nemoj rec da oce klokat i sve 5
blup
mc_fish je offline   Reply With Quote
Staro 19.09.2006., 11:04   #3
Mr. M
Postovi: 718
Autor mc_fish Pregled postova
Vidi se iz cijena koliko puta ide prva je cijena za 1 kom, a drugo ukupna
A covijek zeli biti siguran da ima dosta jako napajanje
Mr. M je offline   Reply With Quote
Staro 19.09.2006., 11:07   #4
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
Autor Mr. M Pregled postova
znam ja to kak mislis da sam skuzio da je 2x i 4x(za ram samo)
a sto se tice napajanja...dosta ce ti bit i 700w (salu na strau) 500w i mos jos nadogradivat
blup
Staro 19.09.2006., 19:12   #5
Mr. M
Postovi: 718
Aj, bar si za ram skuzio
A sto se tice napajanja, danas procitah clanak (nije bitno koji caspois ) i bio neki file server (40ak sata2 diskova) i to chudo trosi 1.2 kW...pa eto...orijentir kad se kupuju wati
Staro 19.09.2006., 20:29   #6
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
prevec vjerujes onom sto pise jer disk trosi kojih ajmo rec 10 w(citaj cca dupla snaga nego u stvarnosti) to je onda 400 w na diskove...grafa maticna proc itd... trosi oko 600 max...sad...kad pogledas quad sli trosi ako 400w: bonker : nemoguce da je 1.2 kw...
edit: nisi naveo dal je to cijeli rack bio ili samo 1
blup
Staro 19.09.2006., 20:53   #7
Mr. M
Postovi: 718
Kako mislis cijeli rack?
Hmmm...znam da je bio 2x Opteron i hmmm... 48 ak se ne varam diskova...i da, s razlogom sam napisao nije bitno koji casopis, jer bi me odmah popljuvao (nije bug, ali je na njihovim stranicama )....i da, ako se ne varam pisalo je ovako; "i trosi "samo" 1200 W"
Staro 19.09.2006., 21:04   #8
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
pa recimo da je ono rack od 5 masina...ok mozda i moze
al jedan komp NEMOGUCE
blup
Staro 19.09.2006., 22:47   #9
Crokill3r
Crokill3r's Avatar
Postovi: 19
da stvarno...750 GB HDD ??? : giljotin
To josh nisam vidio...
CPU Core 2 Duo E6300
DDR2 1 GB 667 MHz
nVIDIA GeForce 7600GT 256MB
HDD WD 250 GB WD 2500 KS
DVD RW ASUS
Crokill3r je offline   Reply With Quote
Staro 19.09.2006., 23:42   #10
Mr. M
Postovi: 718
Autor Crokill3r Pregled postova
nisi dobro gledao onda : bonker :
Staro 19.09.2006., 23:49   #11
Mar
Suit up!
Mar's Avatar
Postovi: 5,967
Mislim covjek kupuje prakticki miniracunalo i onda pita na pce forum.
Graficka Quadro FX ili FireGL?
- Barney Stinson
Mar je online   Reply With Quote
Staro 19.09.2006., 23:50   #12
Router
Hejter
Postovi: 6,521
kaj na tom kucistu bude pisalo NASA ? bolesno zvuci
Router je online   Reply With Quote
Staro 20.09.2006., 00:49   #13
Mr. M
Postovi: 718
Autor Router Pregled postova
LOL : roller :: roller :: roller :
Staro 20.09.2006., 01:04   #14
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
nasa?maximalno pce ovo nejde ni u blizinu nase
blup
Staro 22.09.2006., 00:19   #15
panaso
panaso's Avatar
Lokacija: split
Postovi: 119
Moram skinut cijenu konfiguracije šta mislite koji procesor da odaberem
OPTERON 246 2GHZ S940 1MB 800FSB BULK $129.00 oko 800 kn OSA246CEP5AU AMD OPTERON 246 OSA246CEP5AU
OPTERON 246 2GHZ S940 1MB 1000FSB BULK $150.00
OPTERON 248 2.2GHZ S940 1MB 800FSB BULK -$159.00 OSA248CEP5AL AMD OPTERON OSA248CEP5AL
OPTERON 244 1.8 GHZ DP S940 1MB 800FSB -$125.00
A isto neko je na forumu pitao za singl Opteron
OPTERON 144 1.8GHZ S940 1MB 800FSB BULK - IN STOCK 74 PCS.
manufactured by AMD
$99.00
OPTERON 146 2.0GHZ S940 1MB 800FSB BULK - IN STOCK 109 PCS.
manufactured by AMD
$109.00
OSA146CEP5AT AMD Opteron Processor Model 146 Product Type : Server Processor Processor Type : AMD Opteron Clock Speed : 2.0 GHz Cache Memory : L1 - 128KBL2 - 1MB Compatible Slots : Socket 940 Processor Core : Stepping CG Manufa
Memorija Dell X1562 Dell DDR2 Memory 1GB Speed : PC2-3200 Capacity : 1GB Registered/Unbuffered : Registered Ecc/Non-Ecc : ECC Number of Pins : 240 Form Factor : DIMM cl3 --109 Us$
ili
345113-551 HP HEWLETT PACKARD COMPAQ 345113-551 HYS72T128000HR-5-A cl3 109 Us $
Staro 22.09.2006., 17:53   #16
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,822
koja konfa,valda za potrebe testiranja Super PI-a ispod(1M) 10sec:burn:
Staro 22.09.2006., 18:37   #17
bozzomfeeder
bozzomfeeder's Avatar
Lokacija: Sinj
Postovi: 1,080
što će ti ovo za statičke proračune,CAD etc...Oćeš se igrati s proračunima?
Imaš zato profi kartice aka Wildcat,Matrox...
bozzomfeeder je offline   Reply With Quote
Staro 06.10.2006., 10:26   #18
panaso
panaso's Avatar
Lokacija: split
Postovi: 119
Konfa je stigla dva dana sam je sastavljao zezala memorija na kraju je ušla no name memorija stroj je pretežak tribaju dvojica za nosit.Benchmark ne pokazuje neke bijesne rezultate u radu sa memorijom.Ali windowsi se dižu u par sekundi,programi se otvaraju u sekundi.Stroj je strašno bučan normalno ima 16 ventova.
Znači iako mi niste ništa pomogli hvala vam
