#1 | ||
Postovi: 7,568
Radeon X1950Pro i X1950XTX
Članak: 1, 2 Izvor: HKEPC |
Postovi: 278
napokon malo dinamičniji/močniji izgled: CoolRamb
GPU/CPU Freak
Postovi: 1,606
konačno pravi x1900gt...(ne odrezani r580) |
#5 | ||
Postovi: 7,568
Radeon X1950XT
EDIT: Dodatak Citiraj:
Zadnje izmijenjeno od: McG. 04.08.2006. u 15:12. |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Kaj veli dobri stari Fudo-da li se znaju neke cijene već? |
Postovi: 7,568
Navodno da bu X1950XT koštal ispod $400. Kolko točno, nije spomenuto. |
Postovi: 7,568
DailyTech has received early benchmarks of ATi's upcoming Radeon X1950XTX and X1950 CrossFire graphics cards. ATi’s upcoming Radeon X1950XTX and X1950 CrossFire is expected to make its debut on August 23rd. Specifications for the Radeon X1950XTX and X1950 CrossFire are finalized with a 650 MHz core clock and 2 GHz effective memory clock. The core clock is unchanged from the previous Radeon X1900XTX while memory clock receives a hefty 550 MHz boost. This time around the Radeon X1950XTX and X1950 CrossFire are equipped with 90nm Samsung GDDR4 memory. The benchmarks compare ATi’s Radeon X1950XT in CrossFire against NVIDIA’s Quad SLi. The test setup used for NVIDIA’s Quad SLI is a Dell XPS 700 system equipped with an Intel Core 2 Extreme X6800, 1GB of DDR2-800 memory and two GeForce 7950GX2 graphics cards for four total GPUs. Članak Izvor: DailyTech |
pwner sa stilom
Lokacija: soba
Postovi: 200
to su igracke za malu djecu i Americke bogatase koji si mogu priustit, nemaju svrhe vise sa tim karticama, mene to vec zivcira, ja tu stedim za pisljivu 7300GT a oni vec deru po gf 7950xtžnj i radeonkama 79530žnj ma sve je to : stoopid ja Oblivion vrtim sve na high na svojoj grafi bez beda na dobroj rezi, ne moram igrat na 1600x...
mind of a psychopath killer, blood spiller, mentality much iller |
#10 | |
Postovi: 278
GPU/CPU Freak
#11 | |
pwner sa stilom
Lokacija: soba
Postovi: 200
Postovi: 7,568
X1950XTX Preview
The main difference between the X1950XTX and the X1900XTX lies in the faster Memory clock speed of the GDDR4 Memory used on the X1950XTX. Memory bandwidth improves by about 33% from 750MHz to 1000MHz, according to clock speeds. The cooler is fully copper throughout, including the fins. There is a heat pipe extended from the copper base to aid and speed up heat transfer over to the fins. The X1950XTX is 24% faster than the X1900XTX in 3DMark 05 and 33% faster in 3DMark 06. However, compared against the 7950GX2, the X1950XTX is 11% slower in 3DMark 05 and 20% slower in 3DMark 06. If 3D Mark is your cup of tea, the X1950XTX may not look as appealing as the 7950GX2. Overall, the X1950XTX is about 20% faster than the 7950GX2 at 1600x1200 with 16xAF and no AA. Even with 4xAA turned on, the X1950XTX is still the winner. Članak Izvor: VR-Zone Zadnje izmijenjeno od: McG. 12.08.2006. u 19:39. |
dr. sc. tech. dipl. ing.
Lokacija: Rijeka-Opatija
Postovi: 3,185
khm..jel samo meni nestao članak ili svima? ![]()
Pouzdan i pošten trgovac! (ima još puno novijih primjera, nisam ni pratio jel me još tko stavljao u temu.. slobodno pretražite novije postove na temi) StarCitizen refferal code: |
#15 | |
Postovi: 1,606
kažu da su bili "zamoljeni" da to učine... ![]() |
#16 | |
Super Moderators
Postovi: 17,485
Mislim da se radilo o 05 marku.
#17 | |
Postovi: 1,606
no, kažu na vrzoneu da bi se launch date mogao protegnuti do 14.09. |
#18 | |
Super Moderators
Postovi: 17,485
Navodno je Sapphire trebao sniziti GT na 230$
#19 | |
pwner sa stilom
Lokacija: soba
Postovi: 200
#20 |
Postovi: 7,568
Editiral sam post o X1950XTX Preview-u. Link na članak radi...pitanje kak dugo. ![]() |
#21 |
Postovi: 7,568
ATi is set to introduce its new fall graphics card refresh in the form of the Radeon X1950XTX, Radeon X1950 CrossFire and Radeon X1900XT 256MB tomorrow, August 23rd, 2006. The new Radeon X1950 series cards will have 650 MHz core clocks as the previous X1900XTX graphics cards. Memory has been upgraded to GDDR4 clocked at 2 GHz instead of the previous 1.45 GHz on the Radeon X1900XTX. ATi’s Radeon X1900XT 256MB will also launch the same day and fill the void between the Radeon X1900GT and Radeon X1900XT 512MB. All three new Radeon cards will have the same 48-pixel shaders as previous X1900 cards. The new cards are also fully HDCP compliant too. ATi has also performed internal testing of single card performance of the X1950XTX and shows minor improvements over the Radeon X1900XT. Izvor: DailyTech |
#22 |
Pečurka
Lokacija: U blizini Osijeka
Postovi: 1,294
Na te interne testove mogu reći samo HA HA
ECS Z77H2-A2X Deluxe I5 3350P G-Skill 16 GB DDR3 2133MHz Gainward Phantom GTX760 250 GB Samsung Evo Basic SSD XFX XTR 650W Silencio 650 |
#23 |
Datum registracije: Dec 2003
Lokacija: Sarajevo
Postovi: 62
Hocel od tih grafulja biti sta za AGP ![]() |
#27 |
Čiča s tamića
Lokacija: Prezid
Postovi: 326
moj komp no2: Intel Pentium 4 Prescott 2.8GHz @ 3.4GHz, 1GB RAM 400 MHz @ 450 MHz, ASUS P4S800, Club 3D 7600GS AGP @ 470/450, 80GB WDC , 400W MS Industrial moj komp3: Intel Pentium 3 800MHz, 20GB HP HDD, 256 MB SDRAM, 200W CODEGEN PS, NvIdia TNT RIVA 32, MBO:MS-6309 LITE |
#30 |
Čiča s tamića
Lokacija: Prezid
Postovi: 326
X1950XTX : nuts : : nuts :
