Staro 26.05.2006., 11:39   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Radeon Omega Drivers 3.8.252 (Cat 6.5)
Well, first I would like to apologize to all my fans, I was taking a short recess from the Internet to take care of real life issues with my family, heck, even my WoW time got compromised, so that's why I didn't released a 6.4 version of the Radeon Omega Drivers. In the end I decided to skip the 6.4 and just wait for the 6.5 official drivers to be released to start working on the Omega Drivers again.
Also, I finally decided to upgrade my technologically impaired PC for something that will last me a little while (wife has not seen the new bank balance yet, so I expect WWIII when it arrives at the end of the month), the new specs are in the ABOUT section if anyone is interested.
So, as you may have guessed, the new Omega Drivers based on the Catalyst 6.5 are ready!
Go to the ATI Radeon section and take a look at the Readme while downloading so you know the latest changes, additions to this set and some important notes.
Enjoy!
[*] Based on the Catalyst 6.5 Official drivers.
[*] Some resolutions where not showing for some reason, so I re-made the code for them, now every available resolution for your monitor should show up (as long as you have the proper Monitor INF installed).
[+] Added support for x1k Mobility series and some yet unreleased desktop cards.
[*] Updated the integrated Control Panel to v6.14.10.5183
Known Issues:
1) Some of the settings for both D3D & OGL will not be synchronized between ATT and the normal ATI CP, you must only use one of them to make changes, the best option is to use ATT since the ATI CP does not support changes to AI and in order to use the advanced D3D/OGL features. Changes made in ATT will work on games and such but the changes will not be reflected in the normal ATI CP since ATI stores the registry values that the CP reads separate from the actual values in the registry.
Important Info:
Since these drivers include a non-standard version of ATT, I would recommend that if you have any previous version of ATT installed, please uninstall it before installing these drivers, not doing so may cause unknown problems.
What's new for ATI Tray Tools?
1.0.5.880
[F] Fixed bug with auto fan control on R5xx boards (X1600/X1800/X1900)
[*] Updated injection code to allow to use custom made (fake) d3d dll files.
[F] Fixed bug with loading color profile using hot keys
http://www.omegadrivers.net/
Staro 26.05.2006., 11:41   #2
Jelc
Super Moderators
Postovi: 17,485
Nekima prijavljuje pri instalu "Setup cannot find file atiicdxx.ini" tako da bi bilo pametno pričekati malo da se vidi da li je neka greška...
Staro 26.05.2006., 12:47   #3
Mailman
Mailman's Avatar
Postovi: 1,606
Autor Jelc
Well, the missing file was a mistake in my part (the rush), sorry about that guys, is a configuration file for the integrated CP, so it doesn't affect the drivers AT ALL, just in case I fixed it, added the file again to the installer and re-uploaded it.
If you want the new file please re-download from the mirrors on my site, those already have the updated file available.
Thanks again for your support and sorry for the inconvenience.
izgleda da je ispravio..
čovjek je kupio XT i flešnuo je u XTX
Mailman je offline   Reply With Quote
Staro 26.05.2006., 15:15   #4
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Jeli netko probao ovaj set da mozes komentirati o njemu?
G0RKI je offline   Reply With Quote
Staro 26.05.2006., 15:38   #5
Jelc
Super Moderators
Postovi: 17,485
Ja nisam probao.
Jer mi je pun k***c drivera...instaliram 6.3 Chuch drivere za Oblivion-navečer izađu novi za 6.5
Pa briši stare, stavljaj nove...pričekat ću dan-dva da vidim reakcije prvo.
Staro 26.05.2006., 15:45   #6
piNheaD
piNheaD's Avatar
Lokacija: Senj
Postovi: 636
Malo OT...ko voli control panel evo ATi Catalyst 6.5 with Control Panel
http://www.ngohq.com/showthread.php?t=6306
Suck Satan's cock
piNheaD je offline   Reply With Quote
Staro 26.05.2006., 17:11   #7
Jelc
Super Moderators
Postovi: 17,485
Autor piNheaD
http://forum.pcekspert.com/showthread.php?t=39922
Staro 26.05.2006., 18:45   #8
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 894
rade dobro,samo i dalje nema ful podršku za 1900 (dump video bios,overclocking...) :mad:
MSI B450M pro-m2 max-ryzen 7 5800xt-nvidia 5060 ti - Asus rog swift PG278Q
damir1 je offline   Reply With Quote
Staro 27.05.2006., 03:28   #9
Ozy
Spužva Bob Skockani.. :XD
Ozy's Avatar
Postovi: 1,685
Imam Omege 6.3,rade dobro,i fakat mi se neda mijenjat drivere ko čarape,pa i češće...
Athlon64 X2 5400BE Brisbane @3000Mhz + KATANA 2 + AirTunel@2x Xilence 120mm
Gigabyte GA-MA78G-DS3H @F4
Mushkin Redline @1000Mhz 5-5-5
XFX 9600GSO @680/1700 || 2000Mhz
Seagate Gonzales 250GB & 320GB && Spinpoint F1 500GB
Coolermaster Elite Power RS460; Sharkoon Silvation; LG GH22NP20/LG GH20NS10/Pioneer DVR107D/Pioneer 216DBK/ Samsung SH-S223F; Logitech MX518; Philips 190P7ES 19" LCD
Ozy je offline   Reply With Quote
Staro 27.05.2006., 12:18   #10
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 894
Ati jednom mjesečno (ko ja sex ) ,ako koristiš omegu zna biti i rijeđe(evo 6.4 preskočio npr.) tako daaaaa-gadno Ti noge smrde : evil :
Staro 27.05.2006., 21:24   #11
Ozy
Ozy's Avatar
Postovi: 1,685
I šta tome fali... Zato sam bar sad od proljeća do jeseni bos,pa dakle ne mijenjam čarape nikako...
Staro 28.05.2006., 09:38   #12
vjekson
vjekson's Avatar
Lokacija: osijek
Postovi: 336
omega 6.5
Ati x1600pro AGP-Stavio sam nove omega drv. i rade sasvim ok,ali ni u njima ni u verzijama prije nisam uspio uključiti opciju overclocinga u ATT.Do sada nije radilo podešavanje vent.i temp.,a sa ovim drv.sve radi jedino overclo. ne radi,Kod instalacije te pita da li želiš isključiti opciju overc.zbog kompatibilnosti sa programima ,a ja sam stisao NE i to je trebalo uključiti occ,ali i dalje ne radi!
Da li je još netko imao sličnih problema?Naručito sa X1x00 serijom!
P.S.:Sa zadnjim beta ati tools sve radi ok,ali oni nemaju opcije za podešavanje slike pa bih si ja ostavio ATT.
vjekson je offline   Reply With Quote
Staro 28.05.2006., 12:35   #13
Jelc
Super Moderators
Postovi: 17,485
"Overclocking for X1300/X1600/X1800/X1900 disabled in this release due to lack of information and without hardware sample in my laboratory."
Pa odkad je izašla Xxxx serija ATT nema podršku za overclock istih...samo kontrola fana i temp. monitoring.
Staro 29.05.2006., 15:21   #14
Desperados
Wanted Death or live
Desperados's Avatar
Lokacija: Unimatrix 001
Postovi: 120
Ja ostajem na 6.3 rade dobro i stabilno i to je to, svi noviji driveri su ionak orjentirani na x1xxx serije a za ove stare kao moja i stariji driveri rade ok
Desperados je offline   Reply With Quote
Staro 29.05.2006., 16:38   #15
Ozy
Ozy's Avatar
Postovi: 1,685
Desperados...ista nam grafa,isti clockovi i iste Omege...
Staro 30.05.2006., 12:49   #16
Desperados
Desperados's Avatar
Postovi: 120
Autor Ozy
Šteta mi ju je mijenjati jos se dobro drzi a i nece to nitko svi su zapel za sm3.0
btw. ide ona jos koji Mhz ali nema potrebe a i za r423 chip to je super klok
Staro 01.06.2006., 14:13   #17
weedos
Lokacija: Lokacija
Postovi: 210
izgleda da je dosta ljudi kupilo tu karticu od vranoga1
weedos je offline   Reply With Quote
Staro 01.06.2006., 14:17   #18
Desperados
Desperados's Avatar
Postovi: 120
Autor weedos
Ima nas nekolicina
Staro 02.06.2006., 19:53   #19
4444josip4444
4444josip4444's Avatar
Datum registracije: Sep 2004
Lokacija: VG
Postovi: 846
instalirao sam tu omega na Catalyst 6.5 al nigdje nevidim za overclock....
4444josip4444 je offline   Reply With Quote
Staro 02.06.2006., 21:28   #20
Postovi: 34,058
Meni je malo pomogao - kada sam stavio originalne drivere s cd-a koji je došao s grafom, kod dizanja obavezno mi se pojavio prozorčić u kojem je pisalo nešto o nekoj greški. Od kada sam stavio ovu verziju, prozorčića više nema. : goood :
Staro 02.06.2006., 22:25   #21
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Autor coconut
Da zato sta omega koristi klasicni Control panel a ti si instalirao drajvere sa cd ukljucujuci catalyst control centar i pri tome zaboravija intalirat .net aplikaciju..(pretpostavljam) otud taj magični prozorčić!
Staro 03.06.2006., 09:01   #22
Postovi: 34,058
Imao sam ja već instaliran .Net 2.0, što su driveri i 'vidjeli' pa mi nisu ponudili instalaciju .Net 1.1 sa cd-a.
Staro 03.06.2006., 11:37   #23
Jelc
Super Moderators
Postovi: 17,485
Known Issues:
Important Info:
Staro 16.06.2006., 01:32   #24
frANZi
Dr. Gonzo
frANZi's Avatar
Postovi: 958
Da ne otvaram novi thread, evo ovjde ću.
Dakle, imam problema s instalacijom Omega drivera.
Naime, obrisao sam Display Drivers iz Add/Remove i sve vezano uz catalyste (control c, hydravision i slične gluposti). Restart sistema, ulazak u safe mod, pokretanje Driver Cleanera, odvrtio Cab Cleaner, odvrtio clean s izabranim "ATI" filterom, pobrisao sve iz recycle bina (iako se ništa novo nije pojavilo?). Restartao, ušao normalno u windoze i oni su mi sami instalirali driver za grafu, nikako nisam mogao to prekinuti. Nakon toga sam ja pokrenuo instalaciju omega, sve instalirao, restart i... BSOD! U smislu da je hardware krivo instaliran i da treba otići u safe mode i tamo srediti stvari.
Kada bih drivere, nakon što sam pobrisao stare s driver cleanerom i restartao, instalirao iz safe moda, u sljedećem restartu bi opet windowsi instalirali svoje drivere (valjda preko omega drivera). Tada ne bih mogao ući u control panel koji su stvorili omega driver (shortcut ima krivu putanju), a u device manageru bi verzija drivera bila 6.14.xxx (znači Catalyst).
U čemu je problem?
P.S.: pratio sam postupak objašnjen na ovom linku
frANZi je offline   Reply With Quote
Staro 16.06.2006., 01:44   #25
Postovi: 7,568
Probaj s ovim programom počistiti....možda pomogne. Moreš i s ovim probati.
Staro 16.06.2006., 01:52   #26
Razer
Razer's Avatar
Postovi: 11,642
Sruši Windowse i instaliraj WarCats drivere i riješen problem
Staro 16.06.2006., 01:59   #27
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Autor R@Z3R
LOL koja ispomoc...
frANZi ima jos jedna stvar sta je dobro napravit a nije navedena u postu...u safe modu (kada si vec prethodno maknu drivere) ajde Devise manager i tamo Uninstalaj display adaptere i tek onda pocni rad sa driver cleanerom kako vec jesi...
Staro 16.06.2006., 14:09   #28
Ozy
Ozy's Avatar
Postovi: 1,685
Nisi trebao brisati display driver,nego samo CCC ako si imao i onaj Control Panel;a display driver se ostavlja
Onda se na njega instalira Omega...
Staro 16.06.2006., 14:14   #29
frANZi
Dr. Gonzo
frANZi's Avatar
Postovi: 958
Ajde jel može neko objasniti točan postupak instalacije. Jel se trebaju omega driveri instalirati u safe modu ili u običnom, jel se treba brisati s driver cleanerom...
Staro 16.06.2006., 14:18   #30
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
frANZi..nemoj komplicirat stvari kad nije potriba...drajvere uvik stavljas u nonsafe modu a za sigurno micanje nako sat si ih ukonija u istome maknes ih opet u safe modu da ne ostanu repovi tu ti dobro dode driver cleaner...
