Staro 30.04.2006., 09:37   #1
Quake
Postovi: 177
3200+ za 3800+
Da li mi se isplati mijenjati 3200+ Venice za 3800+ Newcastle s nadoplatom?Ovaj 3800+ nema sse3,koliko on utječe na performanse i za šta on uopće služi?
Quake je offline   Reply With Quote
Staro 30.04.2006., 09:49   #2
baterija
baterija's Avatar
Lokacija: ̣
Postovi: 1,019
đizs,kaj si tolko zapeo za taj sse3.To ti je skup instrukcija koje
A 3800+ ima MMX +,3DNOW +,SSE ,SSE2, x86-64
SSE3, also known by its Intel code name Prescott New Instructions (PNI), is the third iteration of the SSE instruction set for the IA-32 architecture. Intel introduced SSE3 in early 2004 with the Prescott revision of their Pentium 4 CPU. In April 2005, AMD introduced a subset of SSE3 in revision E (Venice and San Diego) of their Athlon 64 CPUs. The earlier SIMD instruction sets on the x86 platform, from oldest to newest, are MMX, 3DNow! (developed by AMD), SSE and SSE2.
Contents
Changes
The most notable change is the capability to work horizontally in a register, as opposed to the more or less strictly vertical operation of all previous SSE instructions. More specifically, instructions to add and subtract the multiple values stored within a single register have been added. These instructions simplify the implementation of a number of DSP and 3D operations. There is also a new instruction to convert floating point values to integers without having to change the global rounding mode, thus avoiding costly pipeline stalls. Finally, the extension adds LDDQU, an alternative misaligned integer vector load that has better performance on NetBurst architectures for loads that cross cacheline boundaries.
CPUs with SSE3
* AMD:
o Athlon 64 (since Venice Stepping E3 and San Diego Stepping E4)
o Athlon 64 X2
o Athlon 64 FX (since San Diego Stepping E4)
o Opteron (since Stepping E4)
o Sempron (since Palermo Stepping E3)
o Turion 64
* Intel:
o Celeron D
o Pentium 4 (since Prescott)
o Pentium D
o Intel Core
o Xeon (since Nocona)
* VIA/Centaur:
o C7
* Transmeta
o Efficeon TM88xx (NOT Model Numbers TM86xx)
New Instructions
Common Instructions
Arithmetic
* ADDSUBPD - ( Add-Subtract-Packed-Double )
o Input - { A0, A1 }, { B0, B1 }
o Output - { A0 - B0, A1 + B1 }
* ADDSUBPS - ( Add-Subtract-Packed-Single )
o Input: { A0, A1, A2, A3 }, { B0, B1, B2, B3 }
o Output: { A0 - B0, A1 + B1, A2 - B2, A3 + B3 }
AOS ( Array Of Structures )
* HADDPD - ( Horizontal-Add-Packed-Double )
o Input: { A0, A1 }, { B0, B1 }
o Output: { B0 + B1, A0 + A1 }
* HADDPS ( Horizontal-Add-Packed-Single )
o Output: { B0 + B1, B2 + B3, A0 + A1, A2 + A3 }
* HSUBPD - ( Horizontal-Subtract-Packed-Double )
o Output: { A0 - A1, B0 - B1 }
* HSUBPS - ( Horizontal-Subtract-Packed-Single )
o Output: { A0 - A1, A2 - A3, B0 - B1, B2 - B3 }
* LDDQU - As stated above, this is an alternative misaligned integer vector load. It can be helpful for video compression tasks.
* MOVDDUP, MOVSHDUP, MOVSLDUP - These are also used for complex numbers, and can be helpful for wave calculation like sound.
* FISTTP - Like the older x87 FISTP instruction, but ignores the floating point control register's rounding mode settings and uses the "chop" (truncate) mode instead. Allows omission of the expensive loading and re-loading of the control register in languages such as C where float-to-int conversion requires truncate behaviour by standard.
Intel Instructions
* MONITOR, MWAIT - These optimize multi-threaded applications, giving processors with Hyper-Threading better performance.
baterija je offline   Reply With Quote
Staro 30.04.2006., 10:37   #3
nicko
Postovi: 4,190
ja ne bi mjenjao...venicea lako kloknes za 400mhz i imas 3800+
nicko je offline   Reply With Quote
Staro 30.04.2006., 11:40   #4
Quake
Postovi: 177
Ma nisam zapeo,samo me zanima za šta služi i to
@baterija:javim ti se onda još
Čuo sam da aplikacije najviše profitiraju od sse3,zato pitam.Je li to istina ili ne?
Staro 30.04.2006., 11:55   #5
Wolverine
Wolverine's Avatar
Postovi: 12,425
ja se nebi mjenjao samo zato kaj je NewCastle a to su najlošije s939 jezgre! A taj E3 Venice ide ziher i preko takta tog 3800+
@baterija
dobar copy/paste ali ti mu još nisi zdravo seljački objasnio ćemu to služi
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 30.04.2006., 12:12   #6
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
A kakva su vam misljenja o NewCastle jezgrama u s.754 procevima?
Milentije je online   Reply With Quote
Staro 30.04.2006., 15:21   #7
nicko
Postovi: 4,190
Autor Quake
samo neke, koje koriste te instrukcije, a takvih nema mnogo...
Staro 01.05.2006., 22:54   #8
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
ne isplati se mjenjat
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 01.05.2006., 23:08   #9
OveRkiLL
Registered Abuser
OveRkiLL's Avatar
Postovi: 590
ne valja ti to, da je winchester jezgra onda još možda, ali ovak ne. newcastle je 130nm, a venice i winchester 90nm.
AMD Ryzen 7700X + Noctua NH-D15
Asus X670 Prime
2x8GB Kingston Fury Beast 6000MHz CL40
XFX RX6800 16GB Qick 319
Kingston NV2 250GB + Crucial P5+ 1TB + Seagate 2TB HDD
EVGA 650W SuperNOVA GQ, 80+ Gold
Fractal Design 7 Compact
23.8" AOC 24G2SPU 165Hz
Windows 10 x64
Logitech G402
Razer Cynosa V2
OveRkiLL je offline   Reply With Quote
Staro 01.05.2006., 23:18   #10
Quake
Postovi: 177
Ma odustao sam od toga
Staro 11.05.2006., 19:52   #11
maX
maX's Avatar
Postovi: 7,326
Pametno
Staro 17.05.2006., 19:17   #12
iveumag
zippo61_junior
iveumag's Avatar
Postovi: 1,296
Dobro si postupio
iveumag je offline   Reply With Quote
