Staro 22.05.2025., 18:30   #301
Dottore
Dottore's Avatar
Postovi: 7,750
Bit će zanimljivo hoće li ti NIC-ovi biti jeftiniji ili učinkovitiji od Marvell Aquantia AQC113C.
Mene posebno veseli 10Gbe podrška PCIe 4.0 x1 - a pritom sumnjam na propusnost
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 22.05.2025., 20:22   #302
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,724
MMA
Staro 22.05.2025., 20:27   #303
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,396
A jel ti sadasnji ima premalo portova pa gledas taj veci ili bas trebas 4 SFP+ porta ?
Staro 22.05.2025., 20:35   #304
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,724
Ne trebam 4, dosta mi 1, poželjno 2.
Sada su mi dva kata povezana UTPom, 10G, ali pošto ide kabel po kanalicama po haustoru, ideja mi je staviti nit :-) Za to mi treba jedan, a drugi za novi NAS, ali nije neophodno. NAS može i na UTP, radi se o 2-3 metra :-D
MMA
Staro 22.05.2025., 20:45   #305
Lewis
Freelancer
Lewis's Avatar
Postovi: 5,396
Ako ti nisu presudni svi RJ45 portovi da budu 10Gbit imam ja UniFi USW Enterprise PoE 8 (8*2.5 PoE i 2*10Gbit SFP+ portovi) - dva komada koja idu u prodaju .
Staro 22.05.2025., 21:00   #306
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,724
A trebaju mi bar 2x 10Gb RJ45. :-(
MMA
Staro 23.05.2025., 15:40   #307
Postovi: 23,756
Samo jedan hint / mišljenje u vezi TRENDnet TEG-S762,
rekao bih da je bolje naći / uzeti V2 verziju,
prepoznate ga po konektoru napajanja naprijed livo (V1 naprijed desno),
a čini se bolje / pametnije riješen unutra,
nekakav review > https://www.enostech.com/trendnet-te...switch-review/
Staro 30.12.2025., 12:49   #308
Postovi: 8,282
Cheap-ish 10G realtek rj45 kartica
https://www.servethehome.com/cheap-1...27-nic-review/
Dobra je stvar što se radi o PCIe Gen4 x1 kartici što je ujedino i mana ako se radi o starijim sistemima, jer je Gen3 throuput cca 8gbe.
https://www.aliexpress.com/item/1005010031423506.html
Zadnje izmijenjeno od: Pupo. 30.12.2025. u 16:06.
Staro 30.12.2025., 14:57   #309
Dottore
Dottore's Avatar
Postovi: 7,750
To je već nešto što čekam.
Napokon dočekao za PCIe 4.0×1
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 30.12.2025., 18:38   #310
darkydark
N0teb00k n00b
darkydark's Avatar
Lokacija: Zagreb/Koprivnica
Postovi: 2,127
Autor Pupo Pregled postova
Taman sve tajnije u labu opskrbio sa 2x2.5gbe i sad ovo - here we go again...
Sent from my 2201116SG using Tapatalk
1TB A2000, 2TB KC3000
Linđa
1x 150GB Intel S3520, 3x2TB Crucial MX500, 5x12TB Toshiba MG07ACA12TE
Truenas Scale
Staro 04.02.2026., 20:07   #311
Postovi: 8,282
Još malo robe iz kineskog dućana
Not bad za 250€
https://www.aliexpress.com/item/1005007668390218.html
Staro 11.03.2026., 18:30   #312
Nikox
Nikox's Avatar
Datum registracije: Aug 2017
Postovi: 1,278
I ja morao preći sa 2.5 na 10GBps
Staro 11.03.2026., 19:27   #313
Postovi: 8,282
Ahh, Vž vremena i EcoNet <3
Mi smo na njihovom wifiu bili prije 12 godina, možda i prije. Korent lik
Staro 18.03.2026., 10:06   #314
X-Man
Datum registracije: Apr 2016
Postovi: 13
Autor Nikox Pregled postova
Pozdrav!
Koje uređaje si nabavio da bi dobio 10 Gbit propusnosti u svojoj kućnoj mreži?
X-Man je offline   Reply With Quote
Staro 18.03.2026., 19:19   #315
Nikox
Nikox's Avatar
Postovi: 1,278
Autor X-Man Pregled postova
Pozdrav!
10GB swicth SFP+
ili ako ideš žično onda je bolje uzeti 10GB rj45 swicth samo su preskupi, a koliko portova ovisi koliko misliš granati. Za PC kolega Pupo je u gore jednom postu već napisao ako hoćeš žični onda kartica sa rj45 ja imam kartice sa SFP+ Za laptop imam USB C to 5Gbps Ethernet Adapter RJ45 USB.
Staro 18.03.2026., 22:04   #316
Postovi: 8,282
Pozdrav!
Ovisi koliko imaš uređaja. Prođi malo temom, svašta je spomenuto, od brand name switcheva do (ultra)jeftinih kineza.
Staro 08.04.2026., 09:24   #317
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,016
10GB swicth SFP+
I nisu više toliko skupi koliko su donedavno bili:
https://www.amazon.de/SODOLA-5-Port-.../dp/B0DLGMS5Q8
Staro 08.04.2026., 11:09   #318
Nikox
Nikox's Avatar
Postovi: 1,278
I to je skupo prema sfp switch ali cijena i da prođe jako se griju rj45 10GB switch.
Staro 08.04.2026., 16:35   #319
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,016
A pošto je 20m kabel za SFP switch, a pošto za RJ45?
Staro 08.04.2026., 17:27   #320
Matta
El Mattador
Matta's Avatar
Lokacija: <->
Postovi: 1,973
Nije istina da se jako griju, pogotovo sa novijim PHY-ovima. Troše oko 2W po portu.
Nije ni to neka velika lova, cca 15-20€ za 20m.
Nije samo stvar potrošnje ili cijene. Ako se radi o postojećoj GBase-T mreži (bakar), onda nema dileme - ide se na RJ45 jer nema alternative. A da je SFP+ bolji izbor na dulje staze - je.
Matta je offline   Reply With Quote
Staro 08.04.2026., 18:36   #321
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,848
OM3 LC-LC - ~13€ (https://www.amazon.de/-/en/Digitus-A.../dp/B00IE7NX78)
RJ45 CAT6 - 16€ (https://www.amazon.de/-/en/DIGITUS-C...dp/B00CU1CM3A/)
Jedan moze gurati 100G na 70m, drugi je uWu DaDdY smeta mi crosstalk na 40+ metara 10G...
Programer
Staro 08.04.2026., 20:22   #322
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,016
Autor Bubba Pregled postova
A kako to uguraš u SFP switch?
Staro 08.04.2026., 20:31   #323
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,848
Najcesce rukom.
Ako pokusavas biti dovitljiv pa cvilis jer postoji stavka transceivera, FS ih prodaje od 25$+, a cak se i kod nas na Njuskalu daju naci od 5€ pa navise, sto stvarno nije drama naspram svih benefita optike.
Programer
Staro 08.04.2026., 20:37   #324
Matta
El Mattador
Matta's Avatar
Lokacija: <->
Postovi: 1,973
Još ako uzmeš LC-LC OS2 za par eura više, možeš gurati 400G+ na 10km.
A osim ovoga što je Bubba već naveo, na njemačkom ebayu imas 100G transcievera za siću a na americkom ih skoro pa dijele mukte. O 40G transcieverima da ne govorim.
Staro 08.04.2026., 20:44   #325
Nikox
Nikox's Avatar
Postovi: 1,278
20m optičkog kabla platio 8.6€ a rj45 Cat6a najniže što sam našao za 20m je 13.76 tako da je optička komplet instalacija jeftinija nego bakar za 10GB mrežu.
Staro 08.04.2026., 20:47   #326
Nikox
Nikox's Avatar
Postovi: 1,278
Matta
Daj neki link tih sa novijim PHY-ovima
Staro 08.04.2026., 20:58   #327
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,016
Najcesce rukom.
Izostaviš dio koji košta više nego sam kabel i onda sam ja dovitljiv
Staro 08.04.2026., 21:24   #328
Matta
El Mattador
Matta's Avatar
Lokacija: <->
Postovi: 1,973
Matta
ServeTheHome ima odličan popis svih 10Gbe switcheva sa karakteristikama. 4-portni Mikrotik CRS304-4XG-IN se može naći već za 150€. Dosta jeftinih "glupih" switcheva (bez managementa) je dobavljivo i na amazon.de.
Staro 08.04.2026., 22:35   #329
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,848
Autor Matta Pregled postova
Neka hvala, muka mi je od konfiguracije 25G da radi kako spada,
Za workstatione mi je i ovo dosta:
Code:
 ~ lspci | grep -i "ethernet"
0000:00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (3) I219-LM (rev 09)
0000:02:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
0000:d7:00.0 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
0000:d7:00.1 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
0000:d7:00.2 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
0000:d7:00.3 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
Istini za volju, tu vec dolazis u relativno rizicne probleme s razno raznim (ne)kompatibilnostima, ali uz malo istrazivanja, svakako.
Jesi, jer je SFP transceiver nepovezan sa switchem na nacin na kojeg ga zelis prikazati. Uz to, cijena mu je zanemariva.
Programer
Staro 09.04.2026., 06:43   #330
Nikox
Nikox's Avatar
Postovi: 1,278
Evo citiram šta piše za taj mikrotik
"The CRS304 features an enclosure that doubles as a robust, lightweight heat sink, eliminating the need for active cooling. This fanless design ensures silent operation, making it ideal for any environment where noise is a concern – offices, libraries, or even your bedroom homelab! The sturdy form-factor provides a premium feel, balancing comfortable weight and durability, all at an accessible price point"
Znači ako mu stave al hladnjak od pola kg to znači da se ne grije?
