Staro 17.02.2026., 23:43   #2491
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,652
Anydesk je radio kad sam zadnji put probao al' ima tome sad već... Radio je čak i na Android TV (Nvidia Shield)
Sent from my moto g stylus 5G - 2024 using Tapatalk
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 17.02.2026., 23:54   #2492
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,566
nabrzak sto sam pogledao ista prica kao teams, odnosno jos skuplje na mjesecnoj bazi. ak sam dobro vidio oko 33e mj. skroz preskupo za ovu namjenu. nisam znao da je to tak skupo.
"We all must hang together, or surly we will hang separately."
AMD Ryzen7 7800x3D+Noctua NH-D14 | MSI Tomahawk WIFI AMD B650 | 2x16GB Corsair Vengeance DDR5-6000 CL30 1,39v | SAPPHIRE Pulse RX 9070xt UV/OC | 1tb NVMe sammy 970 evo plus, 2TB Samsung 990 EVO Plus, 128gb NVMe Patriot P300, Crucial MX500 500GB, Kingston 480gb | Riotoro ENIGMA G2 850W 80 Gold | Corsair Carbide 300R modded | Win10 ENT LTSC IoT (work) + Win11 ENT LTSC IoT (gejming) | logitech g403 | ROCCAT Horde | AOC CQ27C4 + AOC C24G1 + 50" Hisense H50A6140
AMD Ryzen5 2600+Xilence Cryon M806D.B | Asus x370 Prime Pro rev1.03 (bios 6203) | GSkill Aegis 32GB (2x16) DDR4@3,2GHz | 2x Intel 545s 128GB, 1x Crucial MX500 500GB | Gigabyte GTX960 | sisa 620w | Fractal Design Focus G | Win7 x64 + Win10 ENT LTSC IoT | logitech g403 | ROCCAT SuoraFX
intel i5 2500k@4,5ghz (1,28v)+FSP Windale 4 | ASRock Z68 Ext4 Gen3 (bios 1.20) | 2x8gb DDR3 HyperX Savage, 1866mhz, 10-10-11-27,1,5V | Samsung SSD 64gb, 2x256gb SSD | iGPU | corsair vx450w | CoolerMaster Centurion 534 modded | Win7 x64
Staro 18.02.2026., 00:04   #2493
Postovi: 10,435
Rustdesk bi trebao raditi, ako dobro pamtim, a free je
Staro 18.02.2026., 00:04   #2494
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,652
Nekad je bilo čabe... Zato sam i prešao sa TeamViewer na anydesk. Nisam znao da su i oni počeli naplaćivati...
Možda Chrome desktop ili kako se već zove radi na Androidu?
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 18.02.2026., 00:07   #2495
geronimo_2
geronimo_2's Avatar
Postovi: 4,566
samo bacajte pa bum istrazival, al kolko ja vidim sve je to sad for pay. taj rust ima neki free plan, ali ga nisam skuzil jos. sutra cu kopat, mora bit neka caka.
Staro 18.02.2026., 01:06   #2496
d0X
Kostolomac
d0X's Avatar
Postovi: 1,582
Free je AnyDesk za jednostavnu kućnu uporabu. Kenja ako misli da ga poslovno zlorabiš, kao i Teamviewer.
PSN Steam
Staro 18.02.2026., 08:05   #2497
strikoo
strikoo's Avatar
Postovi: 1,058
https://rustdesk.com/docs/en/client/android/
rustdesk je opensource. mozes sam hostati i server. Pro se placa
strikoo je offline   Reply With Quote
Staro 18.02.2026., 08:27   #2498
spiderhr
spiderhr's Avatar
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,267
Za svoje potrebe sam hostam rustdesk tako da svatko tko ima ili neki mali vps ili homelab može si složiti rustdesk. Naravno u rustu se upišu podaci da se ne ide na njihov server.
Staro 18.02.2026., 08:51   #2499
geronimo_2
geronimo_2's Avatar
Postovi: 4,566
ma nista te kompliciranije postavke. kazem vam, to je za curu da se moze ocu spojit na android tablet kad on nesto zezne ili nezna napravit. znaci ako bude srece nikad da joj ne treba, znaci bilo kakva for-pay ili komplicirana opcija je off the table.
ona je u inozemstvu pa im zato to treba, da nemora ljude zivkati da pogledaju sta je covjek zeznuo.
Staro 18.02.2026., 13:10   #2500
ManuChao
ManuChao's Avatar
Datum registracije: Nov 2012
Lokacija: Hercegovina
Postovi: 12
ManuChao je offline   Reply With Quote
Staro 18.02.2026., 13:30   #2501
Postovi: 10,435
Rustdesk je free, ide se preko Rustovih relay servera i ne trebas svoj server za ovo (niti licence). Na mobu podesis fiksni ID i password. Naucis tu osobu da otvori Rust app i pokrene screen share (dva klika) pa se onda spojis na taj mob sa punom kontrolom itd... Ako osoba zna koristiti android appove, ovo je lako za savladati.
Mob i tvoj komp koji ga kontrolira ne moraju biti na istoj mrezi ili vpn-u jer ide preko relay servera.
Ja sam to davno mojima stavio na mobove ali nisam nikad jos koristio. Ovo sam upravo probao na svom mobu pa sheram
Staro 18.02.2026., 13:31   #2502
domy_os
domy_os's Avatar
Postovi: 19,058
Ima i accessibility opciju pa se aktivira duljim držanjem volume tipki, korisno ako polupa ekran.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro Jučer, 18:10   #2503
Postovi: 10,435
Ovo zvuči zanimljivo ali ne uspijevam to dobiti na Pixelu. Po defaultu kada aktiviram acessibility preko volume tipki, on samo togglea input control on/off. To mi ne pomaže. Ima neki način kako promjeniti defaultnu akciju?
Igrao sam se još malo i pojednostavio screen share proces. Kada se pokreće screen share service u Rustu onda dobijete prozor gdje odobravate sheranje ekrana i birate želite li sherati sliku samo jednog appa ili cijeli ekran/uređaj. Default je, jasno, jedan app što i nije neka sreća.
Naredba "adb shell appops set com.carriez.flutter_hbb PROJECT_MEDIA allow" overridea taj pop-up i po defaultu (samo za Rust app!) nudi share cijelog ekrana/moba - nema više pop-upa.
https://www.reddit.com/r/rustdesk/co...casting_popup/
Staro Jučer, 20:00   #2504
Darko150
Datum registracije: Jul 2017
Lokacija: Velika Gorica
Postovi: 63
Na Rustdesku nisam uspio dobiti da sa drugog mobitela pokrećem aplikacije ili bilo što radim na prvom mobitelu... vidim ekran na drugom mobitelu, ali ne mogu upravljati prvim mobitelom...
Darko150 je offline   Reply With Quote
Staro Jučer, 22:29   #2505
Postovi: 10,435
U Rust postavkama na mobu kojeg zelis kontrolirati pod share screen trebas upaliti input control kvacicu i kad pokrenes service onda imas kontrolu. Po defaultu je input control ugasen.
