#2491 |
Pink Floyd fan
Lokacija: Santa Clara, CA
Postovi: 5,668
Anydesk je radio kad sam zadnji put probao al' ima tome sad već... Radio je čak i na Android TV (Nvidia Shield) Sent from my moto g stylus 5G - 2024 using Tapatalk
#2492 |
Lokacija: Rijeka / Grobnik
Postovi: 4,581
nabrzak sto sam pogledao ista prica kao teams, odnosno jos skuplje na mjesecnoj bazi. ak sam dobro vidio oko 33e mj. skroz preskupo za ovu namjenu. nisam znao da je to tak skupo.
"We all must hang together, or surly we will hang separately." AMD Ryzen7 7800x3D+Noctua NH-D14 | MSI Tomahawk WIFI AMD B650 | 2x16GB Corsair Vengeance DDR5-6000 CL30 1,39v | SAPPHIRE Pulse RX 9070xt UV/OC | 1tb NVMe sammy 970 evo plus, 2TB Samsung 990 EVO Plus, 128gb NVMe Patriot P300, Crucial MX500 500GB, Kingston 480gb | Riotoro ENIGMA G2 850W 80 Gold | Corsair Carbide 300R modded | Win10 ENT LTSC IoT (work) + Win11 ENT LTSC IoT (gejming) | logitech g403 | ROCCAT Horde | AOC CQ27C4 + AOC C24G1 + 50" Hisense H50A6140 AMD Ryzen5 2600+Xilence Cryon M806D.B | Asus x370 Prime Pro rev1.03 (bios 6203) | GSkill Aegis 32GB (2x16) DDR4@3,2GHz | 2x Intel 545s 128GB, 1x Crucial MX500 500GB | Gigabyte GTX960 | sisa 620w | Fractal Design Focus G | Win7 x64 + Win10 ENT LTSC IoT | logitech g403 | ROCCAT SuoraFX intel i5 2500k@4,5ghz (1,28v)+FSP Windale 4 | ASRock Z68 Ext4 Gen3 (bios 1.20) | 2x8gb DDR3 HyperX Savage, 1866mhz, 10-10-11-27,1,5V | Samsung SSD 64gb, 2x256gb SSD | iGPU | corsair vx450w | CoolerMaster Centurion 534 modded | Win7 x64 |
#2494 |
Pink Floyd fan
Postovi: 5,668
Nekad je bilo čabe... Zato sam i prešao sa TeamViewer na anydesk. Nisam znao da su i oni počeli naplaćivati... Možda Chrome desktop ili kako se već zove radi na Androidu? Sent from my moto g stylus 5G - 2024 using Tapatalk
#2495 |
Postovi: 4,581
samo bacajte pa bum istrazival, al kolko ja vidim sve je to sad for pay. taj rust ima neki free plan, ali ga nisam skuzil jos. sutra cu kopat, mora bit neka caka.
#2497 | |
Postovi: 1,061
rustdesk je opensource. mozes sam hostati i server. Pro se placa |
#2498 |
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,296
Za svoje potrebe sam hostam rustdesk tako da svatko tko ima ili neki mali vps ili homelab može si složiti rustdesk. Naravno u rustu se upišu podaci da se ne ide na njihov server.
Mali Čile SAD Češka Peru |
#2499 |
Postovi: 4,581
ma nista te kompliciranije postavke. kazem vam, to je za curu da se moze ocu spojit na android tablet kad on nesto zezne ili nezna napravit. znaci ako bude srece nikad da joj ne treba, znaci bilo kakva for-pay ili komplicirana opcija je off the table. ona je u inozemstvu pa im zato to treba, da nemora ljude zivkati da pogledaju sta je covjek zeznuo.
#2500 |
Datum registracije: Nov 2012
Lokacija: Hercegovina
Postovi: 12
#2501 | |
Postovi: 10,452
Mob i tvoj komp koji ga kontrolira ne moraju biti na istoj mrezi ili vpn-u jer ide preko relay servera. Ja sam to davno mojima stavio na mobove ali nisam nikad jos koristio. Ovo sam upravo probao na svom mobu pa sheram
#2502 |
Postovi: 19,068
Ima i accessibility opciju pa se aktivira duljim držanjem volume tipki, korisno ako polupa ekran.
#2503 |
Postovi: 10,452
Ovo zvuči zanimljivo ali ne uspijevam to dobiti na Pixelu. Po defaultu kada aktiviram acessibility preko volume tipki, on samo togglea input control on/off. To mi ne pomaže. Ima neki način kako promjeniti defaultnu akciju? Igrao sam se još malo i pojednostavio screen share proces. Kada se pokreće screen share service u Rustu onda dobijete prozor gdje odobravate sheranje ekrana i birate želite li sherati sliku samo jednog appa ili cijeli ekran/uređaj. Default je, jasno, jedan app što i nije neka sreća. Naredba "adb shell appops set com.carriez.flutter_hbb PROJECT_MEDIA allow" overridea taj pop-up i po defaultu (samo za Rust app!) nudi share cijelog ekrana/moba - nema više pop-upa. https://www.reddit.com/r/rustdesk/co...casting_popup/
#2505 |
Postovi: 10,452
U Rust postavkama na mobu kojeg zelis kontrolirati pod share screen trebas upaliti input control kvacicu i kad pokrenes service onda imas kontrolu. Po defaultu je input control ugasen.
#2506 |
Lokacija: Novska
Postovi: 2,463
Starting in September 2026, Google is implementing a major "Apple-esque" security change that will significantly restrict how apps are installed on Android devices. Cini mi se da cu baciti Huawei sat. |
#2507 |
Postovi: 4,581
moze malo detalja. necu moc vise instalirat sa file-a app koji ja hocu? mogu odma bacit mob ako je tako. boktemazo sta oni nama rade.
#2509 |
Lokacija: Sesvete
Postovi: 1,296
Da, da ide se na zatvoreni sistem kaj se tiče appova. Mislim nećeš moći instalirati app koju ti napravio recimo za firmu da ti olakša posao u nekom segmentu. A kako izgleda i Win bi mogao ići prema tome ili već ide...
#2510 |
Postovi: 4,581
Ja ne znam koji je njima k, ali to zaista nema smisla. Apple me nikad nije zanimao upravo zbog tih sranja i zatvorenosti, i sad ovi idu tim putem. WTF
#2513 |
Datum registracije: Jun 2024
Lokacija: Space
Postovi: 919
Miquella is mine and mine alone. |
#2515 |
Datum registracije: Dec 2014
Lokacija: Area 51
Postovi: 277
Google Is Closing Android https://www.youtube.com/watch?v=5MZfGq5F1NU https://www.youtube.com/watch?v=7dcNcOnuRAc |
#2516 |
Prvoklasni Krkan
Postovi: 5,507
Ošo i andorid u ocat. Ja sam inače još od 2009-e što se privatnog telefona tiče na iOS-u. Ali...imam Shield, imam službeni mob, imam Retroid Pocket G2...i sve su to uređaji na androidu i najbolja stvar je bila taj sideloading bez da moram rootat/jailbreakat uređaj. OK, ovo vj važi samo za najnoviji android, ali svejedno je loše. Baš me zanima kako će ovo riješiti proizvođači ovih retro emu konzola tipa somenuti Retroid. Npr emulatori za PS2, Switch i Wii U uopće nisu na play-u. Nije ni hrpetina drugih pizdarija tipa smartube (android tv) ili Ytvanced (android mob) koji su mi fantastični. Ne bi me čudilo da ove konzole dođu rootane po defaultu i bok. A shield je ionako na prastarom ATVu i tu je sve OK...za sada. Zanima me hoće li oni ovo probat forsirati i na starije verzije androida, jer ako da, e onda je to baš baš loše. Ali dobro, vjerujem da će pametni ljudi sa internetova već nešto smisliti. |
#2517 |
Postovi: 4,581
Sve ocekivano. Godinama navlace ljude, besplatno ovo ono, bla bla. Cloud, free storage... Samo bedak je mogo mislit da ce to dovjeka. Problem je sto sad treba prava konkurencija, a takvog vjerovatno nema, jer su se pobrinuli. Evil corp.
#2518 |
Prvoklasni Krkan
Postovi: 5,507
E da, zab napomenuti, imaju navodno istu spiku kao apple. Platiš godinnju developer članarinu, pa možeš sideloadat app-ove. Mislim da je google članarina manja...za sada. EDIT: Ja sam se inače kod nV registrirao kao "dev"...trebalo mi je zbog image-a za dgrade shielda. ![]() Kod jakne je biti dev đabe. ![]() |
#2519 |
Postovi: 4,581
Od mene mogu dobit samo midd finger a ne za nekakve oblake i pretplate. Prije cu prestat koristit i microslop i zbljugl i zazdit mob u zid. Evo im jos, jer ih navodno jako ljuti: microslop, microslop, MICROSLOP.
#2520 |
Prvoklasni Krkan
Postovi: 5,507
Ne da ih navodno ljuti, nego su ugasili neki svoj discord zbog toga jer je ekipa satrala. ![]() Microsoft gets tired of “Microslop,” bans the word on its Discord, then locks the server after backlash |
