#5191 |
White Rabbit
Postovi: 5,623
Za takve prigode imam ovo...mozda pomogne: Code:
#!/bin/sh
ps -eo rss,pid,user,command | sort -rn | head -$1 | awk '{ hr[1024**2]="GB"; hr[1024]="MB";
for (x=1024**3; x>=1024; x/=1024) {
if ($1>=x) { printf ("%-6.2f %s ", $1/x, hr[x]); break }
} } { printf ("%-6s %-10s ", $2, $3) }
{ for ( x=4 ; x<=NF ; x++ ) { printf ("%s ",$x) } print ("\n") }
#5192 |
Postovi: 19,061
Koristi li netko Keu kao DHCP server (nasljednik ISC dhcpd-a)? Imam manje više defaultnu instalaciju u Dockeru, produžio sam samo lease time i dodao rezervacije. Sve to fercera, ali ne baš brzo, dugo treba da klijenti pokupe IP adrese. U logovima nema grešaka, samo ova tri warninga koja su ajmo reći normalna: Code:
2026/02/04 21:18:21,stdout,"2026-02-04 20:18:21.653 WARN [kea-dhcp4.dhcp4/1.140203944382720] DHCP4_MULTI_THREADING_INFO enabled: yes, number of threads: 4, queue size: 28 " 2026/02/04 21:18:21,stdout,2026-02-04 20:18:21.619 WARN [kea-dhcp4.dhcp4/1.140203944382720] DHCP4_RESERVATIONS_LOOKUP_FIRST_ENABLED Multi-threading is enabled and host reservations lookup is always performed first. 2026/02/04 21:18:21,stdout,2026-02-04 20:18:21.619 WARN [kea-dhcp4.dhcpsrv/1.140203944382720] DHCPSRV_MT_DISABLED_QUEUE_CONTROL disabling dhcp queue control when multi-threading is enabled.
#5193 |
Postovi: 755
Code:
~ >> ./ps.sh 77.44 MB 1043 igor /usr/lib/Xorg :1 vt1 -keeptty -noreset -auth /home/igor/.local/share/sx/xauthority 63.83 MB 1196 igor /usr/bin/node /home/igor/arch/tint2/tint2.js 44.30 MB 1214 igor termite 43.67 MB 966 root node /home/igor/arch/cron/cron.js 25.91 MB 1048 igor /usr/bin/openbox --sm-disable --startup /home/igor/arch/openbox/autostart 24.32 MB 1178 igor tint2 -c /home/igor/arch/tint2/tint2rc-top 22.93 MB 1179 igor tint2 -c /home/igor/arch/tint2/tint2rc-bottom 18.36 MB 1208 igor conky -q -c /home/igor/arch/tint2/conkyrc-tint2 13.59 MB 1177 igor conky -q -d -c /home/igor/arch/conky/conkyrc-kernel --xinerama-head 1 13.52 MB 1175 igor conky -q -d -c /home/igor/arch/conky/conkyrc-kernel --xinerama-head 0 ![]() Zadnje izmijenjeno od: Dule. 05.02.2026. u 03:54. |
#5194 | |
White Rabbit
Postovi: 5,623
Yep. Na 2 bare metal instalacije (jedna na OpenSuse, jedna na Debianu) koje opsluzuju 60-ak fizickih servera i nekoliko desktop klijentana + cca 300-njak virtualki u vcenter clusteru. Nemam zamjerki. Migrirao sam stari config sa isc-dhcpd servera na novi kontrukt, pocistio sto vise nije podrzano i to je to, nisam kemijao. Da ti se ovak nekaj ne dogada? https://forum.netgate.com/topic/1961...wer-to-queries Zadnje izmijenjeno od: tomek@vz. 05.02.2026. u 10:20. |
#5195 |
Postovi: 19,061
Ni blizu, ali svakako hvala na traženju. CPU je 0%, a RAM ispod 30 MB, watchdog nemam. Nego, dodao sam ove tri naredbe i sad šljaka normalno, čak i brže nego prosječan router. Code:
"host-reservation-identifiers": [ "hw-address" ] "match-client-id": false "reservations-out-of-pool": true Ako bude trebalo, u ovoj dokumentaciji ima još toga, dio je već bio postavljen po defaultu, dio je overkill za moj environment. https://kb.isc.org/docs/kea-performance-optimization
#5196 | |
White Rabbit
Postovi: 5,623
#5197 |
Pink Floyd fan
Lokacija: Santa Clara, CA
Postovi: 5,655
https://www.theregister.com/2026/02/..._6_19_7_named/ Sent from my moto g stylus 5G - 2024 using Tapatalk
#5198 |
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,272
Sad kad čitam tu o dokumentaciji. U čemu vodite dokumentaciju? Običan word s/ili excelom ili nešto drugo?
tomek@vz: ajd nemoj | Mali Čile SAD Češka Peru | Windows Free | Dockhttps://github.com/spidermanhr/DockApp |
#5199 | |
Postovi: 1,060
Sluzbeno sve ide u atlassian confluence (za sada) |
#5200 | |
N0teb00k n00b
Lokacija: Zagreb/Koprivnica
Postovi: 2,123
Super stvar. Sent from my 2201116SG using Tapatalk
#5201 |
Postovi: 10,437
#5202 |
White Rabbit
Postovi: 5,623
Sluzbeno? Confluence. Doma? Sve u tikvi sto i kako, rollouti su svi kroz Ansible pa mi dokumentacija ne treba, skripte su uredno dokumentirane za neke extra cickarije van svakog standarda i uma i racuna. Lozinke i ostale kripticne stvari > Keepass. |
#5203 |
Lokacija: Novska
Postovi: 2,454
#5204 |
Postovi: 8,767
#5207 | ||||
Lokacija: Sesvete
Postovi: 1,272
Sve me strah jer uskoro reinstall svih strojeva slijedi zbog sigurnosti.
#5208 |
Datum registracije: Mar 2010
Postovi: 2,068
Kad si već spomenuo GitHub, evo nešto i za ZG gradonačelnika ![]() https://github.com/ZlatanOmerovic/thompson.js |
#5209 |
Postovi: 4,781
a ovaj linux vidjeli ? https://stormos.site/# |
#5210 |
Lokacija: Sesvete
Postovi: 1,272
#5211 |
White Rabbit
Postovi: 5,623
#5212 |
Postovi: 3,568
Uuuu sjećam se tog lika, to je onaj psihički nestabilan ![]() I forkali su to čudo: https://github.com/Zeal-Operating-System/ZealOS Fora na ovom githubu na screensotu, oracle nije nikad ispravio ono Innotek gmbh ![]() |
#5213 | |
White Rabbit
Postovi: 5,623
![]() FFS! |
#5214 |
Postovi: 755
Terry Davis je imao šizofreniju i mislio je da mu Bog govori da napiše OS... i koliko god je to ludo samo po sebi, ekstremno je impresivno da jedna osoba koristeći x86 assembler kao bazu napiše svoj jezik (HolyC) i funkcionalni OS i sve što ide uz to. TempleOS je čak vrtio neke 3D igre. |
#5215 |
Datum registracije: May 2023
Lokacija: Mrkopalj
Postovi: 95
@Mario Evo ti LibreOffice log potpisivanja dokumenta. Iako mislim da si odustao od rješavanja tehničkog problema jer mi se čini da sam ignoriran nakon slanja prethodne poruke. Tools > Options > Security > Certificate Path Code:
[2026-02-14 00:51:01] [Pkcs11] [DEBUG] Log Pkcs11 initialized [2026-02-14 00:51:01] [WinSCard] [DEBUG] Log WinSCard initialized [2026-02-14 00:51:01] [Terminal] [DEBUG] Log Terminal initialized [2026-02-14 00:51:01] [Pkcs11] [DEBUG] ENTER C_GetInterface [2026-02-14 00:51:01] [Pkcs11] [DEBUG] C_GetInterface interface not found [2026-02-14 00:51:01] [Pkcs11] [DEBUG] EXIT C_GetInterface with CKR_ARGUMENTS_BAD [2026-02-14 00:51:01] [Pkcs11] [DEBUG] ENTER C_GetInterface [2026-02-14 00:51:01] [Pkcs11] [DEBUG] C_GetInterface returning interface: PKCS 11 [2026-02-14 00:51:01] [Pkcs11] [DEBUG] ENTER C_GetInterface [2026-02-14 00:51:01] [Pkcs11] [DEBUG] C_GetInterface interface not found [2026-02-14 00:51:01] [Pkcs11] [DEBUG] EXIT C_GetInterface with CKR_ARGUMENTS_BAD [2026-02-14 00:51:01] [Pkcs11] [DEBUG] ENTER C_Initialize [2026-02-14 00:51:01] [WinSCard] [DEBUG] Connected to 'Generic Smart Card Reader Interface [Smart Card Reader Interface] (XXXXXXXXXX00000000) 00 00'. _isStatusMonitored: False [2026-02-14 00:51:01] [Pkcs11] [DEBUG] EXIT C_Initialize with CKR_OK [2026-02-14 00:51:01] [Pkcs11] [DEBUG] ENTER C_GetInfo [2026-02-14 00:51:01] [Pkcs11] [DEBUG] EXIT C_GetInfo with CKR_OK [2026-02-14 00:51:01] [Pkcs11] [DEBUG] ENTER C_GetSlotList [2026-02-14 00:51:01] [Pkcs11] [DEBUG] EXIT C_GetSlotList with CKR_OK [2026-02-14 00:51:01] [Pkcs11] [DEBUG] ENTER C_GetSlotList [2026-02-14 00:51:01] [Pkcs11] [DEBUG] EXIT C_GetSlotList with CKR_OK [2026-02-14 00:51:01] [Pkcs11] [DEBUG] ENTER C_GetSlotInfo [2026-02-14 00:51:01] [Pkcs11] [DEBUG] EXIT C_GetSlotInfo with CKR_OK [2026-02-14 00:51:01] [Pkcs11] [DEBUG] ENTER C_GetTokenInfo [2026-02-14 00:51:01] [WinSCard] [DEBUG] Retrieving card. [2026-02-14 00:51:01] [WinSCard] [DEBUG] Connected to 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXx'. Protocol: T1 [2026-02-14 00:51:01] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:01] [WinSCard] [DEBUG] APDU Received (8.640763 ms). [2026-02-14 00:51:01] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:01] [WinSCard] [DEBUG] APDU Received (10.299353 ms). [2026-02-14 00:51:01] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:01] [WinSCard] [DEBUG] APDU Received (31.978646 ms). [2026-02-14 00:51:01] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:01] [WinSCard] [DEBUG] APDU Received (15.056103 ms). [2026-02-14 00:51:01] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:01] [WinSCard] [DEBUG] APDU Received (19.328714 ms). [2026-02-14 00:51:01] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:01] [WinSCard] [DEBUG] APDU Received (31.990378 ms). [2026-02-14 00:51:01] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:01] [WinSCard] [DEBUG] APDU Received (16.115177 ms). [2026-02-14 00:51:01] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:01] [WinSCard] [DEBUG] APDU Received (41.493263 ms). [2026-02-14 00:51:01] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:01] [WinSCard] [DEBUG] APDU Received (28.195203 ms). [2026-02-14 00:51:01] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:02] [WinSCard] [DEBUG] APDU Received (223.350454 ms). [2026-02-14 00:51:02] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:02] [WinSCard] [DEBUG] APDU Received (37.120080 ms). [2026-02-14 00:51:02] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:02] [WinSCard] [DEBUG] APDU Received (37.138519 ms). [2026-02-14 00:51:02] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:02] [WinSCard] [DEBUG] APDU Received (161.936224 ms). [2026-02-14 00:51:02] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:02] [WinSCard] [DEBUG] APDU Received (98.318641 ms). [2026-02-14 00:51:02] [Pkcs11] [DEBUG] EXIT C_GetTokenInfo with CKR_OK [2026-02-14 00:51:02] [Pkcs11] [DEBUG] ENTER C_GetMechanismList [2026-02-14 00:51:02] [WinSCard] [DEBUG] Retrieving card. [2026-02-14 00:51:02] [Pkcs11] [DEBUG] EXIT C_GetMechanismList with CKR_OK [2026-02-14 00:51:02] [Pkcs11] [DEBUG] ENTER C_GetMechanismList [2026-02-14 00:51:02] [WinSCard] [DEBUG] Retrieving card. [2026-02-14 00:51:02] [Pkcs11] [DEBUG] EXIT C_GetMechanismList with CKR_OK [2026-02-14 00:51:02] [Pkcs11] [DEBUG] ENTER C_OpenSession [2026-02-14 00:51:02] [Pkcs11] [DEBUG] C_OpenSession OpenSession [2026-02-14 00:51:02] [WinSCard] [DEBUG] Retrieving card. [2026-02-14 00:51:02] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:02] [WinSCard] [DEBUG] APDU Received (50.469543 ms). [2026-02-14 00:51:02] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:02] [WinSCard] [DEBUG] APDU Received (28.079268 ms). [2026-02-14 00:51:02] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:02] [WinSCard] [DEBUG] APDU Received (224.380473 ms). [2026-02-14 00:51:02] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:02] [WinSCard] [DEBUG] APDU Received (47.219409 ms). [2026-02-14 00:51:02] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:02] [WinSCard] [DEBUG] APDU Received (73.285012 ms). [2026-02-14 00:51:02] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:02] [WinSCard] [DEBUG] APDU Received (115.925907 ms). [2026-02-14 00:51:02] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:03] [WinSCard] [DEBUG] APDU Received (116.631303 ms). [2026-02-14 00:51:03] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:03] [WinSCard] [DEBUG] APDU Received (116.229297 ms). [2026-02-14 00:51:03] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:03] [WinSCard] [DEBUG] APDU Received (116.138503 ms). [2026-02-14 00:51:03] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:03] [WinSCard] [DEBUG] APDU Received (116.062237 ms). [2026-02-14 00:51:03] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:03] [WinSCard] [DEBUG] APDU Received (115.988205 ms). [2026-02-14 00:51:03] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:03] [WinSCard] [DEBUG] APDU Received (116.364790 ms). [2026-02-14 00:51:03] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:03] [WinSCard] [DEBUG] APDU Received (46.914063 ms). [2026-02-14 00:51:03] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:03] [WinSCard] [DEBUG] APDU Received (73.431679 ms). [2026-02-14 00:51:03] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:03] [WinSCard] [DEBUG] APDU Received (115.964459 ms). [2026-02-14 00:51:03] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:03] [WinSCard] [DEBUG] APDU Received (115.939037 ms). [2026-02-14 00:51:03] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:04] [WinSCard] [DEBUG] APDU Received (116.017818 ms). [2026-02-14 00:51:04] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:04] [WinSCard] [DEBUG] APDU Received (116.320929 ms). [2026-02-14 00:51:04] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:04] [WinSCard] [DEBUG] APDU Received (116.271761 ms). [2026-02-14 00:51:04] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:04] [WinSCard] [DEBUG] APDU Received (116.029830 ms). [2026-02-14 00:51:04] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:04] [WinSCard] [DEBUG] APDU Received (116.055532 ms). [2026-02-14 00:51:04] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:04] [WinSCard] [DEBUG] APDU Received (83.469547 ms). [2026-02-14 00:51:04] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:04] [WinSCard] [DEBUG] APDU Received (46.873834 ms). [2026-02-14 00:51:04] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:04] [WinSCard] [DEBUG] APDU Received (43.658342 ms). [2026-02-14 00:51:04] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:04] [WinSCard] [DEBUG] APDU Received (37.972145 ms). [2026-02-14 00:51:04] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:04] [WinSCard] [DEBUG] APDU Received (42.685593 ms). [2026-02-14 00:51:04] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:04] [WinSCard] [DEBUG] APDU Received (37.816538 ms). [2026-02-14 00:51:04] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:04] [WinSCard] [DEBUG] APDU Received (42.775269 ms). [2026-02-14 00:51:04] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:04] [WinSCard] [DEBUG] APDU Received (121.226580 ms). [2026-02-14 00:51:04] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:05] [WinSCard] [DEBUG] APDU Received (107.504166 ms). [2026-02-14 00:51:05] [Pkcs11] [DEBUG] Session 2895793563 opened on slot 1. [2026-02-14 00:51:05] [Pkcs11] [DEBUG] EXIT C_OpenSession with CKR_OK [2026-02-14 00:51:05] [Pkcs11] [DEBUG] ENTER C_OpenSession [2026-02-14 00:51:05] [Pkcs11] [DEBUG] C_OpenSession OpenSession [2026-02-14 00:51:05] [WinSCard] [DEBUG] Retrieving card. [2026-02-14 00:51:05] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:05] [WinSCard] [DEBUG] APDU Received (50.432667 ms). [2026-02-14 00:51:05] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:05] [WinSCard] [DEBUG] APDU Received (28.263369 ms). [2026-02-14 00:51:05] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:05] [WinSCard] [DEBUG] APDU Received (224.734987 ms). [2026-02-14 00:51:05] [Pkcs11] [DEBUG] Session 1771030267 opened on slot 1. [2026-02-14 00:51:05] [Pkcs11] [DEBUG] EXIT C_OpenSession with CKR_OK [2026-02-14 00:51:05] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:05] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:05] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:05] [Pkcs11] [DEBUG] FindObjects on session 1771030267, max: 10, currentCount: 0. [2026-02-14 00:51:05] [Pkcs11] [DEBUG] FindObjects found 0 objects. [2026-02-14 00:51:05] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:05] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:05] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:05] [Pkcs11] [DEBUG] ENTER C_CloseSession [2026-02-14 00:51:05] [Pkcs11] [DEBUG] EXIT C_CloseSession with CKR_OK [2026-02-14 00:51:05] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:05] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:05] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:05] [Pkcs11] [DEBUG] FindObjects on session 2895793563, max: 1, currentCount: 295819258918259125. [2026-02-14 00:51:05] [Pkcs11] [DEBUG] FindObjects found 0 objects. [2026-02-14 00:51:05] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:05] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:05] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:05] [Pkcs11] [DEBUG] ENTER C_GetSlotInfo [2026-02-14 00:51:05] [Pkcs11] [DEBUG] EXIT C_GetSlotInfo with CKR_OK [2026-02-14 00:51:05] [Pkcs11] [DEBUG] ENTER C_GetTokenInfo [2026-02-14 00:51:05] [WinSCard] [DEBUG] Retrieving card. [2026-02-14 00:51:05] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:05] [WinSCard] [DEBUG] APDU Received (40.495090 ms). [2026-02-14 00:51:05] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:05] [WinSCard] [DEBUG] APDU Received (28.230404 ms). [2026-02-14 00:51:05] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:05] [WinSCard] [DEBUG] APDU Received (224.512612 ms). [2026-02-14 00:51:05] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:05] [WinSCard] [DEBUG] APDU Received (37.222049 ms). [2026-02-14 00:51:05] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:05] [WinSCard] [DEBUG] APDU Received (37.161427 ms). [2026-02-14 00:51:05] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:05] [WinSCard] [DEBUG] APDU Received (121.442529 ms). [2026-02-14 00:51:05] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:05] [WinSCard] [DEBUG] APDU Received (106.939290 ms). [2026-02-14 00:51:05] [Pkcs11] [DEBUG] EXIT C_GetTokenInfo with CKR_OK [2026-02-14 00:51:05] [Pkcs11] [DEBUG] ENTER C_GetMechanismList [2026-02-14 00:51:05] [WinSCard] [DEBUG] Retrieving card. [2026-02-14 00:51:05] [Pkcs11] [DEBUG] EXIT C_GetMechanismList with CKR_OK [2026-02-14 00:51:05] [Pkcs11] [DEBUG] ENTER C_GetMechanismList [2026-02-14 00:51:05] [WinSCard] [DEBUG] Retrieving card. [2026-02-14 00:51:05] [Pkcs11] [DEBUG] EXIT C_GetMechanismList with CKR_OK [2026-02-14 00:51:05] [Pkcs11] [DEBUG] ENTER C_OpenSession [2026-02-14 00:51:05] [Pkcs11] [DEBUG] C_OpenSession OpenSession [2026-02-14 00:51:05] [WinSCard] [DEBUG] Retrieving card. [2026-02-14 00:51:05] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:06] [WinSCard] [DEBUG] APDU Received (49.439803 ms). [2026-02-14 00:51:06] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:06] [WinSCard] [DEBUG] APDU Received (29.232207 ms). [2026-02-14 00:51:06] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:06] [WinSCard] [DEBUG] APDU Received (224.503115 ms). [2026-02-14 00:51:06] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:06] [WinSCard] [DEBUG] APDU Received (119.768295 ms). [2026-02-14 00:51:06] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:06] [WinSCard] [DEBUG] APDU Received (112.049995 ms). [2026-02-14 00:51:06] [Pkcs11] [DEBUG] Session 9852857635 opened on slot 2. [2026-02-14 00:51:06] [Pkcs11] [DEBUG] EXIT C_OpenSession with CKR_OK [2026-02-14 00:51:06] [Pkcs11] [DEBUG] ENTER C_OpenSession [2026-02-14 00:51:06] [Pkcs11] [DEBUG] C_OpenSession OpenSession [2026-02-14 00:51:06] [WinSCard] [DEBUG] Retrieving card. [2026-02-14 00:51:06] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:06] [WinSCard] [DEBUG] APDU Received (49.388400 ms). [2026-02-14 00:51:06] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:06] [WinSCard] [DEBUG] APDU Received (29.373286 ms). [2026-02-14 00:51:06] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:06] [WinSCard] [DEBUG] APDU Received (223.854987 ms). [2026-02-14 00:51:06] [Pkcs11] [DEBUG] Session 1771030269 opened on slot 2. [2026-02-14 00:51:06] [Pkcs11] [DEBUG] EXIT C_OpenSession with CKR_OK [2026-02-14 00:51:06] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:06] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:06] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:06] [Pkcs11] [DEBUG] FindObjects on session 1771030269, max: 10, currentCount: 0. [2026-02-14 00:51:06] [Pkcs11] [DEBUG] FindObjects found 0 objects. [2026-02-14 00:51:06] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:06] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:06] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:06] [Pkcs11] [DEBUG] ENTER C_CloseSession [2026-02-14 00:51:06] [Pkcs11] [DEBUG] EXIT C_CloseSession with CKR_OK [2026-02-14 00:51:06] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:06] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:06] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:06] [Pkcs11] [DEBUG] FindObjects on session 9852857635, max: 1, currentCount: 295819258918259125. [2026-02-14 00:51:06] [Pkcs11] [DEBUG] FindObjects found 0 objects. [2026-02-14 00:51:06] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:06] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:06] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:06] [Pkcs11] [DEBUG] ENTER C_GetSlotInfo [2026-02-14 00:51:06] [Pkcs11] [DEBUG] EXIT C_GetSlotInfo with CKR_OK [2026-02-14 00:51:06] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:06] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:06] [Pkcs11] [DEBUG] ENTER C_GetSlotInfo [2026-02-14 00:51:06] [Pkcs11] [DEBUG] EXIT C_GetSlotInfo with CKR_OK [2026-02-14 00:51:06] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:06] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:10] [Pkcs11] [DEBUG] ENTER C_GetSlotInfo [2026-02-14 00:51:10] [Pkcs11] [DEBUG] EXIT C_GetSlotInfo with CKR_OK [2026-02-14 00:51:10] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:10] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:10] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:10] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:10] [Pkcs11] [DEBUG] ENTER C_GetSlotInfo [2026-02-14 00:51:10] [Pkcs11] [DEBUG] EXIT C_GetSlotInfo with CKR_OK [2026-02-14 00:51:10] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:10] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:10] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:10] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:12] [Pkcs11] [DEBUG] ENTER C_Login [2026-02-14 00:51:12] [Pkcs11] [DEBUG] C_Login to session 9852857635. [2026-02-14 00:51:12] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:12] [WinSCard] [DEBUG] APDU Received (41.641884 ms). [2026-02-14 00:51:12] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:12] [WinSCard] [DEBUG] APDU Received (28.151623 ms). [2026-02-14 00:51:12] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:12] [WinSCard] [DEBUG] APDU Received (224.216486 ms). [2026-02-14 00:51:12] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:12] [WinSCard] [DEBUG] APDU Received (109.922351 ms). [2026-02-14 00:51:12] [Pkcs11] [DEBUG] EXIT C_Login with CKR_OK [2026-02-14 00:51:12] [Pkcs11] [DEBUG] ENTER C_OpenSession [2026-02-14 00:51:12] [Pkcs11] [DEBUG] C_OpenSession OpenSession [2026-02-14 00:51:12] [WinSCard] [DEBUG] Retrieving card. [2026-02-14 00:51:12] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:12] [WinSCard] [DEBUG] APDU Received (40.496767 ms). [2026-02-14 00:51:12] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:12] [WinSCard] [DEBUG] APDU Received (28.207496 ms). [2026-02-14 00:51:12] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:13] [WinSCard] [DEBUG] APDU Received (224.678555 ms). [2026-02-14 00:51:13] [Pkcs11] [DEBUG] Session 1771030270 opened on slot 2. [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_OpenSession with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:13] [Pkcs11] [DEBUG] FindObjects on session 1771030270, max: 10, currentCount: 0. [2026-02-14 00:51:13] [Pkcs11] [DEBUG] FindObjects found object 3. [2026-02-14 00:51:13] [Pkcs11] [DEBUG] FindObjects found 1 objects. [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_CloseSession [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_CloseSession with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:13] [Pkcs11] [DEBUG] FindObjects on session 9852857635, max: 1, currentCount: 3. [2026-02-14 00:51:13] [Pkcs11] [DEBUG] FindObjects found object 1. [2026-02-14 00:51:13] [Pkcs11] [DEBUG] FindObjects found 1 objects. [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_GetSlotInfo [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_GetSlotInfo with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_GetSlotInfo [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_GetSlotInfo with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:13] [Pkcs11] [DEBUG] FindObjects on session 9852857635, max: 10, currentCount: 139671785585919. [2026-02-14 00:51:13] [Pkcs11] [DEBUG] FindObjects found 0 objects. [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:13] [Pkcs11] [DEBUG] FindObjects on session 9852857635, max: 1, currentCount: 1. [2026-02-14 00:51:13] [Pkcs11] [DEBUG] FindObjects found object 3. [2026-02-14 00:51:13] [Pkcs11] [DEBUG] FindObjects found 1 objects. [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:13] [Pkcs11] [DEBUG] FindObjects on session 9852857635, max: 1, currentCount: 1. [2026-02-14 00:51:13] [Pkcs11] [DEBUG] FindObjects found object 3. [2026-02-14 00:51:13] [Pkcs11] [DEBUG] FindObjects found 1 objects. [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:13] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:13] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:17] [Pkcs11] [DEBUG] ENTER C_Login [2026-02-14 00:51:17] [Pkcs11] [DEBUG] C_Login to session 2895793563. [2026-02-14 00:51:17] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:17] [WinSCard] [DEBUG] APDU Received (40.642875 ms). [2026-02-14 00:51:17] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:17] [WinSCard] [DEBUG] APDU Received (29.221591 ms). [2026-02-14 00:51:17] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:17] [WinSCard] [DEBUG] APDU Received (223.559419 ms). [2026-02-14 00:51:17] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:17] [WinSCard] [DEBUG] APDU Received (119.131901 ms). [2026-02-14 00:51:17] [Pkcs11] [DEBUG] EXIT C_Login with CKR_OK [2026-02-14 00:51:17] [Pkcs11] [DEBUG] ENTER C_GetSlotInfo [2026-02-14 00:51:17] [Pkcs11] [DEBUG] EXIT C_GetSlotInfo with CKR_OK [2026-02-14 00:51:17] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:17] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:17] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:17] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:17] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:17] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:17] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:17] [Pkcs11] [DEBUG] FindObjects on session 2895793563, max: 10, currentCount: 0. [2026-02-14 00:51:17] [Pkcs11] [DEBUG] FindObjects found object 1. [2026-02-14 00:51:17] [Pkcs11] [DEBUG] FindObjects found 1 objects. [2026-02-14 00:51:17] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:17] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:17] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:17] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:17] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:17] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:17] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:17] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:17] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_ATTRIBUTE_TYPE_INVALID [2026-02-14 00:51:17] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:17] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_ATTRIBUTE_TYPE_INVALID [2026-02-14 00:51:17] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:17] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_ATTRIBUTE_TYPE_INVALID [2026-02-14 00:51:17] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:17] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_ATTRIBUTE_TYPE_INVALID [2026-02-14 00:51:17] [Pkcs11] [DEBUG] ENTER C_OpenSession [2026-02-14 00:51:17] [Pkcs11] [DEBUG] C_OpenSession OpenSession [2026-02-14 00:51:17] [WinSCard] [DEBUG] Retrieving card. [2026-02-14 00:51:17] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:17] [WinSCard] [DEBUG] APDU Received (40.517161 ms). [2026-02-14 00:51:17] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:17] [WinSCard] [DEBUG] APDU Received (28.157210 ms). [2026-02-14 00:51:17] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:18] [WinSCard] [DEBUG] APDU Received (224.493057 ms). [2026-02-14 00:51:18] [Pkcs11] [DEBUG] Session 1771030271 opened on slot 1. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_OpenSession with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects on session 1771030271, max: 10, currentCount: 0. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects found object 3. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects found 1 objects. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_CloseSession [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_CloseSession with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects on session 2895793563, max: 1, currentCount: 3. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects found object 1. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects found 1 objects. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects on session 2895793563, max: 10, currentCount: 139671785585919. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects found 0 objects. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetSlotInfo [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetSlotInfo with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects on session 2895793563, max: 1, currentCount: 1. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects found object 3. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects found 1 objects. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects on session 2895793563, max: 1, currentCount: 1. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects found object 3. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects found 1 objects. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects on session 2895793563, max: 1, currentCount: 94493804377080. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects found object 1. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects found 1 objects. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects on session 2895793563, max: 1, currentCount: 1. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects found object 3. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects found 1 objects. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects on session 9852857635, max: 1, currentCount: 56. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects found object 1. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects found 1 objects. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects on session 9852857635, max: 1, currentCount: 1. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects found object 3. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] FindObjects found 1 objects. [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:18] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:18] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:21] [Pkcs11] [DEBUG] FindObjects on session 2895793563, max: 1, currentCount: 1. [2026-02-14 00:51:21] [Pkcs11] [DEBUG] FindObjects found object 3. [2026-02-14 00:51:21] [Pkcs11] [DEBUG] FindObjects found 1 objects. [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetSlotInfo [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetSlotInfo with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetSlotInfo [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetSlotInfo with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:21] [Pkcs11] [DEBUG] FindObjects on session 9852857635, max: 10, currentCount: 0. [2026-02-14 00:51:21] [Pkcs11] [DEBUG] FindObjects found object 1. [2026-02-14 00:51:21] [Pkcs11] [DEBUG] FindObjects found 1 objects. [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_ATTRIBUTE_TYPE_INVALID [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_ATTRIBUTE_TYPE_INVALID [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_ATTRIBUTE_TYPE_INVALID [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_ATTRIBUTE_TYPE_INVALID [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_FindObjectsInit [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_FindObjectsInit with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_FindObjects [2026-02-14 00:51:21] [Pkcs11] [DEBUG] FindObjects on session 2895793563, max: 1, currentCount: 1. [2026-02-14 00:51:21] [Pkcs11] [DEBUG] FindObjects found object 3. [2026-02-14 00:51:21] [Pkcs11] [DEBUG] FindObjects found 1 objects. [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_FindObjects with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_FindObjectsFinal [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_FindObjectsFinal with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetMechanismInfo [2026-02-14 00:51:21] [WinSCard] [DEBUG] Retrieving card. [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetMechanismInfo with CKR_MECHANISM_INVALID [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetMechanismInfo [2026-02-14 00:51:21] [WinSCard] [DEBUG] Retrieving card. [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetMechanismInfo with CKR_MECHANISM_INVALID [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_OpenSession [2026-02-14 00:51:21] [Pkcs11] [DEBUG] C_OpenSession OpenSession [2026-02-14 00:51:21] [WinSCard] [DEBUG] Retrieving card. [2026-02-14 00:51:21] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:21] [WinSCard] [DEBUG] APDU Received (40.555713 ms). [2026-02-14 00:51:21] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:21] [WinSCard] [DEBUG] APDU Received (28.241578 ms). [2026-02-14 00:51:21] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:21] [WinSCard] [DEBUG] APDU Received (224.810416 ms). [2026-02-14 00:51:21] [Pkcs11] [DEBUG] Session 2986295127 opened on slot 1. [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_OpenSession with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_SignInit [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_SignInit with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_GetAttributeValue [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_GetAttributeValue with CKR_OK [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_Login [2026-02-14 00:51:21] [Pkcs11] [DEBUG] C_Login to session 2986295127. [2026-02-14 00:51:21] [Pkcs11] [DEBUG] EXIT C_Login with CKR_USER_ANOTHER_ALREADY_LOGGED_IN [2026-02-14 00:51:21] [Pkcs11] [DEBUG] ENTER C_Sign [2026-02-14 00:51:21] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:21] [WinSCard] [DEBUG] APDU Received (40.564373 ms). [2026-02-14 00:51:21] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:21] [WinSCard] [DEBUG] APDU Received (29.324118 ms). [2026-02-14 00:51:21] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:21] [WinSCard] [DEBUG] APDU Received (223.632613 ms). [2026-02-14 00:51:21] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:21] [WinSCard] [DEBUG] APDU Received (110.362351 ms). [2026-02-14 00:51:21] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:21] [WinSCard] [DEBUG] APDU Received (75.385838 ms). [2026-02-14 00:51:21] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:22] [WinSCard] [DEBUG] APDU Received (833.803458 ms). [2026-02-14 00:51:22] [WinSCard] [DEBUG] Sending APDU... [2026-02-14 00:51:22] [WinSCard] [DEBUG] APDU Received (18.175773 ms). [2026-02-14 00:51:22] [Pkcs11] [DEBUG] EXIT C_Sign with CKR_OK [2026-02-14 00:51:22] [Pkcs11] [DEBUG] ENTER C_CloseSession [2026-02-14 00:51:22] [Pkcs11] [DEBUG] EXIT C_CloseSession with CKR_OK [2026-02-14 00:51:22] [Pkcs11] [DEBUG] ENTER C_GetSlotInfo [2026-02-14 00:51:22] [Pkcs11] [DEBUG] EXIT C_GetSlotInfo with CKR_OK [2026-02-14 00:51:22] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:22] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:22] [Pkcs11] [DEBUG] ENTER C_GetSlotInfo [2026-02-14 00:51:22] [Pkcs11] [DEBUG] EXIT C_GetSlotInfo with CKR_OK [2026-02-14 00:51:22] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:22] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:22] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:22] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:22] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:22] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:24] [Pkcs11] [DEBUG] ENTER C_GetSlotInfo [2026-02-14 00:51:24] [Pkcs11] [DEBUG] EXIT C_GetSlotInfo with CKR_OK [2026-02-14 00:51:24] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:24] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:24] [Pkcs11] [DEBUG] ENTER C_GetSlotInfo [2026-02-14 00:51:24] [Pkcs11] [DEBUG] EXIT C_GetSlotInfo with CKR_OK [2026-02-14 00:51:24] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:24] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:24] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:24] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:24] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:24] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:26] [Pkcs11] [DEBUG] ENTER C_GetSlotInfo [2026-02-14 00:51:26] [Pkcs11] [DEBUG] EXIT C_GetSlotInfo with CKR_OK [2026-02-14 00:51:26] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:26] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:26] [Pkcs11] [DEBUG] ENTER C_GetSlotInfo [2026-02-14 00:51:26] [Pkcs11] [DEBUG] EXIT C_GetSlotInfo with CKR_OK [2026-02-14 00:51:26] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:26] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:26] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:26] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:26] [Pkcs11] [DEBUG] ENTER C_GetSessionInfo [2026-02-14 00:51:26] [Pkcs11] [DEBUG] EXIT C_GetSessionInfo with CKR_OK [2026-02-14 00:51:30] [Pkcs11] [DEBUG] ENTER C_Logout [2026-02-14 00:51:30] [Pkcs11] [DEBUG] C_Logout from session 2895793563. [2026-02-14 00:51:30] [Pkcs11] [DEBUG] EXIT C_Logout with CKR_USER_NOT_LOGGED_IN [2026-02-14 00:51:30] [Pkcs11] [DEBUG] ENTER C_Logout [2026-02-14 00:51:30] [Pkcs11] [DEBUG] C_Logout from session 9852857635. [2026-02-14 00:51:30] [Pkcs11] [DEBUG] EXIT C_Logout with CKR_OK [2026-02-14 00:51:30] [Pkcs11] [DEBUG] ENTER C_CloseAllSessions [2026-02-14 00:51:30] [Pkcs11] [DEBUG] EXIT C_CloseAllSessions with CKR_OK Zadnje izmijenjeno od: radi.neradi. 14.02.2026. u 03:04. |
#5216 |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,141
@radi.neradi - thanks, ali na kraju sam koristil web verziju kaj je strikoo polal jer nisam imal volje nit vremena istraživati nekaj kaj bi trebalo biti rešeno za par minuta. Ali svejedno hvala na trudu!
#5217 |
White Rabbit
Postovi: 5,623
Zadnje izmijenjeno od: tomek@vz. 16.02.2026. u 19:49. |
#5220 |
Lokacija: Mrkopalj
Postovi: 95
Code:
# cat /etc/slackware-version Slackware 14.2 # uptime 12:18:24 up 1942 days, 7:29, 1 user, load average: 5.63, 5.41, 5.06 # uname -a Linux server 4.4.240 #1 SMP Wed Oct 21 15:59:03 CDT 2020 x86_64 Intel(R) Xeon(R) CPU E5-1650 v2 @ 3.50GHz GenuineIntel GNU/Linux # passwd -S root root P 11/27/2016 0 -1 -1 -1 Zadnje izmijenjeno od: radi.neradi. 17.02.2026. u 13:36. |
