#1771 |
Lokacija: Rijeka / Grobnik
Postovi: 4,542
trebalo je scroll-at dole, hebga .stavio i njega sad da isprobam. zapelo mi je za oko da on nema mogucnost translate-a?
"We all must hang together, or surly we will hang separately." AMD Ryzen7 7800x3D+Noctua NH-D14 | MSI Tomahawk WIFI AMD B650 | 2x16GB Corsair Vengeance DDR5-6000 CL30 1,39v | SAPPHIRE Pulse RX 9070xt UV/OC | 1tb NVMe sammy 970 evo plus, 2TB Samsung 990 EVO Plus, 128gb NVMe Patriot P300, Crucial MX500 500GB, Kingston 480gb | Riotoro ENIGMA G2 850W 80 Gold | Corsair Carbide 300R modded | Win10 ENT LTSC IoT (work) + Win11 ENT LTSC IoT (gejming) | logitech g403 | ROCCAT Horde | AOC CQ27C4 + AOC C24G1 + 50" Hisense H50A6140 AMD Ryzen5 2600+Xilence Cryon M806D.B | Asus x370 Prime Pro rev1.03 (bios 6203) | GSkill Aegis 32GB (2x16) DDR4@3,2GHz | 2x Intel 545s 128GB, 1x Crucial MX500 500GB | Gigabyte GTX960 | sisa 620w | Fractal Design Focus G | Win7 x64 + Win10 ENT LTSC IoT | logitech g403 | ROCCAT SuoraFX intel i5 2500k@4,5ghz (1,28v)+FSP Windale 4 | ASRock Z68 Ext4 Gen3 (bios 1.20) | 2x8gb DDR3 HyperX Savage, 1866mhz, 10-10-11-27,1,5V | Samsung SSD 64gb, 2x256gb SSD | iGPU | corsair vx450w | CoolerMaster Centurion 534 modded | Win7 x64 |
#1772 |
Postovi: 23,680
Meni taj translate samo smeta a vjerojarno ima kakav extension te namjene. |
#1773 | ||
White Rabbit
Postovi: 5,567
#1774 | ||
White Rabbit
Postovi: 5,567
#1775 | |
White Rabbit
Postovi: 5,567
#1776 |
Postovi: 34,116
Sad smo nahebali. Od odličnog browsera će napraviti AIO program ili čak OS. Isto onako kako je Nero od odličnog programa za prženje postao svaštara tj. s**nje.
#1778 | |
Datum registracije: Jun 2024
Lokacija: Space
Postovi: 868
Firefox Dev Clarifies New AI Feature Killswitch: "I Hope We Can (Re)gain Your Trust Here" Citiraj:
Miquella is mine and mine alone. |
#1779 |
White Rabbit
Postovi: 5,567
I to još dok ne ubrojimo da je Chromium brži, bez obzira dal tehnološki superioriniji ili umjetnim dampeningom web stranica. Najveći problem je u svemu tome da je na čelu Mozille kao korporacije/ustanove/šta već ekipa nesposobnjakovića i sve je bilo OK dok je google pumpao lovu. Odkad to nije slucaj oni se nisu sposobni reorganizirati. Kad projekat jednom izda vlastita načela u očima korisnika pada. Ponovo steći povjerenje korisnika je u takvim slučajevima teško ili nemoguće. Mislim da ako se to dogodi, Mozilla u ovom formatu neće preživjeti. |
#1781 |
White Rabbit
Postovi: 5,567
Youtube mi radi malko bolje. Na FF YT blokira dosta svaki video par sekundi prije nego starta video. Ostalim se iskreno nisam zamarao. |
#1782 | |
Postovi: 737
https://bbs.archlinux.org/viewtopic....36902#p2236902 https://archlinux.org/packages/extra...-nvidia-driver Na X11 kod mene Chromium i dalje ne radi, dok Firefox radi uredno. |
#1784 |
Lokacija: Space
Postovi: 868
Ja FF koristim primarno od 2016te kako je chromium program izbacio GDI text rendring i nisam nikad imao potrebe da se vratim na chrome. Ponekad probam i to je to. Ne znam kako sam Chrome danas radi jer ne zelim da sam ulogovan non stop na google acc ali meni FF daleko bolje radi nego Brave. Mozda sto isti ima gomilu fuinkcija ali nekako je sve na delay. Mislim da je overall chromium program postao trom. Ako FF ode full ka AI, od mene imaju mahanje. Ali na na zalost, AI agenti ce postati standard.
#1785 |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,736
Nemrem sad nać link, ali izjavili su da bude postojao neki "master kill switch" s kojim će se sve te AI điđemiđe moći u potpunosti isključiti. Tak da netreba paničariti i prejudicirati, hopefully. |
#1786 |
Lokacija: Space
Postovi: 868
Ev link ![]()
#1788 |
Lokacija: Space
Postovi: 868
Izgubio sam totalno strpljenje. Kroz par zadnjih updatea video na bilo kojoj platformi loada vjecnost, stane u sred 720p klipa a o 4K sadrzaju da ne pricam. Prije 2 godine je bio katastrofalan problem sa youtube reprodukcijom i to je bilo izgovor: Google ih sabotira. Ali sada, osim sto se isti slucaj vratio, generalno video reprodukcija se jednostavno pati u odnosu na chromium based browsere. Svaki put upalim Edge samo da testiram i radi bez greske. Ako se koristi "picture in picture" mod, ako stranica freeza, PiP prozor se ne moze zatvoriti vec mora tab ili sam browser. Blokira mi ekran a ne mogu ga ni pomjerit.. jer je freezan. Na to sve novi problem gdje cijela stranica freeza sa porukom koju FF izbaci, da je stopiram jer traje predugo. Random shoping stranice kao u vrijeme flash reklama koje opterete PC. Evo maloprije neki low quallity video na twitteru da pogledam, video dugo loada, i nakon 50% reprdukcije stao i vrti loading. Ovo sve je isto na win10 i na win11. Malo sam citao reddit i slicne prijave. Teske muke se evo primarno prebacio na Brave. ![]()
#1789 |
Postovi: 23,680
Pa kog crnog đavla "mora biti zadnja verzija" ? Fino stavi 140.x.0 esr verziju bez onog njihovog update servisa. Po potrebi se u about:config pobije šta treba. Alternativa sa već pogašenim smetjem, brojčano isto ali r3dfox izdanje. |
#1790 |
Lokacija: Space
Postovi: 868
Zbog ovakvih stvari: Mozilla has released an emergency update for Firefox 147, addressing 16 high-severity flaws and suspected zero-days. These vulnerabilities could allow for remote code execution and full system compromise. https://www.linkedin.com/posts/abhis...296548864-esz7
#1792 |
Lokacija: Space
Postovi: 868
Iz istog razloga ni ne koristim profile vec par godina Znaci svjeza instalacija, koja ekstenzija, nista hardcore. Necu da hejtam da je ovo pocelo kad su krenuli sa AI, ali u to neko vrijeme. Eto jos sam gore pisao kako mi FF radi super u poredjenju sa Brave i ..I spoke too soon.Ovih dana radim od kuce pa cu probat jos malo istestirati kad dodjem na posao ali mi cudno, isto ponasanje na dva razlicita OS. EDIT: Cek.. mozda trebam napraviti profil pa da normalno radi Probam i to..
#1793 |
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 4,001
Ne vjerujem da browser može raditi bez profila. Mislim na lokalni profil koji na windowsima ide u, mensečini, AppData. Ne mislim da ono njihovo govanjce za sync između raznih uređaja. U profil ide sve što browser radi na računalu: history, bookmarks, forme, cache itd. Ako nešto pođe po krivu, krenu se čudne stvari događati.
#1794 |
Postovi: 23,680
I za te situacije je zgodan r3dfox koji ima i portable verziju, treba se startati sa parametrom u komandnoj liniji (linku) gdje navedeš "ime profila" a koji je tada u istom folderu gdje je exe a ne u AppData. Gore sam namjerno spominjao verziju gdje još nisu počeli ubacivati AI gofno. |
#1796 |
Lokacija: Space
Postovi: 868
A da, taj lokalni profil brisem. Sve sto ima Mozilla ime. Probat cu jos i Developer Edition ili Nightly. Pa ako ne, onda portabilnu jer zaista mi se ne koristi chrome. Hvala kolege.
#1797 |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,135
Dobro dela Firefox, na Win11 i na Fedora KDE. Čak i bolje nego zadnjih godina. PrivacyBadger, UblockOrigin,SponsorBlock, Multicontainer, ClearURLs i Tabliss su ekstenzije kaj koristim
#1799 |
Lokacija: Space
Postovi: 868
Kad se meni desi problem, pogasim ekstenzije pa probam, i problem isti. Jedino mozda zahtjeva uninstall ekstenzija. Moguce da je Ublock origin ili nesto slicno ali nije sad da imam 20 njih: ![]()
#1800 |
White Rabbit
Postovi: 5,567
Random je - i vise ima veze sa adblockom nego sa Firefoxom (iako je i to za Youtube banana faktor): YouTube's anti-adblock system just got smarter and harder to dodge Meni se isto Youtube cudno ponasa na pola kompova , razliciti web browseri. |
