#2731 |
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,640
1 * AMD Ryzen 7 7800X3D - 4.20/5.00GHz (8 Cores) Socket AM5, 96MB cache, Radeon Graphics, bez hladnjaka, tray Šifra: 74561 1 * CPU hladnjak Thermalright Peerless Assassin 120 SE Šifra: CPTR-103 1 * ASUS TUF GAMING B650-PLUS AM5 MB TUF GAMING B650-PLUS Šifra: 46142103 1 * KINGSTON 32GB 6000MT/s DDR5 CL36 DIMM KF560C36BBE2K2-32 Šifra: 47322358 1 * Sapphire RX 9070 XT PULSE 16GB GDDR6 Šifra: 140757- 1 * Patriot VP4300 LITE, R7400/W6400, 2TB, M.2 NVMe VP4300L2TBM28H Šifra: pat-vp4300lite-2tb 1 * Enermax 850W CyberG II, ATX 3.1, 80+ GOLD, 2×PCIe, 5×SATA, 24-pina, 120mm ventilator Šifra: 69861 1 * Bit Force SPARK ARGB-TG3 Midi Tower ARGB Gaming PC ATX kućište bez napajanja, crno Šifra: 68141 Sveukupno s popustom: 2.047,40€ (-2%=2.006€) Besplatno slaganje i dostava |
#2732 |
Lokacija: Hercegovac
Postovi: 977
Pozdrav... Nećak me moli da mu složim pc konfu bez monitora za igre do max 1300€...grafa obavezno nvidia. Da li bi neko bio ljubazan sklepat prigodnu konfiguraciju ? Zahvaljujem...
HP OMEN G16 AMD Ryzen™ 7 7840HS | NVIDIA® GeForce RTX™ 4060 8 GB GDDR6 | 16 GB DDR5-5600 MHz RAM | 1 TB PCIe® Gen4 NVMe™ M.2 SSD |
#2733 |
Postovi: 8,577
#2734 |
Postovi: 1,640
1 * AMD AM5 Ryzen 7500F TRAY (bez kutije i hladnjaka) Šifra: 100000000597K 1 * ID-Cooling CPU Cooler - SE-224-XTS Šifra: SE-224-XTS 1 * ASROCK B650M-HDV/M.2 AM5 2xDDR5 2xPCIe B650M-HDV/M.2 Šifra: 46344871 1 * Kingston 16GB 6000MT/s DDR5 CL30 DIMM (Kit of 2) FURY Beast Black EXPO Šifra: KF560C30BBEK2-16 1 * Gainward RTX 5060Ti Python III V1 16GB GDDR7 NE7506T019T1-GB2061R Šifra: gai-5060ti-py-16g1 1 * WD Green SN3000 NVMe SSD 1TB M.2 2280 WDS100T4G0E-00CPS0 Šifra: 47731289 1 * ASRock PSU PRO Series PRO-650B, 650W, 80 Bronze Šifra: ASR-PRO-650B 1 * Spire U30 Marine Black, bez napajanja U30 Marine Black Šifra: spi-u30-marine-bl Sveukupno s popustom: 1.329,00€ (-2%=1.301€) Besplatno slaganje i dostava |
#2735 |
Datum registracije: Dec 2009
Postovi: 116
Gaming konfa za 1625€
Pozdrav, kum kupuje gaming konfu, budžet je 1625€ (1300€ + PDV). Ne preferira Intel ili AMD, samo najbolje što se može dobiti za te novce. Može se rastegnuti još 100€ ako radi neku bitnu razliku. SSD od 500 GB mu je dovoljan. Ne treba biti flashy, RGB i ostale pomode su nebitne ![]() Periferiju i monitor ima. Hvala unaprijed ![]() |
#2737 |
Postovi: 1,640
Vjeruj mi 500GB mu nije ni blizu dovoljno za gaming mašinu osim ako ne planira igrat samo igre iz 2008. koje zauzimaju po 5-6-7GB. Od 500GB iskoristivog prostora imaš cca 465GB, full ažurirani Windows + driveri + popratni programi i već si ispod 400GB prostora. Recimo da skine samo Warzone ili BF6 samo jedna od te dvije igre ti zauzme oko 120GB. 1TB je minimum ako planira imati instalirano više od 2 moderne igre. 1 * AMD Ryzen 5 7500F - 3.70/5.00GHz (6 Cores), Socket AM5,32MB, bez grafike, bez hladnjaka, tray Šifra: 70364 1 * LC-Power Aera LC-CC-120-DB6 Digi hladnjak, ARGB LC-CC-120-DB6 Digi Šifra: lcp-cc-120db6-digi 1 * ASUS TUF GAMING B650-PLUS AM5 MB TUF GAMING B650-PLUS Šifra: 46142103 1 * Kingston 32GB 6000MT/s DDR5 CL36 DIMM (Kit of 2) FURY Beast Black EXPO Šifra: KF560C36BBE2K2-32 1 * XFX Swift AMD Radeon RX 9070 OC Triple Fan Gaming Edition, 16GB GDDR6 Šifra: XFX-RX-97SWFB3B9 1 * Crucial P310 1TB PCIe Gen4 NVMe M.2 SSD Šifra: CT1000P310SSD8 1 * Enermax 750W CyberG II, ATX 3.1, 80+ GOLD, 2×PCIe, 5×SATA, 24-pina, 120mm ventilator Šifra: 69860 1 * COUGAR AIRFACE 180 PC Case, Mid Tower, Black Šifra: CGR-5VA4B-RGB Sveukupno s popustom: 1.762,90€ (-2%=1.726€) Besplatno slaganje i dostava |
