Staro 20.11.2025., 18:48   #2941
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,566
Scroll gore. 2929 pa na dalje.
To na ovoj novoj masini sa w11.
Na staroj nikakav problem.
"We all must hang together, or surly we will hang separately."
AMD Ryzen7 7800x3D+Noctua NH-D14 | MSI Tomahawk WIFI AMD B650 | 2x16GB Corsair Vengeance DDR5-6000 CL30 1,39v | SAPPHIRE Pulse RX 9070xt UV/OC | 1tb NVMe sammy 970 evo plus, 2TB Samsung 990 EVO Plus, 128gb NVMe Patriot P300, Crucial MX500 500GB, Kingston 480gb | Riotoro ENIGMA G2 850W 80 Gold | Corsair Carbide 300R modded | Win10 ENT LTSC IoT (work) + Win11 ENT LTSC IoT (gejming) | logitech g403 | ROCCAT Horde | AOC CQ27C4 + AOC C24G1 + 50" Hisense H50A6140
AMD Ryzen5 2600+Xilence Cryon M806D.B | Asus x370 Prime Pro rev1.03 (bios 6203) | GSkill Aegis 32GB (2x16) DDR4@3,2GHz | 2x Intel 545s 128GB, 1x Crucial MX500 500GB | Gigabyte GTX960 | sisa 620w | Fractal Design Focus G | Win7 x64 + Win10 ENT LTSC IoT | logitech g403 | ROCCAT SuoraFX
intel i5 2500k@4,5ghz (1,28v)+FSP Windale 4 | ASRock Z68 Ext4 Gen3 (bios 1.20) | 2x8gb DDR3 HyperX Savage, 1866mhz, 10-10-11-27,1,5V | Samsung SSD 64gb, 2x256gb SSD | iGPU | corsair vx450w | CoolerMaster Centurion 534 modded | Win7 x64
Staro 20.11.2025., 20:29   #2942
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,717
Autor kopija Pregled postova
13 (trinaest!) MILIJARDI DOLARA je MS uložio u OpenAI da bi mogao koristiti ChatGPT model.
Možete se vi zgražati i smijati kolko oćete, ali nije ta ekipa u Redmondu vesla sisala.
Bude to zaživjelo i korisnici će biti oduševljeni.
Meni je sve to vrlo intrigantno jer je mogućnost verbalne interakcije s kompom revolucionarni pomak.
https://youtu.be/hUwHyoKGZKs?t=481
Staro 20.11.2025., 23:07   #2943
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,794
Nekad pretjeruje, ali ovaj puta je u pravu. A nekad je ljute mucila telemetrija.
https://www.youtube.com/watch?v=iX3a-goiE2c
Staro 20.11.2025., 23:26   #2944
geronimo_2
geronimo_2's Avatar
Postovi: 4,566
Nova zabava na w11. Udem u igru, izadem van, i sad trebam restartat jer iz nekog razloga adrenalin ne otvara. Hebo takav os. Znao sam da je losa ideja ic na to gofno umjesto 10, al nije mi vrag dao mira, reko ajde po prvi put idem against gut feeling... Moron
Staro 21.11.2025., 00:06   #2945
Exy
Exy's Avatar
Postovi: 2,717
Meni se to često znalo događati na 7800XT, mislim da čak nema veze sa win nego sa AMD-om
Staro 21.11.2025., 06:43   #2946
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,625
@geronimo...je da je popularno mrziti 11-icu ali ruku na srce vecina ovog sto si napisao su problemi samih aplikacija koje instaliras - ne OS-a. Nije Microsoft bas za sve kriv u ovom slucaju vec lijeno programiranje. Ili nades rijesenje unutar samog appa ili mijenjas app za alternativu. Nema smisla se toliko uzrujavati radi komada softwera.
Staro 21.11.2025., 09:55   #2947
Postovi: 8,689
Spomenul u par postova da mu sve ovo uredno radi na Windows 10 OS-u, a sad kad se prebacil na Windows 11, odjednom se te iste aplikacije kotrljaju nizbrdo.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750
Staro 21.11.2025., 09:59   #2948
geronimo_2
geronimo_2's Avatar
Postovi: 4,566
ma da, iako na win10 je nesto starija adrenalin i 6800, al nekak se iskreno nadam da to nije do hw-a novog jer sam onda nigdje lol.
gore je zadnji adrenalin od pred par dana, pa ak imate slicne probleme napisite.
bacim oko jel izaslo sta novo zadnjih dana, ako ne probam stavit neki stariji, al meni to sve skupa smrdi jer nemam problema nikakvih dok ne udem u neku igru, specificno radi se o metal gear solid i uncharted 4 jucer. udem, postelam nesto sitno, izadem i adrenalin ne dela, odnosno probam uc u njega, prvo hang-a par sekundi, a onda vidim da se srusio/ugasio. pokrenem ga opet, vidim onaj veliki ekran da ga loada i opet se rusi i tak u krug, dok ne restartam.
nebi mi bilo toliko cudno da nisam primjetio slicne probleme i sa drugim, odnosno firefox gore naveden.
nesto tu smrdi.
Staro 21.11.2025., 10:07   #2949
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,625
Svjestan sam toga. Zato kazem mozda developeri iste aplikacije nisu optimirali za Windows 11 - nebih tu mogucnost tako lako izbacio iz jednadzbe pogotovo kad kad je struka preplavljena vibe coderima.
Staro 21.11.2025., 10:18   #2950
Postovi: 8,689
Da, ali evo kod mene su iste te (Adrenalin i Firefox) aplikacije u svojim zadnjim verzijama skupa s firško patchiranim Windows 11 Pro 25H2 i sve dela kak spada.
Staro 21.11.2025., 11:10   #2951
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,738
Možda je do Chris Titusa
kopija je online   Reply With Quote
Staro 21.11.2025., 11:10   #2952
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,625
@geronimo_2 > jesi radio upgrade na 11 ili cistu instalaciju? Dali si radio kakve optimizacije za OS koje mijenjaju default vrijednosti?
Staro 21.11.2025., 11:14   #2953
geronimo_2
geronimo_2's Avatar
Postovi: 4,566
cista instalacija LTSC iot.
ako pod optimizacija i mjenjanje vrijednosti mislis na tool-ove tipa shutup, private winten i sl. nisam jos nista od doticnih stavio, daklem trebalo bi bit sve default.
zadnji available win updejti stavljeni neki dan.
masina je offline vecinu vremena, a i za bilo kakve izlaze ESET pita.
Staro 21.11.2025., 11:36   #2954
calypso
calypso's Avatar
Datum registracije: Oct 2002
Lokacija: Zagreb/Rijeka
Postovi: 2,184
Jbg, podsjetilo me na Titus the fox...
https://www.youtube.com/watch?v=GlW532-MlsA
GMKTec K8Plus
2x EIZO EV2336WFS3-BK
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4-2666
intel UHD 620
13.3" FullHD IPS Touchscreen
Staro 21.11.2025., 11:54   #2955
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,141
Znači koristiš nepodržanu verziju Windowsa za krivu svrhu.
There be dragons...
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 21.11.2025., 11:55   #2956
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,625
Znaci kod tebe LTSC verzija kod Exiled legit Win11 Pro (up to date). Onda mora u tom grmu lezat zec. Jesi probao sa "normalnom" i "up to date" verzijom Windows 11 OS-a?
Staro 21.11.2025., 13:23   #2957
Postovi: 10,437
Mene ovaj ESET ful kopka u cijeloj prici, pa ako se odlucis razj. sustav, probaj prvo maknuti taj suite cisto u znanstvene svrhe
Citamo se u W10 temi
Staro 21.11.2025., 13:38   #2958
geronimo_2
geronimo_2's Avatar
Postovi: 4,566
probat cu i to, al uskoro krece instalacija w10 pa se javim kroz tjedan dva. steta vejstanog vremena na ovaj w11.
Staro 21.11.2025., 19:03   #2959
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,228
/connect 185.107.96.125:28990
server rcon: oldschool
Staro 21.11.2025., 19:32   #2960
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,537
Win11 iot ltsc radi savršeno
Upirem prst u amd ili odakle ti taj image ltsc?inače se skida sa ms legit stranice i onda mass ostalo se nedira jer nema potrebe nema ai govna i ostalih glupoština
Poslano sa mog SM-S918B koristeći Tapatalk
Staro 21.11.2025., 20:01   #2961
Postovi: 23,708
Tko ima vremena za istraživanje neka proba "složiti" tiny11,
nije kao IoT ali dobiješ slični rezultat eliminiranjem "nepotrebnog".
Staro 21.11.2025., 20:26   #2962
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,491
Nebi ni mene čudilo da ga ESET prca, defender radi sasvim dobar posao. Je da je malo prenervozan i skače na sve i svašta, ali sve se to da podesiti.
Fun fact, postoji DefenderUI app za bolju i intuitivniju kotrolu defendera.
Odlična je, koristim već godinama.
EDIT: Sve to prtlajnje po win, a da ne znaš precizno i točno što radiš mi nema nekog smisla jer ćeš usrat nešto.
Jedno je isključit BL, Telemetriju i Copilot, ali sasvim nešto drugo je izmajmunirat i uklonit hrpu drugih stvari koje su možda esencijalne...evo meni se pokazalo da je na 21h2 IoT LTSC čak i telemetrija potrebna jer inače nije bilo kumulativnih updatea.
Slobodno me dodajte na PSN
Staro 21.11.2025., 21:32   #2963
d0X
Kostolomac
d0X's Avatar
Postovi: 1,582
Autor Disco Pregled postova
Slažem se, spominjao sam ga prije par godina kao alternativu Hard_Configuratoru, još ga vrtim.
PSN Steam
d0X je online   Reply With Quote
Staro 21.11.2025., 21:34   #2964
Neo-ST
Neo-ST's Avatar
Postovi: 8,767
Kako? Mladenu sve radi.
Staro 21.11.2025., 21:59   #2965
Mladenxy
Mladenxy's Avatar
Postovi: 4,514
Autor Neo-ST Pregled postova
Javi se na PP i dođi sutra do mene na pivu i vidi kaj mi ne radi. Sve radi savršeno, ali ne može bolje.
Staro 21.11.2025., 22:10   #2966
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,625
Ma Microsoft nema pojma sto prica pa drljaju o tamo nekim problemima, umjesto da dodu kod Mladena na pivce da im on pokaze kako se OS ispravno konfigurira .
/sarcasm off
Mladene moj pa bemu misa zar ti oci ostaju zatvorene i ne zelis promijeniti stav cak i kad proizvodac sam prizna greske? Gle - reci da se Windows 11 vuce ko krepana kokos je pretjerivanje. Da je sporiji od Windows 10 - da. I to vec na desktopu, sve produktivne aplikacije nismo jos ni takli. Racunaj jos jednu stavku - racunalo koje vodis pod "Moj komp" nije bas slabo makar je vec malo starije. Instaliraj Win 10 i Win 11 na neki i3 8th gen ili AMD ekvivalent pa ce razlika biti ocitija.
Zadnje izmijenjeno od: tomek@vz. 21.11.2025. u 22:16.
Staro 21.11.2025., 22:14   #2967
Mladenxy
Mladenxy's Avatar
Postovi: 4,514
Pa to i tvrdite da nemaju pojma, tak da to onda ide i na ovu izjavu da im ne valja OS Koliko god da ne valja bolji je od svega ostalog na tržištu za najširu upotrebu.
AI odgovor
"Windows 11 generally offers marginal performance gains over Windows 10, with faster boot times and improvements in specific areas like task scheduling and updates. However, real-world performance differences are often negligible, with some tests showing Windows 10 performing better in specific applications or games. The biggest difference is that Windows 10 is now out of support, making Windows 11 a more secure and modern option despite minor performance discrepancies. "
Performance differences
Boot time: Windows 11 boots faster, particularly on modern hardware with SSDs and UEFI support.
App launching: Both operating systems launch applications at similar speeds, with Windows 11 having minor, often unnoticeable, improvements in task scheduling.
Gaming: Gaming performance is largely identical. Windows 11 has newer technologies like DirectStorage and Auto HDR, but they don't provide a significant advantage in most current games. Some older tests showed Windows 10 with slight advantages in specific games, especially on certain hardware.
Productivity: Recent benchmarks show mixed results. Some tests indicate Windows 11 has a slight edge in productivity, while others show Windows 10 performing better in certain applications like rendering or number-crunching tasks.
Updates: Windows 11 has more streamlined and faster updates compared to Windows 10, with smaller download size
Staro 21.11.2025., 22:18   #2968
mkey
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 4,134
Reče onaj tko ništa drugo nije probao
Autor George Carlin
But there’s a reason. There’s a reason. There’s a reason for this, there’s a reason education sucks, and it’s the same reason that it will never, ever, ever be fixed. It’s never gonna get any better. Don’t look for it. Be happy with what you got. Because the owners of this country don't want that. I'm talking about the real owners now, the real owners, the big wealthy business interests that control things and make all the important decisions. Forget the politicians. The politicians are put there to give you the idea that you have freedom of choice. You don't. You have no choice. You have owners. They own you. They own everything. They own all the important land. They own and control the corporations. They’ve long since bought and paid for the senate, the congress, the state houses, the city halls, they got the judges in their back pockets and they own all the big media companies so they control just about all of the news and information you get to hear. They got you by the balls. They spend billions of dollars every year lobbying, lobbying, to get what they want. Well, we know what they want. They want more for themselves and less for everybody else, but I'll tell you what they don’t want: They don’t want a population of citizens capable of critical thinking. They don’t want well informed, well educated people capable of critical thinking. They’re not interested in that. That doesn’t help them. Thats against their interests. Thats right. They don’t want people who are smart enough to sit around a kitchen table to figure out how badly they’re getting f*cked by a system that threw them overboard 30 f*cking years ago. They don’t want that. You know what they want? They want obedient workers. Obedient workers. People who are just smart enough to run the machines and do the paperwork, and just dumb enough to passively accept all these increasingly shittier jobs with the lower pay, the longer hours, the reduced benefits, the end of overtime and the vanishing pension that disappears the minute you go to collect it, and now they’re coming for your Social Security money. They want your retirement money. They want it back so they can give it to their criminal friends on Wall Street, and you know something? They’ll get it. They’ll get it all from you, sooner or later, 'cause they own this f*cking place. It's a big club, and you ain’t in it. You and I are not in the big club. And by the way, it's the same big club they use to beat you over the head with all day long when they tell you what to believe. All day long beating you over the head in their media telling you what to believe, what to think and what to buy. The table is tilted folks. The game is rigged, and nobody seems to notice, nobody seems to care. Good honest hard-working people -- white collar, blue collar, it doesn’t matter what color shirt you have on -- good honest hard-working people continue -- these are people of modest means -- continue to elect these rich c*cksuckers who don’t give a f*ck about them. They don’t give a f*ck about you. They don’t give a f*ck about you. They don't care about you at all -- at all -- at all. And nobody seems to notice, nobody seems to care. That's what the owners count on; the fact that Americans will probably remain willfully ignorant of the big red, white and blue dick that's being jammed up their assholes everyday. Because the owners of this country know the truth: it's called the American Dream, because you have to be asleep to believe it.
Staro 21.11.2025., 22:21   #2969
Mladenxy
Mladenxy's Avatar
Postovi: 4,514
Autor mkey Pregled postova
Tko ja? Probao kako je izlazilo od arkadnih automata početkom osamdesetih.
Staro 21.11.2025., 22:21   #2970
Postovi: 10,437
Ja osobno ne pamtim da je Mladen na ovom forumu kritizirao ista sto koristi ili posjeduje, bile to gume na autu 10 godina stare ili neki OS na kompu. Covjek se samo hrani vasim reakcijama i na fino vas, da budem pristojan, prca. A vi ga zazivajte i hranite
