#2941 |
Lokacija: Rijeka / Grobnik
Postovi: 4,493
Scroll gore. 2929 pa na dalje. To na ovoj novoj masini sa w11. Na staroj nikakav problem.
"We all must hang together, or surly we will hang separately." AMD Ryzen7 7800x3D+Noctua NH-D14 | MSI Tomahawk WIFI AMD B650 | 2x16GB Corsair Vengeance DDR5-6000 CL30 1,39v | SAPPHIRE Pulse RX 9070xt UV/OC | 1tb NVMe sammy 970 evo plus, 2TB Samsung 990 EVO Plus, Crucial MX500 500GB, Kingston 480gb | Riotoro ENIGMA G2 850W 80 Gold | Corsair Carbide 300R modded | Win10 ENT LTSC IoT (work) + Win11 ENT LTSC IoT (gejming) | logitech g403 | ROCCAT Horde | AOC CQ27C4 + AOC C24G1 + 50" Hisense H50A6140 AMD Ryzen5 2600+Xilence Cryon M806D.B | Asus x370 Prime Pro rev1.03 (bios 6203) | GSkill Aegis 32GB (2x16) DDR4@3,2GHz | 2x Intel 545s 128GB, 1x Crucial MX500 500GB | Gigabyte GTX960 | sisa 620w | Fractal Design Focus G | Win7 x64 + Win10 ENT LTSC IoT | logitech g403 | ROCCAT SuoraFX intel i5 2500k@4,5ghz (1,28v)+FSP Windale 4 | ASRock Z68 Ext4 Gen3 (bios 1.20) | 2x8gb DDR3 HyperX Savage, 1866mhz, 10-10-11-27,1,5V | Samsung SSD 64gb, 2x256gb SSD | iGPU | corsair vx450w | CoolerMaster Centurion 534 modded | Win7 x64 |
#2942 | |
Lokacija: Zagreb, Črnomerec
Postovi: 2,697
https://youtu.be/hUwHyoKGZKs?t=481 |
#2943 |
Uptime 99.99%
Postovi: 2,742
Nekad pretjeruje, ali ovaj puta je u pravu. A nekad je ljute mucila telemetrija. https://www.youtube.com/watch?v=iX3a-goiE2c
#2944 |
Postovi: 4,493
Nova zabava na w11. Udem u igru, izadem van, i sad trebam restartat jer iz nekog razloga adrenalin ne otvara. Hebo takav os. Znao sam da je losa ideja ic na to gofno umjesto 10, al nije mi vrag dao mira, reko ajde po prvi put idem against gut feeling... Moron
#2946 |
White Rabbit
Postovi: 5,430
@geronimo...je da je popularno mrziti 11-icu ali ruku na srce vecina ovog sto si napisao su problemi samih aplikacija koje instaliras - ne OS-a. Nije Microsoft bas za sve kriv u ovom slucaju vec lijeno programiranje. Ili nades rijesenje unutar samog appa ili mijenjas app za alternativu. Nema smisla se toliko uzrujavati radi komada softwera. |
#2947 |
Postovi: 8,574
Spomenul u par postova da mu sve ovo uredno radi na Windows 10 OS-u, a sad kad se prebacil na Windows 11, odjednom se te iste aplikacije kotrljaju nizbrdo.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX |
#2948 |
Postovi: 4,493
ma da, iako na win10 je nesto starija adrenalin i 6800, al nekak se iskreno nadam da to nije do hw-a novog jer sam onda nigdje lol. gore je zadnji adrenalin od pred par dana, pa ak imate slicne probleme napisite. bacim oko jel izaslo sta novo zadnjih dana, ako ne probam stavit neki stariji, al meni to sve skupa smrdi jer nemam problema nikakvih dok ne udem u neku igru, specificno radi se o metal gear solid i uncharted 4 jucer. udem, postelam nesto sitno, izadem i adrenalin ne dela, odnosno probam uc u njega, prvo hang-a par sekundi, a onda vidim da se srusio/ugasio. pokrenem ga opet, vidim onaj veliki ekran da ga loada i opet se rusi i tak u krug, dok ne restartam. nebi mi bilo toliko cudno da nisam primjetio slicne probleme i sa drugim, odnosno firefox gore naveden. nesto tu smrdi.
#2949 | |
White Rabbit
Postovi: 5,430
Svjestan sam toga. Zato kazem mozda developeri iste aplikacije nisu optimirali za Windows 11 - nebih tu mogucnost tako lako izbacio iz jednadzbe pogotovo kad kad je struka preplavljena vibe coderima. |
#2950 |
Postovi: 8,574
Da, ali evo kod mene su iste te (Adrenalin i Firefox) aplikacije u svojim zadnjim verzijama skupa s firško patchiranim Windows 11 Pro 25H2 i sve dela kak spada.
#2951 |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,727
Možda je do Chris Titusa ![]() |
#2952 | |
White Rabbit
Postovi: 5,430
@geronimo_2 > jesi radio upgrade na 11 ili cistu instalaciju? Dali si radio kakve optimizacije za OS koje mijenjaju default vrijednosti? |
#2953 |
Postovi: 4,493
cista instalacija LTSC iot. ako pod optimizacija i mjenjanje vrijednosti mislis na tool-ove tipa shutup, private winten i sl. nisam jos nista od doticnih stavio, daklem trebalo bi bit sve default. zadnji available win updejti stavljeni neki dan. masina je offline vecinu vremena, a i za bilo kakve izlaze ESET pita.
#2954 |
Datum registracije: Oct 2002
Lokacija: Zagreb/Rijeka
Postovi: 2,052
#2955 | |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,122
There be dragons...
#2956 | |
White Rabbit
Postovi: 5,430
Znaci kod tebe LTSC verzija kod Exiled legit Win11 Pro (up to date). Onda mora u tom grmu lezat zec. Jesi probao sa "normalnom" i "up to date" verzijom Windows 11 OS-a? |
#2957 |
Postovi: 10,333
Mene ovaj ESET ful kopka u cijeloj prici, pa ako se odlucis razj. sustav, probaj prvo maknuti taj suite cisto u znanstvene svrhe ![]() Citamo se u W10 temi ![]()
#2958 |
Postovi: 4,493
probat cu i to, al uskoro krece instalacija w10 pa se javim kroz tjedan dva. steta vejstanog vremena na ovaj w11.
#2959 |
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,227
/connect 185.107.96.125:28990 server rcon: oldschool COD2 PCekspert ekipa https://discord.com/invite/zZ4PeqVpBv |
#2960 | |
Dobro je sve.
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,528
Upirem prst u amd ili odakle ti taj image ltsc?inače se skida sa ms legit stranice i onda mass ostalo se nedira jer nema potrebe nema ai govna i ostalih glupoština Poslano sa mog SM-S918B koristeći Tapatalk |
#2961 |
Postovi: 23,641
Tko ima vremena za istraživanje neka proba "složiti" tiny11, nije kao IoT ali dobiješ slični rezultat eliminiranjem "nepotrebnog". |
#2962 |
Prvoklasni Krkan
Postovi: 5,416
Nebi ni mene čudilo da ga ESET prca, defender radi sasvim dobar posao. Je da je malo prenervozan i skače na sve i svašta, ali sve se to da podesiti. Fun fact, postoji DefenderUI app za bolju i intuitivniju kotrolu defendera. Odlična je, koristim već godinama. EDIT: Sve to prtlajnje po win, a da ne znaš precizno i točno što radiš mi nema nekog smisla jer ćeš usrat nešto. Jedno je isključit BL, Telemetriju i Copilot, ali sasvim nešto drugo je izmajmunirat i uklonit hrpu drugih stvari koje su možda esencijalne...evo meni se pokazalo da je na 21h2 IoT LTSC čak i telemetrija potrebna jer inače nije bilo kumulativnih updatea. |
#2963 | |
Kostolomac
Postovi: 1,566
#2964 | |
Postovi: 8,608
#2966 |
White Rabbit
Postovi: 5,430
Ma Microsoft nema pojma sto prica pa drljaju o tamo nekim problemima, umjesto da dodu kod Mladena na pivce da im on pokaze kako se OS ispravno konfigurira ./sarcasm off Mladene moj pa bemu misa zar ti oci ostaju zatvorene i ne zelis promijeniti stav cak i kad proizvodac sam prizna greske? Gle - reci da se Windows 11 vuce ko krepana kokos je pretjerivanje. Da je sporiji od Windows 10 - da. I to vec na desktopu, sve produktivne aplikacije nismo jos ni takli. Racunaj jos jednu stavku - racunalo koje vodis pod "Moj komp" nije bas slabo makar je vec malo starije. Instaliraj Win 10 i Win 11 na neki i3 8th gen ili AMD ekvivalent pa ce razlika biti ocitija. Zadnje izmijenjeno od: tomek@vz. 21.11.2025. u 22:16. |
#2967 |
Postovi: 4,479
Pa to i tvrdite da nemaju pojma, tak da to onda ide i na ovu izjavu da im ne valja OS Koliko god da ne valja bolji je od svega ostalog na tržištu za najširu upotrebu.AI odgovor "Windows 11 generally offers marginal performance gains over Windows 10, with faster boot times and improvements in specific areas like task scheduling and updates. However, real-world performance differences are often negligible, with some tests showing Windows 10 performing better in specific applications or games. The biggest difference is that Windows 10 is now out of support, making Windows 11 a more secure and modern option despite minor performance discrepancies. " Performance differences Boot time: Windows 11 boots faster, particularly on modern hardware with SSDs and UEFI support. App launching: Both operating systems launch applications at similar speeds, with Windows 11 having minor, often unnoticeable, improvements in task scheduling. Gaming: Gaming performance is largely identical. Windows 11 has newer technologies like DirectStorage and Auto HDR, but they don't provide a significant advantage in most current games. Some older tests showed Windows 10 with slight advantages in specific games, especially on certain hardware. Productivity: Recent benchmarks show mixed results. Some tests indicate Windows 11 has a slight edge in productivity, while others show Windows 10 performing better in certain applications like rendering or number-crunching tasks. Updates: Windows 11 has more streamlined and faster updates compared to Windows 10, with smaller download size |
#2970 |
Postovi: 10,333
Ja osobno ne pamtim da je Mladen na ovom forumu kritizirao ista sto koristi ili posjeduje, bile to gume na autu 10 godina stare ili neki OS na kompu. Covjek se samo hrani vasim reakcijama i na fino vas, da budem pristojan, prca. A vi ga zazivajte i hranite ![]()
