Staro 07.10.2025., 20:27   #4201
Neo-ST
Neo-ST's Avatar
Postovi: 8,745
Staro 22.10.2025., 22:05   #4202
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,903
Staro 28.10.2025., 00:01   #4203
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,614
Staro 12.11.2025., 20:16   #4204
Postovi: 8,667
Valve Steam Machine, Desktop SteamOS, Steam Frame VR, & Controller | ft. Engineering Discussion
Shipping early 2026 in every region where the Steam Deck is sold today, Valve’s new living room box is best thought of as a far more powerful, stationary version of the same technology. It’s a 6-inch cube that runs Windows games, but without Windows at the helm. Like the Steam Deck, it runs Valve’s Linux-based SteamOS operating system, using a compatibility layer called Proton to make games think they’re running on Windows and translate their API calls. Steam Machine has two things the Steam Deck does not: raw power, and the promise that you’ll never be waiting around for a game to update.
Code:
Steam Machine Info:
    Models
        512GB model and 2TB model
        Steam Machine will ship in a bundle with Steam Controller and will also be available standalone
    Main Specs
        CPU: Semi-custom AMD Zen 4 6C / 12T
            up to 4.8 GHz, 30W TDP
        GPU: Semi-Custom AMD RDNA3 28CUs
            2.45GHz max sustained clock, 110W TDP
            Supports 4K gaming at 60 FPS with FSR
            Ray tracing supported
            Over 6x more powerful than Steam Deck
        16GB DDR5 + 8GB GDDR6 VRAM
        512 GB & 2 TB SSD models
            micro SD card slot for expanded storage/portable catalog
        Internal power supply, AC power 110-240V
    I/O
        DisplayPort 1.4
            Up to 4K @ 240Hz or 8K@60Hz
            Supports HDR, FreeS ync, and daisy-chaining
        HDMI 2.0
            Up to 4K @ 120Hz
            Supports HDR, FreeS ync, and CEC
        Ethernet 1 Gbps
        USB-C 10 Gbps, 3.2 Gen 2
        4x T ype USB-A ports
            2x USB 3 in the front
            2x USB 2 in the rear
        2x2 Wi-Fi 6E, dedicated BT antenna
        Integrated Steam Controller 2.4GHz radio
    Other features
        Works with other controllers, accessories, and PC peripherals
        Wake with Steam Controller
        Runs SteamOS
            Familiar, gaming first user experience
            Fast suspend / resume
            Steam cloud saves, and all the other Steam features you’d expect
        Customizable LED bar
            Personalize with colors and animation
            Reflect system status (e.g. downloads, booting, updating)
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750
Zadnje izmijenjeno od: The Exiled. 12.11.2025. u 20:34.
Staro 12.11.2025., 21:28   #4205
Piksa
Piksa's Avatar
Lokacija: Chakovec
Postovi: 519
Nastavak na ovaj gore post. Novi Steam Machine i stiže HL3. (ovo već liči na vrlo ozbiljan trač)
https://www.hcl.hr/vijest/valve-pred...achine-234120/
Piksa je online   Reply With Quote
Staro 12.11.2025., 22:05   #4206
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,614
8gb grafa i 4k60, how yes no
Staro 12.11.2025., 22:09   #4207
Postovi: 8,667
Da, ali ne bi bilo ništa čudno da taj hardver bez ikakvih problema (od)vrti popularne naslove, a Valve je itekak sposoban to sprovesti u djelo.
Zadnje izmijenjeno od: The Exiled. 12.11.2025. u 22:19.
Staro 13.11.2025., 15:07   #4208
BlackDwarf
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,454
moci ce se mijenjati prednja maska tak da ce biti sareno
Staro 24.11.2025., 19:23   #4209
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,032
Command & Conquer™ The Ultimate Collection
https://store.steampowered.com/bundl...te_Collection/
6.56€ za hrpu Command & Conquera
Command & Conquer™ Remastered Collection
https://store.steampowered.com/app/1...ed_Collection/
2,99€ za Original i Red Alert remastered
Zadnje izmijenjeno od: vga killer. 24.11.2025. u 19:28.
Staro 24.11.2025., 20:32   #4210
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,903
ovaj bundle Command & Conquer™ The Ultimate Collection bi se mogo uzet zbog zero houra,ra 3 i tiberium 4 imam.
kupljeno 4,58 me došlo.
Zadnje izmijenjeno od: demetrius. 24.11.2025. u 20:42.
Staro 24.11.2025., 21:43   #4211
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,603
Developer Fatshark is currently in the middle of celebrating a decade of developing Warhammer games, starting with End Times – Vermintide from 2015. Dubbed 10 Years of Tide, the event just kicked off a giveaway, offering all PC gamers access to the horde-fighting title Warhammer: Vermintide 2.
> Warhammer: Vermintide 2 is free to claim for the next couple of days on Steam
Staro 24.11.2025., 23:25   #4212
Promo
Promo's Avatar
Datum registracije: Jun 2024
Lokacija: Space
Postovi: 888
Staro 04.12.2025., 05:17   #4213
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,603
If you wrote off the Steam Frame as yet another VR headset few will want to wear, I guarantee you're not alone. But the Steam Frame isn't just a headset; it's a Trojan horse that contains the tech gamers need to play Steam games on the next Samsung Galaxy, the next Google Pixel, perhaps Arm gaming notebooks to come. I know, because I'm already using that tech on my Samsung Galaxy. There is no official Android version of Hollow Knight: Silksong, one of the best games of 2025, but that doesn't have to stop you anymore. Thanks to a stack of open-source technologies, including a compatibility layer called Proton and an emulator called Fex, games that were developed for x86-based Windows PCs can now run on Linux-based phones with the Arm processor architecture. With Proton, the Steam Deck could already do the Windows-to-Linux part; now, Fex is bridging x86 and Arm, too.
This stack is what powers the Steam Frame's own ability to play Windows games, of course, and it was widely reported that Valve is using the open-source Fex emulator to make it happen. What wasn't widely reported: Valve is behind Fex itself. In an interview, Valve's Pierre-Loup Griffais, one of the architects behind SteamOS and the Steam Deck, tells The Verge that Valve has been quietly funding almost all the open-source technologies required to play Windows games on Arm. And because they're open-source, Valve is effectively shepherding a future where Arm phones, laptops, and desktops could freely do the same. He says the company believes game developers shouldn't be wasting time porting games if there's a better way.
Remember when the Steam Deck handheld showed that a decade of investment in Linux could make Windows gaming portable? Valve paid open-source developers to follow their passions to help achieve that result. Valve has been guiding the effort to bring games to Arm in much the same way: In 2016 and 2017, Griffais tells me, the company began recruiting and funding open-source developers to bring Windows games to Arm chips. Fex lead developer Ryan Houdek tells The Verge he chatted with Griffais himself at conferences those years and whipped up the first prototype in 2018. He tells me Valve pays enough that Fex is his full-time job. "I want to thank the people from Valve for being here from the start and allowing me to kickstart this project," he recently wrote.
Ako bude dobar kao Proton (Linux) bi cak moglo biti nekaj iz toga...
Staro 04.12.2025., 11:07   #4214
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,854
Dobro je da dio prihoda upucavaju u open source i rješenja koja će možda omogućiti razbijanje monopola na igre.
Staro 16.12.2025., 18:19   #4215
mkey
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 4,084
Autor George Carlin
But there’s a reason. There’s a reason. There’s a reason for this, there’s a reason education sucks, and it’s the same reason that it will never, ever, ever be fixed. It’s never gonna get any better. Don’t look for it. Be happy with what you got. Because the owners of this country don't want that. I'm talking about the real owners now, the real owners, the big wealthy business interests that control things and make all the important decisions. Forget the politicians. The politicians are put there to give you the idea that you have freedom of choice. You don't. You have no choice. You have owners. They own you. They own everything. They own all the important land. They own and control the corporations. They’ve long since bought and paid for the senate, the congress, the state houses, the city halls, they got the judges in their back pockets and they own all the big media companies so they control just about all of the news and information you get to hear. They got you by the balls. They spend billions of dollars every year lobbying, lobbying, to get what they want. Well, we know what they want. They want more for themselves and less for everybody else, but I'll tell you what they don’t want: They don’t want a population of citizens capable of critical thinking. They don’t want well informed, well educated people capable of critical thinking. They’re not interested in that. That doesn’t help them. Thats against their interests. Thats right. They don’t want people who are smart enough to sit around a kitchen table to figure out how badly they’re getting f*cked by a system that threw them overboard 30 f*cking years ago. They don’t want that. You know what they want? They want obedient workers. Obedient workers. People who are just smart enough to run the machines and do the paperwork, and just dumb enough to passively accept all these increasingly shittier jobs with the lower pay, the longer hours, the reduced benefits, the end of overtime and the vanishing pension that disappears the minute you go to collect it, and now they’re coming for your Social Security money. They want your retirement money. They want it back so they can give it to their criminal friends on Wall Street, and you know something? They’ll get it. They’ll get it all from you, sooner or later, 'cause they own this f*cking place. It's a big club, and you ain’t in it. You and I are not in the big club. And by the way, it's the same big club they use to beat you over the head with all day long when they tell you what to believe. All day long beating you over the head in their media telling you what to believe, what to think and what to buy. The table is tilted folks. The game is rigged, and nobody seems to notice, nobody seems to care. Good honest hard-working people -- white collar, blue collar, it doesn’t matter what color shirt you have on -- good honest hard-working people continue -- these are people of modest means -- continue to elect these rich c*cksuckers who don’t give a f*ck about them. They don’t give a f*ck about you. They don’t give a f*ck about you. They don't care about you at all -- at all -- at all. And nobody seems to notice, nobody seems to care. That's what the owners count on; the fact that Americans will probably remain willfully ignorant of the big red, white and blue dick that's being jammed up their assholes everyday. Because the owners of this country know the truth: it's called the American Dream, because you have to be asleep to believe it.
Staro 17.12.2025., 08:09   #4216
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,228
/connect 185.107.96.125:28990
server rcon: oldschool
Staro 18.12.2025., 20:28   #4217
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,614
Staro 19.12.2025., 17:00   #4218
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,194
Quantic Dreams bundle igri na super popustu.
https://store.steampowered.com/agecheck/bundle/14936
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 22.12.2025., 18:26   #4219
Blue Spirit
Postovi: 2,228
Staro 23.12.2025., 19:55   #4220
ICT Avatar
ICT Avatar's Avatar
Datum registracije: Dec 2014
Lokacija: Area 51
Postovi: 274
ICT Avatar je offline   Reply With Quote
Staro 23.12.2025., 20:01   #4221
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,838
Autor ICT Avatar Pregled postova
Prestar sam ja za to.
Kad se samo sjetim Intelovih snova o otključavanju jezgri uz plaćanje...
Staro 29.01.2026., 20:48   #4222
mkey
Lokacija: tu
Postovi: 4,084
Autor George Carlin
Staro 06.02.2026., 22:20   #4223
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,903
