Staro 27.06.2024., 20:13   #1
strikoo
strikoo's Avatar
Postovi: 1,059
Assetto Corsa EVO
Pustili prve screenshotove i steam page
https://store.steampowered.com/app/3...tto_Corsa_EVO/
https://youtu.be/TFx56vtjnAs
As with its predecessor, Assetto Corsa EVO will include cars from different classes spanning across years of motoring history. From road cars, classics, hypercars, and race cars. The most iconic representation of the automotive and motorsport world. Each vehicle is reproduced through an advanced system that simulates mechanical, electronic, and aerodynamic performance, combined with the fidelity of the circuits created using Laserscan technology.
Assetto Corsa EVO raises the bar of realism that has made the franchise one of the most popular driving simulations of the last decade even higher.
With the launch of a new KUNOS Simulazioni proprietary, high-performance photorealistic engine, VR and triple screen support have become first-class features and the new mathematical model meticulously simulates asphalt performance in different dynamic weather conditions that guarantees an authentic and realistic experience which will redefine the standards that have made Assetto Corsa globally renowned.
strikoo je offline   Reply With Quote
Staro 29.06.2024., 04:39   #2
Promo
Promo's Avatar
Datum registracije: Jun 2024
Lokacija: Space
Postovi: 896
Još od AC cekam da izbace bolju podrsku za multiplayer. Da ponude dijelom ono sto nudi iRacing. Da ne moram ganjati LFM utrke. Nadam se da ce to biti EVO.
Sa grafikom i autima nisam imao problem ni sa ACC ali ovo stvarno izgleda obecavajuce. I ako je dobro sto su se odaljili od Blancpain GT serijala koji ih je mnogo limitirao.
Moze EVO biti na nivou AC sto se mene tice samo da MP ne bude afterthought. Samo da me iRacing prestane guliti svaki mjesec.
Staro 18.10.2024., 22:08   #3
strikoo
strikoo's Avatar
Postovi: 1,059
Staro 19.10.2024., 11:00   #4
RainZG
Postovi: 754
Taj lik mi je apsolutno najvise antipatican od svih yt car sim likova na koje sam naletio.
Acc evo s druge strane izgleda obecavajuce jako
RainZG je offline   Reply With Quote
Staro 21.10.2024., 01:05   #5
Promo
Promo's Avatar
Lokacija: Space
Postovi: 896
Ni spomena o multiplayeru. Ni od strane streamera ni od KUNOS-a. I dalje ce ih vaditi LFM. Ali su potvrdili da igra nece imati "career mode" ala GT7.
Prosli put sam ih podrzao u early access fazi kada je bio samo huracan i nurburgring. Ovaj put cu kada uvedu ligu.
Tuga.
Staro 10.12.2024., 21:21   #6
strikoo
strikoo's Avatar
Postovi: 1,059
Staro 11.12.2024., 08:28   #7
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,623
Iskreno - mozda nije popularno misljenje ali - multiplayer me ne zanima. Ovo bi moglo biti bas ono sto u zadnje vrijeme trazim...we shall see.
Staro 16.01.2025., 20:42   #8
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,623
Early Access je vani...recenzije bas nisu obecavajuce...
https://store.steampowered.com/app/3...p_reviews_hash
Staro 16.01.2025., 22:08   #9
RainZG
Postovi: 754
ja kupio, igrao malo, ima problema, ali ovo je early access tako da je ocekivano.
Nisam siguran da li su sada rijesili da se ode offline, kada sam isprobavao imao sam na izbor samo 6 auta radi toga.
Staro 16.01.2025., 22:09   #10
RainZG
Postovi: 754
a je, dosao je update, budem bacio oko opet kasnije
Staro 25.06.2025., 00:56   #11
Promo
Promo's Avatar
Lokacija: Space
Postovi: 896
Kad je ACC tek izasao kao EA, uzeo sam ga kada je bio samo Huracan i Nurburgring. Meni je bilo super za demo i isplatilo se na kraju vozeci stotine sati.
Kupio EVO i danas ga po prvi put probao. Izaslo je kontam dosta patcheva. Sad ce SPA update. Treba uzet. Ja.. ja se nacuditi ne mogu koliko je ovo lose. U sredini kao da volan ima deadzone. Kada smotam kao da je neki delay. Grafika je max out, bez DLSSa i izgleda siromasno. Morao sam poslije odraditi par krugova na iRacingu da dodjem sebi.
Nadam se da mi volan nije dobro registrovan i ako u SETTINGS-u izgleda sve ok. Nadam se da ce 1.0 biti nesto sasvim drugo ali ovo sad za sad, jako razocaran. Ne znam kako su uspjeli da im igra izgleda losije od SPA sa iRacinga. Igre bazirane na NASCAR-u iz 2003-ce.
Staro 02.09.2025., 23:58   #12
Promo
Promo's Avatar
Lokacija: Space
Postovi: 896
Izasla 0.3 beta verzija (Izasla bete verzija updatea igre koja je u alfi? Hajd sad ostani normalan sa danasnjim igrama). Ko hoce da proba 0.3, evo kod koji se ubaci u steam pod EVO pa beta version: h5gUeGopJOlM5yoJlgFu
Sa ovom verzijom su konacno ubacili multiplayer. Stigao je i prvi GT3 model, M4 GT3.
Nisam puno vozao, malo testirao. FF je cudan. Imam osjecaj da salje slip feedback kad je vec kasno. Fizika auta generalno nesto izmedju LMU i ACC. Wobbly. Kao da vozis na balonima. Nije strasno kao LMU ali nesto kao prva tyre verzija za ACC koja je pustena sa 1.9.
Fizika dosta cudna. Auto gubi vise grip u sporijim krivinama sto mi govori da imaju problema sa aero gripom a ne sa mehaničkim gripom. Mozda grijesim. Pri kocenju je auto rock solidi i pri ulasku u krivinu sve dok je veca brzina. Ali ako su sporije krivine u pitanju poput SPA krivina 10 ili 13 kada se dosta koristi trail braking pri ulasku, auto iz cista mira izgubi grip i klizi na "sva četiri". Nema nikakve logike. Cak i sa zagrijanim gumama.
Kao i LMU, previse understeera. Auto se jednostavno ne da zaokrenuti pod gasom. Ako se gadja apex, mora se racunati da ce prednji tockovi raditi overshoot pa se mora kompenzirati sto je sve kontra muscle memory kojeg imam od ACC, AC, iRacinga itd.
UI uber traljav. Dovodi do ludila. Morao sam guglati kako da prebacim gear shifting sa auto na manuelni jer asistencije nisu ni u settingsu ni u opcijama dok si na stazi. Vec negdje tamo gdje biras auto, stazu itd prije ulaska. Jos nisam nasao kako da ugasim virtualni volan. Ne mozes ugasiti "rear camera" view. Ekran na centralnom dijelu konzole jer igra to smatra mirror. Moze se ugasiti kao mirror ali nema virtualni mirror na vrh ekrana. Unutrasnji ekran bi bio cool da nije 240p i ako je na max. Zrnasto nista ne vidim. A i FOV je katastrofa da kad vidim auto iza, vec je kasno. Znaci jedina je opcija imati i jedan i drugi. A oba beskorisna koliko su losi.
HUD elementi su u nekom 20FPS fazonu. I dash informacije i 3D radar. Opet, ne znam je li bug, feature ili iam negdje u opcijama da se rate poveca.
Ima potencijala ali ima ovdje posla najmanje 2 godine. Ne znam koji su im vise planovi. Kako stvari stoje, nisam nista zainteresovan. Multiplayer funkcionalan ali nista vise od toga. Kao AC, bare bone. A kada smo kod servera, mislim da ce rentanje 30 slotova kostati oko 30€. Reference radi, AC se mogao hostati lokalno dok sam ja rentao ACC servere sa 32 slota za 9€ ili tako nesto.
Evo nesto vise oko updatea:
Staro 03.09.2025., 09:01   #13
RainZG
Postovi: 754
Ja sam AC EVO stavio sa strane, uzeo jesam cim je izisla igra, odigrao mozda 3-4 sata i stoji. Dok se ne popegla kako spada ne pada mi na pamet trositi vrijeme.
Staro 25.09.2025., 18:44   #14
Promo
Promo's Avatar
Lokacija: Space
Postovi: 896
Staro 04.12.2025., 13:29   #15
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,617
Staro 04.12.2025., 14:45   #16
VandaL.pr!
VandaL.pr!'s Avatar
Lokacija: zaDAR
Postovi: 852
E, mogao bi veceras pasti đir po ringu
Staro 04.12.2025., 16:24   #17
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,617
ja kupio danas da probam, na xbox kontroler mi je prejak sensitivity kod skretanja, morat ću pronać settingse za to
Staro 04.12.2025., 22:29   #18
GreenLife
Čika Zeljeni
GreenLife's Avatar
Datum registracije: Sep 2013
Lokacija: Tannhausen (Aalen)
Postovi: 499
Autor VandaL.pr! Pregled postova
Ne znam jesi probao, ali meni tek svaki 5-ti put očita multiplayer servere.
Frend sad ima probleme s igrom (malo stariji komp) pa mu nakon updatea počelo štekuckat
Staro 04.12.2025., 22:46   #19
Promo
Promo's Avatar
Lokacija: Space
Postovi: 896
Autor GreenLife Pregled postova
Neka proba ovo i neka ugasi vsync. Meni je uklonilo stuttering:
EDIT
Napravio 2-3 kruga na green hellu. Ostalo nisam dirao. Overall, super. Vozat ce se ovo dosta. I dalje ne mogu da se naviknem na wobbly auto pa stalno fulam ulaz u krivine. Ali sacekat cu 1.0 pa se pozabavit sa setupima. Isto tako trailbrake kao da ne postoji pa treba i brake bias testirati. Evo jedan krug sa Norda..
Zadnje izmijenjeno od: Promo. 05.12.2025. u 00:08.
Staro 05.12.2025., 15:18   #20
Promo
Promo's Avatar
Lokacija: Space
Postovi: 896
Staro 06.12.2025., 09:58   #21
danijel_b
danijel_b's Avatar
Datum registracije: Jun 2004
Lokacija: Sj. Njemacka
Postovi: 505
Evo i ja kupio i probao i posto sam njubara jedva ostajem na stazi. Meni je ovo nerealno klizavo, kao da na ledu vozim. Imam isti problem u AC Evo i AC Rally, a to je da igra uopce ne odaje dojam brzine, vozim 200, a osjecaj je kao da idem 50 na sat, jednostavno se ne mogu naviknuti na taj osjecaj sporosti, tako da u sve zavoje ulazim prebrzo.
Jos sam uzeo i LMU i Raceroom, tamo je druga prica, puno se lakse ufuram u igru i brojevi na satu prate opticki utisak.
Sent from my CPH2645 using Tapatalk
danijel_b je offline   Reply With Quote
Staro 06.12.2025., 10:35   #22
Promo
Promo's Avatar
Lokacija: Space
Postovi: 896
Jedini efekti koji uticu na osjecaj brzine su FOV i motion blur. Probaj ih kopirati iz LMU. Sto se ostalog tice. Staze su 1:1 laserski skenirane u tim simulacijama (ne znam za raceroom) tako da bi trebao dobiti slican osjecaj.
Meni je od svih simulacija LMU najgori po tom pitanju. Nece da "klizi" a imam preko 100FPS. Cudan im je engine. A na svim mi je isti FOV, oko 45.
Staro 06.12.2025., 11:08   #23
Silvio
Datum registracije: May 2016
Lokacija: Velika Gorica
Postovi: 110
Autor danijel_b Pregled postova
Namjestis FOV koji tebi odgovara i tad ces dobit pravi dojam brzine, ocito ti je FOV onak 50 ili 60 pa izgleda kao da vozis 50kmh a zapravo si na 200.
https://www.youtube.com/watch?v=Ic9_Lfna_9M
A ovo za klizanje... to je do tebe...
Silvio je offline   Reply With Quote
Staro 06.12.2025., 11:56   #24
strikoo
strikoo's Avatar
Postovi: 1,059
Staro 06.12.2025., 16:23   #25
GreenLife
Čika Zeljeni
GreenLife's Avatar
Postovi: 499
Pošto imam iskustva iz prve ruke s Nordschleifea (odvoženo nekoliko krugova prošle i ove godine) mogu reći da je dojam jako realan i auto se ponaša 90% onako kako se pravi auto ponaša na stazi (da se razumijemo - ovih 10% se ne može prenijeti jer ovisi o stvarnim i realnim uvjetima na stazi kao sjena/sunce, prolivene tekućine iz auta, količina nanešene gume na asfaltu itd itd. )
Ali da je jako bliza realnosti - je, itekako.
Staro 14.12.2025., 22:21   #26
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,903
vidim da izlazi free roam,ćemo vidjet,prazan svijet,gledo videe,bit će sigurno vozača kad izađe free roam,AI vozača će bit??
Staro 15.12.2025., 00:15   #27
Promo
Promo's Avatar
Lokacija: Space
Postovi: 896
Trebao je free roam izaci sa 0.4 ali su ga odgodili radio drugih tehničkih prioriteta. Izlazi iduce godine ako ne bude promjena. Inace, sama igra 1.0 je trebala izaci jos na jesen ali kao i svaka beta, uvijek izlete neki problemi.
Staro 09.01.2026., 20:18   #28
VandaL.pr!
VandaL.pr!'s Avatar
Lokacija: zaDAR
Postovi: 852
Staro 04.02.2026., 17:11   #29
Promo
Promo's Avatar
Lokacija: Space
Postovi: 896
With Release 0.5, we want to take a moment to share an important update about the direction of Assetto Corsa EVO, shaped by ongoing discussion and feedback from our community.
After careful evaluation and many internal conversations, we’ve decided to move away from the current Career mode and in-game economy systems. This means features such as XP, virtual currency, and economy-based progression will no longer be part of the experience. This decision wasn’t taken lightly, but it allows us to focus on building a clearer, more authentic experience that better reflects what our community values and supports the long-term vision of the game. Rather than simply removing structure, this change allows us to replace the Career mode with experiences that are more directly focused on driving and improvement. The single-player experience will continue to grow through a completely reworked Driving Academy, designed to be a meaningful tool for learning, improving driving skills, and mastering cars and tracks.
Alongside this, we’re investing in a set of competitive features and special events built around online leaderboards, hotstints, and other focused game modes. These experiences are designed to offer clear goals, replayability, and healthy competition, without the limitations of a traditional economy system.
By simplifying the overall structure, we gain more freedom to focus on what matters most behind the wheel: driving quality, racing, and simulation depth. It also allows the team to move faster and spend more time polishing systems that many of you care deeply about, including:
• deeper racing and simulation systems
• strong modding foundations
• future community-driven multiplayer options
• richer and more flexible single-player content
• competitive features and special events based on leaderboards and time-based challenges
• free-roam development and ongoing UI improvements
While the original Career mode won’t be part of the final direction, providing meaningful structure for solo play remains very important to us. Our goal is to guide progression through skill, learning, and competition, rather than through an artificial economy, while continuing to support well-received features like vehicle tuning.
Looking Ahead
Release 0.5 is a meaningful step forward in variety and usability, with new content to drive, UI and performance improvements and the aim of being a foundation for what will come up next.
Assetto Corsa EVO development has never been more intense, and with every Early Access update, the goal is to deliver at our best towards our vision of Driving, Simulation, Evolved.
Zadnje izmijenjeno od: Promo. 06.02.2026. u 05:01.
Staro 12.02.2026., 12:28   #30
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,617
