Staro 26.08.2025., 09:35   #451
Postovi: 8,552
Autor Disco Pregled postova
Bacio sam oko na brzinu na TPU i Guru3D, dva većinom GPU orijentirana sitea.
Nigdje ni spomena o GN istraživanju i Bloombergovom blokiranju.
Ne da nema spomena, nego je otprilike u to vrijeme krcato nV pozitivnim vjestima o ovome i onome. GG Jensen.
VideoCardz je bil jedan od rijetkih portala koji su taj dan kad je dokumentarac pušten u opticaj, odmah spomenuli o čemu je riječ, ali izuzev toga, većina je ostala tiho.
Kina je u međuvremenu kompletno zabranila H20 modele, dok nVidia priprema nove B30 varijante, koje se tak jasno "neće moći nabaviti mimo službenih kanala".
Zadnje izmijenjeno od: The Exiled. 26.08.2025. u 09:41.
Staro 27.08.2025., 17:45   #452
Mladenxy
Mladenxy's Avatar
Postovi: 4,472
Javil se ovaj mali, volim ga slušat jer ima razgovijetan i jasan glas
Staro 05.09.2025., 00:28   #453
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,882
Staro 05.09.2025., 13:25   #454
Postovi: 8,552
nVidia discrete GPU market share dominance expands to 94%
nVidia is continuing to expand its dominance in the desktop graphics card (GPU) market. According to data from Jon Peddie Research, nVidia now controls about 94% of the add-in-board GPU segment as of the end of Q2 2025. AMD's presence has dropped to just 6%, and Intel's is nearly nonexistent. While the rollouts of current GPU generations are now complete, we expect to hear more from Intel soon, which now holds a market share of less than 1% among AIBs. Dr. Jon Peddie, president of JPR, said that prices for midrange and entry-level cards dropped, while high-end AIB prices increased, and most retail suppliers ran out of stock, which he said is very unusual for the second quarter.
Izvor: TechPowerUp, ExtremeTech i TechSpot
nVidia jako lijepo napreduje prema cementiranju ionako već dobro debelo potvrđenog monopola, dok se gospoda u Bloombergu aktivno bave vanškolskim aktivnostima.
Forbes put up an article on Bloomberg vs GN last Friday, and now it's been pulled. It's on Wayback Machine though.
How GPUs get smuggled to China (Gamers Nexus Interview)
Staro 08.09.2025., 11:16   #455
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,389
Lijepo je to da se on bori protiv ovih divova, ali sve mi se čini da će mu na kraju Jensen ipak doći glave. Vidimo kroz par mj/godinu.
I najvj će ostati sam u ovome, jer su se drugi stisnuli, drugi će mu uskočit onda kada praktički više ne budu ni trebali ako dođe do toga da Jensen mora odgovarati za ove muljavine. Uvijek bude tako, mudonje dođe pobirat vrhnje kada je već sve gotovo.
Čak su i HWU tihi po ovom pitanju, bio je samo kratki odg na ptanje u ovomjesečnom Q&A gdje je Stevo rekao da nije stigao pogledat doku do kraja i da će komentirati tek kada sve pogleda, a da čeka da GN uploada jer da ne želi gledati to na tuđim kanalima...zvučalo mi je iskreno poprilično izmotavajuće, ali neka mu bude.
Slobodno me dodajte na PSN
Staro 08.09.2025., 11:35   #456
Postovi: 8,552
Heavy Metal Steve im sigurno to ne bude pustil, mada je sve počelo s onim prijetnjama tijekom Computexa, a posebice sad kad Bloomberg kroz DMCA prijave gasi i reupload orginalnog videa na tuđim kanalima. Australski Steve se izjasnil kratko da je očito kak nVidia koristi Bloomberg da se što je bolje moguće utiša ta buka koju GN diže oko krijumčarenja i popratnog veselja. Kaj se općenito cijele situacije i YouTube ekskurzije tiče, nažalost većina ne bude išla kontra nVidije, neovisno o tome kaj pričali, jer im je itekak u interesu da ne dođu na crnu listu, dok su GN i HUB jedni od rijetkih koji nemaju tih problema, makar je u ovome sad aktivan isključivo GN.
Staro 08.09.2025., 11:41   #457
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,342
HUB se drži svog područja, ne ulaze previše u leakove niti pogađanja, imali su čak i foru s kristalnom kuglom neko vrijeme, žao mi je što ju ne koriste više I mislim da jasno shvaćaju svoje područje kompetencije, znamo hardver, ali ne znamo međunarodnu politiku i krijumčarenje. Opalili su žestoko po Nvidii u tom području u kojem su kompetentni, vrijednosti za novac koju nude i kvalitetu proizvoda, ali generalno ne ulaze u područje gdje nisu kući. Iako mogu jer su prilično neovisni. To respektiram i draže mi je da ostanu jak HW kanal nego loš novinarski.
Staro 08.09.2025., 11:49   #458
Postovi: 8,552
Oba Stevea se ionak mimo svojih kanala redovito čuju i komentiraju sve u pozadini, do te mjere da je Heavy Metal Steve u nekoliko navrata spomenul da mu australski Steve redovito proslijedi sve mutne situacije na koje naleti, tak da je suradnja neupitna. HUB i GN su zapravo prošli kroz iste pizdarije s nVidijom, pošto su se oba kanala našli na udaru, jer ne pričaju dovoljno pozitivno o onome kaj nVidia diktira.
EDIT:
Vratili su orginalni video.
Zadnje izmijenjeno od: The Exiled. 10.09.2025. u 15:08.
Staro 19.11.2025., 08:35   #459
Postovi: 8,552
Staro 06.12.2025., 22:33   #460
ICT Avatar
ICT Avatar's Avatar
Datum registracije: Dec 2014
Lokacija: Area 51
Postovi: 253
Z(luda) vs Cuda
Cuda on non-nvidia gpu
https://www.youtube.com/watch?v=k7GVmBu_NFM
ICT Avatar je online   Reply With Quote
Staro 17.12.2025., 18:09   #461
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,357
Recent reports have claimed that Nvidia intends to reduce its production capacity for GeForce RTX 50 series GPUs in the first half of 2026. These cuts are reportedly due to shortages of memory, not just GDDR7, but all memory types.
30-40% of Nvidia’s GeForce GPU production could be axed. This implies that Nvidia cannot get enough GDDR7 memory to produce GPUs at its current rate. Alternatively, it implies that Nvidia expects significantly reduced GPU sales in 2026, possibly due to rising NAND and DRAM costs and their impact on PC prices.
Note that there is no mention of non-GeForce RTX PRO series GPUs. If GDDR7 memory supply is indeed limited, Nvidia may be allocating its limited memory stocks to its more profitable RTX PRO GPU lineup, sacrificing its GeForce lineup.
> Nvidia reportedly plans 30-40% cut in GeForce GPU production in early 2026
Dakle..."nestasica RAM-a" koja povlaci za sobom cijene SSD-ova i - svega kaj ima RAM na sebi u nebo i sad jos i ovo. Decki vrijeme je za finalni upgrejd tko si moze priustiti jer u narednih 3-4 godine bu grdo.
