Staro 22.07.2025., 13:37   #4351
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,346
Vezano za ARM (Snapdragon konkretno), relativno nedavno je bilo neko fiksanje power managementa u kernelu.
Meni isto rastu zazubice. Ryzen 4800U me sasvim lijepo služi već skoro 4 godine i sve radi od prvog dana. Možda bi ARM bio dobra alternativa?
Staro 22.07.2025., 14:41   #4352
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,714
znaš pravilo:
if it works, don't fix it.
Staro 22.07.2025., 17:01   #4353
Postovi: 8,131
Autor stef Pregled postova
Meni se ovaj model dopada, cijena je isto tak popularana, jedini zajeb je kaj ih je konkurencija polako dostigla.
Staro 26.07.2025., 18:56   #4354
tomek@vz
tomek@vz's Avatar
Lokacija: München/Varaždin
Postovi: 4,695
One of the nice Linux kernel accomplishments during the pandemic was getting the NTFS3 driver upstreamed for that modern NTFS file-system read/write driver developed by Paragon Software. In recent times that NTFS3 driver has been seeing occasional fixes and for the Linux 6.17 kernel -- and perhaps then back-ported to existing kernels -- are some notable fixes for those relying on drives formatted with this Microsoft file-system.
The NTFS3 driver will now handle symlinks created on NTFS partitions under Windows. It turns out symbolic links created on Windows weren't handled correctly with the Linux NTFS3 driver until now, but thanks to adjusting a few dozen lines of code is now addressed.
> Phoronix
Staro 26.07.2025., 19:16   #4355
medo
#erase startup-config
medo's Avatar
Postovi: 3,654
znaš pravilo:
Tako se i ja tješim što sam još uvijek na Visheri
Staro 26.07.2025., 20:36   #4356
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,486
Ja bi bio na i7 2600 da mi nije matična crkla.
Staro 27.07.2025., 20:53   #4357
medo
medo's Avatar
Postovi: 3,654
To je trauma nas linuxaša iz 90-tih - radimo na outdated hardwareu jer na njemu sve radi
Staro 27.07.2025., 20:59   #4358
Postovi: 23,501
Pa sasvim logično kad za win treba 13-14-28 gen intela za prožvakat svu silu smetja i špijuna jer tvoj komp služi njima a ne tebi
Staro 27.07.2025., 23:05   #4359
spiderhr
spiderhr's Avatar
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,010
Autor Nikky Pregled postova
Možda i majnaju u pozadini a da ni ne znamo
Staro 28.07.2025., 19:39   #4360
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,748
OK, vredu, snašli budu se. Intel je sigurno ušparal prijeko potrebne milijune s ovim potezom.
A propos - bas mi je danas sletio (iako stvarno nemam pojma đe me nađe) jedan Intelov oglas u inbox, za MLIR kompajler tim.
Morao sam Googlati koji q je MLIR kompajler. Ali to je sad manje vazno. Bilo kako bilo - ima oglasa za naoko bitne stvari za svinje hraniti, ne mogu reci.
Programer
Staro 28.07.2025., 19:52   #4361
Postovi: 8,131
Uopće ne sumnjam, samo je žalosno da su se doveli u ovakvu situaciju, pa sad ni kriv ni dužan Clear Linux ode pod nož, jer u Intelu više ne znaju na koji način se izvući iz crne rupe.
Staro 28.07.2025., 20:20   #4362
tomek@vz
tomek@vz's Avatar
Postovi: 4,695
Open Source...možda netko preuzme daljnji developement ili forka u novu distru. Iako bi smislenije bilo da ostale distre preuzmu bar dio tih optimizacija.
Staro 28.07.2025., 20:54   #4363
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,748
Nismo li vec oplakali distribuciju ciji korisnici stanu u obiteljski auto bez krsenja Zakona o sigurnosti prometa na cestama?
-O3 i prijatelji nisu univerzalni magicni stapic osim ako nemas specificne potrebe. Pod specificne potrebe ne mislim na "korisnik ocekuje da mu manje vise sve radi", za sto neprezaljeni Clear Linux definitivno nije, nego "cepam atome pa mi je turska sila biti brz".
Za sto Clear Linux opet uglavnom nije iz xyz razloga, jer da je, ne bi bili tu gdje jesmo.
Programer
Staro 28.07.2025., 21:04   #4364
medo
medo's Avatar
Postovi: 3,654
Autor spiderhr Pregled postova
Pa majnaju naše podatke… ovaj, podatke o nama
Staro 28.07.2025., 21:06   #4365
Postovi: 8,131
Autor Bubba Pregled postova
Je, oplakali smo, nije ni toliko do toga da su ugasili Clear Linux, koliko im je taj potez u rangu kad je prijašnji direktor ukinul besplatno voće po kampusima, jer teška su vremena i mora se šparati. Nedugo nakon toga su ga najurili i sad nova direktorska garnitura siječe sve pred sobom u džungli zvanoj Intel, dok i njega ne potjeraju, jer im fabrike nisu ono kaj su bile.
Zadnje izmijenjeno od: The Exiled. 28.07.2025. u 21:12.
Staro 28.07.2025., 21:09   #4366
tomek@vz
tomek@vz's Avatar
Postovi: 4,695
Zato kažem - iste optimizacije se bi morale moći primjeniti na bilo koju drugu distru. Pitanje je - zašto ne? Dali se nekaj potrga kao posljedica? Nisam već 15 godina dirao kompajlere pa sam van svega toga.
Staro 29.07.2025., 19:18   #4367
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,346
Pa šta je Intel imao svoj kompajler na toj distri? Nego gledam malo, tech sector generalno reže glave na veliko, a Intel još dodatno ... jel nam stigla konačno nova 2008.?
Staro 29.07.2025., 19:51   #4368
Postovi: 8,131
U svakom slučaju računica za Clear Linux im više nije štimala.
Farewell benchmarks of Intel's Clear Linux on AMD EPYC shows more performance left to tap
Very strong Clear Linux performance on AMD hardware is no surprise as has been showcased on Phoronix over the years. Especially since Zen 4 with adding AVX-512 to AMD CPUs, the Clear Linux performance has been exceptional thanks to its AVX-512 and employing function multi-versioning (FMV) and other compiler optimizations for delivering a splendid out-of-the-box performance. Whether AMD Ryzen desktops/laptops or AMD EPYC server hardware, Intel's Clear Linux was a great showcase of optimal out-of-the-box software potential on AMD platforms.
Izvor: Phoronix
Staro 29.07.2025., 20:31   #4369
medo
medo's Avatar
Postovi: 3,654
Ja sam *nix admin po opisu posla i nazivu radnog mjesta pa nisam znao za Clear Linux
Staro 29.07.2025., 20:41   #4370
Postovi: 8,131
To je bila Intelova slatka tajna.
Clear Linux OS was not intended to be a general-purpose Linux distribution; it was designed to be used by IT professionals for DevOps, AI application development, cloud computing, and containers and optimized for Intel's microprocessors with an emphasis on performance and security.
Staro 29.07.2025., 22:41   #4371
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,748
Prebaciti/otpustiti xyz ljudi s besplodnog pet projekta je tebi u rangu gasenja redundantnih benefita poput banane i jabuke?
Odnosno, kako bi se reklo, reci mi da imas nula iskustva s vodjenjem trgovackog drustva bez da mi kazes da imas nula iskustva s vodjenjem trgovackog drustva.
Pa i mogu. Cuo ikada za Arhc i Gentoo?
Zato sto za takav agresivan pristup vrlo fleksibilnom i sirokom konceptu kao sto je kernel najcesce, a to je ukoliko bas nemas jako superspecifican razlog, imas u pravilu daleko vise stete nego par % sinteticke koristi.
gcc i llvm su u pitanju. Intelov C/C++ kompajler za pocetak uopce nije open source.
Intel se ionako u zadnjih 5-6 godina orijentirao se na FPGA/GPU specificnosti koje su nebitne za generalni C/C++ kod i zapravo bi bilo vrlo neobicno da ga netko bez specijalne potrebe koristi za takvo sto. Ista stvar je i s Fortran kompajlerom za tih par specificnih komada softvera sto ga i dan danas koriste.
Super je kad vezes arbitrarno nebitnu godinu koje se strucLJaci vole hvatati na populistickim portalima kao eponim za totalnu propast.
Intel nije uspio uspjesno monetizirati svoje diseminacije (mreze, memorije, FPGA i slicno), dosli su neki novi (stari) klinci s novim (starim) proizvodima - i to sveje posljedicno dovelo do nedostatka fokusa i statusa quo.
Ovo ostalo je ruzna posljedica laznog ufanja i hypea oko LLM-ova i ekosustava vezanog za tu temu, uz prezaposljavanje tijekom i neposredno nakon korone.
Posla ima, ali nazalost ne vise za kursadzije i nezainteresirane individue zeljne mjehuricastog tech bro prihoda. Realno, *uvijek* je bilo tesko doci do posla u ovoj bransi, da se ne lazemo. Sada je jednako tesko, samo ima puno vise onih glasnih sto jamraju jer industrija vise ne moze trpiti kronicnu podkapacitiranost novopridoslih kolega. Super simple stuff.
Programer
Staro 29.07.2025., 23:08   #4372
Postovi: 8,131
Lako za mene, jer vidimo iz aktualne situacije da nitko u Intelu posljednjih godina ne zna voditi to velebno trgovačko društvo, pošto su uspjeli sjebati sve kaj su mogli, dok sam ovaj nebitan Clear Linux izjednačil s podjednako nevažnim voćem po kuhinjama, kad su došli u potez očajnika fazu, pa se više uopće ne bira kaj se gasi i tko dobiva otkaz uz vječnu rotaciju direktora. Spomenul sam u jednom od prijašnjih postova kak su "sigurno ušparali milijune" na tom prokletom Clear Linuxu, a onda dođe direktor i veli - jebiga nismo, ali sljedeća godina je ključna s njim ili bez njega.
Staro 30.07.2025., 06:11   #4373
tomek@vz
tomek@vz's Avatar
Postovi: 4,695
Si Sancho Gentoo bi u toj cjeloj prici bio najjednostavniji za primjenu. Zato sam prije svega mislio na "User friendly desktop distre".
Na to sam i mislio - kaj se potrga i u kom smislu. U tolike benefite bez nekakvih posljedica za aktualne aplikacije sam malo skeptican vecinom...
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16 GB DDR5 / 1TB Micron M.2 2242 / nVidia Geforce RTX 4050 / Windows 11 Pro
Lenovo Thinkpad T540p || Intel Core i7-4700MQ / 16GB DDR3 / 240GB Sandisk Plus / nVidia Geforce GT 730 / FreeBSD 14.3
Staro 30.07.2025., 07:50   #4374
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,748
Nisam te vidio na sastanku ovdje a moglo se glasati za nove ljude.
A ti si stvarno duboko uvjeren da su voce i Clear Linux jedine dvije stvari koje su napravljene.
Desktop i driveri su redovno najveci problem.
Cijeli taj koncept je prakticki zadnjih par godina totalno deplasiran; ePBF/XDP/DPDK/io_uring i ekipa izvlace sve u userspace. Isto tako, clickbaitovski naslovi su posljedica malo bolje odabranih kernel parametara, popratnog softvera i nanovo iskompajliranih paketa, a vrlo rijetko u razlikama u samom nacinu kernel builda na razini kompajlera i optimizacija.
Drugim rijecima, nista sto ako imas stvarno takve potrebe ne mozes napraviti sa manje vise svakom drugom distribucijom.
Na kraju dana, Larabelova testiranja su samo simpatican nacin da si puni stranicu materijalom i svakako mu skidam kapu na tome. No tu otprilike prestaje veza sa stvarnim svijetom i pocinje tugy plaky pacenistvo nebitne sintetike.
Programer
Staro 30.07.2025., 08:47   #4375
Ivo_Strojnica
PRO
Postovi: 4,714
"cijela baza korisnika Clear LInuxa stane u auto, bez kršenja zakona o prometnim vozilima"
Biće i košara voća u gepeku
Staro 30.07.2025., 08:51   #4376
medo
medo's Avatar
Postovi: 3,654
To je tako kad se firma ukiseli. Loši su bili kada im je bilo dobro, sada su još gori kada im je loše.
Poluvodički Titanic
ARM i RiscV dolaze sve više na desktope…
Staro 30.07.2025., 08:55   #4377
Postovi: 8,131
Da, nema me na tim sastancima, jer se uvijek ko za inat potrefi da imam nekog posla na gruntu.
Kak god se okrene, Clear Linux je završil kao i mnoge druge kolateralne žrtve, dok se Intel s opet novim direktorom trudi spasiti kaj se spasiti može. Uz silne milijarde potrošene na kojekakve Altere, Habane, Nervane uz začarani krug otkupa vlastitih dionica, popraćeno s novim otpuštanjima za desetke tisuća ljudi, otkazivanjem naprednih proizvodnih procesa i pratećih fabrika, dobro da su se riješili Clear Linux utega - i voća.
Autor medo Pregled postova
Poluvodički Titanic
U 80-ima su imali priliku uložiti u tada skroz novu firmu zvanu TSMC, pa su ih ismijali i potjerali, samo da bi danas ovisili o njihovim naprednim proizvodnim procesima za Intelovu "domaću proizvodnju". Intelu se kasnije Apple javil na temu proizvodnje procesora za nadolazeći iPhone, ali tu su isto odmahnuli rukom, ne treba fala, ne vidimo neki profit u tim smiješnim čipovima za telefone. Kad je trebalo uložiti u ASML-ove EUV mašine, Brian Krzanich kao direktor donosi odluku da su to nepotrebne gluposti i bačeni nofci i to nikad neće raditi. TSMC im je dokazal suprotno. Bob Swan kao novopečeni direktor svima jasno daje do znanja kak 2018. potencijalno ulaganje u OpenAI nema nikakve računice, jer on osobno ne vidi da taj AI ima mogućnost ikakve tržišne vrijednosti. Pat Gelsinger je nakon toga pričal kak se nVidiji posrećilo na AI polju, ARM je nebitan u svakom tržišnom aspektu, dok im je šrot AMD u retrovizoru koliko su jadni, a ovaj novi direktor je između ostalog odlučil ugasiti Clear Linux, jer eto - to su uz voće ti strašni generatori troška koji Intel sputavaju u daljnjem razvoju.
Zadnje izmijenjeno od: The Exiled. 30.07.2025. u 09:11.
Staro 30.07.2025., 10:05   #4378
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,346
Uglavnom i non-technical ekipa ide ća. Negdje sam uhvatio da Microsoft mijenja omjer sa 1:6 nontech-tech na 1:9.
Staro 30.07.2025., 11:29   #4379
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,748
Ako izmaksimiziraju B kategoriju, imaju jos mjesta za 4 kurve iz Villacha.
Mogao si se spojiti i virtualno, bilo preko telefona ili aplikacije.
Voce i Klir lajnuks su trebali zakucati u zid kad ikad iovako ionako. Da ne budem grub i kazem da je zbog takvog gubitka fokusa situacija mozda upravo takva kakva je.
Kupio je i AMD Xilinx a promasaj je jos gori, pa ne vidim da ostrascen po tom pitanju. <3
Rijetko pametna, s obzirom da 2024 imaju gubitke al pari Intelu.
Hoces da napravimo crowdfunding na forumu i zapečemo ti jedan originalni CD da ne cendras?
Ne bi me cudilo, povjerenici za moral, ćudoređe, DSZ i ONO su bili de facto must have do nedavno.
Da ne pricam o usahlim umjetnim vaginama nakon svakog "hi guys" na pocetku besplodnih virtualnih sastanaka.
Jos i danas vjerujem u vlastitu teoriju zavjere da u Hrvatskoj nije uspjela niti jedna ozbiljna podruznica tech firme zbog tradicionalnog hrvatskog pozdrava "di ste pederi, mamu vam jebem, guzi li se išta?". :'(
Programer
Staro 30.07.2025., 11:44   #4380
Postovi: 8,131
Ne treba Bubba, fala na CD-u, ko da jesi - Intel je taj kojem treba itekakav crowdfunding, jer malo fali da počnu brojati krvna zrnca zaposlenika, pa da i na taj način odluče koji ostaje, a koji nestaje, dok direktor ne prestaje. Možemo se ovak podjebavati unedogled, ali bojim se da to ne bude promijenilo činjenično stanje u kojem se Intel trenutno nalazi ponajviše svojom krivicom. Trgovačko društvo i šrot firma u 2025. svaka sa svojom plejadom hitova, pokušaja i promašaja uključujući i Xilinx akviziciju.
