Staro 23.06.2025., 22:22   #20581
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 6,008
Nije samo lg nego izgleda i qd oled i filips, neki namjerni post processing, izgleda da ditheraju namjerno, trebaju dati ljudima da to iskljuce i gotovo....
It is not limited to LG or Samsung, I can confirm that at least Philips's equivalent of the G4 has the same issue.
Forgot to mention LG's official marketing names this "Detail Enhancer", Samsung doesn't have an official name as far as i know but LG does make completely false statements in their marketing material however, they state it is used to fight banding but it is believed to be a low quality mitigation against overshoot, the quality leaves a lot to be desired considering it's always there even in static images and video that are unlikely to provoke banding or overshoot artifacts.
From what i've seen on Vincent G5 review dithering proces ad diagonal lines still remains on G5.
LG sucks
Staro 23.06.2025., 22:58   #20582
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,838
Pa jel ima koji oled da nema nekih gluposti koje bodu čovjeka u oko..
Znam da se tehnologija razvija i da je oled sad bolji, ali...
Sljedeće godine bi navodno trebao sony izbacit na tržište rgb minled tv i to bi kao trebala bit prava stvar.
Gledam recenzije Sony Bravia 9, nudi najbolje od oba svijeta, a nisam našao nekaj loše da čovjeka odvrati od kupnje, uglavnom ekipa je blago rečeno oduševljena s tom telkom, mislim da je to čak i flagšip model miniled.
Zadnje izmijenjeno od: zvonac. 23.06.2025. u 23:05.
Staro 24.06.2025., 12:18   #20583
darkijas
darkijas's Avatar
Postovi: 1,811
A koji to ekran ne smeta očima,pogotvo kada u zamračenoj prostoriji nafrljiš brightness. Meni je tako danak za oči uzeo ips ekran 27" x 2 monitora kad sam gledao u zatamnjenoj sobi to nakon desetljeća buljenja u stetni crt koji mi vidu nije nastetio
darkijas je offline   Reply With Quote
Staro 24.06.2025., 13:05   #20584
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
Autor darkijas Pregled postova
Logicno govoris
Treba cuvat vid tako da pazis kako/koliko buljis u nesto sto (jako) bljesti, nema druge.
MojSkuter
Staro 24.06.2025., 14:10   #20585
Prezime
Datum registracije: Aug 2013
Postovi: 4,364
ODLICNO.., sad mi jos samo neki nagluhi lik treba dati savjete kako podesit moj AV 7.1 prijemnik, pa sam potpuno zdrastveno osiguran pri gledanju filmova
PS, vec desetljece buljim dnevno preko 6 sati u LG Olede i vid mi je jos uvjek 20/20 i oci nikako da prosuze. Ako neko ima problema s ocima, onda postoje nacini da ih se podesno zastiti od "pogubnih" Oled ekrana. Slusati i primjenjivati savjete za smanjivanje svjetline/kontrasta ispod vrijednosti na koje je TV predpodesen/kalibriran nije moj "cup of tea". Sto veca sjetlina i tamnina je potrebna za moj potpuni Dolby Vision dozivljaj.
Zadnje izmijenjeno od: Prezime. 24.06.2025. u 14:24.
Staro 24.06.2025., 15:44   #20586
brodjo
Playmaker
brodjo's Avatar
Lokacija: Osijek/Wien
Postovi: 1,670
Imam LG C4 65" od zadnjeg BF i gleda se baš dosta svaki dan, nitko se nije žalio da ga oči peku ili nešto slično. Podesio sliku prema rtings ili Vincentu, ne sjećam se više, za svaki mod posebno i stvarno izgleda show slika. Isto tako kum uzeo 85" TCL C803 i slika je show, tako da i mini-led i OLED imaju sasvim dobrih opcija za odabrat. Ove priče da se vide dijagonalne crte od kojih oči ispadaju kad se uslika ekran sa 10cm udaljenosti... jel treba uopće komentirati.
Gledam svašta na C4, od 100GB 4K filmova sa HDR10+/Dolby Vision, 4K Sky Sports F1 pa i FHD nogomet i stvarno izgleda velika većina sadržaja izuzetno dobro. Ovi klasični TV kanali nisu neka sreća, ali su i dalje ok, teško je očekivati puno kad ih je većina i dalje 720i ili 720p.
brodjo je offline   Reply With Quote
Staro 24.06.2025., 16:47   #20587
zvonac
zvonac's Avatar
Postovi: 5,838
Autor brodjo Pregled postova
Kak izgleda slika na tom miniledu?
Očito ne odgovara svakom oled, a zanimljivo, neko je prešao sa oleda (problematični) na drugi oled i problemi su nestali.
LG C4
https://www.reddit.com/r/OLED/commen...in_in_oled_c4/
https://www.reddit.com/r/LGOLED/comm...in_from_lg_c4/
LG G4
https://www.reddit.com/r/LGOLED/comm...is_it_too_big/
https://www.reddit.com/r/LGOLED/comm...grading_to_65/
https://www.avforums.com/threads/6-n...2468048/page-4
Uglavnom preporuka je prigušit osvjetljenje što je za mene neprihvatljivo ili imat svjetlo upaljeno kod gledanja telke.
E vidiš drugi dio bolda me zanima.
A baš sam našao C4 za dobre novce, al ak je samo (HD) ok, onda niš od toga.
Jel onda bar FHD odličan?
Navodno se LG G5 približio (ili mu čak stoji uz bok) sonyu ako pričamo o skaliranju niže rezolucije.
LG opet kiksa sa DTSom koji je nepostojeći na G5.
Staro 24.06.2025., 16:54   #20588
tascam
Datum registracije: Jun 2010
Lokacija: hr
Postovi: 887
Svaki tv ima prednosti i mana.Savršeni tv ne postoji, premda oled tehnologija se najviše približila savršenstvu.
tascam je offline   Reply With Quote
Staro 24.06.2025., 17:02   #20589
zvonac
zvonac's Avatar
Postovi: 5,838
Autor tascam Pregled postova
Daleko je još oled do toga, daleko..
Mislim da je microled koji će dost tog ispravit a s čim se oled bori, al microled će i koštat dost.
Čitajući recenzije, da, svaki oled ima neke propuste, al čovjek se nada, ako je oled skuplji da je ujedno i bolji, a to zapravo ipak nije tako.
Staro 24.06.2025., 17:32   #20590
kamacnik1
Datum registracije: Sep 2020
Lokacija: Ravna Gora
Postovi: 56
U iščekivanju " perfektnog " TV-a , nabavka radija nije loša ideja
kamacnik1 je offline   Reply With Quote
Staro 24.06.2025., 19:24   #20591
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,190
Što je točno "savršeno"?
Slika kakvu ste si zamislili da treba biti?
Slika za kakvu je netko rekao da treba biti?
Kakve su reference uopće za mjerenje savršenog? U kakvim uvjetima, s kakvim izvorom?
Jel TV mora prikazati sport na način kakvim ga vidite vlastitim očima?
Ne kužim koja su točno mjerila danas, da eto baš ništa ne valja?
Ne znam ni jel ovo ikakvo mjerilo, ali eto... ako je vjerovati IMAX mjerilima, Sony, TCL i Hisense su "savršeni"
https://www.imax.com/en/gb/imaxenhanced-products
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 24.06.2025., 19:52   #20592
d0X
Kostolomac
d0X's Avatar
Postovi: 1,575
@zvonac pričekaj još malo, pa možda dođu hologrami od tvrdog svjetla
Super je OLED, može smetati samo neukima (loše konfiguriran) ili onima sa očnim problemima.
PSN Steam
d0X je online   Reply With Quote
Staro 24.06.2025., 19:53   #20593
9800pro
aka Edo, aka Syncros
9800pro's Avatar
Postovi: 1,791
Također, uzeo G4 65" i jedino što me smeta je što nisam uzeo veći. Nitko se nije žalio da ima takve probleme kod gledanja a bome ni ja.
Staro 25.06.2025., 09:06   #20594
tascam
Lokacija: hr
Postovi: 887
Autor d0X Pregled postova
Staro 26.06.2025., 19:45   #20595
Matijac
Matijac's Avatar
Postovi: 855
Trebam pomoć. Negdje u temi sam vidio da netko koristi USB to gigabit ethernet adapter za sony KD xe/xf9005, nisam siguran je li Lewis bio.
Ugl. kupio sam cable matters USB 3.0 to gigabit ethernet adapter i pokušam spojiti, ali nejde. Uštekao sam u onaj treći USB u TV koji ima 900mW, ethernet kabel je provjeren.
Googlanjem i GPTom sam pročitao da ethernet adapteri ne radi na verziji 9 androida nego mora biti najmanje Android 10.
GPT veli da xf9005 kojeg ja imam ima mogućnosti nadogradnje na android 9, ali najnovija verzija v6.7220 koju imam instalirano (OTA preko TV-a) je i dalje android 9. Išao sam gledati ima li noviji update, na stranici sonya ima iz rujna 2023, ali isto piše v6.7220 pa nisam ni pokušavao preko USBa taj firmware staviti.
Ima li netko ideju mogu li ikako to upogoniti?
Staro 26.06.2025., 20:45   #20596
Prezime
Postovi: 4,364
Autor Matijac Pregled postova
Hehe, glupe li umjetne inteligencije, "USB3.0 to Ethernet" adapteri rade uredno na Android 9 OS-u.
Imam ih tri komada "Amazon Basics USB 3.0", "Schwaiger CKUH1000" i "Uni USB-A Hub ( 4 in 1 ) | USB 3.0"
I sva tri rade odlicno na raznim Android 9 uredjajima.
Jedino sto treba pazit je da ne rade svi moguci adapteri na svim mogucim uredjajima, nego je bitna kompatibilnost ugradjenih chipova sa SoC-om. Prije kupnje bi rebao bi saznat koji je kompatibilan tvom uredjeju...
Staro 26.06.2025., 21:53   #20597
Matijac
Matijac's Avatar
Postovi: 855
E to sam i gledao, i na redditu i avforumu su preporučili baš taj chipset AX88179. Dal je do toga, ne znam. A sad tražim, pišu ljudi da im isto ne radi. Očito sam se morao bolje informirati prije kupnje.
Ako netko ima sony i ethernet adapter neka napiše. U temi kodi je Lewis pisao da ima i da mu radi.
Staro 04.07.2025., 12:14   #20598
puding22
puding22's Avatar
Datum registracije: May 2013
Lokacija: ...
Postovi: 371
tcl 65c655
Da napisem kratak osvrt na TCL 65c655
Iz Bih i većinom koristim IPTV
Limitiran si signalom koji ti IPTV daje pa ti bolji micro ful lled oled tv ne pomaže baš
Ovaj tv ima ok sliku malo zasićeniju u startu ali se lako smanji
Android google tv radi dobro nekad ima mrvu laga ali je ok
Zvuk je dosta dobar i zadovoljava kriterije
daljinski ima dobar odaziv i mislim da je blutetooth
Nakon 5 mjeseci kad sam uzeo imao sam prvi kvar poceo se paliti i samo ugasi
poslan na servis gdje su to rijesili ali se na povratku stvorio diming i dead pixel
Opet ga vracam i salju novi uređaj
Evo mjesec dana novog valjda posluži
Nažalost nisam aktivirao dodatnu garanciju 3 godine jer to valjda moras u prvih mjesec dana kupovine
Eto toliko
puding22 je offline   Reply With Quote
Staro 09.07.2025., 10:07   #20599
gin.tonic
gin.tonic's Avatar
Postovi: 2,446
Ekipa, isprobao sam Stremio + Torrentio kombinaciju na LG C2 tv-u...
Da li za normalno gledanje 4k sadržaja treba platiti Real Debris?
Pitam jer mi reprodukcija 4k sadržaja ne radi kak treba, brzina streamanja je prespora.
Tv je spojen kablom na ruter i brzina od ISP (D 1Gbps, U 1 Gbps) to ne bi trebao biti problem...
gin.tonic je offline   Reply With Quote
Staro 09.07.2025., 10:18   #20600
brodjo
Playmaker
brodjo's Avatar
Postovi: 1,670
Trebas real-debrid za sve preko 10-20GB
Staro 09.07.2025., 10:18   #20601
gin.tonic
gin.tonic's Avatar
Postovi: 2,446
To me zanimalo
Staro 09.07.2025., 10:20   #20602
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,710
Autor gin.tonic Pregled postova
Brzina 1Gbps a C2 ima ethernet port od 100 megabita
Ali da, nije u tome problem.
Staro 09.07.2025., 10:22   #20603
gin.tonic
gin.tonic's Avatar
Postovi: 2,446
Autor Exy Pregled postova
To je točno
Ne znam koliko mu wi-fi može povući
Staro 09.07.2025., 13:08   #20604
tascam
Lokacija: hr
Postovi: 887
Stavi se usb to lan adapter.I povlači one od 100+ gb
Staro 09.07.2025., 13:34   #20605
ti.le
[CTN]Mr.Ti
ti.le's Avatar
Lokacija: Zg, Novi Zg
Postovi: 567
Ako netko zna, TCL-ovi, da li imaju opciju napajanja za antenu (pojačalo), brzinski sam postavljao jedan, i nisam vidio opciju paljenja / gašenja napajanja antene (konkretno 55C655)
CPU: Ryzen 7 5700G / Noctua D15S; MBO: MSI B550 Tomahawk; RAM:Corsair Vengeance 2x16 3200MHz; GPU: XFX Merc 319 RX 6900 XT; HDD: 1. Samsung 970EVO 256 GB; 2. Crucial P2 500GB; PSU: EVGA Supernova G2 750; CASE: NZXT H440 White; MONITOR: Asus MG279Q; KEYBOARD: Roccat Vulcan 100; MOUSE: Razer ViperMini @ SteelSeries QCK mass; HEADPHONES: Kingston HyperX Cloud (I) - Superlux HD-681 EVO
ti.le je offline   Reply With Quote
Staro 07.08.2025., 17:27   #20606
njOob
njOob's Avatar
Lokacija: Jug
Postovi: 506
Zna li netko gdje bi mogao nac kratke sarafe za Vogels? Montirao sam originalno prije 10 godina za 49incha samsung ue49ku6402 koji je u donjem imao velike sarafe a nova 55qn90 je dosta slim pa veliki...
Sent from my SM-S926U1 using Tapatalk
njOob je offline   Reply With Quote
Staro 07.08.2025., 18:04   #20607
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,176
Bauhaus, Pevex itd
Lowrider
Staro 07.08.2025., 18:13   #20608
Postovi: 17,143
Uzmi šaraf u ruku i pravac Bauhaus.
Staro 07.08.2025., 20:03   #20609
driftwood
driftwood's Avatar
Datum registracije: Jan 2010
Lokacija: .
Postovi: 689
Možeš i staviti one odstojnike koje si dobio sa nosačem pa ti ne treba kraća vida.
Dazed and confused
driftwood je offline   Reply With Quote
Staro 10.08.2025., 11:51   #20610
Exomaniac
Datum registracije: Mar 2016
Postovi: 775
Selim se u novi stan i dnevni boravak s kuhinjom je prilično velik pa kupujem i novi TV. Ne planiram trošiti neke basnoslovne novce niti sam previše zahtjevan po pitanju kvalitete slike pa je po pitanju cijene i dobivenog fokus trenutno pao na dva.
Hisense 75U6NQ i Hisense 65U7NQ
Oba su oko 700€, vidim da po recenzijama U7NQ ima bolju sliku i veći refresh rate iako ne planiram nešto osim povremeno osnovnog PS5 goniti na njemu. Nekako me vuče veći model, ne čini mi se da na osnovnom PS5 ima puno igara koje nude visok FPS, a 75 inča već izgleda dosta impozantno.
Ono što mi je najveće pitanje je zapravo OS, vidim da koriste taj Vidaa OS, a o njemu ne znam ništa kakva je podrška. Uglavnom mi je bitan Youtube, Netflix, a koristim EON TV i MaxTV aplikacije, a ne nalazim ima li podrške za njih na njima.
Ako ima neka druga preporuka za TV sličnih dimenzija, a da nije iznad 750-800€, rado ću poslušati.
