			 Member
				Lokacija: Kutina
					Postovi: 979
				x800gto2
			modao sam x800gto2 sapphire(modani flashrom i modan bios gto2) ,otključano  16 pipa ali mi gpu ne ide preko 460 mhz a memorija ide do 570 pa me zanima dali bi s biosom od x850xt mogao bolje overclokati gpu i memoriju (1.6 ns samsung)3d mark05 oko 5700  |
			 Headbangig Grunf!
			Datum registracije: Aug 2003
				Lokacija: headbanger's ball
					Postovi: 4,373
		 čemu modani X800gto2 bios??? Stavi X850XT bios jer to je taj čip a svi modani biosi za tu grafu su dreq. Automatski dobijaš i taktove od X850XT i sve postavke od te grafe.
	Porsche 6cyl.boxer se hladi zrakom komp se hladi vodom! Chairman of G.M.S.  , Heavy Metal Thunder!Former member of PCE 100+kg demolition squad Grunf je moj idol! Moji Grunf type modovi NB:Mini Monster NB,VGA:Ye Monster C!, Ye Monster D!,Abit NB:Abit mini Monster,PSU:Ultra Monster! ![]() Alfisti site, Alfisti forum  |
					Postovi: 140
		 Dali ti ja cip R430 ili R480?  |
			 Member
				Lokacija: Kutina
					Postovi: 979
		 R480  |
					Postovi: 140
		 Dali si to provjerio podizanjem hladnjaka ili iz ATI tool-a  |
			 Member
				Lokacija: Kutina
					Postovi: 979
		 sve sapphire-ove X800GTO2 imaju R480 gpu, CONFIG_DIE_FUSES 0xFFFFFFFF, CONFIG_SUBSTRATE_FUSES 0xFFFFFFF9F, to znaci da je gpu R480, sa orginal biosima prijavljuje R430 a sa modanim X800GTO2 R480 sa 16 pipeline-ova  |
					Postovi: 140
		 Sve sapphirove GTO2  kartice nemaju R480,ima ih dosta sa R430 narocito ako je novijeg datuma.  |
			 Member
				Lokacija: Kutina
					Postovi: 979
		 The even bigger news though on this card is what lies within, that this card is not only highly overclockable out of the box but also can be modded. TechPowerUp have an article and broke the story on the ability to mod X800GTOs into basically an X850XT or even Platinum Edition. That's right, they don't feature 12 pixel pipelines but 16 and that is an R480 core underneath not R420. ATI do this because not every core comes out as guaranteed to run at the higher clock speeds or to have all pixel pipelines working. With Sapphire's GTO2 Limited Edition, every card can be modded by flashing the BIOS to run at 16 pixel pipelines instead of 12 has worked correctly. And all the cards have some amazing overclockability, even with Sapphire's standard cooling. We were able to get the card to mod for 16 pixel pipelines and run the core at 520MHz and the 256MB of DDR3 memory at 590MHz. Past that of an X850XT and almost to X850XT PE levels, let alone the GTO speed of 400MHz for the core and 490MHz for the memory. With some additional cooling, one should be able to see X850XT PE levels but our system crashed so we hit something just above XT. As you'll see in the benchmarks, this obviously lends to a giant leap in performance. URL  |
					Postovi: 140
		 Lijepo si ti to copy-paste,ali reci mi koje ti je boje kartica?  |
			 Member
				Lokacija: Kutina
					Postovi: 979
		 crvene  |
					Postovi: 140
		 Onda si naletio na los cip.Medutim u posljednje vrijeme pojavljuju varijacije na temu GTO2.Dolaze sa cipom 430 ,zato sam ti irekao da pogledas ispod hladnjaka. Evo ti link o tome pa provijeri. http://www.sapphiretech.com/en/forum...ead.php?t=1779  |
			 Hejter
					Postovi: 6,521
		 ovo u clanku se radi , ak sam dobro skuzio , da je trgovac u ducanu iz kutije uzeo zver sa r480 a ubacio u kutiju x800xl sa r430 .  |
			 Member
				Lokacija: Kutina
					Postovi: 979
		 nije jer se može modati(16 pipa)  |
			 Hejter
					Postovi: 6,521
		 @gil - kako ti se kloka ? i ako nije tajna , di si je kupio?  |
					Postovi: 140
		 Nisi dobro skuzio. Sada sve Gto2 kartice dolaze sa 430 ,ali sa otkljucanih svih 16p  |
		#16 |
			 Hejter
					Postovi: 6,521
		 dakle , ove kaj su po ducanima sad su r430 ? isto kaj je i u powercoloru x800gto16 , odnosno to je onda ko x800xl .  |
		#17 |
					Postovi: 140
		 Upravo tako ,jedina dobr stvar je sto imaju memoriju deklariranu na 1.6 ns  |
		#18 |
			 Hejter
					Postovi: 6,521
		 a zato i je cijena pala - u dingu sa 1700 na 1450 , dakle na rang x800gto16 . mozda i malo jer izlaze novi aduti , ali mora imati i veze sa tim jezgrama.  |
		#19 |
					Postovi: 140
		 Valjda je zbog toga,ali i ovakva je konkurentna u toj klasi  |
		#20 |
			 Member
				Lokacija: Kutina
					Postovi: 979
		 kloka se na 450/550 , 3d mark05 5703 , kupljena u hgspotu za 1560 kn  |
		#21 |
			 Hejter
					Postovi: 6,521
		 Bas i nije , ak gledas kaj bu za mjesec dana na trzistu za istu lovu .  Ali zasad - odlican izbor .  |
		#22 |
					Postovi: 140
		 ako ti nije tesko,poviri ispod hladnjaka.Dosada su se te nakaze pojavljivale u plavoj boji,ali ko zna....  |
		#23 |
			 Member
				Lokacija: Kutina
					Postovi: 979
		 ma neda mi se zezati ,a i nemam paste  |
		#24 |
			 Hejter
					Postovi: 6,521
		 po clocku nemre biti r480 . dakle , rasprsila mi se jos jedna iluzija  ![]()  |
		#25 |
					Postovi: 140
		 za router-a: znas li mozda koji su default i max klokovi za 850xt?  |
		#26 |
			 Hejter
					Postovi: 6,521
		 mislim da je nesto sa 550/550 , tak sam citao nesto .  |
		#27 |
					Postovi: 140
		 to su max ili...?  |
		#28 |
			 Hejter
					Postovi: 6,521
		 krivo sam mislio . evo na linku tablica kak idu klokovi .  http://www.hexus.net/content/item.ph...6&redirect=yes ima na netu x800gto2 sa r480 sa jezgrom na 600mhz!  |
		#29 |
					Postovi: 140
		 ok ,hvala  |
		#30 |
			 Hejter
					Postovi: 6,521
		 nema na cemu .  ![]()  |
