#5971 |
Lokacija: rijeka
Postovi: 3,882
ako sam dobro razumio Core Ultra 9 285K nasljeđuje i9 14900 k/s Ultra 7 265K nasljeđuje i7 14700 k Core Ultra 5 245K nasljeđuje i5 14600k This next-generation lineup promises to deliver one of the most significant performance leaps for desktop processors in recent years i ovo ćemo vidjet. |
#5973 |
Postovi: 8,553
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 04.06.2024. u 18:28. |
#5974 | ||
Postovi: 8,553
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX |
#5975 | ||
Postovi: 8,553
#5976 | ||
Postovi: 8,553
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 02.08.2024. u 00:42. |
#5977 |
Prvoklasni Krkan
Postovi: 5,390
#5978 |
Postovi: 8,553
Znači sve OK, a CEO Pat & Mat prilikom jučerašnjeg izlaganja poprilično samouvjereno odgovara na pitanja, do te mjere da se stječe dojam kako Intel kao firma zapravo ide iz pobjede u pobjedu, jer sve faze P.L.A.N.A._i_P.R.O.G.R.A.M.A. ![]() su uspješno realizirane. Intel je prema riječima glavnog i odgovornog generalnog direktora, već u ovo vrijeme vodeća svjetska fabless tvrtka (iako "sve proizvode sami"), a ujedno i istovremeno su i vodeća svjetska fabrika (Intel Foundry - IFS) za druge firme koje trebaju najbolje i najnaprednije proizvodne procese. 2026. godina će biti ključna za Intel, jer onda se opet sve što trenutno (po CEO-u samo "privremeno") za njih proizvodi TSMC, opet vraća u Intelove sposobne ruke, a do 2027. će se sva dosadašnja ulaganja i popratna rezanja, višestruko isplatiti. Jedini je problem u tome da je nadobudni direktor isto u superlativima pričal za sve kaj se u međuvremenu izjalovilo, rasprodalo, otkazalo i kompletno prebacilo u TSMC.![]()
#5979 | |
Postovi: 1,707
"Eppur si muove" Sent from my SM-S908B using Tapatalk |
#5980 |
Postovi: 8,553
Komotno su mogli i 20 godina produljiti garanciju, ali ako se i dalje na sve moguće načine misle ciganiti prilikom reklamacija, onda uzlaud im trud.
#5981 |
Postovi: 8,553
#5984 |
Datum registracije: Oct 2021
Postovi: 74
Namjeravao sam negdje početkom iduće godine složiti novu konfiguraciju kad izađe nova Arrow Lake generacija procesora i taman nedavno naletim na sve ove vijesti o apsolutnim užasima i kompletno sfušanoj 13. i 14. generaciji procesora, tako da ću odgoditi planirano na neodređeno dok ne vidim razvoj situacije, tko zna da i ovi nadolazeći procesori neće biti problematični. Da čovjek ne povjeruje na što je Intel spao i što se ovdje uopće dogodilo, je li greška u samom dizajnu procesora ili se nešto dogodilo u samom proizvodnom procesu, a koliko sam upoznat vlastitu proizvodnju trenutačno nemaju nego im TSMC sve radi, sve to dok izlaze vijesti da je Ohio fab odgođen najmanje do 2027./2028., a ovaj u Magdeburgu u Njemačkoj do 2029./2030. s početkom rada, izgleda da će još dugo vremena proći dok ne stanu opet na noge, nadam se da im ipak ne slijedi Nokia scenarij kako je netko ovdje spominjao, no budući da su praktički monopolisti najvjerojatnije će se ipak izvući... |
#5985 |
Datum registracije: May 2016
Lokacija: Velika Gorica
Postovi: 110
Pa mozes ti slobodno kupit, ali racunaj da ces morat malo se igrat sa klokanjem (ja to radim bez obzira imaju li problema ili ne). Fiksiras ga na 1.35v i stavis 100mhz nizi clock od tvornickog i 99% da ce ti sve radit bez problema, bez degradacije a imat ces prakticki iste performanse u gaming/workloadu... I to govorim ja kao osoba koja obozava ryzen (well, dok nisu izbacili zen-5%), namjeravao sam prec sa 5600x na buduci 9800x3d ali izgleda da se to nece desit jer 9800x3d pak mora bit jedno 40-50% jaci od kompletne zen 5 ergele u gamingu da se isplati naspram 7800x3d, a to se 10000000000000000% nece desit. Sad bi prije uzeo 14700k i igrao se sat vremena sa klokanjem i miran sam 3-4god min. |
#5987 |
Prvoklasni Krkan
Postovi: 5,390
Ne znam koliko je TT dobar izvor, ali... Intel has just sold ALL of its Arm shares, as the CPU behemoth continues to struggle Ako je istina, čudan potez...ARM mi se ne čini nešto čega bi se netko htio riješiti....pa i jakna ga je htio samo za sebe... |
#5988 | |
Postovi: 8,553
Izgleda da je istina, a ako im je tih ~150 milijuna bitno, onda je to samo dodatna potvrda da imaju povećih (financijskih) problema. Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 14.08.2024. u 15:35. |
#5989 | |||||
Postovi: 8,553
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 20.08.2024. u 18:24. |
#5991 | |
White Rabbit
Postovi: 5,360
Ne vidim scenarij u kojem bi to bilo od koristi korisnicima (cipovi su i dalje nestabilno smece ) a drugo Intel ce jos vise spusit lovu. Intelu treba dobar proizvod i to jos jucer inace je nahebo Intel a nakon toga i svi mi skupa. ARM izgleda nije neka alternativa (opet) a MAC pod moj krov nece nikad pa ni onda (kak god je arhitektura hebena). |
#5992 | ||
Postovi: 8,553
Nažalost kod Intela je sad sve upitno, a ukoliko Arrow Lake ispadne super, moguće da budu ga prodavali po nekim popularno nižim cijenama, makar sumnjam, jer ide skroz nova platforma. Intelovi proizvodni procesi su sve samo ne najbolji, a TSMC uredno svima diže cijenu, tak da i Intel uz AMD i nVidiju plaća koliko god treba, jer inače nemaju konkurentan proizvod. Taman da se u Intelu već danas riješe bajnog direktora, opet imaju situaciju kakvu je i ovaj sadašnji zatekel - totalno rasulo, dok se ne nađe netko sposoban, a u međuvremenu, tko živ, tko mrtav. EDIT:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 27.08.2024. u 22:47. |
#5993 | |||
Postovi: 8,553
EDIT:Izgleda da Intel CEO, inače stručLJak po zanimanju, ima pametnijeg i bitnijeg posla, dok sve oko njega gori u plamenu. ![]()
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 30.08.2024. u 13:37. |
#5996 | ||
Postovi: 8,553
Direktor bude pričal pizdarije, tak dugo dok mu nVidia u gotovini ne kupi firmu i rasproda sve, jer realno nemaju koristi od ičega, ali samo da ušutkaju njegova bajkovita obećanja i najave. Citiraj:
Desetljeće bez konkurencije, OEM mito i korupcija uz redovni otkup vlastitih dionica i cijelu paletu nadobudnih direktora + Ryan Shrout i Raja Koduri. Ništ, evo par prigodnih za Intel stručLJake koji vode firmu u pravom smjeru s uvijek jasnom vizijom za budućnost. ![]() ![]() Lost in the void.
#5998 | ||
Postovi: 8,553
#5999 | ||
Postovi: 8,553
#6000 | ||||||
Postovi: 8,553
EDIT:Jedino kaj fali u ovom Intel čušpajzu je da CEO Pat da/dobi otkaz i da onda država službeno krene u spašavanje Intela. Intel 20A i 18A su zapravo dio iste nekadašnje 5nm obitelji, tak da, ako odustaju i otkazuju 20A, a pričaju da 18A ide bez problema (Broadcom se ne bi složil) - lažu sami sebe. Tim više lažu sami sebe kroz ove PR budalaštine, jer se već više od pola godine (1 - 2) zna da budu Lunar i Arrow Lake na TSMC 3nm procesu, a sad kao odjednom otkazuju nekaj kaj u startu nije valjalo.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 05.09.2024. u 12:42. |
