Staro 12.08.2022., 13:30   #1201
thesaint255
thesaint255's Avatar
Datum registracije: Dec 2009
Lokacija: Graz
Postovi: 539
ID-Cooling SE-224-XT, ima ga od 160-200 kn okolo po ducanima kod nas, pa vidi gdje ti najvise pase. Ako zelis ici na nesto provjerenije (em je vent pouzdaniji/tisi), baci oko na Pure Rock 2, 330-350 kn.
7800X3D @ Scythe Fuma 2
ASRock B650I Lightning WiFi
32 GB Corsair Vengeance DDR5-6000
RTX 4070 ti Gamerock
Corsair SF750
Cooler Master NR200P
thesaint255 je offline   Reply With Quote
Staro 12.08.2022., 20:49   #1202
Dottore
Dottore's Avatar
Postovi: 7,697
Nigdje nema dostupan Noctua hladnjak NH-D12 L.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 13.08.2022., 14:14   #1203
nino
nino's Avatar
Postovi: 12,613
Autor Dottore Pregled postova
Makarsta!
https://www.uzishop.hr/hladnjaci-za-...018000337.html
Staro 26.04.2023., 17:46   #1204
darkijas
darkijas's Avatar
Postovi: 1,809
Dečki može preporuka za neki hladnjak lga 1200. Nakon i3 10105 koji se nije grijao ništa na ploču msi b560m vdh wi-fi stavio i5 11400f i tvornički hladnjak i temperatura 48 celzijevaca idle, da ne spominjem zavijanje ventilatora pri najmenjam opterećenju. Vjerujem da će bilo što drugo biti bolje od ovoga pa tražim preporuku nešto jeftinije, par stupnjeva tamo vamo nije bitno
darkijas je offline   Reply With Quote
Staro 26.04.2023., 19:07   #1205
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
LC-CC-120 22E (165kn) u Linksa na akciji
https://www.links.hr/hr/cooler-lc-po...m_medium=click
Provjeri samo jel paše na tvoj socket s Linksom (na stranicama proizvođača piše da je podržan LGA1200), i visinu od min. 16cm (izmjeri od socketa do bočne stranice kejsa)
Imam navedeni hladnjak na stock Ryzenu iz potpisa i radi kak spada, ne buči, FDB vent izdržao godinama u hrpi prašine, montaža ništa komplicirano, ako ćeš montirat drugi vent ima normalne metalne zakačke, priteže se šarafima na ploču, a ne plastikanerima...
Slabije/manje hladnjake sa 9cm ventovima ne bi baš uzima, nije neka razlika u cijeni, a buka zna bit malo veća za nešto niže performanse.
Također nije loš ni Jonsbo CR-1000 za istu cijenu kao i ovaj gore.
https://www.adm.hr/jonsbo-cr-1000-bl...m_medium=click
Pomelo mi sig -.-
Staro 26.04.2023., 20:04   #1206
c-shadow
c-shadow's Avatar
Postovi: 3,514
Imam takav stariji CC-120 na i5-11400. Vent na tom čudu je neuništiv, cooler je iz 2015 i ništa ne zvrnda, samo sam ga preselio kod upgradea kante. Cooler radi ok, testirao sam ga s otključanim power limitom u biosu, idle cca 33°C, neki normalan load all cores ide do 60-65 i tu ide do cca pkg power nekih oko 90W.
Samo ne prime pokretati na tom procu jer je onda pkg pwr 120-140W i temp 80-90 bez beda. Kad prime navine avx-512 proc zakuha
Ako se normalno koristi sa standardnim TDPom od 65W to CC-120 hladi s ventom na najmanjim okretajima
Staro 26.04.2023., 21:30   #1207
darkijas
darkijas's Avatar
Postovi: 1,809
Ok tak cu nesto i kupiti. Jer ovak se plasim upaliti neku igru da ne bi cpu zgoril. Intel pakira isti hladnjak za i3 10105 i i5 11400. Za i3 cpu je ok ali za i5 je neupotrebljiv. Bas da su malo masivniji hladnjak pakirali za i5 ne bi im
nis bilo.
Staro 15.05.2023., 09:42   #1208
Dacher
Datum registracije: Dec 2022
Postovi: 244
Jel mi treba bolji cooler od stocka za i5 7500. U igrama ne prelazi 57/58 C. Imam doma stari Zalman 9500LED ali prva verzija koja nema adapter za 1511. Novije verzije dolaze sa tim adapterom ali ga nema više nigdje za kupit.
Dacher je offline   Reply With Quote
Staro 15.05.2023., 12:06   #1209
bambi56x
bambi56x's Avatar
Postovi: 357
Sam si si odgovorio s tom temperaturom. Ako ti zadovoljava što se tiče razine buke, sve je u redu.
bambi56x je offline   Reply With Quote
Staro 15.05.2023., 14:25   #1210
ICT Avatar
ICT Avatar's Avatar
Datum registracije: Dec 2014
Lokacija: Area 51
Postovi: 242
Imam adapter za zalmana ako ti treba javi se na PM
Zadnje izmijenjeno od: ICT Avatar. 15.05.2023. u 14:44.
ICT Avatar je offline   Reply With Quote
Staro 16.05.2023., 00:50   #1211
darkijas
darkijas's Avatar
Postovi: 1,809
Evo na kraju kupio arctic cooling freezer i35, vulgaris verzija bez rgb-a 215kn tak nešto u Hg spotu. Rgb verzija koliko vidim ima ledice na ventilatoru i hladnjak je ofarban u crno. Ostalo bi trebalo biti isto
Sad je komp naravno puno tiši i temperature su niže u odnosu na stock. E sad koliko niže to ću morat tek vidjeti
Staro 16.05.2023., 08:10   #1212
mijur
Datum registracije: Jan 2015
Postovi: 13
pozdrav,
molim preporuku hladnjaka za i5 13400, socket 1700, kučište je mini itx format Height CPU cooler (max.)115mm
budžet 30ak eur
hvala
mijur je offline   Reply With Quote
Staro 16.05.2023., 13:58   #1213
bambi56x
bambi56x's Avatar
Postovi: 357
Vidi ako stanu Thermaltake Toughair 110, Thermalright Silver Soul 110, tu bi negdje bili cijenom, ako opterećuješ procesor, a ako je za igranje bude ID Cooling ID-55 dosta.
Staro 20.06.2023., 15:05   #1214
Igor_Zg
Igor_Zg's Avatar
Postovi: 909
Ima li nešto bolje u cijenovnom rangu od Arctic Cooling Freezer i35? može koji euro gore ako je opravdano. Hladio bi intela 7700K čipanog. Hvala!
Igor_Zg je offline   Reply With Quote
Staro 20.06.2023., 22:25   #1215
Drvoje
Drvoje's Avatar
Postovi: 4,037
Da citiram kolegu
Autor ansha Pregled postova
Thermalright Peerless Assassin 120 sa performansama u rangu D15 i DRP4 kosta 38€ + dostava na Amazonu
https://www.amazon.com/Thermalright-...09LGY38L4?th=1
DRP4 je BeQuiet Dark Rock Pro 4
Provjeriti širinu kejsa prije kupnje usput/tj. do koliko max visine stanu CPU hladnjaci - sprečiti pa ne kmečiti
Pomelo mi sig -.-
Staro 23.08.2023., 10:33   #1216
jp_rv
Datum registracije: May 2014
Lokacija: istra
Postovi: 3,545
šta staviti na i7-13700k? a da ne probije 100eur?
max visina koliko vidim po specifikaciji kučišta je 160mm.
to je office pc, neće bit gaming ali će bit povremene zahtjevnije operacije. kupujem u adm-u ili edigitalu...
tnx
Staro 23.08.2023., 11:18   #1217
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,494
neznam, moj nhd15 u cinebenchu ide mid 90s, ako nećeš undervoltat pazi šta stavljaš
ako te operacije nisu zahtjevne onda neće bit problema sa ovik nečim valjda https://www.bequiet.com/en/cpucooler/1378
Staro 23.08.2023., 15:39   #1218
jp_rv
Lokacija: istra
Postovi: 3,545
gledao sam rock 4, bez pro.
ja mislio da je prescott bio najtopliji cpu ikad, a vidim da se vraćaju u to stanje, ova serija 13 grije ko mutava, a i potrošnja struje nikad veća.
Staro 23.08.2023., 15:52   #1219
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,494
a velim, undervoltat se doslovno mora, ja još nisam zalazio u te vode, ali izgleda da možeš dobit puno bolje temperature a iste performanse
Staro 23.08.2023., 19:17   #1220
jp_rv
Lokacija: istra
Postovi: 3,545
too much šit za office kantu.
nek se pregrijava , kupit ćemo novu.
Staro 23.08.2023., 20:01   #1221
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,494
razmislite o 13600k, brutalno manje troši i grije
Staro 23.08.2023., 20:22   #1222
Postovi: 8,506
Treba vam kakvih 15min da se to podesi kak spada u BIOS-u ili kroz Intel XTU i nemate brige kasnije, jer spomenuti cooleri su itekak sposobni, samo nemojte dopustiti da automatika radi kaj ju volja.
Staro 23.08.2023., 20:33   #1223
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,494
jedva čekam vidit raptor lake refresh potrošnju i temp
Staro 05.12.2023., 21:52   #1224
Getriba
Postovi: 234
Napokon sam uspio u naumu da kupim i7 4790k i zamijenim postojeći i5 4460. Po specifikacijama procesora razlika u TDP-u je svega 4W (88W vs 84W) i računao sam da neće biti problema ako i dalje koristim stock cooler.
Prije nego sam migrirao na i7 4790k, vrtio sam Cinebench R23 na postojećem procecsoru i temperature nisu prelazile 60ak stupnjeva. Kada sam zamijenio procesor (nikakve postavke u biosu oko voltaže nisam dirao), imao sam što vidjeti. Čim sam pokrenuo rendering skočilo na 90+ stupnjeva u roku 10 sekundi. Skidam hladnjak, provjeravam jel pasta predebelo namazana (sve bilo oke), također jel sjeo cooler kako spada (isto sve bilo oke). Probam opet - isto 90+ nakon pokretanja rendera.
Reko, vraćam natrag i5 4460, probam Cinebench odvrtiti, temperature u očekivanim razinama (60ak stupnjeva).
Iskreno, nisam to baš očekivao, al ajd, očito ne ide sa stock coolerom. Hoću li se razveseliti s npr. LC-POWER Cosmo Cool LC-CC-120 ili mi treba nešto bolje?
Getriba je offline   Reply With Quote
Staro 05.12.2023., 23:15   #1225
Postovi: 10,233
Ako ti sta pomaze... Imao i5 6500 65W sa stock coolerom. Taj cpu nije vidio znoja i vrucine, ne mozes ga ugrijati. Zamijenio ga za i7 6700 i naknadno i7 7700, oba su 65W. Aluminijski stock cooler nije to mogao drzati u normalnim granicama. Kupio LC-CC 120 i sada je mir. Hladi kako treba na minimalnoj brzini venta, nema problema i stvarno je bio minimalan trosak.
Hyperthreading se dosta osjeti na temperaturama.
Staro 18.12.2023., 22:24   #1226
Getriba
Postovi: 234
Evo status update. Kupio LC-CC 120, napokon stigao montirati, odvrtio Cinebench R23 i nakon 10 minuta rendera (multicore) jedva se približila CPU temperatura granici od 60 stupnjeva.
Case closed
